git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (247 commits)
[media] gspca - sunplus: Fix some warnings and simplify code
[media] gspca: Fix some warnings tied to 'no debug'
[media] gspca: Unset debug by default
[media] gspca - cpia1: Remove a bad conditional compilation instruction
[media] gspca - main: Remove USB traces
[media] gspca - main: Version change to 2.13
[media] gspca - stk014 / t613: Accept the index 0 in querymenu
[media] gspca - kinect: Remove __devinitdata
[media] gspca - cpia1: Fix some warnings
[media] video/Kconfig: Fix mis-classified devices
[media] support for medion dvb stick 1660:1921
[media] tm6000: fix uninitialized field, change prink to dprintk
[media] cx231xx: Add support for Iconbit U100
[media] saa7134 add new TV cards
[media] Use a more consistent value for RC repeat period
[media] cx18: Move spinlock and vb_type initialisation into stream_init
[media] tm6000: remove tm6010 sif audio start and stop
[media] tm6000: remove unused exports
[media] tm6000: add pts logging
[media] tm6000: change from ioctl to unlocked_ioctl
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
[mchehab@redhat.com: The same patch were sent by Alf and by Randoslaw.
I've applied the oldest version, just fixing the entry index]
Cc: Patrick Boettcher <pboettcher@kernellabs.com>
Tested-by: James Huk <huk256@gmail.com>
Tested-by: Alf Fahland <alf-f@gmx.de>
Signed-off-by: Radoslaw Warowny <radoslaww@gmail.com>
Signed-off-by: Andreas Oberritter <obi@linuxtv.org>
- Holds the parameters detected by the demod.
- Updated on every call to get_frontend, either through ioctl or when
a frontend event occurs.
- Reset to input parameters after every call to set_frontend, tune or
search/track.
- Preparation to distinguish input parameters from output parameters.
- Drivers should be able to override properties returned to the user.
- The default values get prefilled from the cache.
- Use const pointers and remove assignments.
- delivery_system already gets assigned by DTV_DELIVERY_SYSTEM
and dtv_property_cache_sync.
This is supported in DVB-T2 mode, so added to the T/T2 frontend.
Signed-off-by: Steve Kerrison <steve@stevekerrison.com>
Acked-by: Antti Palosaari <crope@iki.fi>
drivers/media/dvb/frontends/drxd_hard.c: In function ‘DRX_Start’:
drivers/media/dvb/frontends/drxd_hard.c:2327: warning: enumeration value ‘BANDWIDTH_5_MHZ’ not handled in switch
drivers/media/dvb/frontends/drxd_hard.c:2327: warning: enumeration value ‘BANDWIDTH_10_MHZ’ not handled in switch
drivers/media/dvb/frontends/drxd_hard.c:2327: warning: enumeration value ‘BANDWIDTH_1_712_MHZ’ not handled in switch
[mchehab@redhat.com: removed the status = status assignment after the switch]
[steve@stevekerrison.com: Remove private definitions from cxd2820r that existed before API was defined]
- Return values should not be ORed. Abort early instead.
- Return -EINVAL instead of -1.
This patch removes the remaining on-stack buffer for USB DMA transfer.
This patch also reduces the stack memory usage.
Cc: stable@kernel.org
Cc: Florian Mickler <florian@mickler.org>
Signed-off-by: Olivier Grenie <olivier.grenie@dibcom.fr>
Signed-off-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
Remove old DVB-T2 freq module param and detect DVB-T/T2 automatically.
Implementation is trial and error, if DVB-T does not lock try DVB-T2
and vice versa. That's done by replacing normal DVBFE_ALGO_SW with
DVBFE_ALGO_CUSTOM which gives better control for tuning process.
DVB-C still uses normal software ZigZag, DVBFE_ALGO_SW.
Signed-off-by: Antti Palosaari <crope@iki.fi>
Make checkpatch.pl happy by fixing whitespaces introduced by
commit 79e8b8e3b8cbf67130247a3f6d25732373fe2f34
It is very first DVB-T2 Linux driver!
Change firmware download split, which I introduced few patch earlier,
a little bit to make it more readable as requested [1].
Anyhow, for some reason this seems to increase compiled binary size
52 bytes, on my AMD64 box, which is rather much for so small change.
[1] http://www.spinics.net/lists/linux-media/msg31968.html
It is DVB-S/S2 USB box.
* DNBU10512IST NIM
* STV0903 demod
* STV6110 tuner
* Intersil ISL6423 LNB controller
Cc: info@anysee.com
It is USB DVB-S/S2 box.
