This change fixes the Debian Bug #579332
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=579332
Signed-off-by: Jean-François Moine <moinejf@free.fr>
pvrusb2: Delete sysfs class device as the _very_ last step, after
we're sure that all driver contexts have gone away first. This is
important because it appears that there isn't any protection from a
struct device instance reference a deleted struct class instance. The
assumption in the kernel code appears to be that the class instance is
assumed to be around for the life of the device. So we can't let the
class instance go away until all referencing device instances are
gone; this is ensured by delaying removal of the class instance until
after the driver contexts have all gone away. This bug has been
present for a very long time but it didn't apparently become malignant
until recently (probably because of other changes in the kernel).
Signed-off-by: Mike Isely <isely@pobox.com>
pvrusb2: Need one extra attribute slot allocated so that worst case still has a
trailing null pointer. This wasn't causing visible symptoms; it was
found through inspection while investigating other issues.
pvrusb2: Correctly reference count pointer to parent USB device when linked
from sysfs interface. This is technically a pretty nasty problem,
however as far as I know nobody had been getting burned by it (yet).
pvrusb2: Fix oops caused by touching deleted memory after
unregistration. This bug was introduced when we had started using
video_device_node_name() - that function was being called potentially
after the underlying structure (referenced by that function) had been
deleted. The fix rearranges things slightly so that the function is
called before destruction takes place.
This adds a flag in the device attribute structure which can be used
to mark support for a particular device as experimental. Any devices
flagged in this way, when encountered at run-time, will generate a
warning message to the kernel log.
Drivers shouldn't assume that the stack is DMA-safe.
[mchehab@redhat.com: fix patch description]
pvrusb2: Fix RF tuner problem with gotview hardware - this bug was
introduced when switching over to the subdev model of driver control
Fix kernel Oops when number of NetUP Dual DVB-S2-CI cards more than
DVB_MAX_ADAPTERS limit.
[mchehab@redhat.com: move the return to the proper place]
Signed-off-by: Abylay Ospan <aospan@netup.ru>
Note: due to lack of hardware this conversion is untested.
However, it is pretty straightforward so I do not expect any problems.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Note: due to lack of hardware I was not able to test this conversion.
But it is pretty straightforward, so I do not expect any problems.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits)
USB: remove unused usb_buffer_alloc and usb_buffer_free macros
usb: musb: update gfp/slab.h includes
USB: ftdi_sio: fix legacy SIO-device header
USB: kl5usb105: reimplement using generic framework
USB: kl5usb105: minor clean ups
USB: kl5usb105: fix memory leak
USB: io_ti: use kfifo to implement write buffering
USB: io_ti: remove unsused private counter
USB: ti_usb: use kfifo to implement write buffering
USB: ir-usb: fix incorrect write-buffer length
USB: aircable: fix incorrect write-buffer length
USB: safe_serial: straighten out read processing
USB: safe_serial: reimplement read using generic framework
USB: safe_serial: reimplement write using generic framework
usb-storage: always print quirks
USB: usb-storage: trivial debug improvements
USB: oti6858: use port write fifo
USB: oti6858: use kfifo to implement write buffering
USB: cypress_m8: use kfifo to implement write buffering
USB: cypress_m8: remove unused drain define
Fix up conflicts (due to usb_buffer_alloc/free renaming) in
drivers/input/tablet/acecad.c
drivers/input/tablet/kbtab.c
drivers/input/tablet/wacom_sys.c
drivers/media/video/gspca/gspca.c
sound/usb/usbaudio.c
This patch (as1373) fixes a couple of drivers outside the USB
subtree. Devices are now disabled or enabled for autosuspend by
calling a core function instead of setting a flag.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pedro Ribeiro <pedrib@gmail.com>
Fix vivi and mem2mem_testdev build errors: need to #include <linux/slab.h>:
drivers/media/video/vivi.c:1144: error: implicit declaration of function 'kfree'
drivers/media/video/vivi.c:1156: error: implicit declaration of function 'kzalloc'
drivers/media/video/vivi.c:1156: warning: assignment makes pointer from integer without a cast
drivers/media/video/mem2mem_testdev.c:862: error: implicit declaration of function 'kzalloc'
drivers/media/video/mem2mem_testdev.c:862: warning: assignment makes pointer from integer without a cast
drivers/media/video/mem2mem_testdev.c:874: error: implicit declaration of function 'kfree'
drivers/media/video/mem2mem_testdev.c:944: warning: assignment makes pointer from integer without a cast
My concern initially was we dereference "dev" in the parameter list to
s2255_dev_err() but it turns out that code path is never used.
