path: root/drivers/media/usb/pwc
2015-01-29[media] pwc: fix WARN_ONHans Verkuil
If start_streaming fails, then the buffers must be given back to vb2 with state QUEUED, not ERROR. Otherwise a WARN_ON will be generated. In the disconnect it is pointless to call pwc_cleanup_queued_bufs() as stop_streaming() will be called anyway. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Tested-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-09-03[media] pwc: fix sparse warningHans Verkuil
drivers/media/usb/pwc/pwc-v4l.c:55:12: warning: symbol 'pwc_auto_whitebal_qmenu' was not declared. Should it be static? Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: remove the setting of the flag V4L2_FL_USE_FH_PRIORamakrishnan Muthukrishnan
Since all the drivers that use `struct v4l2_fh' use the core priority checking, the setting of the flag in the drivers can be removed. Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-04-23[media] vb2: stop_streaming should return voidHans Verkuil
The vb2 core ignores any return code from the stop_streaming op. And there really isn't anything it can do anyway in case of an error. So change the return type to void and update any drivers that implement it. The int return gave drivers the idea that this operation could actually fail, but that's really not the case. The pwc amd sdr-msi3101 drivers both had this construction: if (mutex_lock_interruptible(&s->v4l2_lock)) return -ERESTARTSYS; This has been updated to just call mutex_lock(). The stop_streaming op expects this to really stop streaming and I very much doubt this will work reliably if stop_streaming just returns without really stopping the DMA. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Pawel Osciak <pawel@osciak.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-03-11[media] pwc: do not decompress the image unless the state is DONEHans Verkuil
There is no point in trying to decompress a captured frame unless the buffer state is OK. It won't be used in any other state, and in fact the contents of the buffer might well be corrupt. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-03-11[media] vb2: change result code of buf_finish to voidHans Verkuil
The buf_finish op should always work, so change the return type to void. Update the few drivers that use it. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Pawel Osciak <pawel@osciak.com> Reviewed-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-03-05[media] v4l: Rename vb2_queue.timestamp_type as timestamp_flagsSakari Ailus
The timestamp_type field used to contain only the timestamp type. Soon it will be used for timestamp source flags as well. Rename the field accordingly. [m.chehab@samsung.com: do the change also to drivers/staging/media and at s2255] Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-07[media] media: Remove OOM message after input_allocate_deviceJoe Perches
Emitting an OOM message isn't necessary after input_allocate_device as there's a generic OOM and a dump_stack already done. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-11-29[media] media_tree: Fix spelling errorsJonathan McCrohan
Fix various spelling errors in strings and comments throughout the media tree. The majority of these were found using Lucas De Marchi's codespell tool. [m.chehab@samsung.com: discard hunks with conflicts] Signed-off-by: Jonathan McCrohan <jmccrohan@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2013-05-07[media] pwc: Fix comment wrt lock orderingHans de Goede
With all the changes to handle the locking in the v4l2-core rather then at the driver level, the order in which the 2 pwc locks need to be taken has changed, update the comment in the header file to correctly reflect this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-03-05[media] vb2: Add support for non monotonic timestampsKamil Debski
Not all drivers use monotonic timestamps. This patch adds a way to set the timestamp type per every queue. In addition, set proper timestamp type in drivers that I am sure that use either MONOTONIC or COPY timestamps. Other drivers will correctly report UNKNOWN timestamp type instead of assuming that all drivers use monotonic timestamps. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2013-02-05[media] pwc: Don't return EINVAL when an unsupported pixelformat is requestedHans de Goede
Instead chaneg the passed in format to the pwc default pixelformat. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-27[media] pwc: Replace memcpy with struct assignmentEzequiel Garcia
This kind of memcpy() is error-prone. Its replacement with a struct assignment is prefered because it's type-safe and much easier to read. Found by coccinelle. Hand patched and reviewed. Tested by compilation only. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier struct_name; struct struct_name to; struct struct_name from; expression E; @@ -memcpy(&(to), &(from), E); +to = from; // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-12-21[media] v4l: Convert drivers to use monotonic timestampsSakari Ailus
Convert drivers using wall clock time (CLOCK_REALTIME) to timestamp from the monotonic timer (CLOCK_MONOTONIC). Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-11-21[media] pwc: Fix codec1 cameras no longer workingHans de Goede
2012-10-28[media] pwc-if: must check vb2_queue_init() successMauro Carvalho Chehab
drivers/media/usb/pwc/pwc-if.c: In function 'usb_pwc_probe': drivers/media/usb/pwc/pwc-if.c:1003:16: warning: ignoring return value of 'vb2_queue_init', declared with attribute warn_unused_result [-Wunused-result] In the past, it used to have a logic there at queue init that would BUG() on errors. This logic got removed. Drivers are now required to explicitly handle the queue initialization errors, or very bad things may happen. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-10-28[media] pwc-if: get rid of warning: no previous prototypeMauro Carvalho Chehab
drivers/media/usb/pwc/pwc-if.c:158:23: warning: no previous prototype for 'pwc_get_next_fill_buf' [-Wmissing-prototypes] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-13[media] pwc: Remove unneeded struct vb2_queue clearingEzequiel Garcia
struct vb2_queue is allocated through kzalloc as part of a larger struct, there's no need to clear it. Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-09-13[media] pwc: Use vb2 queue mutex through a single nameEzequiel Garcia
This lock was being taken using two different names (pointers) in the same function. Both names refer to the same lock, so this wasn't an error; but it looked very strange. Cc: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-16[media] Fix some Makefile rulesMauro Carvalho Chehab
On a few places, := were using instead of +=, causing drivers to not compile. While here, standardize the usage of += on all cases where multiple lines are needed, and for obj-y/obj-m targets, and := when just one line is needed, on <module>-obj rules. Reported-by: Hans Verkuil <hverkuil@xs4all.nl> Identified-by: Antti Polosaari <crope@iki.fi> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-15[media] rename most media/video usb drivers to media/usbMauro Carvalho Chehab
Rename all USB drivers with their own directory under drivers/media/video into drivers/media/usb and update the building system. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
