The PO2030N sensor chip found in hama AC-150 webcam supports horizontal
and vertical flipping the image by hardware.
Signed-off-by: Jean-François Moine <moinejf@free.fr>
The number 0xdd is used for marking delay init sequence steps.
Replace 0xdd values only if the meaning is delay.
The bug was introduced by commit d5aa3856fd09ad0ea04619d6cba31192dac08e84
removing the probe sequence of hv7131r with bridge sn9c120 and so, letting
the sensor inactive.
Cc: stable@kernel.org
The bug was introduced by commit 23a98274cc348880ecb6803307c254448084953a
applying values of sensor sp80708 to sensors hv7131r and mi0360.
Add a driver for the video capture port on VIA integrated chipsets. This
version has a remaining OLPCism or two and expects to be talking to an
ov7670; those can be improved as the need arises.
This work was supported by the One Laptop Per Child project.
Thanks to Laurent Pinchart for a number of useful comments.
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
The QVGA mode has a green horizontal line on the left hand side, and a red
(or sometimes blue) vertical line at the bottom. Tweak the visible area
to remove them.
Thanks to Mauro for explaining how to fix this.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Michel Garnier <catimimi@orange.fr>
In file included from drivers/media/video/cx231xx/cx231xx-audio.c:40:
drivers/media/video/cx231xx/cx231xx.h:559: error: field ‘frontends’ has incomplete type
make[4]: ** [drivers/media/video/cx231xx/cx231xx-audio.o] Erro 1
make[3]: ** [drivers/media/video/cx231xx] Erro 2
make[2]: ** [drivers/media/video] Erro 2
make[1]: ** [drivers/media] Erro 2
make: ** [drivers] Erro 2
Reported-by: Marcio Araujo Alves <froooozen@gmail.com>
Polaris design uses MCE support. Instead of reinventing the wheel,
just let mceusb handle the remote controller.
Acked-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Sri Devi <Srinivasa.Deevi@conexant.com>
Interface 0 is used by IR. The current driver starts initializing
on it, finishing on interface 6. Change the logic to only handle
interface 1. This allows another driver (mceusb) to take care of
the IR interface.
Reviewed-by: Jarod Wilson <jarod@redhat.com>
drivers/media/video/cx25840/cx25840-core.c: In function ‘cx25840_s_frequency’:
drivers/media/video/cx25840/cx25840-core.c:1563: warning: unused variable ‘state’
This adds support for the AUX_PLL in cx2583x chips which is available in
those although the audio part of the chip is not.
The AUX_PLL is used at least by Terratec in their Grabster AV400 device.
Signed-off-by: Sven Barth <pascaldragon@googlemail.com>
Acked-by: Mike Isely <isely@pobox.com>
Reviewed-by: Andy Walls <awalls@md.metrocast.net>
Fixes these build errors and warnings:
drivers/media/video/cx231xx/cx231xx-417.c: In function 'cx231xx_load_firmware':
drivers/media/video/cx231xx/cx231xx-417.c:943: error: implicit declaration of function 'vmalloc'
drivers/media/video/cx231xx/cx231xx-417.c:943: warning: cast to pointer from integer of different size
drivers/media/video/cx231xx/cx231xx-417.c:950: warning: cast to pointer from integer of different size
drivers/media/video/cx231xx/cx231xx-417.c:1039: error: implicit declaration of function 'vfree'
The switch to the new control framework caused a regression where the audio was
no longer unmuted after the carrier scan finished.
The original code attempted to set the volume control to its current value in
order to have the set-volume control code to be called that handles the volume
and muting. However, the framework will not call that code unless the new volume
value is different from the old.
Instead we now call msp_s_ctrl directly.
It is a bit of a hack: we really need a v4l2_ctrl_refresh_ctrl function for this
(or something along those lines).
Thanks to Andy Walls for bisecting this and to Shane Shrybman for reporting it!
Reported-by: Shane Shrybman <shrybman@teksavvy.com>
Thanks-to: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
When audio is present, some alternate settings were skipped.
This prevented some webcams to work, especially when bulk transfer was used.
This patch permits to use the last or only alternate setting.
Reported-by: Antonio Ospite <ospite@studenti.unina.it>
Tested-by: Antonio Ospite <ospite@studenti.unina.it>
SR030PC30 VGA camera
Siliconfile SR030PC30 VGA camera fails to compile with this error:
drivers/media/video/sr030pc30.c: In function ‘sr030pc30_probe’:
drivers/media/video/sr030pc30.c:834: error: implicit declaration of function ‘kzalloc’
drivers/media/video/sr030pc30.c:834: warning: assignment makes pointer from integer without a cast
drivers/media/video/sr030pc30.c: In function ‘sr030pc30_remove’:
drivers/media/video/sr030pc30.c:858: error: implicit declaration of function ‘kfree’
Signed-off-by: Janne Grunau <j@jannau.net>
Based on USB traces of the windows driver.
refine the firmware version test and print the version only once
Hauppauge released different firmwares using the same version number.
