path: root/drivers/media/video/tveeprom.c
2008-10-17V4L/DVB (9268): tuner: add FMD1216MEX tunerDarron Broad
This tuner was already supported by proxy as an FMD1216ME, however, the MEX uses a different FM Radio IF so this addition is now required. Signed-off-by: Darron Broad <darron@kewl.org> Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-26V4L/DVB (8487): videodev: replace videodev.h includes by videodev2.h where ↵Hans Verkuil
possible Several V4L2 drivers still included videodev.h. Fix this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8479): tveeprom/ivtv: fix usage of has_ir fieldHans Verkuil
has_ir was set to and compared to -1 in several cases, even though it is an u32. ivtv also contained a FIXME for an old kernel that could be removed. Thanks to Roel Kluin for creating an initial patch for this. Although I chose a different solution here it did help in pointing out the problem. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8477): v4l: remove obsolete audiochip.hHans Verkuil
Converted the last users of audiochip.h to the v4l2-chip-ident.h header and remove the now unused audiochip.h header. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-14V4L/DVB (7895): tveeprom: update Hauppauge analog audio and video decodersMichael Krufky
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7240): tveeprom: remove obsolete i2c driver codeHans Verkuil
The i2c driver code was once added for the out-of-tree ivtv driver, but the ivtv driver hasn't used that for a long time so this code can now be removed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7193): tveeprom: Add proper tuner mapping for hauppauge eeprom id 133Ricardo Cerqueira
Do away with the need to set tuner=63 on cx88xx with recent HVR-1300 boards Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6888): Add Hauppauge tuner type 150 defintionSteven Toth
Add Hauppauge tuner type 150 defintion. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6860): tveeprom: CodingStyle cleanupHans Verkuil
2008-01-25V4L/DVB (6859): tveeprom: add support for Hauppauge models 74xxxHans Verkuil
Thanks to Steve Toth from Hauppauge with providing me with the information needed to add support for these models. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6562): Make HVR900 to use also tveepromMauro Carvalho Chehab
Hauppauge firmwares can be decoded using tveeprom. This patch adds HVR-900 as a tveeprom client. It also adds xc3028 tuner entry to tveeprom. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6469): tuner: remove TUNER_PHILIPS_TDA8295Michael Krufky
TUNER_PHILIPS_TDA8290 will autodetect a TDA8290 or a TDA8295, so we don't need this separate entry anymore. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6435): tda8290: add support for NXP TDA18271 tuner and TDA8295 ↵Michael Krufky
analog demod Add basic support for NXP TDA8295 analog demod and TDA18271 tuner silicon. TDA8295 + TDA8275a not yet tested. TDA8290 + TDA18271 not yet supported. Digital mode of TDA18271 not yet tested & needs more work. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5841): tveeprom: add support for Philips FQ1216LME MK3 tuner.Hans Verkuil
2007-07-18V4L/DVB (5739): Replace C code with calls to ARRAY_SIZE macro.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5434): Updates to the tveeprom tuner, video decoder and audio chipSteven Toth
Some of the new tuner entries may need to be mapped to compatible tuners already defined. I don't know for certain which tuners are compatible between manufacturers. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5389): Add tveeprom entry for tuner LG S701D MK3Hans Verkuil
2007-01-15V4L/DVB (5071): Tveeprom: autodetect LG TAPC G701D as tuner type 37Michael Krufky
autodetect LG TAPC G701D as tuner type 37. Thanks to Adonis Papas, for pointing out the missing autodetection for this tuner. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4812): Detect presence of IR receiver/IR transmitter in tveepromHans Verkuil
Thanks to input from Steven Toth from Hauppauge the tveeprom module has been extended to detect the presence of an IR transmitter (aka IR-blaster). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-13V4L/DVB (4817): Fix uses of "&&" where "&" was intendedJean Delvare
Fix uses of "&&" where "&" was intended in bttv-cards.c and tveeprom.c Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-04V4L/DVB (4708): Add tveeprom support for Philips FM1236/FM1216ME MK5Hans Verkuil
Add new Philips tuners: Philips FM1236 MK5 and Philips FM1216ME MK5. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4488): Fix possible crash in Hauppauge eeprom readingTrent Piepho
If an eeprom defined two tuners and they supported more than eight standards combined (as opposed to each), it would overflow an array. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-30V4L/DVB (4290): Add support for the TCL M2523_3DB_E tuner.Hans Verkuil
2006-06-30V4L/DVB (4272): Fix tveeprom supported standardsMauro Carvalho Chehab
The supported standards by the tuner on tveeprom were too restricted. It were showing just the main format, instead of the format family. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3814): Add support for Samsung TCPG 6121P30A PAL tuner.Hans Verkuil
2006-05-12V4L/DVB (3813): Add support for TCL M2523_5N_E tuner.Hans Verkuil
2006-04-02V4L/DVB (3605): Add support for I2C_HW_B_CX2341X board adapterHans Verkuil
