path: root/drivers/media/i2c/s5k6a3.c
2017-11-30media: s5k6a3: document some fields at struct s5k6a3Mauro Carvalho Chehab
drivers/media/i2c/s5k6a3.c:68: warning: No description found for parameter 'clock' drivers/media/i2c/s5k6a3.c:68: warning: No description found for parameter 'clock_frequency' drivers/media/i2c/s5k6a3.c:68: warning: No description found for parameter 'power_count' Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-02-03[media] drivers: media: i2c: constify v4l2_subdev_* structuresBhumika Goyal
v4l2_subdev_{core/pad/video}_ops structures are stored in the fields of the v4l2_subdev_ops structure which are of type const. Also, v4l2_subdev_ops structure is passed to a function having its argument of type const. As these structures are never modified, so declare them as const. Done using Coccinelle: (One of the scripts used) @r1 disable optional_qualifier @ identifier i; position p; @@ static struct v4l2_subdev_video_ops i@p = {...}; @ok1@ identifier r1.i; position p; struct v4l2_subdev_ops obj; @@ obj.video=&i@p; @bad@ position p!={r1.p,ok1.p}; identifier r1.i; @@ i@p @depends on !bad disable optional_qualifier@ identifier r1.i; @@ +const struct v4l2_subdev_video_ops i; File sizes before: text data bss dec hex filename 7810 736 16 8562 2172 drivers/media/i2c/mt9p031.o 9652 736 24 10412 28ac drivers/media/i2c/mt9v032.o 4613 552 20 5185 1441 drivers/media/i2c/noon010pc30.o 2615 552 8 3175 c67 drivers/media/i2c/s5k6a3.o File sizes after: text data bss dec hex filename 8322 232 16 8570 217a drivers/media/i2c/mt9p031.o 10164 232 24 10420 28b4 drivers/media/i2c/mt9v032.o 4933 232 20 5185 1441 drivers/media/i2c/noon010pc30.o 2935 232 8 3175 c67 drivers/media/i2c/s5k6a3.o Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-09-22[media] s5k6a3: Add missing entity function initializationSylwester Nawrocki
Suppresses warning like: s5p-fimc-md camera: Entity type for entity S5K6A3 13-0010 was not initialized! Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-09-06[media] media/i2c: Delete owner assignmentMarkus Elfring
The field "owner" is set by core. Thus delete an extra initialisation. Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-01-25[media] s5k6a3: Fix VIDIOC_SUBDEV_G_FMT ioctl for TRY formatJacek Anaszewski
VIDIOC_SUBDEV_G_FMT ioctl should return TRY format previously set with VIDIOC_SUBDEV_S_FMT. Currently it is not the case as only ACTIVE formats are saved in the driver. Since the driver doesn't alter hardware state in the set_fmt op anyway, the op can save the format in both TRY and ACTIVE case. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2016-01-11[media] media framework: rename pads init function to media_entity_pads_init()Mauro Carvalho Chehab
With the MC next gen rework, what's left for media_entity_init() is to just initialize the PADs. However, certain devices, like a FLASH led/light doesn't have any input or output PAD. So, there's no reason why calling media_entity_init() would be mandatory. Also, despite its name, what this function actually does is to initialize the PADs data. So, rename it to media_entity_pads_init() in order to reflect that. The media entity actual init happens during entity register, at media_device_register_entity(). We should move init of num_links and num_backlinks to it. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2016-01-11[media] media: get rid of unused "extra_links" param on media_entity_init()Mauro Carvalho Chehab
Currently, media_entity_init() creates an array with the links, allocated at init time. It provides a parameter (extra_links) that would allocate more links than the current needs, but this is not used by any driver. As we want to be able to do dynamic link allocation/removal, we'll need to change the implementation of the links. So, before doing that, let's first remove that extra unused parameter, in order to cleanup the interface first. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-08-11[media] Export I2C module alias information in missing driversJavier Martinez Canillas
The I2C core always reports the MODALIAS uevent as "i2c:<client name" regardless if the driver was matched using the I2C id_table or the of_match_table. So the driver needs to export the I2C table and this be built into the module or udev won't have the necessary information to auto load the correct module when the device is added. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2015-03-23[media] v4l2-subdev: replace v4l2_subdev_fh by v4l2_subdev_pad_configHans Verkuil
If a subdevice pad op is called from a bridge driver, then there is no v4l2_subdev_fh struct that can be passed to the subdevice. This made it hard to use such subdevs from a bridge driver. This patch replaces the v4l2_subdev_fh pointer by a v4l2_subdev_pad_config pointer in the pad ops. This allows bridge drivers to use the various try_ pad ops by creating a v4l2_subdev_pad_config struct and passing it along to the pad op. The v4l2_subdev_get_try_* macros had to be changed because of this, so I also took the opportunity to use the full name of the v4l2_subdev_get_try_* functions in the __V4L2_SUBDEV_MK_GET_TRY macro arguments: if you now do 'git grep v4l2_subdev_get_try_format' you will actually find the header where it is defined. One remark regarding the drivers/staging/media/davinci_vpfe patches: the *_init_formats() functions assumed that fh could be NULL. However, that's not true for this driver, it's always set. This is almost certainly a copy and paste from the omap3isp driver. I've updated the code to reflect the fact that fh is never NULL. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-11-14[media] i2c: Make use of media_bus_format enumBoris BREZILLON
In order to have subsytem agnostic media bus format definitions we've moved media bus definitions to include/uapi/linux/media-bus-format.h and prefixed values with MEDIA_BUS_FMT instead of V4L2_MBUS_FMT. Replace all references to the old definitions in i2c drivers. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-07-22[media] v4l: s5k6a3: Return V4L2_FIELD_NONE from pad-level set formatLaurent Pinchart
The sensor is progressive, always return the field order set to V4L2_FIELD_NONE. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-03-14[media] V4L: Add driver for s5k6a3 image sensorSylwester Nawrocki
This patch adds subdev driver for Samsung S5K6A3 raw image sensor. As it is intended at the moment to be used only with the Exynos FIMC-IS (camera ISP) subsystem it is pretty minimal subdev driver. It doesn't do any I2C communication since the sensor is controlled by the ISP and its own firmware. This driver, if needed, can be updated in future into a regular subdev driver where the main CPU communicates with the sensor directly. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
