path: root/drivers/media/video/cx88/cx88-cards.c
2006-01-23V4L/DVB (3416): Recognise Hauppauge card #34519Ian Pickworth
- Recognise Hauppauge card #34519 Signed-off-by: Ian Pickworth <ian@pickworth.me.uk> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3392): Add PCI ID for DigitalNow DVB-T Dual, rebranded DViCO ↵Michael Krufky
FusionHDTV DVB-T Dual. - Add PCI ID for DigitalNow DVB-T Dual, rebranded DViCO FusionHDTV DVB-T Dual. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-12V4L/DVB (3349): Add PCI ID for UltraView DVB-T Plus, rebranded DViCO ↵Michael Krufky
FusionHDTV DVB-T Plus - Add PCI ID for UltraView DVB-T Plus,rebranded DViCO FusionHDTV DVB-T Plus Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L/DVB (3329): cx88_subids whitespace cleanupChris Pascoe
- Clean up a recently introduced spaces vs tabs whitespace problem. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3311): DViCO FusionHDTV DVB-T Dual Digital PCI supportChris Pascoe
- Support for DVB reception on the PCI half of the DViCO DVB-T Dual Digital. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3294): Add Kworld/Vstream Xpert DVB-T card with cx22702 tuner.Manenti Marco
- Add Kworld/Vstream Xpert DVB-T card with cx22702 tuner. Signed-off-by: Manenti Marco <marco_manenti@colman.it> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3220): Add support for VP-3054 HDTV boardChris Pascoe
- Added support for VP-3054 (aka DigitalNow DNTV Live! DVB-T Pro!). - This board has a secondary I2C bus and remote control. - Added a new module to handle secondary I2C bus on this board. Signed-off-by: Chris Pascoe <c.pascoe@itee.uq.edu.au> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3196): correct Thomson DTT 761x frequency rangesMichael Krufky
- Corrected Thomson DTT 7611 tuner programming, based on spec sheet - renamed to Thomson DTT 761x - applies to DTT 7611 7611A 7612 7613 7613A 7614 7615 7615A (DTT 7610 is similar, but slightly different programming) - corrected frequency ranges for analog and digital modes Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3112): Several fixes for Hauppauge Roselyn Design (blackbird)Steven Toth
- This patch adds eeprom awareness for the Roslyn. In effect, the blackbird will query the tuner V4L2_STD_xxxx definitions to determine whether it's connected to a NTSC or PAL tuner. Based on that, various default values will change for blackbird encoding. - Fixes back panel SVIDEO/COMPOSITE with audio, work properly. - Fixes a problem with lip sync issues, due to bad framerate vs audio rate assumptions. - Fixed a problem with the GPIO configuration in cx88-cards. - Removed the comments in cx88-cards that made no sense. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3092): Add support for another Nova-T-PCI PCI subdevice 0x9001Steven Toth
- Add support for another Nova-T-PCI PCI subdevice 0x9001 Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L/DVB (3089): Adding support for the Hauppauge HVR1100 and HVR1100-LP ↵Steven Toth
products. - Add support for the Hauppauge HVR1100 and HVR1100-LP products. - Add i2c_gate_ctrl callback function to dvb_frontend_ops struct. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L (1007): Add support for KWorld DVB-S 100Vadim Catana
- Add support for KWorld DVB-S 100, based on the same chips as Hauppauge Nova-S Plus (CX23883/CX24123/CX24109), without the Intersil ISL6421, which is used for LNB control. - LNB voltage and tone are controled by LNBDC and LNBTone bits from register 0x29 of the CX24123 demodulator. - The MO_GP0_IO register from CX23883 is used to turn LNB power on and off. Signed-off-by: Vadim Catana <skystar@moldova.cc> Acked-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L (0990): Enable IR support for the Nova-S-PlusSteven Toth
- Enable IR support for the Nova-S-Plus. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-09V4L (0979): Added V4L support for the Nova-S-Plus and Nova-SE2 DVB-S productsSteven Toth
- Added V4L support for the Nova-S-Plus and Nova-SE2 DVB-S products. - Basic DVB-S support is working, analog video inputs work. - It has one or two fixme comments, primarily analog GPIOs (audio) and eeprom parsing. - CX24123 code (in cx88-dvb.c) disabled until the - cx24123 module is added to dvb-kernel cvs. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-12-04[PATCH] V4L/DVB (3087) fix analog NTSC for pcHDTV 3000Mauro Carvalho Chehab
- fix analog NTSC for pcHDTV 3000 - Fix regression: broken analog NTSC for DViCO FusionHDTV3 Gold-T - add tda9887 to card struct, required for both cards. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4L: Fixed eeprom handling for cx88 and added Nova-T PCI model 90003Steven Toth
- Fixed code handling for eeprom on cx88 boards. - Hauppauge released a new version of the Nova-T-PCI (9002) a few months ago with a different (compatible) tuner (but lacking RF passthru). The official model# is 90003. All features are working. - Adding entry to the known model list after testing. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4L: tveeprom MAC address parsing/cleanupSteven Toth
