This change removes the old i2c module controlling layer from the
pvrusb2 driver. This is code that first had appeared in the driver
back in December 2005. It's history. Now we use v4l2-subdev. Please
note also that with this change, the driver will no longer be usable
in kernels older that 2.6.22.
Signed-off-by: Mike Isely <isely@pobox.com>
This is the first step in the effort to move the pvrusb2 driver over
to using the v4l2-subdev framework. This commit involves mainly
splitting apart pvrusb2-i2c-core - part of it is the driver's I2C
adapter driver and the rest is the old i2c module handling logic. The
i2c module handling junk is moved out to pvrusb2-i2c-track and various
header references are correspondingly updated. Yes, this patch has a
huge pile of checkpatch complaints, but I'm NOT going to fix any of
it. Why? First, I'm moving a large chunk of existing code and I'm
not going to spend time adjusting it to match someone's idea of coding
style. Second, in the end I expect all that moved code to go away by
the time the rework is done so wasting time on it now to adhere to the
standard is in the end a large waste of time.
first attach
It appears that various v4l-dvb drivers are changing to require
explicit initialization before use. This change to the pvrusb2 driver
implements an automatic issuance of VIDIOC_INT_INIT when a module is
bound to the driver, thus conforming to the new behavior.
Implement pvrusb2 driver plumbing to support cropping. Submitted by a
pvrusb2 user.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Audio mode changes are not private to the audio chip - other I2C
modules need to see this as well. And since the command in question
is VIDIOC_S_TUNER which is a standard v4l2 command, we really should
be broadcasting it out. This change sets up a broadcast pathway for
VIDIOC_S_TUNER and also eliminates the now redundant code from the
audio chip handler.
This fix enables stereo reception for the FM radio
Clean up use of VIDIOC_G_TUNER; we now correctly gather info from all
the I2C client modules. Also abide by V4L2_TUNER_CAP_LOW
appropriately.
Ensure we don't accidentally broadcast the standard while in radio mode.
This is the logic that supports switching modes via e.g.,
echo radio > /sys/class/pvrusb2/sn-*/ctl_input/cur_val.
To do the mode switching we need to:
a) broadcast AUDC_SET_RADIO and
b) issue the CX2341X_ENC_MUTE_VIDEO command to the encoder.
The first is done by adding a new pvr2_i2c_op and having it trigger on
input change, the second by adding this command in pvr2_encoder_start()
and requesting an encoder restart on input change by setting
stale_subsys_mask appropriately.
The clues about AUDC_SET_RADIO and CX2341X_ENC_MUTE_VIDEO were kindly
provided by Hans Verkuil on the pvrusb2 mailing list. The idea to
implement mode switching this way (on input change) is due to Mike Isely.
Why AUDC_SET_RADIO/VIDIOC_S_STD are used for switching? I can 't be sure,
but I think this can be traced to a cornell student being the first to
implement radio support in ivtv "as a different standard". I think the
rest just evolved from there (it 's in the ivtv ML archives).
Signed-off-by: Pantelis Koukousoulas <pakt223@freemail.gr>
Use NULL instead of 0 for pointer value, eliminate sparse warnings.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Support for 24xxx devices was previously explicitly bracketed with
CONFIG_VIDEO_PVRUSB2_24XXX inside the code because we didn't trust the
stability of these changes. We trust it now; so there's no reason to
leave this out of the driver anymore.
Implement V4L2 driver for the Hauppauge PVR USB2 TV tuner.
The Hauppauge PVR USB2 is a USB connected TV tuner with an embedded
cx23416 hardware MPEG2 encoder. There are two major variants of this
device; this driver handles both. Any V4L2 application which
understands MPEG2 video stream data should be able to work with this
device.
