path: root/drivers/media/rc/ir-sony-decoder.c
2012-03-08[media] media: ir-sony-decoder: 15bit function decode fixJames Hogan
The raw Sony IR decoder decodes 15bit messages slightly incorrectly. To decode the function number, it shifts the bits right by 7 so that the function is in bits 7:1, masks with 0xFD (0b11111101), and does an 8 bit reverse so it ends up in bits 6:0. The mask should be 0xFE to correspond with bits 7:1 (0b11111110). The old mask had the effect of dropping the MSB of the function number from bit 6, and leaving the LSB of the device number in bit 7. Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-10-31drivers/media: Add module.h to all files using it implicitlyPaul Gortmaker
A pending cleanup will mean that module.h won't be implicitly everywhere anymore. Make sure the modular drivers in clocksource are actually calling out for <module.h> explicitly in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-12-29[media] rc: Rename remote controller type to rc_type instead of ir_typeMauro Carvalho Chehab
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,IR_TYPE,RC_TYPE,g <$i >a && mv a $i; done for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,ir_type,rc_type,g <$i >a && mv a $i; done Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Rename all public generic RC functions from ir_ to rc_Mauro Carvalho Chehab
Those functions are not InfraRed specific. So, rename them to properly reflect it. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] ir-core: make struct rc_dev the primary interfaceDavid Härdeman
This patch merges the ir_input_dev and ir_dev_props structs into a single struct called rc_dev. The drivers and various functions in rc-core used by the drivers are also changed to use rc_dev as the primary interface when dealing with rc-core. This means that the input_dev is abstracted away from the drivers which is necessary if we ever want to support multiple input devs per rc device. The new API is similar to what the input subsystem uses, i.e: rc_device_alloc() rc_device_free() rc_device_register() rc_device_unregister() [mchehab@redhat.com: Fix compilation on mceusb and cx231xx, due to merge conflicts] Signed-off-by: David Härdeman <david@hardeman.nu> Acked-by: Jarod Wilson <jarod@redhat.com> Tested-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Rename rc-core files from ir- to rc-Mauro Carvalho Chehab
As protocol decoders are specific to InfraRed, keep their names as-is. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] rename drivers/media/IR to drives/media/rcMauro Carvalho Chehab
