path: root/drivers/media/video/fsl-viu.c
2011-05-20[media] media: fsl_viu: fix bug in streamon routineAnatolij Gustschin
Currently video capturing using streaming I/O method doesn't work if capturing to overlay buffer took place before. When enabling the stream we have to check the overlay enable driver flag and reset it so that the interrupt handler won't execute the overlay interrupt path after enabling DMA in streamon routine. Otherwise the capture interrupt won't be handled correctly causing non working VIDIOC_DQBUF ioctl. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] fsl_viu: add VIDIOC_OVERLAY ioctlAnatolij Gustschin
Currently the driver enables overlay when running VIDIOC_S_FMT ioctl with fmt type V4L2_BUF_TYPE_VIDEO_OVERLAY. Actually, this is wrong. Add proper VIDIOC_OVERLAY support instead of using VIDIOC_S_FMT for overlay enable. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] fsl-viu: replace .ioctl by .unlocked_ioctlAnatolij Gustschin
Use the core-assisted locking in fsl-viu driver and switch to .unlocked_ioctl. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29[media] fsl_viu: add VIDIOC_QUERYSTD and VIDIOC_G_STD supportAnatolij Gustschin
VIDIOC_QUERYSTD and VIDIOC_G_STD ioctls are currently not supported in the FSL VIU driver. The decoder subdevice driver saa7115 extended by previous patch supports QUERYSTD for saa711x, so we add the appropriate ioctls to the VIU driver to be able to determine the video input's standard. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] media: fsl-viu: fix support for streaming with mmap methodAnatolij Gustschin
Streaming using mmap didn't work in the VIU driver. We need to start/stop DMA in streamon/streamoff and free the buffers on release. Add appropriate driver extension now. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-22[media] v4l: Remove module_name argument to the v4l2_i2c_new_subdev* functionsLaurent Pinchart
The argument isn't used anymore by the functions, remove it. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-22[media] v4l: Remove hardcoded module names passed to v4l2_i2c_new_subdev*Laurent Pinchart
With the v4l2_i2c_new_subdev* functions now supporting loading modules based on modaliases, replace the hardcoded module name passed to those functions by NULL. All corresponding I2C modules have been checked, and all of them include a module aliases table with names corresponding to what the drivers modified here use. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: videobuf: add ext_lock argument to the queue init functions (part 2)Hans Verkuil
Missed a few init functions on non-Intel platforms the first time :-( Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: videobuf: add queue argument to videobuf_waiton()Hans Verkuil
videobuf_waiton() must unlock and relock ext_lock if it has to wait. For that to happen it needs the videobuf_queue pointer. Don't attempt to unlock/relock q->ext_lock unless it was locked in the first place. vb->state has to be protected by a spinlock to be safe. This patch is based on code from Mauro Carvalho Chehab <mchehab@redhat.com>. [mchehab@redhat.com: add extra argument to a few missing places] Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l: fsl-viu.c: add slab.h include to fix compile breakageAnatolij Gustschin
mpc512x kernel configurations without SPI support do not build: drivers/media/video/fsl-viu.c: In function 'viu_open': drivers/media/video/fsl-viu.c:1248: error: implicit declaration of function 'kzalloc' drivers/media/video/fsl-viu.c:1248: warning: assignment makes pointer from integer without a cast drivers/media/video/fsl-viu.c: In function 'viu_release': drivers/media/video/fsl-viu.c:1335: error: implicit declaration of function 'kfree' If CONFIG_SPI is enabled, the slab.h will be included in linux/spi/spi.h which is included by media/v4l2-common.h and the fsl_viu.c driver builds. Let's incluce linux/slab.h directly to fix the build breakage. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-02V4L/DVB: v4l: Add MPC5121e VIU video capture driverAnatolij Gustschin
Adds support for Video-In (VIU) unit of Freescale MPC5121e. The driver supports RGB888/RGB565 formats, capture and overlay on MPC5121e DIU frame buffer. Signed-off-by: Hongjun Chen <hong-jun.chen@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