- Add missing class check to tveeprom_attach_adapter. - Add CX2341X specific IR probe address list. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3577): Cleanup audio input handlingHans Verkuil
Cleanup audio input handling in bttv and tvaudio: - inputs were specified that were never used - mute was handled as a special input which led to confusing code - confusing naming made it difficult to see if the setting was for i2c or gpio. The old audiochip.h input names moved to tvaudio.h. Currently this is used both by tvaudio and msp3400 until the msp3400 implements the new msp3400-specific inputs. Detect in bttv the tvaudio and msp3400 i2c clients and use these client pointers to set the inputs directly instead of broadcasting the command. Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be replaced again later by the new ROUTING commands. Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is a user level command and not to be used internally. It wasn't called at all anyway. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-13V4L/DVB (3363): Add support for Samsung tuner TCPN 2121P30AHans Verkuil
- Add support for Samsung tuner TCPN 2121P30A, used in Hauppauge PVR-500 cards. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3278): convert diagnostics over to the new v4l2-common.h macros.Hans Verkuil
- Convert diagnostics over to the new v4l2-common.h macros. - deprecated tuner_debug option, the new option is debug. - renamed cx25840_debug to debug. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3160): Updates to the tveeprom eeprom checkingSteven Toth
Updates to the tveeprom eeprom checking Signed-of-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3108): tveeprom cleanup of hardcoded tuner format values.Steven Toth
- Cleaned up the structure to use the V4L2_STD_xxx definitions rather than a one off set of hardcoded values - which could change in the future. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 5 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers/media/video and usb/media drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Rework client usage count, 2 of 3Jean Delvare
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't hurt if the usage count is actually never used for any given driver, and allows for nice code simplifications in i2c-core. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-19[PATCH] V4L/DVB (3180): Fix tuner 100 definition for hauppauge eepromRicardo Cerqueira
- Tuner 100 is the TUNER_PHILIPS_FMD1216ME_MK3, not TUNER_ABSENT. This was causing the tuner module to be skipped, and rendered boards with this value in the eeprom (like the HVR1100) unable to tune Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-12[PATCH] V4L/DVB: (3086c) Whitespaces cleanups part 4Mauro Carvalho Chehab
Clean up whitespaces at v4l/dvb files Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] V4L/DVB: (3086c) Whitespaces cleanups part 3Mauro Carvalho Chehab
2005-12-01[PATCH] V4l/dvb: Restore missing tuner definition for Hauppauge tuner type 0x103Mike Isely
Type 0x103 ("TCL MFNM05-4") in the Hauppauge eeprom is a more recent tuner that maps to TUNER_PHILIPS_FM1236_MK3. This had been previously defined but due to some accident the definition got removed. This change restores that definition. Change committed on advice from Hans Verkuil <hverkuil@xs4all.nl>, who thinks he's the one who had accidentally removed it before. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4L: Add workaround for Hauppauge PVR150 with certain NTSC tuner modelsHans Verkuil
Add workaround for Hauppauge PVR150 hardware problem with tuner models 85, 99 and 112 (model numbers as reported by tveeprom). The audio standard autodetection does not always work correctly for these models. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4L: Fixed eeprom handling for cx88 and added Nova-T PCI model 90003Steven Toth
- Fixed code handling for eeprom on cx88 boards. - Hauppauge released a new version of the Nova-T-PCI (9002) a few months ago with a different (compatible) tuner (but lacking RF passthru). The official model# is 90003. All features are working. - Adding entry to the known model list after testing. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4L: tveeprom MAC address parsing/cleanupSteven Toth
- Added a mac address field to the tveeprom structure. - allow callers to query the MAC address. - removed some redundant eeprom parsing code in cx88-cards.c (specific to Hauppauge DVB products) Instead, placed calls directly to the single eeprom parsing function in tveeprom.c Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 885: second round of i2c ids redefinition cleanupJean Delvare
- Second round of i2c IDs redefinition cleanup. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 801: whitespaces cleanupsMauro Carvalho Chehab
- Whitespaces Cleanups. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 800: whitespace cleanupsMauro Carvalho Chehab
- Whitespace Cleanups. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 729: fixed include when compiling at kernel treeMauro Carvalho Chehab
- Fixed include when compiling at kernel tree Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 702: included audio chips enumMauro Carvalho Chehab
- Included audio chips enum Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
