Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Same status/res mixup.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The variables are unsigned so the test `>= 0' is always true,
the `< 0' test always fails. In these cases the other part of
the test catches wrapped values.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
It is no longer needed to use a struct pointer as argument, since v4l2_subdev
doesn't require that ioctl-like approach anymore. Instead just pass the input,
output and config (new!) arguments directly.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
Replace 'VIDIOC_' references in v4l i2c drivers by their new v4l2_subdev
callback names.
Zoran doesn't do autoprobing anymore, so remove support for this from the
i2c modules.
The zoran i2c modules were still using V4L1 internally. Replace this
with V4L2. Also deleted saa7111.c and saa7114.c, we use saa7115.c instead.
[mchehab@redhat.com: fix v4l2_ctrl_query_fill_std merge conflict]
- Convert to use v4l2-i2c-drv-legacy.h to be able to handle the new i2c API
- Cleanups
- Use v4l_dbg/v4l_info to have uniform kernel messages
BIT define conflicts on kernels < 2.6.24, byteorder/swab.h doesn't need
to be included at all.
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
videodev2.h
The videodev.h and videodev2.h describe the public API for V4L and V4L2.
It shouldn't have there any kernel-specific stuff. Those were moved to
v4l2-dev.h.
This patch removes some uneeded headers and include v4l2-common.h on all
V4L driver. This header includes device implementation of V4L2 API provided
on v4l2-dev.h as well as V4L2 internal ioctls that provides connections
between master driver and its i2c devices.
Several media/video and sound drivers include i2c-dev.h while they
don't need it at all. Clean it up.
This header file is really only needed by i2c-dev.c and
compat_ioctl.c, other drivers should never need it.
Conversions from kmalloc+memset to k(z|c)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Now that i2c_add_driver() doesn't need the module owner to be set by
hand, we can delete it from the drivers. This patch catches all of the
drivers that I found in the current tree (if a driver sets the .owner by
hand, it's not a problem, just not needed.)
Cc: Jean Delvare <khali@linux-fr.org>
We should use the i2c_driver.driver's .name and .owner fields
instead of the i2c_driver's ones.
This patch updates the drivers/media/video and usb/media drivers.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't
hurt if the usage count is actually never used for any given driver,
and allows for nice code simplifications in i2c-core.
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we
can simply make it the default and drop the flag. If any driver really
doesn't want to be notified when i2c adapters are added, that driver
can simply omit to set .attach_adapter. This approach is also more
robust as it prevents accidental NULL pointer dereferences.
Fix the fact that the svideo input will only give input in black/white in
some circumstances. Reason is that in the PCI controller driver (zr36067),
after setting input, we reset norm, which overwrites the input register
with the default. This patch makes it always set the correct value for the
input when changing norm.
Signed-off-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net>
Fix bug #5404 in kernel bugzilla.
It basically updates the vpx3220 initialization tables with some newer
values that we've had in CVS for a while (and that, for some reason, never
ended up in the kernel... must've gotten lost). Those fix a ~16 pixels
noise at the top of the picture in at least SECAM, although (now that I
think about it) PAL was probably affected, also.
Add support for kind-forced addresses to i2c_probe, like i2c_detect
has for (essentially) hardware monitoring drivers.
Note that this change will slightly increase the size of the drivers
using I2C_CLIENT_INSMOD, with no immediate benefit. This is a
requirement if we want to merge i2c_probe and i2c_detect though, and
seems a reasonable price to pay in comparison with the previous
cleanups which saved much more than that (such as the i2c-isa cleanup
or the i2c address ranges removal.)
On top of my previous patch which removes the use of address ranges in
video i2c drivers, this one can save an additional few bytes of memory.
Most of these drivers which do not use I2C_CLIENT_INSMOD initialize the
unused address lists in a less than optimal way. This patch simply
optimizes this, by using a single one-element list instead of 3
different lists with two elements each.
This saves an average 63 bytes on these drivers.
diff -ruN linux-2.6.12-rc1-bk5.orig/drivers/media/video/adv7170.c linux-2.6.12-rc1-bk5/drivers/media/video/adv7170.c
Some months ago, you killed the address ranges mechanism from all
sensors i2c chip drivers (both the module parameters and the in-code
address lists). I think it was a very good move, as the ranges can
easily be replaced by individual addresses, and this allowed for
significant cleanups in the i2c core (let alone the impressive size
shrink for all these drivers).
Unfortunately you did not do the same for non-sensors i2c chip drivers.
These need the address ranges even less, so we could get rid of the
ranges here as well for another significant i2c core cleanup. Here comes
a patch which does just that. Since the process is exactly the same as
what you did for the other drivers set already, I did not split this one
in parts.
A documentation update is included.
The change saves 308 bytes in the i2c core, and an average 1382 bytes
for chip drivers which use I2C_CLIENT_INSMOD, 126 bytes for those which
do not.
This change is required if we want to merge the sensors and non-sensors
i2c code (and we want to do this).
Index: gregkh-2.6/Documentation/i2c/writing-clients
infrastructure for it.
Let it rip!
