path: root/drivers/media/dvb/frontends/cx24110.h
2008-04-24V4L/DVB (7514): media/dvb/frontends replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-11-03V4L/DVB (4751): Fix DBV_FE_CUSTOMISE for card drivers compiled into kernelTrent Piepho
When a front-end is disabled, card drivers that use it are compiled with a stub version of the front-end's attach function. This way they have no references to the front-end's code and don't need it to be loaded. If a card driver is compiled into the kernel, and a front-end is a module, then that front-end is effectively disabled wrt the card driver. In this case, the card driver should get the stub version. This was not happening. The stub vs real attach function selection is changed so that when the front-end is a module the real attach function is only used if the card driver is a module as well. This means a module front-end will be supported by card drivers that are modules and not supported by card drivers compiled into the kernel. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4387): Add Kconfig infrastructure for dvb_attachAndrew de Quincey
Allow it to be en/disabled Disable it in < 2.6.17 due to symbol_xxx() bug Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4384): Remove remaining static function callsAndrew de Quincey
Rewrote _write() calls to use write() op. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3863): Convert cx24110 to refactored tuner codeAndrew de Quincey
Convert to tuner_ops calls. Remove pll function pointers from structure. Remove unneeded tuner calls. Remove unneeded sleep function completely. Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-02-27V4L/DVB (3389): Fix broken IF-OUT Relay handlingManu Abraham
Fixed broken IF-OUT on pinnacle sat board. Thanks to Edgar Toernig Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-09-09[PATCH] dvb: email address updateJohannes Stezenbach
Update email address of Peter Hettkamp. Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
