Some v4l drivers currently don't initialize their struct v4l2_subdev
with zeros, and this is a problem since some of the v4l2 code expects
this. One example is the addition of internal_ops in commit 45f6f84,
after that we are at risk of random oopses with these drivers when code
in v4l2_device_register_subdev tries to dereference sd->internal_ops->*,
as can be shown by the report at http://bugs.launchpad.net/bugs/745213
and analysis of its crash at https://lkml.org/lkml/2011/4/1/168
Use kzalloc within problematic drivers to ensure we have a zeroed struct
v4l2_subdev.
BugLink: http://bugs.launchpad.net/bugs/745213
Cc: <stable@kernel.org>
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
The new i2c binding model doesn't use i2c_probe.
It is no longer needed to use a struct pointer as argument, since v4l2_subdev
doesn't require that ioctl-like approach anymore. Instead just pass the input,
output and config (new!) arguments directly.
< 2.6.22
Originally the intention was to switch to the new style i2c API starting with
the introduction of the API in 2.6.22. However, the i2c_new_probed_device()
function has a lethal bug that wasn't fixed until 2.6.25. Or more accurately,
it was only fixed in the stable series of 2.6.25 and 2.6.26.
Given the fact that the new i2c API also changed starting with 2.6.26 (the
addition of i2c_device_id), it is easiest to switch APIs starting with
2.6.26.
This patch updates all the legacy code accordingly.
Modified mxb to load the i2c modules through v4l2_subdev. So no more probing.
Modified tea6415c and tea6420 to use the standard routing ops to do the
routing, rather than using private commands. Dropped the private commands
from tda9840 (they were never used except during initialization of the
module).
Added saa7146 support for VIDIOC_DBG_G_CHIP_IDENT.
Converted saa5246a and saa5249 to v4l2_subdev.
I2C_DRIVERIDs are phased out. Remove those that are unused at the moment.
Since internal to v4l2 the ioctl prototype is the same regardless of it
being called through .ioctl or .unlocked_ioctl, we need to convert it all
to the long return type of unlocked_ioctl.
Thanks to Jean-Francois Moine for posting an initial patch for this and
thus bringing it to our attention.
Cc: Jean-Francois Moine <moinejf@free.fr>
Also remove some blank lines that were used to split compat code at -devel
tree.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
Acked-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
I2C_foo were used for some i2c addresses. Bad, since those constants could
mean other i2c chip things.
Conversions from kmalloc+memset to k(z|c)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Now when kbuild passes KBUILD_MODNAME with "" do not __stringify it when
used. Remove __stringnify for all users.
This also fixes the output of:
$ ls -l /sys/module/
drwxr-xr-x 4 root root 0 2006-01-05 14:24 pcmcia
drwxr-xr-x 4 root root 0 2006-01-05 14:24 pcmcia_core
drwxr-xr-x 3 root root 0 2006-01-05 14:24 "processor"
drwxr-xr-x 3 root root 0 2006-01-05 14:24 "psmouse"
The quoting of the module names will be gone again.
Thanks to GregKH + Kay Sievers for reproting this.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Now that i2c_add_driver() doesn't need the module owner to be set by
hand, we can delete it from the drivers. This patch catches all of the
drivers that I found in the current tree (if a driver sets the .owner by
hand, it's not a problem, just not needed.)
Cc: Jean Delvare <khali@linux-fr.org>
We should use the i2c_driver.driver's .name and .owner fields
instead of the i2c_driver's ones.
This patch updates the drivers/media/video and usb/media drivers.
Signed-off-by: Laurent Riffard <laurent.riffard@free.fr>
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we
can simply make it the default and drop the flag. If any driver really
doesn't want to be notified when i2c adapters are added, that driver
can simply omit to set .attach_adapter. This approach is also more
robust as it prevents accidental NULL pointer dereferences.
I2C_DEVNAME and i2c_clientname were introduced in 2.5.68 [1] to help
media/video driver authors who wanted their code to be compatible with
both Linux 2.4 and 2.6. The cause of the incompatibility has gone since
[2], so I think we can get rid of them, as they tend to make the code
harder to read and longer to preprocess/compile for no more benefit.
I'd hope nobody seriously attempts to keep media/video driver compatible
across Linux trees anymore, BTW.
[1] http://marc.theaimsgroup.com/?l=linux-kernel&m=104930186524598&w=2
[2] http://www.linuxhq.com/kernel/v2.6/0-test3/include/linux/i2c.h
In theory, there should be no more users of I2C_ALGO_* at this point.
However, it happens that several drivers were using I2C_ALGO_* for
adapter ids, so we need to correct these before we can get rid of all
the I2C_ALGO_* definitions.
Note that this also fixes a bug in media/video/tvaudio.c:
/* don't attach on saa7146 based cards,
because dedicated drivers are used */
if ((adap->id & I2C_ALGO_SAA7146))
return 0;
This test was plain broken, as it would succeed for many more adapters
than just the saa7146: any those id would share at least one bit with
the saa7146 id. We are really lucky that the few other adapters we want
this driver to work with did not fulfill that condition.
Some months ago, you killed the address ranges mechanism from all
sensors i2c chip drivers (both the module parameters and the in-code
address lists). I think it was a very good move, as the ranges can
easily be replaced by individual addresses, and this allowed for
significant cleanups in the i2c core (let alone the impressive size
shrink for all these drivers).
Unfortunately you did not do the same for non-sensors i2c chip drivers.
These need the address ranges even less, so we could get rid of the
ranges here as well for another significant i2c core cleanup. Here comes
a patch which does just that. Since the process is exactly the same as
what you did for the other drivers set already, I did not split this one
in parts.
A documentation update is included.
The change saves 308 bytes in the i2c core, and an average 1382 bytes
for chip drivers which use I2C_CLIENT_INSMOD, 126 bytes for those which
do not.
This change is required if we want to merge the sensors and non-sensors
i2c code (and we want to do this).
Index: gregkh-2.6/Documentation/i2c/writing-clients
infrastructure for it.
Let it rip!
