path: root/drivers/media/video/omap3isp/isp.c
2012-01-23iommu/omap: eliminate the public omap_find_iommu_device() methodOhad Ben-Cohen
Eliminate the public omap_find_iommu_device() method, and don't expect clients to provide the omap_iommu handle anymore. Instead, OMAP's iommu driver now utilizes dev_archdata's private iommu extension to be able to access the required iommu information. This way OMAP IOMMU users are now able to use the generic IOMMU API without having to call any omap-specific binding method. Update omap3isp appropriately. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Hiroshi Doyu <hdoyu@nvidia.com> Conflicts: drivers/media/video/omap3isp/ispccdc.c Change-Id: Ia9b3421662fab7bb4bee298693ed6da716599ee5
2012-01-23iommu/core: Add bus_type parameter to iommu_domain_allocJoerg Roedel
This is necessary to store a pointer to the bus-specific iommu_ops in the iommu-domain structure. It will be used later to call into bus-specific iommu-ops. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Conflicts: drivers/iommu/iommu.c Change-Id: Iddbd561739552b663a4be293f1992314eb0f775a
2012-01-23omap: iommu: omapify 'struct iommu' and exposed APIOhad Ben-Cohen
Prepend 'omap_' to OMAP's 'struct iommu' and exposed API, to prevent namespace pollution and generally to improve readability of the code that still uses the driver directly. Update the users as needed as well. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Conflicts: arch/arm/plat-omap/include/plat/iommu.h arch/arm/plat-omap/include/plat/iovmm.h drivers/iommu/omap-iommu.c drivers/iommu/omap-iovmm.c drivers/media/video/omap3isp/isp.c drivers/media/video/omap3isp/isp.h drivers/media/video/omap3isp/ispccdc.c drivers/media/video/omap3isp/ispstat.c drivers/media/video/omap3isp/ispvideo.c Change-Id: I6e4825d93115596184ed3e2274fa759d13a5d6dc
2011-07-27[media] Stop using linux/version.h on the remaining video driversMauro Carvalho Chehab
Standardize the remaining video drivers to return the API version for the VIDIOC_QUERYCAP version, instead of a per-driver version. Those drivers had the version updated more recently or are SoC drivers. Even so, it doesn't sound a good idea to keep a per-driver version control, so, let's use the per-subsystem version control instead. Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-06-30[media] media: omap3isp: fix a potential NULL derefOhad Ben-Cohen
Fix a potential NULL pointer dereference by skipping registration of external entities in case none are provided. This is useful at least when testing mere memory-to-memory scenarios. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-06-01[media] omap3isp: fix compiler warningSanjeev Premi
This patch fixes this compiler warning: drivers/media/video/omap3isp/isp.c: In function 'isp_isr_dbg': drivers/media/video/omap3isp/isp.c:392:2: warning: zero-length gnu_printf format string Signed-off-by: Sanjeev Premi <premi@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-27Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits) [media] media: vb2: correct queue initialization order [media] media: vb2: fix incorrect v4l2_buffer->flags handling [media] s5p-fimc: Add support for the buffer timestamps and sequence [media] s5p-fimc: Fix bytesperline and plane payload setup [media] s5p-fimc: Do not allow changing format after REQBUFS [media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4 [media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet [media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet [media] tda18271: fix bad calculation of main post divider byte [media] tda18271: prog_cal and prog_tab variables should be s32, not u8 [media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init [media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails [media] v4l: Don't register media entities for subdev device nodes [media] omap3isp: Don't increment node entity use count when poweron fails [media] omap3isp: lane shifter support [media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts [media] media: add missing 8-bit bayer formats and Y12 [media] v4l: add V4L2_PIX_FMT_Y12 format cx23885: Fix stv0367 Kconfig dependency [media] omap3isp: Use isp xclk defines ... Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
2011-04-19[media] omap3isp: Don't increment node entity use count when poweron failsLaurent Pinchart
When open a device node, all entities part of the same pipeline are powered on. If one of the entities fails to be powered on, the open operations fails. In that case the device node entity use count must not be incremented. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] omap3isp: lane shifter supportMichael Jones
To use the lane shifter, set different pixel formats at each end of the link at the CCDC input. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: Use isp xclk definesStanimir Varbanov
Use isp defines for isp xclk selection in isp_set_xclk(). Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: isp: Reset the ISP when the pipeline can't be stoppedLaurent Pinchart
When a failure to stop a module in the pipeline is detected, the only way to recover is to reset the ISP. However, as other users can be using a different pipeline with other modules, the ISP can't be reset synchronously with the error detection. Mark the ISP as needing a reset when a failure to stop a pipeline is detected, and reset the ISP when the last user releases the last reference to the ISP. Modify the omap3isp_pipeline_set_stream() function to record the new ISP pipeline state only when no error occurs, except when stopping the pipeline in which case the pipeline is still marked as stopped. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: Fix trivial typosMichael Jones
It doesn't get more trivial than these. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] omap3isp: OMAP3 ISP coreSakari Ailus
The Image Signal Processor provides the system interface and the processing capability to connect RAW or YUV image-sensor modules to the OMAP3. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: David Cohen <dacohen@gmail.com> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Vimarsh Zutshi <vimarsh.zutshi@gmail.com> Signed-off-by: Tuukka Toivonen <tuukkat76@gmail.com> Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Antti Koskipaa <akoskipa@gmail.com> Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com> Signed-off-by: RaniSuneela <r-m@ti.com> Signed-off-by: Atanas Filipov <afilipov@mm-sol.com> Signed-off-by: Gjorgji Rosikopulos <grosikopulos@mm-sol.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Nayden Kanchev <nkanchev@mm-sol.com> Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Dominic Curran <dcurran@ti.com> Signed-off-by: Ilkka Myllyperkio <ilkka.myllyperkio@sofica.fi> Signed-off-by: Pallavi Kulkarni <p-kulkarni@ti.com> Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