- Added a mac address field to the tveeprom structure. - allow callers to query the MAC address. - removed some redundant eeprom parsing code in cx88-cards.c (specific to Hauppauge DVB products) Instead, placed calls directly to the single eeprom parsing function in tveeprom.c Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] V4: Include comments for DVB models and includes missing onesSteven Toth
Include comments for DVB models and includes missing ones Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 895: new avermedia 303 card without radioLubomir Bulej
- New Avermedia 303 card (without radio). Signed-off-by: Lubomir Bulej <bulej@nenya.ms.mff.cuni.cz> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 868: added support for nxt200x based cards ati hdtv wonderKirk Lapray
- Added support for NXT200X based cards (ATI HDTV Wonder) Signed-off-by: Kirk Lapray <kirk.lapray@gmail.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 800: whitespace cleanupsMauro Carvalho Chehab
- Whitespace Cleanups. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 795: new config option for tda9887 to specifically set intercarrierNickolay V. Shmyrev
- New config option for tda9887 to specifically set intercarrier Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 766: add dvb card winfast dtv1000-tDavid Shirley
- Add DVB card WinFast DTV1000-T Signed-off-by: David Shirley <David.Shirley@team.telstra.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 712: added analog support for ati hdtv wonderKirk Lapray
- Added analog support for ATI HDTV Wonder Signed-off-by: Kirk Lapray <kirk.lapray@gmail.com> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 705: added kworld vstream expertdvdAlexander Wold
- Added Kworld Vstream ExpertDVD. Signed-off-by: Alexander Wold <awold@bigfoot.com> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 630: capitalized hex a f changed to lowercase in pci subsystem ↵Michael Krufky
id constants - Capitalized hex A-F changed to lowercase in pci subsystem id constants Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 628: added new avermedia card 550Nickolay V. Shmyrev
- Added new Avermedia card 550 Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v4l: tveeprom improved to support newer Hauppage cardsMauro Carvalho Chehab
- tveeprom improved and updated to reflect newer Hauppage cards. - CodingStyle fixes. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v4l: CX88 updates and card additionsMauro Carvalho Chehab
- Remove $Id CVS logs for V4L files - add ioctl indirection via cx88_ioctl_hook and cx88_ioctl_translator to cx88-blackbird.c. - declare the indirection hooks from cx88-blackbird.c. - dcprintk macro which uses core instead of dev->core on cx88-video.c. - replace dev->core occurances with core on cx88-video.c. - CodingStyle fixes. - MaxInput replaced by a define. - cx8801 structures moved from cx88.h. - The output_mode needs to be set for the Hauppauge Nova-T DVB-T for versions after 2.6.12. - Corrected GPIO values for cx88 cards #28 & #31 for s-video and composite. - Updated DViCO FusionHDTV5 Gold & added DVB support. - Fixed DViCO FusionHDTV 3 Gold-Q GPIO. - Some clean up in cx88-tvaudio.c - replaced hex values when writing to AUD_CTL to EN_xx for better reading. - Allow select by hand between Mono, Lang1, Lang2 and Stereo for BTSC. - Support for stereo NICAM and BTSC improved. - Broken stereo check removed. - Added support for remote control to Cinergy DVBT-1400. - local var renamed from rc5 to a better name (ircode). - LGDT330X QAM lock bug fixes. - Some reorg: move some bits to struct cx88_core, factor out common ioctl's to cx88_do_ioctl. - Get rid of '//' comments, replace them with #if 0 and /**/. - Minor clean-ups: remove dcprintk and replace all instances of "dev->core" with "core". - Added some registers to control PCI controller at CX2388x chips. - New tuner standby API. - Small mpeg fixes and cleanups for blackbird. - fix mpeg packet size & count - add VIDIOC_QUERYCAP ioctl for the mpeg stream - return more information in struct v4l2_format - fix default window height - small cleanups Signed-off-by: Uli Luckas <luckas@musoft.de> Signed-off-by: Torsten Seeboth <Torsten.Seeboth@t-online.de> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Patrick Boettcher <patrick.boettcher@desy.de> Signed-off-by: Catalin Climov <catalin@climov.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] v4l: cx88 card support and documentation finishing touchesMichael Krufky
Peter Missel: - Add support for the SVideo input on the GDI Black Gold. Mauro Carvalho Chehab: - Linux/version.h removed. Replaced by linux/utsname.h Michael Krufky: - Added analog support for DViCO FusionHDTV5 Gold. CC: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] V4L: Miscellaneous fixesMauro Carvalho Chehab
