For two of the supported sensors the stv06xx driver allocates memory which
is stored in sd->sensor_priv. This memory is freed on a disconnect, but if
the probe() fails, then it isn't freed and so this leaks memory.
Add a new probe_error() op that drivers can use to free any allocated
memory in case there was a probe failure.
Thanks to Pavel Skripkin <paskripkin@gmail.com> for discovering the cause
of the memory leak.
Reported-and-tested-by: syzbot+e7f4c64a4248a0340c37@syzkaller.appspotmail.com
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
The gspca driver leaks memory when a probe fails. gspca_dev_probe2()
calls v4l2_device_register(), which takes a reference to the
underlying device node (in this case, a USB interface). But the
failure pathway neglects to call v4l2_device_unregister(), the routine
responsible for dropping this reference. Consequently the memory for
the USB interface and its device never gets released.
This patch adds the missing function call.
Reported-and-tested-by: syzbot+44e64397bd81d5e84cba@syzkaller.appspotmail.com
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@vger.kernel.org>
If a device supports a resolution in 2 different formats, mode[0] is
skipped on first iteration and a different format is selected.
Example: 320x240/YUYV isn't reachable for OV534/ov772x
Signed-off-by: Florin Tudorache <florin_tudorache@live.com>
'GRABBER' is a weird name, all other types map to the /dev
device names. Rename to 'VIDEO' to be consistent with the
other types.
Allocate gspca_dev->usb_buf with kzalloc instead of kmalloc to
ensure it is property zeroed. This fixes various syzbot errors
about uninitialized data.
Syzbot links:
https://syzkaller.appspot.com/bug?extid=32310fc2aea76898d074
https://syzkaller.appspot.com/bug?extid=99706d6390be1ac542a2
https://syzkaller.appspot.com/bug?extid=64437af5c781a7f0e08e
Reported-and-tested-by: syzbot+32310fc2aea76898d074@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+99706d6390be1ac542a2@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+64437af5c781a7f0e08e@syzkaller.appspotmail.com
The priv field of struct v4l2_pix_format shouldn't be set by drivers,
it's set by the v4l2 core instead to V4L2_PIX_FMT_PRIV_MAGIC.
Drop this from the few media drivers that still do this.
Note that the gspca patch is slightly more involved since some of the
sub-gspca drivers use the priv field internally.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[hverkuil-cisco@xs4all.nl: fix clash in gspca between priv arg and priv variable]
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
The V4L2 core sets the description for the driver in order to ensure
consistent naming.
So drop the strscpy of the description in drivers. Also remove any
description strings in driver-internal structures since those are
no longer needed.
There are some conflicts due to SPDX changes. We also have more
patches being merged via media tree touching them.
So, let's merge back from upstream and address those.
Linux 5.2-rc4
* tag 'v5.2-rc4': (767 commits)
Linux 5.2-rc4
MAINTAINERS: Karthikeyan Ramasubramanian is MIA
i2c: xiic: Add max_read_len quirk
lockref: Limit number of cmpxchg loop retries
uaccess: add noop untagged_addr definition
x86/insn-eval: Fix use-after-free access to LDT entry
kbuild: use more portable 'command -v' for cc-cross-prefix
s390/unwind: correct stack switching during unwind
block, bfq: add weight symlink to the bfq.weight cgroup parameter
cgroup: let a symlink too be created with a cftype file
drm/nouveau/secboot/gp10[2467]: support newer FW to fix SEC2 failures on some boards
drm/nouveau/secboot: enable loading of versioned LS PMU/SEC2 ACR msgqueue FW
drm/nouveau/secboot: split out FW version-specific LS function pointers
drm/nouveau/secboot: pass max supported FW version to LS load funcs
drm/nouveau/core: support versioned firmware loading
drm/nouveau/core: pass subdev into nvkm_firmware_get, rather than device
block: free sched's request pool in blk_cleanup_queue
pktgen: do not sleep with the thread lock held.
net: mvpp2: Use strscpy to handle stat strings
net: rds: fix memory leak in rds_ib_flush_mr_pool
Instead of filling in the struct v4l2_capability device_caps
field, fill in the struct video_device device_caps field.
That way the V4L2 core knows what the capabilities of the
video device are.
But this only really works if all drivers use this, so convert
all usb drivers in this patch.
