Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
dvb_frontend interface
Convert tda9887 and tda8290/5 to dvb_frontend interface
analog demod
Add basic support for NXP TDA8295 analog demod and TDA18271 tuner silicon.
TDA8295 + TDA8275a not yet tested.
TDA8290 + TDA18271 not yet supported.
Digital mode of TDA18271 not yet tested & needs more work.
tda827x module
Add analog tuning support to tda827x dvb_frontend tuner module.
Convert tda8290 module back to native tuner interface.
The tda8290 analog demodulator will be handled the same way as tda9887.
The tuner.ko module (tuner-core) will pass commands to tda8290 via the
tuner_operations interface. tda8290 will communicate with tda827x via
the dvb_frontend interface, while passing a pointer to a private data
structure.
efficiency
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
Acked-by: Mike Isely <isely@pobox.com>
Acked-by: Steven Toth <stoth@hauppauge.com>
Acked-by: Patrick Boettcher <pb@linuxtv.org>
Acked-by: Jarod Wilson <jwilson@redhat.com>
Acked-by: Trent Piepho <xyzzy@speakeasy.org>
To ease the conversion of the analog tuner sub-drivers into dvb_frontend
style tuner modules, we must remove the i2c_client interface.
dvb_frontend style tuner modules use i2c_transfer directly on the i2c_adapter.
This change only alters the interface between tuner.ko and the tuner
sub-drivers. The v4l2 / i2c_client interface to tuner.ko remains intact.
This patch adds inline functions tuner_i2c_xfer_send, and tuner_i2c_xfer_recv,
to replace i2c_master_send and i2c_master_recv inside the tuner sub-drivers.
Move internal structures and debug macros to drivers/media/video/tuner-driver.h
Create static struct tuner_operations tda8290_tuner_ops
for tda8290 tuning function callback pointers
Move tuner callback function pointers out of struct tuner, into
struct tuner_operations.
Define tuner release callbacks for mt20xx, tda9887 and tda8290, so that
these drivers can release their own private structures themselves.
Create private data struct for device specific private data.
Set tda8290 to analog mode after init, otherwise the tuner driver will
not accept i.e. the standby command.
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
This change supplies a more generic version of the tuner callback.
The tuner struct now has a function pointer
int (*tuner_callback) (void *dev, int command, int arg)
additionally to a int config parameter.
both can be set through the TUNER_SET_TYPE_ADDR client call.
Note that the meaning of the parameters depend on the tuner type.
This patch contains
- new tuning code for the tda827xa silicon tuner.
- controls the preamplifier of some boards with this tuner.
- support for the Philips Tiger S hybrid DVB-T reference design.
- reworked the saa7134-dvb modulue to get rid of most of the
small board specific functions.
The probing code for tda8290 changes the state of the tda9887 GP ports.
The patch assumes that if probing for tda8290 failed, this must be a
tda9887 and restores its power on defaults.
This should solve the module load order issue with some pinnacle cards.
This patch
- works around a bug in the I2C bridge that makes the initialization
of the TDA10046 fail on recent LifeView cards
- puts the AGC output to tristate in sleep mode. This is necessary for
recent hybrid cards that switch the AGC via tristateing.
Signed-off-by: Hartmut Hackmann<hartmut.hackmann@t-online.de>
tuners that need this.
- Moved MSP_SET_MATRIX to v4l2-common.h
- Fix typos and integer overflows in tea5767.c
- Split old freq field into a tv_freq and a radio_freq. Prevents
that a radio tuner is initialized with a tv frequency or vice versa.
- When switching to radio mode initialize the tuner with the last
used radio frequency (this was already done for the TV mode).
As a result of these changes the tuner module now remembers the
last set radio and TV frequencies, which is what you would expect
to happen.
- Move out of range frequencies to the closest valid frequency as per
v4l2 API spec.
- Fix incorrect initial radio frequency (multiplier is 16000, not 16)
- Add boundary check for out of range frequencies.
- Use new flag to check if the order of the CB and freq. depends on
the last set frequency. That is needed for some tuners or you can
get static as a result. The flag is added for those tuners where I know
that the datasheet indicates that this is necessary.
- For this new check use the last set div value, not the last frequency
as radio frequencies are always much higher due to the 16000 multiplier.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
- Added SECAM L' video standard
- Common std macros moved to videodev2.h
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
Added support for SECAM L'
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t.online.de>
Fixed tda8290 SECAM-L
- Unify whitespaces.
Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
- Corrected probing code for tda8290
- Added autodetection code to tda8290, to avoid conflicts with tda9887.
- Supports the Pinnacle PCTV 110i board, video inputs, and remote.
Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org>
- Strip trailing whitespaces.
- Add support for tda8275a
- Whitespace Cleanups.
- Set IF of tda8275 according to tv norm.
according with
- Included CB3 structures on tda8290
- Remove $Id CVS logs for V4L files
- Included newer cards.
- Added a new NEC protocol for ir based on pulse distance.
- Enable ATSC support for DViCO FusionHDTV5 Gold.
- Added tuner LG NTSC (TALN mini series).
- Fixed tea5767 autodetection.
- Resolve more tuner types.
- Commented debug function removed from mainstream.
- Remove comments from mainstream. Still on development tree.
- linux/version dependencies removed.
- BTSC Lang1 now is set to auto_stereo mode.
- New tuner standby API.
- i2c-core.c uses hexadecimal for the i2c address, so it should stay consistent.
Signed-off-by: Uli Luckas <luckas@musoft.de>
Signed-off-by: Mac Michaels <wmichaels1@earthlink.net>
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de>
- Fixed a trouble on tuner-core that generates erros on computers with more
than one TV card.
- Rename tuner structures fields.
- Tail spaces removed.
- I2C cleanups and converged to a basic reference structure.
- Removed unused structures.
- Fix setting frequency on tda8290.
- Added code for TEA5767 autodetection.
- Standby mode support implemented. It is used to disable
a non used tuner. Currenlty implemented on tea5767.
- New macro: set_type disables other tuner when changing mode.
- Some cleanups.
- Use 50 kHz step when tunning radio for most tuners to improve precision.
Signed-off-by: Fabien Perrot <perrot1983@yahoo.fr>
Signed-off-By: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
*tuner-core.c:
- some tuner_info msgs will be generated only if insmod opt
tuner_debug enabled.
- Implemented tuner-core support for VIDIO_S_TUNER to allow
changing mono/stereo mode
- Remove unneeded config options.
- I2C_CLIENT_MULTI option removed.
- support for Philips FMD12ME hybrid tuner
- allow to initialize with another tuner
- Move PHILIPS_FMD initialization code to set_type function,
* tda8290:
- Fix dumb error in tda8290 tunning.
- Radio tuner uses high-precision step instead of 62.5 KHz.
*tea5767.c:
- tuner_info msgs will be generated only if insmod tuner option
- some cleanups for better reading.
- Changing radio mode stereo/mono for tea5767 working.
*tuner-simple.c:
- TNF9533-D/IF UHF fixup.
- Radio tuners now uses high-precision step instead of 62.5 KHz.
*mt20xx.c:
*tda9887.c:
- tab and blank spaces corrections.
Signed-off-by: Gerd Knorr <kraxel@bytesex.org>
Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru>
infrastructure for it.
Let it rip!
