path: root/drivers/media/dvb
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18freezer: introduce freezer-friendly waiting macrosRafael J. Wysocki
Introduce freezer-friendly wrappers around wait_event_interruptible() and wait_event_interruptible_timeout(), originally defined in <linux/wait.h>, to be used in freezable kernel threads. Make some of the freezable kernel threads use them. This is necessary for the freezer to stop sending signals to kernel threads, which is implemented in the next patch. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12cdev: remove unneeded setting of cdev namesGreg Kroah-Hartman
struct cdev does not need the kobject name to be set, as it is never used. This patch fixes up the few places it is set. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10V4L/DVB (6311): dvb: Replace list_for_each+list_entry with list_for_each_entryTrent Piepho
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6296): dib0700: add support for AverMedia DVB-T Express cardJoachim Steiger
add Avermedia dvb-t express card 34 (usb2) id Signed-off-by: Joachim Steiger <roh@hyte.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6279): en_50221: convert to kthread APIChristoph Hellwig
Here's an attempted update to the full kthread API + wake_up_process: Signed-off-by: Andrew Morton <akpm@linux-foundation.org> CC: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6241): fix typo in DVB_PLL Kconfig help textMichael Krufky
s/driver/drives/1 Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6232): dvb-pll: report whether input rf will be autoselected or set ↵Michael Krufky
via insmod option Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6231): dvb-pll: always show pll name if forced via insmod optionMichael Krufky
The name of the pll will be shown if forced via insmod option, or if debug is enabled. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6230): dvb-pll: add module option to force dvb-pll desc id (for ↵Michael Krufky
debug use only) Add a module option to force the dvb-pll module to use an alternate dvb-pll description without having to recompile the kernel. Having a module option like this is useful in some cases, where the vendor may release an alternate revision of the hardware using a different tuner, but without changing the pci subsystem / usb device ids. This option is intended for debugging purposes _only_. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6229): dvb-pll: increase DVB_PLL_MAX to 64Michael Krufky
Increased DVB_PLL_MAX from 16 to a figure that would never be reached in a practical sense. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6228): dvb-pll: add module option to specify rf inputMichael Krufky
Add a module option to dvb-pll, called "input" to specify which rf input to use on devices with multiple rf inputs. If the module option is not specified, then the driver will autoselect the rf input, as per previous behavior. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6227): dvb-pll: store instance ID in dvb_pll_priv structureMichael Krufky
Store an instance ID in the dvb_pll_priv structure, so that module options specific to a given pll may be used by the functions within the driver. When debug is turned on, print a message indicating which pll was attached and it's instance id. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6226): dvb-pll: pass fe pointer into dvb_pll_configure() and set() ↵Michael Krufky
functions The pll-specific set() function will need access to the dvb_pll_priv structure for new functionality. This patch gives access to this structure to the required functions. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6221): budget-ci: select TT keymap for DVB-S TT 1500Oliver Endriss
DVB-S TT 1500 must use the TT keymap. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6169): Removed unused function mt2131_set_gpo()Steven Toth
Unused code is removed. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6136): dvb_frontend: add get_rf_strength function pointer to ↵Michael Krufky
dvb_tuner_ops Add get_rf_strength function pointer to dvb_tuner_ops, so that rf signal strength can be read directly from the tuner driver by the dvb demodulator driver and / or the analog tuning system. This is an internal api addition -- userspace is not affected. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6128): hybrid tuner refactoring core changes, phase 1Michael Krufky
Prepare tuner-core for conversion of tuner sub-drivers into dvb_frontend modules Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Mike Isely <isely@pobox.com> Acked-by: Steven Toth <stoth@hauppauge.com> Acked-by: Patrick Boettcher <pb@linuxtv.org> Acked-by: Jarod Wilson <jwilson@redhat.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6125): whitespace cleanup: replace leading spaces with tabsMichael Krufky
There were many instances of 7-space indents spread throughout the v4l-dvb tree. This patch replaces the 7-space indents with tabs. The whitespace cleaner script doesn't catch these, because it assumes that all indents are 8-space. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6107): dvb_frontend: clean-up shutdown handlingOliver Endriss
Now dvb_powerdown_on_sleep controls whether - whether LNB power is turned off - whether the tuner/frontend enters sleep mode Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6106): dvb_frontend: Default for dvb_shutdown_timeout set to 0Oliver Endriss
Default for dvb_shutdown_timeout set to 0. dvb_shutdown_timeout > 0 is used for debugging only. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6105): dvb_frontend: ts_bus_ctrl() handling fixedOliver Endriss
ts_bus_ctrl() should only be called by - the first open - the last release call. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6104): dvb_ca_en50221: decrement module use count on errorMarco Schluessler