- Fixed some bttv card numbers. - BTTV and SAA7134 version numbers incremented to reflect changes. - pci_dma_supported() is called after pci_set_dma_mask() which already did check that for us. This patch removes the unneeded call to pci_dma_supported() at bttv-driver.c - Ensure a sufficient I2C bus idle time between 2 messages for saa7134-i2c.c - It is important to write at first to MO_GP3_IO for cx88-tvaudio.c - Use try_to_freeze() instead of refrigerator at msp3400.c - Recognizing the MFPE05-2 Tuner at tveeprom.c - Add new parameter to help identify radio chipsets at tuner module: show_i2c=1 will show 16 reading bytes from detected tuners. - BTTV does generate some Unimplemented IOCTL log at tuner module: 0x40046d11(dir=1,tp=0x6d,nr=17,sz=4) means that it is sending MSP3400 calls to non-msp3400 tuners. Warning eliminated. VIDIOSAUDIO is also called, so debug messages updated. It is still requiring IOCTL implementation. - Added two more tuners. - Add support for the SVideo input on the GDI Black Gold. Signed-off-by: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Graham Bevan <graham.bevan@ntlworld.com> Signed-off-by: Torsten Seeboth <Torsten.Seeboth@t-online.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t.online.de> Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-15[PATCH] v4l: bug fixes for tuner, cx88 and tea5767Mauro Carvalho Chehab
- In CX88 code, some cards needs to have audio reprogramed after changing video channel; - Tuner autodetection code seems not to work on some cards. Now, no_autodetect insmod option allows disabling autodetection code; - Minor fixes in tea5767 to reduce integer trunc; - There are some new Pixelview Ultra Pro cards that doesn't use TEA5767 for radio. As autodetection is capable of checking for tea, radio tuners and addresses removed. - CX88 version number incremented. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] v4l: add DVB support for DViCO FusionHDTV3 Gold-TMichael Krufky
- Correct sync byte for MPEG-2 transport stream packets. - Add lgdt3302 as dependency of cx88-dvb in Kconfig. - Add dvb support in v4l for DViCO FusionHDTV3 Gold-T using lgdt3302 frontend. This adds support for a different board from the previous (Gold-Q) patch. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] v4l: add TerraTec Cinergy 1400 DVB-TMichael Krufky
Add support for TerraTec Cinergy 1400 DVB-T. Signed-off-by: Uli Luckas <luckas@musoft.de> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] v4l: add DVB support for DViCO FusionHDTV3 Gold-QMichael Krufky
Add dvb support in v4l for DViCO FusionHDTV3 Gold-Q using lgdt3302 frontend. Signed-off-by: Mac Michaels <wmichaels1@earthlink.net> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] v4l: cx88 updateMauro Carvalho Chehab
- Add support for ADS Tech Instant TV DVB-T PCI. - Remove obsoleted config options. - Fix DViCO Board names - Remove CABLE type setting from DViCO FusionHDTV3 Gold-T. - Fix compilation with gcc4.0. - V4L2_TUNER_CAP_LOW implemented according with V4L2 API for Radio. - radio range is now defined on tuner-core.c. Cleaning up. - Fix a bug on frequency report for cx88 based cards. - Added support for changing radio mode stereo/mono. - Add remove for MSI TV@nywhere. Signed-off-by: Jorik Jonker <jorik@dnd.utwente.nl>. Signed-off-by: Didier Caillaud <mailing.cld@free.fr> Signed-off-by: Benoit Laniel <benoit.laniel@gmail.com>. Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: CX88 cards updateMauro Carvalho Chehab
This patch adds support for various CX88 cards and allows specifying card addresses. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: cybercide@f2s.com <cybercide@f2s.com> Signed-off-by: Catalin Climov <catalin@climov.com> Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: support tuner for Thomson DDT 7611 (ATSC/NTSC)Michael Krufky
Add support for tuner#60: Thomson DDT 7611 (ATSC/NTSC) Change tuner in card#28 (DViCO FusionHDTV3 Gold-T) from tuner=52 (Tuner Thomson DDT 7610) to tuner=60 (Tuner Thomson DDT 7611) Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] DViCO FusionHDTV3 Gold-T documentation fixMichael Krufky
Even though it says DViCO FusionHDTV3 Gold-Q on the box, Gold-T is printed on the card. This fix corrects the error in all places, and corrects the tuner name Thomson DDT 7611 (ATSC/NTSC) in the documentation. This applies against 2.6.12-rc5-mm2 after applying Manueal Capinha's patch "Add support for PixelView Ultra Pro in v4l" (because of the change from card=27 to card=28) Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: add support for PixelView Ultra ProManuel Capinha
The following patch adds support for the PixelView Ultra Pro video capture card in v4l. - It removes the remote control key definitions from ir-kbd-gpio.c and moves them to ir-common.c so that they can be shared between bt878 and cx88 based cards. - The patch also moves the FUSIONHDTV_3_GOLD_Q card from number 27 to 28 to regain compatibility with the V4L cvs. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] Fix for cx88-cards.c for DVICO-FusionHDTV 3 GOLD QMichael Krufky
This patch allows full analog functionality for the DViCO FusionHDTV3 Gold-Q, 18ac:d820 which has a Conexant cx23882, Thompson7611, and LG 3202. It does NOT yet support digital decoding or digital audio without the internal analog audio jack connected to the sound board, but it works perfectly in analog mode. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