The s2255_stop_readpipe() is only called from one place and "dev" is
never null. So this patch just removes the whole condition here.
Cc: linux-dev@sensoray.com
The original code didn't handle the case where vdev was not found so I
added a check for that.
We dereference "ov" unconditionally throughout the function so there is
no way it can be NULL here. This code has been around for ages so if
it were possible for "ov" to be NULL someone would have complained.
We dereferenced "ctx" on the error path.
Signed-off-by: Mats Randgaard <mats.randgaard@tandberg.com>
Implement enum_dv_presets in tvp7002.
Signed-off-by: Brian Johnson <brijohn@gmail.com>
Reverse HAS_BUTTON logic since most webcams either have a button or if
they don't don't bother to send any interrupts. However I have at least
one model that appears to leave the button GPIO floating and can send
a bogus interrupt.
VIDIOC_S_PRIORITY is also part of the ioctls that need to check the
access priority.
The detection of the saa711x often failed. Adding a small delay before
attempting to detect it fixed this.
handle this
v4l2_device_register already sets intfdata, no need to do this again.
Disconnecting the HDPVR caused a kernel oops if lockdep was enabled.
In addition, if an app still had video0 open and attempted to call ioctl
when the device was already disconnected the system would crash.
Move the freeing and cleanup code to the release function: that is the
right place for it since you know when you get there that nobody is
using the device.
Also removed usb_set_intfdata: v4l2_device_register sets this already
to v4l2_dev.
No need to lock when unregistering the device: clear_bit is already an
atomic operation.
The 'type' field was undefined but should be set to ANALOG_TV.
If no signal or valid format is detected, then VIDIOC_QUERY_DV_PRESET must
return 0 and set the preset to V4L2_DV_INVALID.
This driver returned an error instead.
Also simplified the kernel messages a bit: change v4l2_err to v4l2_dbg (not
detecting a signal/valid format is not an error, so only print this info when
debug == 1) and do not call v4l_fill_dv_preset_info: it's overkill to do this
just for a debug message.
Thanks to Mats Randgaard for bringing this to my attention.
v4l2_prio_init/open/close returned an int when in fact they would
always return 0. Make these void functions.
v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a
pointer for no good reason. Replace with a normal enum v4l2_priority
argument.
These changes will simplify the work of moving priority handling into
the v4l core.
Now that s_fmt is no longer used for VBI format setup in subdevs, remove
the VBI support from s_fmt.
Also removed the bogus zeroing of fmt.sliced when setting up raw VBI.
This should have been removed in ivtv, but it was just copied-and-pasted
into cx18.
Switching between raw and sliced VBI changed in 2.6.28 and this memset
should have been removed at that time. It was never noticed because
the bridge driver will fill in the fmt.vbi values anyway.
Only a relatively small number of video receivers and transmitters actually
support VBI. So start moving the vbi specific ops to an ops struct of their
own.
The control step values reported by the device are used as a divisor
unchecked, which can result in a division by zero.
Check the step value and make it 1 when null.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The UVC relative controls (exposure time, iris, focus, zoom, pan/tilt)
are write-only (despite the UVC specification stating that the GET_CUR
request is mandatory). Mark the controls as such, and report the related
V4L2 controls V4L2_CTRL_FLAG_WRITE_ONLY.
The Miricle 307K (17dc:0202) camera reports a 16-bit greyscale format,
support it in the driver.