Based on 3 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details
your option any later version [author] [kishon] [vijay] [abraham]
[i] [kishon]@[ti] [com] this program is distributed in the hope that
it will be useful but without any warranty without even the implied
warranty of merchantability or fitness for a particular purpose see
your option any later version [author] [graeme] [gregory]
[gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i]
[kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema]
[hk] [hemahk]@[ti] [com] this program is distributed in the hope
that it will be useful but without any warranty without even the
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1105 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de
In order to prevent ISOC URBs from being infinitely resubmitted,
the driver's USB disconnect handler must kill all the in-flight URBs.
While here, change the URB packet status message to a debug level,
to avoid spamming the console too much.
This commit fixes a lockup caused by an interrupt storm coming
from the URB completion handler.
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
When streaming is stopped all URBs are killed, but in fill_frame and in
bulk_irq this results in an attempt to resubmit the killed URB. That is
not what you want and causes spurious kernel messages.
So check if streaming has stopped before resubmitting.
Also check against gspca_dev->streaming rather than vb2_start_streaming_called()
since vb2_start_streaming_called() will return true when in stop_streaming,
but gspca_dev->streaming is set to false when stop_streaming is called.
Fixes: 6992effe5344 ("gspca: Kill all URBs before releasing any of them")
If a driver supports multiple pixel formats with the same frame size,
TRY_FMT will currently always return the first pixel format.
Fix this by adding pixelformat support to wxh_to_nearest_mode().
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
ENUM_FRAMEINTERVALS will currently only work for the first pixel format.
Fix this by adding pixelformat support to wxh_to_mode().
When converting gspca to vb2 I missed that fact that the buffer sizes
were rounded up to the next page size. As a result some gspca drivers
(spca561 being one of them) reported frame overflows.
Modify the code to align the buffer sizes to the next page size, just
as the original code did.
Fixes: 1f5965c4dfd7 ("media: gspca: convert to vb2")
Tested-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Reported-by: softwarebugs <softwarebugs@protonmail.com>
Cc: <stable@vger.kernel.org> # for v4.18 and up
The implementation of strscpy() is more robust and safer.
That's now the recommended way to copy NUL terminated strings.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Some subdrivers access the gspca_dev->urb array in the completion handler.
To prevent use-after-free (actually, NULL dereferences) we need to
synchronously kill all the URBs before we release them.
In particular, this is currently the case for drivers such
as sn9c20x and sonixj, which access the gspca_dev->urb[0]
in the context of completion handler for *any* of the URBs.
This commit changes the destroy_urb implementation, so it kills
all URBs first, and then proceed to set the URBs to NULL in the
array and release them.
Fix v4l2-compliance error: s_parm never set V4L2_CAP_TIMEPERFRAME.
Also various g/s_parm-related cleanups.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The gspca core has its own buffere implementation. Use the
core VB 2 instead.
This is the mindless scripted replacement of kernel use of POLL*
variables as described by Al, done by this script:
for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do
L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'`
for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done
done
with de-mangling cleanups yet to come.
NOTE! On almost all architectures, the EPOLL* constants have the same
values as the POLL* constants do. But they keyword here is "almost".
For various bad reasons they aren't the same, and epoll() doesn't
actually work quite correctly in some cases due to this on Sparc et al.
The next patch from Al will sort out the final differences, and we
should be all done.
Scripted-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- videobuf2 was moved to a media/common dir, as it is now used by the
DVB subsystem too
- Digital TV core memory mapped support interface
- new sensor driver: ov7740
- several improvements at ddbridge driver
- new V4L2 driver: IPU3 CIO2 CSI-2 receiver unit, found on some Intel
SoCs
- new tuner driver: tda18250
- finally got rid of all LIRC staging drivers
- as we don't have old lirc drivers anymore, restruct the lirc device
code
- add support for UVC metadata
- add a new staging driver for NVIDIA Tegra Video Decoder Engine
- DVB kAPI headers moved to include/media
- synchronize the kAPI and uAPI for the DVB subsystem, removing the gap
for non-legacy APIs
- reduce the kAPI gap for V4L2
- lots of other driver enhancements, cleanups, etc.