decrement module use count on error Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6103): dvb_ca_en50221: return correct error code valueMarco Schluessler
return correct error code value Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6102): dvb: remove some unneeded vmalloc() return value casts from ↵Jesper Juhl
av7110 vmalloc() returns void * - no need to cast it. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6100): dvb_net: whitespace cleanupMichael Krufky
Clean whitespace brain-damage caused by previous patch, "Fix a warning at dvb_net" Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6040): Add IR support for Nova-T StickDarren Salt
Working with Nova-T Stick (70001) with remote control model A415. Untested with other dib0700m/dib0700p devices. Signed-off-by: Darren Salt <linux@youmustbejoking.demon.co.uk> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6039): Typo fix in Nova-TD descriptionDarren Salt
Typo fix in Nova-TD description Signed-off-by: Darren Salt <linux@youmustbejoking.demon.co.uk> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6038): Trivial: repair mixed parm descs in dvb-usb-init.cMichael Mauch
Repair modinfo parameter descriptions for force_pid_filter_usage and disable_rc_polling. Signed-off-by: Michael Mauch <michael.mauch@gmx.de> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6037): Updated GenPix USB driverAlan Nisota
There are now 4 different versions of the GENPIX USB adapter. The newest 'Skywalker' models are fully self-contained, and need no additional hardware to be used. A very reliable DVB-S card even without using any of the alternate modulatations (which this kernel module does not currently support) The following patch adds support for all 4 versions of the genpix adapter (www.genpix-electronics.com). Signed-off-by: Alan Nisota alannisota@gmail.com Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6031): Fix for bug 7819: fixed hotplugging for dvbnetTrent Piepho
The first part of dvb_net_close() is just a cut&paste from dvb_generic_release(), so maybe it would be better to just call dvb_generic_release() instead? Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Markus Rechberger <mrechberger@gmail.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6025): Net_ule(): fix check-after-useAdrian Bunk
The Coverity checker spotted that we'd have already oops'ed if "dev" was NULL. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6015): DVB: convert struct class_device to struct deviceKay Sievers
The currently used "struct class_device" will be removed from the kernel. Here is a trivial patch that converts DVB to use struct device. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6010): Use inline functions instead of inline asm for powerpcKumar Gala
Change io_st_le32() to use inline functions rather than direct inline assembly code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6009): Bt8xx: "extern inline" -> "static inline"Adrian Bunk
"extern inline" will have different semantics with gcc 4.3. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5990): cinergyt2_suspend: don't forget to unlock cinergyt2->wq_semOleg Nesterov
Restore unlock of cinergyt2->wq_sem, was deleted by accident. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5986): dvb_frontend: Fixed GET_INFO ioctl and check of frequency limitsOliver Endriss
The calculation of frequency limits ignored tuner-specific frequency limits. Range checks and GET_INFO ioctl updated accordingly. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5985): Fix the min/max frequencies of some DVB-C frontendsHartmut Birr
The min frequencies of the DVB-C frontends are wrong. In Europe, the center frequency of the lowest channel is 50.5MHz and not 51MHz. All known cards with the stv0297/tda0002x/ves1820 frontend are able to tune to this frequency. I've changed the range to the lowest channel - 1/2 bandwidth and the highest channel + 1/2 bandwidth. For the design of the dvb driver, the frequency ranges must be part of the tuner and not of the frontend itself. The same frontend may be used for different tuners. The attached patch does only fix the ranges and not the design. Signed-off-by: Hartmut Birr <e9hack@googlemail.com> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5980): tda8083: fix frequency and symbolrate infoOliver Endriss
The TDA8083 supports a symbol rate from 12..30 MSym/s. The Grundig 29504-451 tuner uses the TDA8060 down-converter, which has a frequency range from 920..2200MHz. Thanks-to: Lars Buerding <lindvb@metatux.net> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5976): mt2131 s5h1409: correct frontend selection logicTrent Piepho
If a card driver is compiled into the kernel and mt2131 or s5h1409 are compiled as modules, the kernel won't link. A compiled in driver can't use a module, so in this case the mt2131 or s5h1409 are effectively disabled w.r.t the compiled in driver and the stub attach function should be used. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5965): Frontend_ioctl(): fix check-after-useAdrian Bunk
The Coverity checker spotted that we have already oops'ed if "fe" was NULL. Since "fe" being NULL seems impossible at this point this patch removes the NULL check. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5964): Fixed remote control for dib0700 with new firmwareJanne Grunau
The new firmware returns the data of the REQUEST_POLL_RC request in reversed order. The default is RC5, but it can be adjusted using a module parameter. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5963): Module parameter description for SFN workaroundPatrick Boettcher
Thanks to Matt Doran I found that there the module parameter description was not OK. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5962): Fix line-break in err outputJanne Grunau
line-breaks in dib0700-remote-query function fixed. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
