drivers/media/tuners/xc4000.c: In function ‘check_firmware’:
drivers/media/tuners/xc4000.c:1048:45: warning: ‘fw_minor’ may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/media/tuners/xc4000.c:1048:39: warning: ‘fw_major’ may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/media/tuners/xc4000.c:1062:39: warning: ‘hw_minor’ may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/media/tuners/xc4000.c:1062:33: warning: ‘hw_major’ may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/media/tuners/tua9001.c:211:5: warning: 'ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
Cc: Antti Palosaari <crope@iki.fi>
drivers/media/tuners/max2165.c:164:5: warning: no previous prototype for 'fixpt_div32' [-Wmissing-prototypes]
The tda18271 datasheet says:
"The image rejection calibration and RF tracking filter
calibration must be launched exactly as described in the
flowchart, otherwise bad calibration or even blocking of the
TDA18211HD can result making it impossible to communicate
via the I2C-bus."
(yeah, tda18271 refers there to tda18211 - likely a typo at their
datasheets)
That likely explains why sometimes tda18271 stops answering. That
is now happening more often on designs with drx-k chips, as the
firmware is now loaded asyncrousnly there.
While the above text doesn't explicitly tell that the I2C bus
couldn't be used by other devices during such initialization,
that seems to be a requirement there.
So, let's explicitly use the I2C lock there, avoiding I2C bus
share during those critical moments.
Compile-tested only. Please test.
Acked-by: Michael Krufky <mkrufky@linuxtv.org>
Fix a series of warnings when compiled with W=1:
drivers/media/tuners/mt2063.c: In function 'mt2063_setreg':
drivers/media/tuners/mt2063.c:290:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits]
drivers/media/tuners/mt2063.c:2013:2: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits]
drivers/media/tuners/mt2063.c:2271:14: warning: no previous prototype for 'tuner_MT2063_SoftwareShutdown' [-Wmissing-prototypes]
drivers/media/tuners/mt2063.c:2286:14: warning: no previous prototype for 'tuner_MT2063_ClearPowerMaskBits' [-Wmissing-prototypes]
Several of those warnings are real bugs: the error status code
used to be unsigned, but they're assigned to negative error
codes.
Fix it by using unsigned int.
While here, comment the two power management functions, while we
don't add a code there to properly handle tuner suspend/resume.
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
when != e = e1
when != e += e1
when != e -= e1
when != ++e
when != --e
when != e++
when != e--
when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Until now, if there is a read error in tda18271_get_id, the driver
reports "Unknown device..." Instead, check the return value of
tda18271_read_regs and display the appropriate error message.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
if the configuration option 'delay_cal' is set, delay both IR & RF
calibration until init() is called.
both module option 'cal' or configuration option 'rf_cal_on_startup'
will override this delay. it makes no sense to mix 'delay_cal' with
'rf_cal_on_startup' as these options conflict with each other.
Ensure that unnecessary features are powered down at the end of the
attach() function on attach of the tuner's first instance. If the
configuration requires the loop thru or xtout features, they will
remain enabled.
This must *only* be done after attaching the first instance of the tuner.
If there are multiple instances of the tuner, the bridge driver will need
to maintain power managament by itself.
attach() function. If the configuration requires the loop thru or
xtout features, they will remain enabled.
Thanks to Antti Palosaari for noticing the additional power consumption.
Fixes the following warnings on a 32 bit system with GCC 4.4.3 and kernel Ubuntu 2.6.32-43 32 bit:
WARNING: "__udivdi3" [fc2580.ko] undefined!
WARNING: "__umoddi3" [fc2580.ko] undefined!
Signed-off-by: Gianluca Gennari <gennarone@gmail.com>
Reviewed-by: Antti Palosaari <crope@iki.fi>
Signed-off-by: Antti Palosaari <crope@iki.fi>
fc2580.c: In function 'fc2580_set_params':
fc2580.c:118: warning: 'ret' may be used uninitialized in this function
fc2580.c:150: warning: this decimal constant is unsigned only in ISO C90
Callbacks were set even attach failed. This leads calling
.release() in error case and resulted crash.
Reported-by: Oliver Schinagl <oliver@schinagl.nl>
* better readability
* make checkpatch.pl happy
* few bytes smaller binary footprint
This is initial support for the Asus MyCinema U3100Mini Plus. The driver
in its current form gets detected and loads properly.
Scanning using dvbscan works without problems, Locking onto a channel
using tzap also works fine. Only playback using tzap -r + mplayer was
tested and was fully functional.
It uses the af9035 USB Bridge chip, with an af9033 demodulator. The tuner
used is the FCI FC2580.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
Disable RXEN and enable RESETN pins on attach to ensure chip is
totally powered down after attach.
A number of old drivers still had the experimental tag. Time to remove it.
It concerns the following drivers:
VIDEO_TLV320AIC23B
USB_STKWEBCAM
VIDEO_CX18
VIDEO_CX18_ALSA
VIDEO_ZORAN_AVS6EYES
DVB_USB_AF9005
MEDIA_TUNER_TEA5761
VIDEO_NOON010PC30
This decision was taken during the 2012 Media Workshop.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
There is three pins used for controlling that tuner.
Implement those using frontend callback.
removes unnecessary semicolon
Found by Coccinelle: http://coccinelle.lip6.fr/
Old i2c message length splitting logic was faulty. Make it better.
I didn't found easy way to handle register dump only when needed so
remove it totally. It is quite useless and trivial function, every
developer could write new one in few minutes when needed.
Changing cached frequency during init is something no-no.
Make it behave a little bit better. After that device could
survive from suspend/resume when streaming is ongoing.
Instead of having 3 options to allow customizing the media
sub-drivers (tuners, I2C drivers, frontends), merge all of
them into just one.
That simplifies the life for users, as they can just keep
this untouched.
Life for developers is also simpler, as there's now just
one Kconfig item to remember, for the ancillary sub-drivers
providing supports for chips that could change from one
board design to another.
Move the tuners one level up, as the "common" directory will be used
by drivers that are shared between more than one driver.