* tag 'media/v4.16-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (407 commits)
media: v4l2-compat-ioctl32.c: make ctrl_is_pointer work for subdevs
media: v4l2-compat-ioctl32.c: refactor compat ioctl32 logic
media: v4l2-compat-ioctl32.c: don't copy back the result for certain errors
media: v4l2-compat-ioctl32.c: drop pr_info for unknown buffer type
media: v4l2-compat-ioctl32.c: copy clip list in put_v4l2_window32
media: v4l2-compat-ioctl32.c: fix ctrl_is_pointer
media: v4l2-compat-ioctl32.c: copy m.userptr in put_v4l2_plane32
media: v4l2-compat-ioctl32.c: avoid sizeof(type)
media: v4l2-compat-ioctl32.c: move 'helper' functions to __get/put_v4l2_format32
media: v4l2-compat-ioctl32.c: fix the indentation
media: v4l2-compat-ioctl32.c: add missing VIDIOC_PREPARE_BUF
media: v4l2-ioctl.c: don't copy back the result for -ENOTTY
media: v4l2-ioctl.c: use check_fmt for enum/g/s/try_fmt
media: vivid: fix module load error when enabling fb and no_error_inj=1
media: dvb_demux: improve debug messages
media: dvb_demux: Better handle discontinuity errors
media: cxusb, dib0700: ignore XC2028_I2C_FLUSH
media: ts2020: avoid integer overflows on 32 bit machines
media: i2c: ov7740: use gpio/consumer.h instead of gpio.h
media: entity: Add a nop variant of media_entity_cleanup
Use a more typical logging style.
The current macro hides the gspca_dev argument so add it to the
macro uses instead.
Miscellanea:
o Add missing '\n' terminations to formats
o Realign arguments to open parenthesis
o Remove commented out uses of PDEBUG
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Use a more typical kernel logging style.
macro uses instead.
Miscellanea:
Only POLL... bitmaps ever end up there and their only use is checking
for POLL... bits in them.
Variable j is being set to zero before a loop and also
immediately inside the loop and is not used after the loop.
Hence the first assignment is redundant and can be removed.
Cleans up clang warning:
drivers/media/usb/gspca/gspca.c:1078:2: warning: Value stored
to 'j' is never read
Declare v4l2_file_operations structures as const as they are only stored
in the fops field of video_device structures. This field is of type
const, so declare v4l2_file_operations structures with similar properties
as const.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Drop the FSF's postal address from the source code files that typically
contain mostly the license text. Of the 628 removed instances, 578 are
outdated.
The patch has been created with the following command without manual edits:
git grep -l "675 Mass Ave\|59 Temple Place\|51 Franklin St" -- \
drivers/media/ include/media|while read i; do i=$i perl -e '
open(F,"< $ENV{i}");
$a=join("", <F>);
$a =~ s/[ \t]*\*\n.*You should.*\n.*along with.*\n.*(\n.*USA.*$)?\n//m
&& $a =~ s/(^.*)Or, (point your browser to) /$1To obtain the license, $2\n$1/m;
close(F);
open(F, "> $ENV{i}");
print F $a;
close(F);'; done
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Due to the 80-cols restrictions, and latter due to checkpatch
warnings, several strings were broken into multiple lines. This
is not considered a good practice anymore, as it makes harder
to grep for strings at the source code.
As we're right now fixing other drivers due to KERN_CONT, we need
to be able to identify what printk strings don't end with a "\n".
It is a way easier to detect those if we don't break long lines.
So, join those continuation lines.
The patch was generated via the script below, and manually
adjusted if needed.
</script>
use Text::Tabs;
while (<>) {
if ($next ne "") {
$c=$_;
if ($c =~ /^\s+\"(.*)/) {
$c2=$1;
$next =~ s/\"\n$//;
$n = expand($next);
$funpos = index($n, '(');
$pos = index($c2, '",');
if ($funpos && $pos > 0) {
$s1 = substr $c2, 0, $pos + 2;
$s2 = ' ' x ($funpos + 1) . substr $c2, $pos + 2;
$s2 =~ s/^\s+//;
$s2 = ' ' x ($funpos + 1) . $s2 if ($s2 ne "");
print unexpand("$next$s1\n");
print unexpand("$s2\n") if ($s2 ne "");
} else {
print "$next$c2\n";
$next="";
next;
} else {
print $next;
$next="";
} else {
if (m/\"$/) {
if (!m/\\n\"$/) {
$next=$_;
next;
print $_;
</script>
kmalloc will print enough information in case of failure.
Signed-off-by: Wolfram Sang <wsa-dev@sang-engineering.com>
Allow for SS+ devices
Signed-off-by: Oliver Neukum <ONeukum@suse.com>
v4l2-compliance fails with this message:
fail: v4l2-test-buffers.cpp(250): \
timestamp != V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC && \
timestamp != V4L2_BUF_FLAG_TIMESTAMP_COPY
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
When setting the frame time, gspca uses v4l2_get_timestamp() which uses
ktime_get_ts() which uses ktime_get_ts64() which returns a monotonic
timestamp, so it's safe to initialize the buffer flags to
V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC to fix the failure.
