Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
"sd" and "err" are too common names to be used in macros for local variables.
Prefix them with an underscore to avoid name clashing.
[mchehab@redhat.com: whitespace cleanups]
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Reviewed-by: Andy Walls <awalls@md.metrocast.net>
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16
bytes of uninitialized stack memory, because the "reserved" member of
the fb_vblank struct declared on the stack is not altered or zeroed
before being copied back to the user. This patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB: v4l2-ctrls.c: needs to include slab.h
V4L/DVB: fix Kconfig to depends on VIDEO_IR
V4L/DVB: Fix IR_CORE dependencies
warning: (VIDEO_BT848 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_DEV && PCI && I2C && VIDEO_V4L2 && INPUT || VIDEO_SAA7134 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && VIDEO_DEV && PCI && I2C && INPUT || VIDEO_CX88 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && VIDEO_DEV && PCI && I2C && INPUT || VIDEO_IVTV && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && PCI && I2C && INPUT || VIDEO_CX18 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && DVB_CORE && PCI && I2C && EXPERIMENTAL && INPUT || VIDEO_EM28XX && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT || VIDEO_TLG2300 && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT && SND && DVB_CORE || VIDEO_CX231XX && MEDIA_SUPPORT && VIDEO_CAPTURE_DRIVERS && VIDEO_V4L2 && V4L_USB_DRIVERS && USB && VIDEO_DEV && I2C && INPUT || DVB_BUDGET_CI && MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && DVB_BUDGET_CORE && I2C && INPUT || DVB_DM1105 && MEDIA_SUPPORT && DVB_CAPTURE_DRIVERS && DVB_CORE && PCI && I2C && INPUT || VIDEO_GO7007 && STAGING && !STAGING_EXCLUDE_BUILD && VIDEO_DEV && PCI && I2C && INPUT && SND || VIDEO_CX25821 && STAGING && !STAGING_EXCLUDE_BUILD && DVB_CORE && VIDEO_DEV && PCI && I2C && INPUT) selects VIDEO_IR which has unmet direct dependencies (IR_CORE)
The probe method used by i2c_new_probed_device() may not be suitable
for all cases. Let the caller provide its own, optional probe
function.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
The cx25840 used a private control CX25840_CID_ENABLE_PVR150_WORKAROUND
to be told whether to enable a workaround for certain pvr150 cards.
This is really config data that it needs to get at load time.
Implemented this in cx25840 and ivtv.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
Stanse found that in ivtvfb_callback_cleanup and ivtvfb_callback_init
there are unneeded tests for itv being NULL. But itv is initialized
as container_of with non-zero offset in those functions, so it is
never NULL (even if v4l2_dev is). This was found because itv is
dereferenced earlier than the test.
If the firmware has failed, this patch will automatically reload &
restart the card. The previous card state will be restored on a
successful restart. Firmware reload will only happen if neither the
encoder or decoder is active. If the card is busy then behaviour is as
before, returning -EIO on device access until the reload can occur. On
cards that support video output, coloured bars will be displayed during
the reload.
Andy Walls (ivtv maintainer and patch committer) made minor tweaks to
comments and the logged messages, but nothing substantial otherwise.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
>From Ian's e-mail:
When a device is opened the firmware state will be checked. If it isn't
responding then the open will fail with -EIO. Due to the nature of the
hardware, a single failed check will block everything since we don't know
exactly what has failed. A side effect of this is the blocking of debug
access, so an additional debug level has been created which allows the block
to be bypassed.
Andy Walls' modifications:
I modified Ian's patch to add a separate fw_debug module parameter to change
the driver's behavior, as opposed to using the normal debug module parameter.
The fw_debug module parameter is only available when CONFIG_VIDEO_ADV_DEBUG
is set.
I also made some minor whitespace adjustments and changed some warning
messages to be a bit more specific. s/happy/glad/g
screen
Add a short delay when stopping the decoder, allowing it to settle and
preventing some unexpected interaction with other firmware commands.
Tested-by: Martin Dauskardt <martin.dauskardt@gmx.de>
Upcoming workqueue updates will no longer guarantee fixed workqueue to
worker kthread association, so giving RT priority to the irq worker
won't work. Use kthread_worker which guarantees specific kthread
association instead. This also makes setting the priority cleaner.
Cc: Andy Walls <awalls@md.metrocast.net>
Cc: ivtv-devel@ivtvdriver.org
Cc: linux-media@vger.kernel.org
Added small delay on device open & close to allow hardware to settle. Move yuv
register restore to before the decoder firmware call to stop playback.
