path: root/drivers/media/dvb
2008-04-29V4L/DVB (7783): drivers/media/dvb/frontends/s5h1420.c: printk fixAndrew Morton
drivers/media/dvb/frontends/s5h1420.c: In function `s5h1420_setsymbolrate': drivers/media/dvb/frontends/s5h1420.c:484: warning: long long unsigned int format, u64 arg (arg 2) We do not know what type the architecture uses for u64. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29Rename common tuner Kconfig names to use the sameMauro Carvalho Chehab
namespace for all of them.
2008-04-29V4L/DVB (7769): Move other terrestrial tuners to common/tunersMauro Carvalho Chehab
Those tuners are currently used only under media/dvb. However, they can support also analog TV. Better to move them to the same place as the other hybrid tuners. This would make easier to use those tuners also by analog drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB (7768): reorganize some DVB-S Kconfig itemsMauro Carvalho Chehab
There are some DVB-S tuners together with DVB-S tags, while others together with tuners. Better to have all of them together. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-29V4L/DVB(7767): Move tuners to common/tunersMauro Carvalho Chehab
There were several issues in the past, caused by the hybrid tuner design, since now, the same tuner can be used by drivers/media/dvb and drivers/media/video. Kconfig items were rearranged, to split V4L/DVB core from their drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-26V4L/DVB (7741): s5h1411: Adding support for this ATSC/QAM demodulatorSteven Toth
This adds full support for this demodulator. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-26V4L/DVB (7739): mt312.h: dubious one-bit signed bitfieldHarvey Harrison
Make it unsigned (0/1) rather than signed (0/-1). Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-25v4l/dvb: add statics to avoid multiple definitionsHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24V4L/DVB (7674): tda10048: Adding an SNR tableSteven Toth
Trying to improve the SNR reporting. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7672): dib7000p: Add output mode param to the attach structSteven Toth
This allows future drivers to select the most appropriate output mode. Signed-off-by: Steven Toth <stoth@hauppauge.com> Reviewed-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7663): budget: Support for Activy budget card with BSBE1 tunerOliver Endriss
Add support for Activy budget card with BSBE1 tuner, subsystem id 0x1131:0x4f60. Low band and DiSEqC support should work now (BSBE1 and BSRU6 tuner). Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7662): stv0299: Fixed some typosOliver Endriss
Fixed some typos. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7661): stv0299: Add flag to turn off OP0 outputOliver Endriss
Add flag to turn off OP0 output. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7660): bsbe1: Use settings recommended by the manufacturerOliver Endriss
Reworked the BSBE1 tuner support in bsbe1.h to follow the ALPS-recommended parameters more closely. Tested with BSBE1-based Activy cards and TT DVB-S rev 2.3. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7659): dvb-core: Implement DMX_SET_BUFFER_SIZE for dvrAndrea Odetti
Implementation of DMX_SET_BUFFER_SIZE for dvr. Synchronization of the code of DMX_SET_BUFFER_SIZE for demux and dvr. Signed-off-by: Andrea Odetti <mariofutire@gmail.com> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7658): dvb-core: Fix DMX_SET_BUFFER_SIZE in case the buffer shrinksAndrea Odetti
This patch fixes the bug in DMX_SET_BUFFER_SIZE for the demux. Basically it resets read and write pointers to 0 in case they are beyond the new size of the buffer. Signed-off-by: Andrea Odetti <mariofutire@gmail.com> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7656): tda826x: Calculate cut off fequency from symbol rateHartmut Hackmann
This patch makes the tuner work with transonders providing higher symbol rates. It was contributed by Oliver Endriss. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7655): tda10086 coding stlye fixesHartmut Hackmann
This patch replaces the c++ style comments. No functional changes Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7654): tda10086: make the xtal frequency a configuration optionHartmut Hackmann
Some DVB-S boards, i.e. with the SD1878 tuner, use a 4 MHz reference frequency. This reqires a different setup of the clock PLL. This patch adds an enum to the tda10086_config struct and sets the proper values for the boards. This patch also fixes the DVB-S section of the MD7134_BRIDGE_2 Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7651): tuner-xc2028: Several fixes to SCODEMauro Carvalho Chehab
This patch fixes several issues on SCODE: 1) The extracting tool weren't generating the proper tags for SCODE. This has almost no effect, since those tags shouldn't be used; 2) DIBCOM52 were using a wrong IF. It should be 5200, instead of 5700; 3) seek_firmware were wanting an exact match for firmware type. This is wrong. As result, no SCODE firmware were loaded; 4) A few files were including the wrong file for seeking demod firmwares; 5) XC3028_FE_DEFAULT can be used, if user doesn't want to load a firmware. However, this weren't documentated. This feature require more testing. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7644): Adding support for the NXP TDA10048HN DVB OFDM demodulatorSteven Toth
Adding support for the NXP TDA10048HN DVB OFDM demodulator Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7639): au8522: fix a small bug introduced by Checkpatch cleanupMauro Carvalho Chehab
2008-04-24V4L/DVB (7638): CodingStyle fixes for au8522 and au0828Mauro Carvalho Chehab
2008-04-24V4L/DVB (7635): au8522: CleanupSteven Toth
au8522: Cleanup Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7633): au8522: consolidate mse2snr_lookup functionsMichael Krufky