The firmware date can be used to identify the exact driver/firmware
combination.
Necessary on arm.
Remove unused is_userptr variable from videobuf-dma-contig.
Signed-off-by: Pawel Osciak <p.osciak@samsung.com>
Patch add support of TwinHan 1027 DVB-S card.
Refreshed version of https://patchwork.kernel.org/patch/79753/ patch.
(adapted for the new IR system), still works.
DVB-S support come from a patch originally authored by
Manu Abraham (abraham.manu@gmail.com).
IR Port support were added by Sergey.
Cc: Manu Abraham <abraham.manu@gmail.com>
This patch also sets to 0 the sequence of the first frame.
Add an I2C/v4l2-subdev driver for Siliconfile SR030PC30 VGA
camera sensor with Image Signal Processor. SR030PC30 is
the low resolution camera sensor on Samsung Aquila boards.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Enable FIMC operation on S5PC210 (S5PV310) SoCs. This a minimal
adaptation to obtain functionality of older FIMC IP revisions
(S5PC100, S5PC110) on S5PC210 SOcs.
Add a video device driver per each FIMC entity to support
the camera capture input mode. Video capture node is registered
only if CCD sensor data is provided through driver's platfrom data
and board setup code.
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com>
It is not necessary to lock both capture and output buffer queue while
setting format for single queue.
Due to errorneous swapping of image dimensions the rotation
control was not handled properly in subsequent calls.
Register access functions refactored for camera capture interface
control. Removed the workqueue since it was only useful for FIFO
output mode which is not supported at this time.
Fixed errors on module unload. Comments and whitespace cleanup.
Add MIPI CSI format definitions, prepare DMA address
definitions for interlaced input frame mode.
operations
No need to duplicate default .get_parm() and .set_parm() operations.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
This patch adds an initial driver for the IMXъ74 image sensor from Sony.
Lacking documentation, only very basic functionality in one specific image
format has been implemented and tested.
This patch adds support for g_parm / s_parm operations to the SoC Camera
framework. It is usefull for checking/setting camera frame rate.
Example usage can be found in the previous patch from this series,
"SoC Camera: add driver for OV6650 sensor".
Created and tested against linux-2.6.36-rc3 on Amstrad Delta.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
This patch provides a V4L2 SoC Camera driver for OV6650 camera sensor, found
on OMAP1 SoC based Amstrad Delta videophone.
Since I have no experience with camera sensors, and the sensor documentation I
was able to find was not very comprehensive, I left most settings at their
default (reset) values, except for:
- those required for proper mediabus parameters and picture geometry and
format setup,
- those used by controls.
Resulting picture quality may be far from perfect, but better than nothing.
In order to be able to get / set the sensor frame rate from userspace, I
decided to provide two not yet SoC camera supported operations, g_parm and
s_parm. These can be used after applying patch 4/6 from this series,
"SoC Camera: add support for g_parm / s_parm operations".
Created and tested against linux-2.6.36-rc5 on Amstrad Delta.
This is a V4L2 driver for TI OMAP1 SoC camera interface.
Both videobuf-dma versions are supported, contig and sg, selectable with a
module option. The former uses less processing power, but often fails to
allocate contignuous buffer memory. The latter is free of this problem, but
generates tens of DMA interrupts per frame. If contig memory allocation ever
fails, the driver falls back to sg automatically on next open, but still can
be switched back to contig manually. Both paths work stable for me, even
under heavy load, on my OMAP1510 based Amstrad Delta videophone, that is the
oldest, least powerfull OMAP1 implementation.
The interface generally works in pass-through mode. Since input data byte
endianess can be swapped, it provides up to two v4l2 pixel formats per each of
several soc_mbus formats that have their swapped endian counterparts.
Boards using this driver can provide it with the following platform data:
- if and what freqency clock is expected by an on-board camera sensor,
- what is the maximum pixel clock that should be accepted from the sensor,
- what is the polarity of the sensor provided pixel clock,
- if the interface GPIO line is connected to a sensor reset/powerdown input
and what is the input polarity.
Signed-off-by: Philipp Wiesner <p.wiesner@phytec.de>
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Remove usage of the BKL and instead used video_set_drvdata() during
open fops.
Signed-off-by: Steven Toth <stoth@kernellabs.com>
Remove V4L2_CAP_STREAMING capability flag, we don't support
the ioctls. It breaks VLC otherwise.
Signed-off-by: Gavin Hurlbut <gjhurlbu@gmail.com>