For yuv video output, pass fake values to avoid firmware trying to change
video standard.
Check firmware state when loading module & if firmware is not responding exit
with an error. When module is unloaded, only disable the framebuffer & not all
decoder output.
VIDIOC_S_PRIORITY is also part of the ioctls that need to check the
access priority.
v4l2_prio_init/open/close returned an int when in fact they would
always return 0. Make these void functions.
v4l2_prio_close and v4l2_prio_check pass an enum v4l2_priority as a
pointer for no good reason. Replace with a normal enum v4l2_priority
argument.
These changes will simplify the work of moving priority handling into
the v4l core.
Only a relatively small number of video receivers and transmitters actually
support VBI. So start moving the vbi specific ops to an ops struct of their
own.
Now that video_ioctl2 no longer clobbers the argument for _IO() ioctls we
can move these into vidioc_default where they really belong.
Instead of using the ugly keymap sequences, use the new rc-*.ko keymap
files. For now, it is still needed to have one keymap loaded, for the
RC code to work. Later patches will remove this depenency.
Replaces most of the occurences of IR keytables on V4L drivers by a macro
that evaluates to provide the name of the exported symbol.
This fixes a smatch warning:
drivers/media/video/ivtv/ivtv-vbi.c +138 ivtv_write_vbi(43)
error: buffer overflow 'vi->cc_payload' 256 <= 1023
Reviewed-by: Andy Walls <awalls@radix.net>
Signed-off-by: Andy Walls <awalls@radix.net>
address
Get rid of the magic number 0x28c0 used in several places in the ivtv and
ivtvfb driver and define the register address to a meaningful name.
Changing the decoder video standard just prior to, or during, the output of
the lower field may result in a hard system lock. To avoid this, try to ensure
the firmware call occurs only during the first 100 lines of the top field.
(Minor comment addition and a line break added Andy Walls <awalls@radix.net>.)
When a capture is started, the firmware also appears to start a secondary
stream. Unless this secondary stream is also stopped, the encoder will remain
active and not reinitialise for the next capture. Unfortunately, setting up
the video source can glitch the encoder and result in undesirable effects that
this initialisation will clear.
Combine the two 150 ms delays into a single 300 ms delay. Ian Armstrong has
noted that the delay between CX2341X_ENC_INITIALIZE_INPUT and
CX2341X_ENC_START_CAPTURE can cause problems if the temporal filter is allowed
to be enabled.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Based on experiments by Eric Wescott, edit the Sony GigaPocket (Kikyou)
card entry video and audio mux settings.
This is a slightly modified version of Eric Anderson's original patch
for the Sony Giga Pocket board. It has been updated to apply to the
latest ivtv driver version by Hans Verkuil <hverkuil@xs4all.nl> and
Andy Walls <awalls@radix.net>. Also Andy Walls modified the patch to
use a new Sony BTF-Pnx01Z tuner entry based on Eric Anderson's experimental
findings for the bandswitch.
>From Eric Anderson's original email:
1. The tuner on the card doesn't seem to match any standard
ones. I modified an existing tuner entry. Ideally a new tuner
entry should be created. (The only difference from the one I
modified is that the low-to-mid range frequency cut-off is
slightly different, as are the bit config settings.)
2. It wasn't obvious how to choose a second audio input other
than using "radio" as an option. Basically there's two GPIO
audio inputs. Using radio allowed me to avoid major restructuring
to the code. (perhaps other cards don't have this often...)
3. It's not clear that there's a mute setting that works. Not
sure why.
4. I haven't had a chance to test the two Svideo inputs. I set
them to COMPOSITE1 and SVIDEO2, but I'm not sure those are the
correct settings. The standard composite video inputs seem to work.
ivtv_api_get_data() was performing more PCI MMIO than needed, resulting
often in it accounting for more than half the total time spent in
ivtv_irq_handler(). Now it only reads at most 7 of the 16 mailbox data words
over the PCI bus, and in some instances only 2 or 3 data words as needed.
bus hang
Martin Dauskardt <martin.dauskardt@gmx.de> has done extensive testing on what
values can be used and and concluded that only 300 ms total is required to
avoid bad video effects such as occasional black screen and short sync
disturbances. Furthermore he determined how this 300 ms was split between
the two msleep()s did matter very much, so he suggested 150ms/150ms as one
acceptable alternative that is implemented here.
Many thanks go to Martin.