consolidate au8522_qam256_mse2snr_lookup, au8522_qam64_mse2snr_lookup and au8522_vsb_mse2snr_lookup into a single function, au8522_mse2snr_lookup. Pass the mse2snr table into au8522_mse2snr_lookup depending on the modulation type. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7632): au8522: Added SNR support and basic cleanupSteven Toth
au8522: Added SNR support and basic cleanup Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7631): au8522: add function au8522_read_mseMichael Krufky
add function au8522_read_mse, which will be used to compute snr TO DO: mse2snr Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7630): au8522: fix au8522_read_ucblocks for qamMichael Krufky
ucblocks are reported in separate registers for vsb & qam Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7629): au8522: replace __FUNCTION__ with __func__Michael Krufky
replace __FUNCTION__ with __func__ and clean associated checkpatch.pl warnings. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7628): au8522: codingstyle cleanupsMichael Krufky
Fixed some checkpatch.pl warnings Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7621): Add support for Hauppauge HVR950Q/HVR850/FusioHDTV7-USBSteven Toth
Including support for the AU0828 USB Bridge. Including support for the AU8522 ATSC/QAM Demodulator. Including support for the AU8522 ATSC/QAM Demodulator. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7569): Added support for SkyStar2 rev2.7 and ITD1000 DVB-S tunerPatrick Boettcher
This patches adds support for the SkyStar2 rev2.7 with the PN1010/ITD1000 Frontend. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7471): SkyStar2: preparing support for the rev2.8Patrick Boettcher
Support is prepared, but the CX24113-driver .c-file is missing. After sorting out the NDA problems, the file will be there immediatly. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7575): mt312: add attach-time setting to invert lnb-voltageMatthias Schwarzott
Add a setting to config struct for inversion of lnb-voltage. Needed for support of Avermedia A700 cards. Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7574): mt312: Add support for zl10313 demodMatthias Schwarzott
Add zl10313 support to mt312 driver. zl10313 uses 10.111MHz xtal. Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7573): mt312: Supports different xtal frequenciesMatthias Schwarzott
Do not hardcode xtal frequency but allow different values for future zl10313 support. Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7572): mt312: Fix diseqcMatthias Schwarzott
Correct the frequency of the emitted diseqc signal to 22kHz. Adds sleep(100) to wait for message to be transmitted. For now the only user of mt312 is b2c2-flexcop, and it does overwrite all diseqc related functions with own code. Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7571): mt312: Cleanup buffer variables of read/write functionsMatthias Schwarzott
Change type of buffer variables from void* to u8* to save some casts. Signed-off-by: Matthias Schwarzott <zzam@gentoo.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7568): Support for DVB-S demod PN1010 (clone of S5H1420) addedPatrick Boettcher
This device is a clone of the PN1010 used by SkyStar2 rev2.7 . This patch adds support for the flexcop-device and makes the driver look a little bit nicer. It needs to be checked whether the driver is still ok for the budget-cards. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7538): Adds selectable adapter numbers as per module optionJanne Grunau
The adapter_nr module options can be used to allocate static adapter numbers on a driver level. It avoids problems with changing DVB apapter numbers after warm/cold boot or device unplugging and repluging. Each driver holds DVB_MAX_ADAPTER long array of the preferred order of adapter numbers. options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a reversed allocation of adapter numbers. With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If both are already in use it will allocate the lowest free adapter number. Signed-off-by: Janne Grunau <janne-dvb@grunau.be> Acked-by: Hermann Pitton <hermann.pitton@arcor.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7532): budget: Add support for Fujitsu Siemens DVB-T Activy BudgetOliver Endriss
Implement support for Fujitsu Siemens DVB-T Activy Budget, sub-system id 0x1131:0x5f61. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7531): budget-av: Fix CI interface on (some) KNC1 DVBS cardsChristoph Pfister
Quoting the commit introducing reinitialise_demod (3984 / by adq): "These cards [KNC1 DVBT and DVBC] need special handling for CI - reinitialising the frontend device when the CI module is reset." Apparently my 1894:0010 also needs that fix, because once you initialise CI/CAM you lose lock. Signed-off-by: Christoph Pfister <pfister@linuxtv.org> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7530): budget-av: Fix support for certain camsChristoph Pfister
The current ci implementation doesn't accept 0xff when reading data bytes (address == 0), thus breaks cams which report a buffer size of 0x--ff like my orion one. Remove the 0xff check altogether, because validation is really the job of a higher layer. Signed-off-by: Christoph Pfister <pfister@linuxtv.org> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7517): media/dvb/ttusb-dec replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7516): media/dvb/ttusb-budget replace remaining __FUNCTION__ ↵Harvey Harrison
occurrences __FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7515): media/dvb/ttpci replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7514): media/dvb/frontends replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-24V4L/DVB (7513): media/dvb/dvb-usb replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-24V4L/DVB (7512): media/dvb/dvb-core replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-24V4L/DVB (7511): media/dvb/cinergyT2 replace remaining __FUNCTION__ occurrencesHarvey Harrison
