tea5767 has several possible configurations. Before the patch, the
driver were assuming the more common configuration. However, some newer
cards, like MSI @nyware Master requires other configurations, like
de-activating a gpio port and changing chip Xtal.
This patch adds the capability of altering device configuration at
runtime. This may also be used later to activate some features like
auto-mute when signal is weak.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
efficiency
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
Acked-by: Mike Isely <isely@pobox.com>
Acked-by: Steven Toth <stoth@hauppauge.com>
Acked-by: Patrick Boettcher <pb@linuxtv.org>
Acked-by: Jarod Wilson <jwilson@redhat.com>
To ease the conversion of the analog tuner sub-drivers into dvb_frontend
style tuner modules, we must remove the i2c_client interface.
dvb_frontend style tuner modules use i2c_transfer directly on the i2c_adapter.
This change only alters the interface between tuner.ko and the tuner
sub-drivers. The v4l2 / i2c_client interface to tuner.ko remains intact.
This patch adds inline functions tuner_i2c_xfer_send, and tuner_i2c_xfer_recv,
to replace i2c_master_send and i2c_master_recv inside the tuner sub-drivers.
Acked-by: Trent Piepho <xyzzy@speakeasy.org>
Move internal structures and debug macros to drivers/media/video/tuner-driver.h
Create static struct tuner_operations tea5767_tuner_ops for tea5767
tuning function callback pointers
Move tuner callback function pointers out of struct tuner, into
struct tuner_operations.
tuners that need this.
- Moved MSP_SET_MATRIX to v4l2-common.h
- Fix typos and integer overflows in tea5767.c
- Split old freq field into a tv_freq and a radio_freq. Prevents
that a radio tuner is initialized with a tv frequency or vice versa.
- When switching to radio mode initialize the tuner with the last
used radio frequency (this was already done for the TV mode).
As a result of these changes the tuner module now remembers the
last set radio and TV frequencies, which is what you would expect
to happen.
- Move out of range frequencies to the closest valid frequency as per
v4l2 API spec.
- Fix incorrect initial radio frequency (multiplier is 16000, not 16)
- Add boundary check for out of range frequencies.
- Use new flag to check if the order of the CB and freq. depends on
the last set frequency. That is needed for some tuners or you can
get static as a result. The flag is added for those tuners where I know
that the datasheet indicates that this is necessary.
- For this new check use the last set div value, not the last frequency
as radio frequencies are always much higher due to the 16000 multiplier.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
- Debug global var is already used inside kernel, so renamed
debug to tuner_debug for the tuner module
- Convert diagnostics over to the new v4l2-common.h macros.
- deprecated tuner_debug option, the new option is debug.
- renamed cx25840_debug to debug.
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
- Move signal strength level to the 0-65535 range as per V4L2 spec.
- Whitespace Cleanups.
- Remove $Id CVS logs for V4L files
- Included newer cards.
- Added a new NEC protocol for ir based on pulse distance.
- Enable ATSC support for DViCO FusionHDTV5 Gold.
- Added tuner LG NTSC (TALN mini series).
- Fixed tea5767 autodetection.
- Resolve more tuner types.
- Commented debug function removed from mainstream.
- Remove comments from mainstream. Still on development tree.
- linux/version dependencies removed.
- BTSC Lang1 now is set to auto_stereo mode.
- New tuner standby API.
- i2c-core.c uses hexadecimal for the i2c address, so it should stay consistent.
Signed-off-by: Uli Luckas <luckas@musoft.de>
Signed-off-by: Mac Michaels <wmichaels1@earthlink.net>
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de>
This patch does correct radio chip autodetection to avoid misdetecting
mt20xx microtune as tea5767 chip.
- Fixed some bttv card numbers.
- BTTV and SAA7134 version numbers incremented to reflect changes.
- pci_dma_supported() is called after pci_set_dma_mask() which
already did check that for us. This patch removes the unneeded call to
pci_dma_supported() at bttv-driver.c
- Ensure a sufficient I2C bus idle time between 2 messages for
saa7134-i2c.c
- It is important to write at first to MO_GP3_IO for cx88-tvaudio.c
- Use try_to_freeze() instead of refrigerator at msp3400.c
- Recognizing the MFPE05-2 Tuner at tveeprom.c
- Add new parameter to help identify radio chipsets at tuner module:
show_i2c=1 will show 16 reading bytes from detected tuners.
- BTTV does generate some Unimplemented IOCTL log at tuner module:
0x40046d11(dir=1,tp=0x6d,nr=17,sz=4) means that it is sending
MSP3400 calls to non-msp3400 tuners. Warning eliminated.
VIDIOSAUDIO is also called, so debug messages updated. It is still
requiring IOCTL implementation.
- Added two more tuners.
- Add support for the SVideo input on the GDI Black Gold.
Signed-off-by: Peter Missel <peter.missel@onlinehome.de>
Signed-off-by: Graham Bevan <graham.bevan@ntlworld.com>
Signed-off-by: Torsten Seeboth <Torsten.Seeboth@t-online.de>
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t.online.de>
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
- In CX88 code, some cards needs to have audio reprogramed after changing
video channel;
- Tuner autodetection code seems not to work on some cards. Now,
no_autodetect insmod option allows disabling autodetection code;
- Minor fixes in tea5767 to reduce integer trunc;
- There are some new Pixelview Ultra Pro cards that doesn't use TEA5767
for radio. As autodetection is capable of checking for tea, radio tuners
and addresses removed.
- CX88 version number incremented.
- Fixed a trouble on tuner-core that generates erros on computers with more
than one TV card.
- Rename tuner structures fields.
- Tail spaces removed.
- I2C cleanups and converged to a basic reference structure.
- Removed unused structures.
- Fix setting frequency on tda8290.
- Added code for TEA5767 autodetection.
- Standby mode support implemented. It is used to disable
a non used tuner. Currenlty implemented on tea5767.
- New macro: set_type disables other tuner when changing mode.
- Some cleanups.
- Use 50 kHz step when tunning radio for most tuners to improve precision.
Signed-off-by: Fabien Perrot <perrot1983@yahoo.fr>
Signed-off-By: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
*tuner-core.c:
- some tuner_info msgs will be generated only if insmod opt
tuner_debug enabled.
- Implemented tuner-core support for VIDIO_S_TUNER to allow
changing mono/stereo mode
- Remove unneeded config options.
- I2C_CLIENT_MULTI option removed.
- support for Philips FMD12ME hybrid tuner
- allow to initialize with another tuner
- Move PHILIPS_FMD initialization code to set_type function,
* tda8290:
- Fix dumb error in tda8290 tunning.
- Radio tuner uses high-precision step instead of 62.5 KHz.
*tea5767.c:
- tuner_info msgs will be generated only if insmod tuner option
- some cleanups for better reading.
- Changing radio mode stereo/mono for tea5767 working.
*tuner-simple.c:
- TNF9533-D/IF UHF fixup.
- Radio tuners now uses high-precision step instead of 62.5 KHz.
*mt20xx.c:
*tda9887.c:
- tab and blank spaces corrections.
Signed-off-by: Gerd Knorr <kraxel@bytesex.org>
Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru>
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
