The DVB API was originally defined using typedefs. This is against
Kernel CodingStyle, and there's no good usage here. While we can't
remove its usage on userspace, we can avoid its usage in Kernelspace.
So, let's do it.
This patch was generated by this shell script:
for j in $(grep typedef include/uapi/linux/dvb/frontend.h |cut -d' ' -f 3); do for i in $(find drivers/media -name '*.[ch]' -type f) $(find drivers/staging/media -name '*.[ch]' -type f); do sed "s,${j}_t,enum $j," <$i >a && mv a $i; done; done
While here, make CodingStyle fixes on the affected lines.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> # for drivers/media/firewire/*
X-Patchwork-Delegate: m.chehab@samsung.com
As shown at the code, upd_demod_gain_period is used to write
to two 16-bit registers:
dib8000_write_word(state, 1946, upd_demod_gain_period & 0xFFFF);
dib8000_write_word(state, 1947, reg | (1<<14) | ((upd_demod_gain_period >> 16) & 0xFF));
So, it should be declared as u32.
This fixes the following smatch warning:
drivers/media/dvb-frontends/dib8000.c:1282 dib8000_agc_startup() warn: right shifting more than type allows
The message is currently highly encoded:
[70299.863521] DiB8000: Mpeg locks [ L0 : 0 | L1 : 1 | L2 : 0 ]
And doesn't properly reflect that some problems might have happened.
Instead, display it as:
[75160.822321] DiB8000: Not all ISDB-T layers locked in 32 ms: Layer A NOT LOCKED, Layer B locked, Layer C not enabled
In order to better reflect what's happening with layer locking.
Acked-By: Patrick Boettcher <pboettcher@kernellabs.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
When debug is enabled:
- Report when frontend gets restarted;
- Be coherent on the displayed lines;
- Show the transmission mode;
- Hide unused layers.
No functional changes (except at the printk's).
This table doesn't match the new one.
Update it.
Instead of doing the tuning delays and timeouts using
current_kernel_time(), use jiffies. That consumes less
CPU cycles, and it is monotonic.
msleep() is not too precise: its precision depends on the
HZ config. As the driver selects precise timings for the
state machine, change it to usleep_range().
Just like the Windows driver, restart SAD during reset
TV broadcasters generally use partial reception. So, enable it by
default in auto-search mode. The driver will latter detect if the
transmission is on some other mode.
The symbol duration was already obtained at CT_DEMOD_START.
No need to do it again at CT_DEMOD_STEP_3.
Without that, tuning may fail on 4K FFT mode, as the transmission
parameter cache will be initialized with a wrong value.
There are two tabs instead of one aligning this struct.
Worse than that, on some places, the alignment is wrong.
Fix it.
No functional changes.
The ADC OFF values are wrong. This causes troubles on detecting
weak signals.
If interleave is bigger than 2, the code will set it to 0, as
dib8000 registers use a log2(). So, change the code to handle
it accordingly.
Exporting multiple symbols don't work as it causes compilation
breakages, due to the way dvb_attach() works.
The bug happens when:
CONFIG_DVB_DIB8000=m
CONFIG_DVB_USB_DIB0700=y
As a bonus, dib8000 won't be loaded anymore if the device uses
a different frontend, reducing the memory footprint.
Tested with both Pixelview PV-D231 and MyGica S870.
Well, what we call as "foo_attach" is the method that should
be called by the dvb_attach() macro.
It should be noticed that the name "dvb_attach" is really a
bad name and don't express what it does.
dvb_attach() basically does three things, if the frontend is
compiled as a module:
- It lookups for the module that it is known to have the
given symbol name and requests such module;
- It increments the module usage (anonymously - so lsmod
doesn't print who loaded the module);
- after loading the module, it runs the function associated
with the dynamic symbol.
When compiled as builtin, it just calls the function given to it.
As dvb_attach() increments refcount, it can't be (easily)
called more than once for the same module, or the kernel
will deny to remove the module, because refcount will never
be zeroed.
In other words, the function name given to dvb_attach()
should be one single symbol that will always be called
before any other function on that module to be used.
For almost all DVB frontends, there's just one function,
but, on dib8000, there are several exported symbols.
We need to get rid of all those direct calls, because they
cause compilation breakages when bridge is builtin and
frontend is module, we'll need to add a new function that
will be the first one to be called, whatever initialization
is needed.
So, let's rename this function, in order to prepare for
a next patch that will add a new attach() function that
will be the only one exported by this module.
drivers/media/dvb-frontends/dib8000.c: In function 'dib8000_get_time_us':
drivers/media/dvb-frontends/dib8000.c:3957: warning: 'interleaving' may be used uninitialized in this function
drivers/media/dvb-frontends/dib8000.c:3956: warning: 'rate_denum' may be used uninitialized in this function
Those are actually false positives, but it doesn't hurt cleaning them.
When compiling with avr32, it gets those errors:
drivers/media/dvb-frontends/dib8000.c: In function 'dib8000_get_stats':
drivers/media/dvb-frontends/dib8000.c:4121: warning: integer constant is too large for 'long' type
Fix integer representation to avoid overflow.
As reported by kbuild test robot <fengguang.wu@intel.com>:
with a random config:
drivers/built-in.o: In function `dib8000_get_time_us.isra.16':
>> dib8000.c:(.text+0x3075aa): undefined reference to `__udivdi3'
PER/UCB statistics are collected once on each 1 second.
However, it doesn't provide the total number of packets
needed to calculate PER.
Yet, as we know the bit rate, it is possible to estimate
such number. So, do it.
