file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
VIDEOBUF_
s/STATE_NEEDS_INIT/VIDEOBUF_NEEDS_INIT/g
s/STATE_PREPARED/VIDEOBUF_PREPARED/g
s/STATE_QUEUED/VIDEOBUF_QUEUED/g
s/STATE_ACTIVE/VIDEOBUF_ACTIVE/g
s/STATE_DONE/VIDEOBUF_DONE/g
s/STATE_ERROR/VIDEOBUF_ERROR/g
s/STATE_IDLE/VIDEOBUF_IDLE/g
Signed-off-by: Brandon Philips <bphilips@suse.de>
PCI-dependent videobuf_foo methods were renamed as videobuf_pci_foo.
Also, videobuf_dmabuf is now part of videobuf-dma-sg private struct.
So, to access it, a subroutine call is needed.
This patch renames all occurences of those function calls to be
consistent with the video-buf split.
http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981
Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
Video_buf were concerned to allow PCI devices to be used as
video capture devices. This patch extends video_buf features
by virtualizing pci-dependent functions and allowing other
type of devices to use it.
It is still DMA centric, although it may be used also by
devices that emulates scatter/gather behavior or a DMA device
- Remove $Id CVS logs for V4L files
- linux/version.h replaced by linux/utsname.h
- Add new Digimatrix card and LG TAPC Mini tuner for it
Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
- Corrected all cards marked as 7135 cards to 7133.
- Add new card support for Compro VideoMate TV Gold+II.
- Add new card support for Kworld Xpert TV PVR7134
- Add new card support for Typhoon DVB-T Cardbus.
- Changes to comply with CodingStyle: // comments converted to /* */
- Remove irq2_mask field from saa7134_dev structure.
- Collect all the bits needed in saa7134_hwinit2() instead.
- Distinguish the different variants of the Medion MD7134 modules via eeprom
- moved Philips FMD1216 radio specific setup to saa7134-core.c
- Fix kernel compile error with CONFIG_MODULES=n
- Cleanup tuner private calls.
- Some Indent fixes.
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
Signed-off-by: Michael Krufky <mkrufky@m1k.net>
Signed-off-by: Hannibal <hannibal@megapolis.pl>
Signed-off-by: Elshin Roman <roxmail@list.ru>
Signed-off-by: Juergen Orschiedt <jorschiedt@web.de>
Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de>
This patch adds support for various SAA7134 cards and brings some fixes.
Signed-off-by: Fabrice Aeschbacher <fabrice.aeschbacher@laposte.net>
Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de>.
Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru>
This patch fixes NTSC VBI capturing in the saa7134 driver.
Signed-off-by: Michael H. Schimek <mschimek@gmx.at>
Cc: <video4linux-list@redhat.com>
infrastructure for it.
Let it rip!