Signed-off-by: Antonio Ospite <ao2@ao2.it>
According to v4l2-compliance VIDIOC_ENUM_FRAMEINTERVALS should fail for
unsupported frame sizes, but gspca is too tolerant and tries to find
the frame intervals for the frame size nearest to the requested one.
This makes v4l2-compliance fail with this message:
fail: v4l2-test-formats.cpp(123): \
found frame intervals for invalid size 321x240
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
Fix this by using an exact match for the frame size when enumerating
frame intervals, and retuning an error if the frame size for which the
frame intervals have been asked is not supported.
The name wxh_to_nearest_mode() reflects better what the function does.
Set the frame _interval_ type to V4L2_FRMIVAL_TYPE_DISCRETE instead of
using V4L2_FRMSIZE_TYPE_DISCRETE which is meant for frame _size_.
The old and new values happen to be the same so there is no functional
change.
This is a preparation for a change to the type of v4l2 timestamps.
v4l2_get_timestamp() is a helper function that reads the monotonic
time and stores it into a 'struct timeval'. Multiple drivers implement
the same thing themselves for historic reasons.
Changing them all to use v4l2_get_timestamp() is more consistent
and reduces the amount of code duplication, and most importantly
simplifies the following changes.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[hans.verkuil@cisco.com: dropped the v4l2-dev.c patch that didn't belong here]
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
"n" is a user controlled integer. The code here doesn't handle the case
where "n" is negative and this causes a static checker warning.
drivers/media/usb/gspca/gspca.c:1571 vidioc_s_parm()
warn: no lower bound on 'n'
parm.capture.readbuffers is unsigned, so make n unsigned too, fixing this.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
comment
Fix indentation of a comment, put it on the same level of the code it
refers to.
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
The v4l2_pix_format structure has no reserved field. It is embedded in
the v4l2_framebuffer structure which has no reserved fields either, and
in the v4l2_format structure which has reserved fields that were not
previously required to be zeroed out by applications.
To allow extending v4l2_pix_format, inline it in the v4l2_framebuffer
structure, and use the priv field as a magic value to indicate that the
application has set all v4l2_pix_format extended fields and zeroed all
reserved fields following the v4l2_pix_format field in the v4l2_format
structure.
The availability of this API extension is reported to userspace through
the new V4L2_CAP_EXT_PIX_FORMAT capability flag. Just checking that the
priv field is still set to the magic value at [GS]_FMT return wouldn't
be enough, as older kernels don't zero the priv field on return.
To simplify the internal API towards drivers zero the extended fields
and set the priv field to the magic value for applications not aware of
the extensions.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Since all the drivers that use `struct v4l2_fh' use the core
priority checking, the setting of the flag in the drivers can
be removed.
Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com>
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
Currently gspca selects the first ISOC input endpoint as the input
transfer endpoint, however some devices can provide streams on endpoints
different then the first one, so some subdrivers (e.g. gspca_kinect) may
want to select a specific endpoint to use as a transfer endpoint.
Add an xfer_ep field to struct gspca_dev, and change alt_xfer() so that
it accepts a parameter which represents a specific endpoint address to
look for.
If a subdriver wants to specify a value for gspca_dev->xfer_ep it can do
that in its sd_config() callback.
Add variable resolution support to gspca by allowing subdrivers to
specify try_fmt and enum_framesizes functions.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Store complete current mode (struct v4l2_pix_format) in struct gspca_dev
instead of separate pixfmt, width and height parameters.
This is a preparation for variable resolution support.
If v4l2_fh_open() fails in dev_open(), gspca_dev->module left locked.
The patch adds module_put(gspca_dev->module) on this path.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Remove g_chip_ident and replace it with g_chip_info.
This ioctl is defined as IOW, so pass the argument as const.
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
usb_free_coherent() is safe with NULL addr and this check is
not required.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Instead use v4l2_dbg and v4l2_err. Note that the PDEBUG macro is kept to
make this patch-set less invasive, but it is simply a wrapper around
v4l2_dbg now. Most of the other changes are there to make the dev parameter
for the v4l2_xxx macros available everywhere we do logging.
Signed-off-by: Theodore Kilgore <kilgota@auburn.edu>
replace:
#if defined(CONFIG_INPUT) || \
defined(CONFIG_INPUT_MODULE)
with:
#if IS_ENABLED(CONFIG_INPUT)
This change was made for: CONFIG_INPUT
Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