Conexant cx24116/cx24118 demod tuner combo
Cc: info@anysee.com
It is very rare I2C adapter hardware which can provide 32kB I2C write
as one write. Add .i2c_wr_max option to set desired max packet size.
Split transaction to smaller pieces according to that option.
Cc: Steven Toth <stoth@hauppauge.com>
Bits 4 and 5 on register 02 should always be set to 1.
Opera1/Bsru6/z0194a/mantis_vp1033
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Acked-by: Oliver Endriss <o.endriss@gmx.de>
Issues with Register 02 causing spurious channel locking from standby.
Should have always bits 4 & 5 written to 1.
Lower nibble not used in any current driver. Usage if necessary can be
applied through initab to mcr_reg. stv0299 not out of standby before
writing inittab.
Signed-off-by: HIRANO Takahito <hiranotaka@zng.info>
Improve PID filtering and program register 20 correctly.
Make sure stream_on message is sent if streaming is off, otherwise
PIDs are not registered.
Move mutex outside lme2510_enable_pid.
usb_buffer not inside mutex lock, waiting caller can alter buffer.
Static added to lme2510_exit and lme2510_exit_int.
Gate could close after first I2C message. On stv0288 it does.
Keep 2nd and 3rd message I2C gate control alive.
Remove unnecessary gate closing in this module.
after free'
In drivers/media/dvb/siano/smsusb.c we have this code:
kfree(dev);
sms_info("device %p destroyed", dev);
at least one static analysis tool (Coverity Prevent) complains about this
as a use-after-free bug.
While it's true that we do use the pointer variable after freeing it, the
only use is to print the value of the pointer, so there's not actually any
problem here. But still, silencing the complaint is trivial by just moving
the kfree() call below the sms_info(), so why not just do it?. It doesn't
change the workings of the code in any way, but it makes the tool shut up.
The patch below also removes a rather pointless blank line.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Return device errors to demuxer from on/off streamming and
pid filtering.
Please test this patch with all dvb-usb devices.
There are a couple of places where mutex_unlock() is called even
if mutex_lock_interruptible() failed. The patch fixes the issue.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Avoid unnecessary DVB TS 188 sized packet copying from DMA buffer into stack.
Backtrack one 188 sized packet just after some garbage bytes when possible.
This obsoletes patch https://patchwork.kernel.org/patch/118147/
Signed-off-by: Marko Ristola <marko.ristola@kolumbus.fi>
Acked-by: Andreas Oberritter <obi@linuxtv.org>
If the second memory allocation in dib9000_attach() fails, we'll leak the
memory allocated by the first.
Cc: Patrick Boettcher <patrick.boettcher@dibcom.fr>
A greatly simplified version of the PID Filter now added
back to the Driver.
The driver allows for the PID filter to be turned off.
applied after patch 683781.
Register 42 bits 2,3,6 and 7 should be set to 0.
This gives difficult locking on some channels and may be compensated
for by other methods.
This affects any driver using the stv0288 frontend on the default
or earda inittab.
stv0288 Register 42 bits 6 & 7 should be set to 0.
This is causing intermittent lock, the dvb-usb-lmedm04 driver uses
register 50 (auto fine mode) to correct for this, this register is
now returned to its default setting.
Add support for TT S-1500 with BSBE1-D01A tuner.
Signed-off-by: Oliver Endriss <o.endriss@gmx.de>
Seems like 'adap->fe' test for NULL was meant to be before we dereference
that pointer.
Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl>
Acked-by: Patrick Boettcher <patrick.boettcher@dibcom.fr>
usb_control_msg initiates (and waits for completion of) a dma transfer using
the supplied buffer. That buffer thus has to be seperately allocated on
the heap.
In lib/dma_debug.c the function check_for_stack even warns about it:
WARNING: at lib/dma-debug.c:866 check_for_stack
Tested-by: Malcolm Priestley <tvboxspy@gmail.com>
Signed-off-by: Florian Mickler <florian@mickler.org>
the heap.
Reviewed-by: Antti Palosaari <crope@iki.fi>
Tested-by: Antti Palosaari <crope@iki.fi>
the heap.
the heap.
Note: This change is tested to compile only as I don't have the
hardware.
Cc: Patrick Boettcher <pb@linuxtv.org>
If we need a bigger buffer, we reallocte a new buffer and free the old
one.
hardware.
hardware.
Otherwise it is not obvious that vp702x_usb_in_op or vp702x_usb_out_op
will not interfere with any vp702x_usb_inout_op.
Note: This change is tested to compile only, as I don't have the
hardware.
the heap.
Note: This change is tested to compile only, as I don't have the hardware.
