This patch introduces the use of IS_ENABLED() macro. For example,
replacing:
#if defined(CONFIG_I2C) || (defined(CONFIG_I2C_MODULE) && defined(MODULE))
with:
#if IS_ENABLED(CONFIG_I2C)
All changes made by this patch respect the same replacement pattern.
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Acked-by: Antti Palosaari <crope@iki.fi>
When subdev registration fails the subdev v4l2_dev field is left to a
non-NULL value. Later calls to v4l2_device_unregister_subdev() will
consider the subdev as registered and will module_put() the subdev
module without any matching module_get().
Fix this by setting the subdev v4l2_dev field to NULL in
v4l2_device_register_subdev() when the function fails.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: stable@vger.kernel.org
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
With a filter function you can control more precisely which controls
are added. This is useful in particular for radio device nodes for
combined TV/Radio cards where you want to show just the radio-specific
controls and not controls like brightness.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Currently, the v4l2 core is mixed together with other non-core drivers.
Move them into a separate directory.