This change attempts to fix the ivtv tinny audio problem by keeping digitizer
to encoder audio clocks running, while disabling the video clocks as needed to
avoid unpredictable PCI bus hangs.
To accomplish this, for the cx25840 module enabling of audio streaming had
to be separated from enabling video streaming, requiring an additional
v4l2_subdev_audio_op and calls to this new op in the pvrusb2 and ivtv drivers.
The cx231xx and cx23885 driver use the cx25840 module for affecting only
video on s_stream calls, so those drivers needed no change.
The CX23418 hardware does not exhibit either the tinny audio problem nor the PCI
bus hang, so the cx18 driver did not need corresponding changes.
CX2341[56] based cards that are not using the CX2584x family of chips
do not seem to be affected by the tinny audio problem, and this change should
not affect how they are configured. It will delay their first capture by
starting by another 300 msec though.
Many thanks go to Argus <pthorn-ivtvd@styx2002.no-ip.org> and
Martin Dauskardt <martin.dauskardt@gmx.de> whose persistent testing and
investigation of this problem will hopefully fix this problem once and for all
for many ivtv users.
Reported-by: Martin Dauskardt <martin.dauskardt@gmx.de>
Reported-by: Argus <pthorn-ivtvd@styx2002.no-ip.org>
There are several DMA related interrupts which wake up the dma_waitq. The udma
routines use this queue while they wait for their transfer to complete. When
woken, the udma routine will check the IVTV_F_I_UDMA_PENDING & IVTV_F_I_UDMA
flags to see if the transfer is still queued or has finished. However, a small
window exists between the IVTV_F_I_UDMA_PENDING flag being cleared and the
IVTV_F_I_UDMA flag being set. Given that the completion of an unrelated DMA
transfer may wake up the udma routine, it's possible for this check to fail
and the udma routine will start unmapping pages when the transfer has only
just started. The result of this is unpredictable.
This fix simply delays the clearing of the IVTV_F_I_UDMA_PENDING flag until
after IVTV_F_I_UDMA has been set.
Instead of using the minor number in kernel log messages, use the device
node name as returned by the video_device_node_name() function. This
makes debug, informational and error messages easier to understand for
end users.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Fix all device drivers to use the new video_device_node_name function.
This also strips kernel log messages from the "/dev/" prefix, has the device
node location is a userspace policy decision unknown to the kernel.
Hauppauge cards
Avoid legacy IR I2C probing for PVR-150, PVR-500, and PVR-350 cards. This
still probes, but restricts the possbile addresses probed per card.
Also removed legacy probe addresses for the KNC and PixelView cards which are
not supported by ivtv as far as I know.
AVerTV M116
Add explicit support for the AVerTV M116 for use with the ir-kbd-i2c module.
This also eases future support for other AVerMedia ivtv boards with the same
microcontroller program at I2C address 0x40.
This is a reworked version of an earlier patch that was...
Reviewed-by: Jean Delvare <khali@linux-fr.org>
known I2C devices
This avoids collisions of legacy IR controller probing with known I2C devices
in the card definitions in ivtv-cards.c. I2C driver modules for device listed
explicitly in a card definition should always take precedence over a probe
guessing where and IR controller may be.
per board
Add a module parameter to adjust I2C SCL clock period per board. This allows
some experimental fine tuning by end users to overcome quirky I2C device
problems.
Reported-by: "Aleksandr V. Piskunov" <aleksandr.v.piskunov@gmail.com>
Plus card
Signed-off-by: Aleksandr V. Piskunov <alexandr.v.piskunov@gmail.com>
M113 variant
Add an AVerMedia M113 variant that was...
Reported-by: Hiemanshu Sharma <hiemanshu@fedoraproject.org>
Trivial patch which adds the __init/__exit macros to the module_init/
module_exit functions of the following drivers in media video:
drivers/media/video/ivtv/ivtv-driver.c
drivers/media/video/cx18/cx18-driver.c
drivers/media/video/davinci/dm355_ccdc.c
drivers/media/video/davinci/dm644x_ccdc.c
drivers/media/video/saa7164/saa7164-core.c
drivers/media/video/saa7134/saa7134-core.c
drivers/media/video/cx23885/cx23885-core.c
Cc: Hermann Pitton <hermann-pitton@arcor.de>
Acked-by: Steven Toth <stoth@kernellabs.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Andy Walls <awalls@radix.net>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Muralidharan Karicheri <m-karicheri2@ti.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
function
Warn when the desired device node number is already in use, except when
the new video_register_device_no_warn function is called since in some
use-cases that warning is not relevant.
