path: root/drivers/media/dvb-frontends/si21xx.c
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-02media: dvb: represent min/max/step/tolerance freqs in HzMauro Carvalho Chehab
Right now, satellite frontend drivers specify frequencies in kHz, while terrestrial/cable ones specify in Hz. That's confusing for developers. However, the main problem is that universal frontends capable of handling both satellite and non-satelite delivery systems are appearing. We end by needing to hack the drivers in order to support such hybrid frontends. So, convert everything to specify frontend frequencies in Hz. Tested-by: Katsuhiro Suzuki <suzuki.katsuhiro@socionext.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2017-12-28media: move dvb kAPI headers to include/mediaMauro Carvalho Chehab
Except for DVB, all media kAPI headers are at include/media. Move the headers to it. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-11-18[media] dvb: make DVB frontend *_ops instances "const"Max Kellermann
These are immutable. Making them "const" allows the compiler to move them to the "rodata" section. Note that cxd2841er_t_c_ops cannot be made "const", because cxd2841er_attach() modifies it. Ouch! [mchehab@s-opensource.com: fix merge conflicts] Signed-off-by: Max Kellermann <max.kellermann@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-10-21[media] dvb-frontends: don't break long linesMauro Carvalho Chehab
Due to the 80-cols restrictions, and latter due to checkpatch warnings, several strings were broken into multiple lines. This is not considered a good practice anymore, as it makes harder to grep for strings at the source code. As we're right now fixing other drivers due to KERN_CONT, we need to be able to identify what printk strings don't end with a "\n". It is a way easier to detect those if we don't break long lines. So, join those continuation lines. The patch was generated via the script below, and manually adjusted if needed. </script> use Text::Tabs; while (<>) { if ($next ne "") { $c=$_; if ($c =~ /^\s+\"(.*)/) { $c2=$1; $next =~ s/\"\n$//; $n = expand($next); $funpos = index($n, '('); $pos = index($c2, '",'); if ($funpos && $pos > 0) { $s1 = substr $c2, 0, $pos + 2; $s2 = ' ' x ($funpos + 1) . substr $c2, $pos + 2; $s2 =~ s/^\s+//; $s2 = ' ' x ($funpos + 1) . $s2 if ($s2 ne ""); print unexpand("$next$s1\n"); print unexpand("$s2\n") if ($s2 ne ""); } else { print "$next$c2\n"; } $next=""; next; } else { print $next; } $next=""; } else { if (m/\"$/) { if (!m/\\n\"$/) { $next=$_; next; } } } print $_; } </script> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2015-06-09[media] dvb: Get rid of typedev usage for enumsMauro Carvalho Chehab
The DVB API was originally defined using typedefs. This is against Kernel CodingStyle, and there's no good usage here. While we can't remove its usage on userspace, we can avoid its usage in Kernelspace. So, let's do it. This patch was generated by this shell script: for j in $(grep typedef include/uapi/linux/dvb/frontend.h |cut -d' ' -f 3); do for i in $(find drivers/media -name '*.[ch]' -type f) $(find drivers/staging/media -name '*.[ch]' -type f); do sed "s,${j}_t,enum $j," <$i >a && mv a $i; done; done While here, make CodingStyle fixes on the affected lines. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> # for drivers/media/firewire/*
2014-09-23[media] dvb: si21xx: buffer overflow in si21_writeregs()Dan Carpenter
"len" is user controlled and can be up to 255. Anything more than 59 will cause a buffer overflow so we need to add a test for that. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2012-10-07[media] drivers/media: Remove unnecessary semicolonPeter Senna Tschudin
A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r1@ statement S; position p,p1; @@ S@p1;@p @script:python r2@ p << r1.p; p1 << r1.p1; @@ if p[0].line != p1[0].line_end: cocci.include_match(False) @@ position r1.p; @@ -;@p // </smpl> [mchehab@redhat.com: some hunks got bitroted; applied only the ones that succeeds] Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> [crope@iki.fi: For my drivers a8293, af9013, af9015, af9035] Acked-by: Antti Palosaari <crope@iki.fi> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-08-13[media] move the dvb/frontends to drivers/media/dvb-frontendsMauro Carvalho Chehab
Raise the DVB frontends one level up, as the intention is to remove the drivers/media/dvb directory. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