Acked-by: Patrick Boettcher <pboettcher@kernellabs.com>
On dib8000, the BER statistics are updated on every 1.25e6 bits.
Adjust the code to only update the statistics after having it
done.
On dib8000, the block error count is a monotonic 32 bits register.
With DVBv5 stats, we use a 64 bits counter, that it is reset
when a new channel is tuned.
Change the UCB counting start from 0 and to be returned with
64 bits, just like the API requests.
Use multiple linear segments to better interpolate the dBm
for the signal strength.
The table that converts from linear strength to dB was
empirically determinated with the help of a signal generator
(DTA-2111).
The entries from -35dBm to -22.5dBm were taken using just
the signal generator and the board.
For the entries from -36dBm to -51dBm, a 16 dB tap was used,
in order to extend its range.
Signals below to -51dBm are just linearly interpolated.
Better to have Signal strength in dB.
This takes a very rough estimation for the signal strength,
that was calibrated using a Dektec DTA-2111 Gold RF generator
and a Pixelview dib8076 stick.
It estimates the signal strength using a linear equation where:
- the max is -22.5 dBm, with returns 55953
- the min is -35.0 dBm, with returns 50110
With -22dBm, the signal strengh is returned as 65535.
Unfortunately, the min strength generated with DTA-2111 is
-35dBm.
It should be noticed that approximating it by a linear equation
is not right. I should probably be splitting it into 0.5 dB
linear segments, in order to get a higher precision, just like
it is done on mb86a20s, but that would force me to add some
attenuators, in order to get dB levels below -35dBm, which is,
btw, strong enough to get signal lock.
The advantage of DVBv5 stats is that it allows adding proper
scales to all measures. use it for this frontend.
This patch adds a basic set of stats, basically cloning what's already
provided by DVBv3 API. Latter patches will improve it.
On ISDB-T, the valid values for interleaving are 0, 1, 2 and 4.
While the first 3 are properly reported, the last one is reported
as 3 instead. Fix it.
Tested with a Dektec DTA-2111 RF generator.
The logic that detects if auto search mode should be used is too
complex.
Also, it doesn't cover all cases, as the dib8000_tune logic
requires either auto mode or a fully specified manual mode.
So, move it to a separate function and add some extra debug
data to help identifying when it falled back to auto mode,
because the manual settings are invalid.
Both dvbv5-scan and dvbv5-zap tools call FE_GET_PROPERTY inside the
loop that checks for stats. If the frontend doesn't support DVBv5, it
falls back to call the DVBv5 stats APIs(FE_READ_BER, FE_READ_SIGNAL,
FE_READ_SNR and FE_READ_UNCORRECTED_BLOCKS).
A call to FE_GET_PROPERTY makes dvb-frontend core to call get_frontend().
However, due to a race condition on dib8000 between dib8000_get_frontend
and dib8000_tune, if get_frontend occurs too early, it causes the
tune state machine to fail and not get any lock.
This patch adds a workaround code that makes get_frontend() to just
return if none of the frontends have a SYNC. This change fixed the issue
with dvbv5-scan/dvbv5-zap, but a fine-tuned logic might be needed in
the future, when we implement DVBv5 stats on this frontend.
The procedure to test the bug and the fix is the one below:
1) tune into a non-existing frequency with:
$ dvbv5-zap -I dvbv5 -c non_existing_freqs -m 679142857 -t3
2) tune/lock into an existing frequency with:
$ dvbv5-zap -I dvbv5 -c isdb-test -m 479142857
or
$ dvbv5-scan isdb-test
In this case, 679 MHz carrier doesn't exist. Only 479 MHz does.
As the dvb-frontend kthread can be called anytime, it can race
with some get status ioctl. So, it seems better to avoid one to
race with the other while reading a 32 bits register.
I can't see any other reason for having a mutex there at I2C, except
to provide such kind of protection, as the I2C core already has a
mutex to protect I2C transfers.
Note: instead of this approach, it could eventually remove the dib8000
specific mutex for it, and either group the 4 ops into one xfer or
to manually control the I2C mutex. The main advantage of the current
approach is that the changes are smaller and more puntual.
Cc: stable@vger.kernel.org
Commit 173a64cb3fcf broke support for some dib807x versions.
Fix it by providing backward compatibility with the older versions.
[mkrufky@linuxtv.org: conflict handling and CodingStyle fixes]
Signed-off-by: Olivier Grenie <olivier.grenie@parrot.com>
Fix various spelling errors in strings and comments throughout the media
tree. The majority of these were found using Lucas De Marchi's codespell
tool.
[m.chehab@samsung.com: discard hunks with conflicts]
Signed-off-by: Jonathan McCrohan <jmccrohan@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
drivers/media/dvb-frontends/dib8000.c: In function ‘dib8000_set_frontend’:
drivers/media/dvb-frontends/dib8000.c:3556: warning: ‘ret’ is used uninitialized in this function
Remove the variable and return zero instead.
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
drivers/media/dvb-frontends/dib8000.c: In function 'dib8000_wait_lock':
drivers/media/dvb-frontends/dib8000.c:3972:1: warning: 'value' may be used uninitialized in this function [-Wmaybe-uninitialized]
drivers/media/dvb-frontends/dib8000.c:2419:6: note: 'value' was declared here
isdbt_sb_subchannel is unsigned with 8 bits. So, it will
never be -1. Instead, any value bigger than 13 is invalid.
As is, the current code generates the following warnings:
drivers/media/dvb-frontends/dib8000.c: In function 'dib8000_set_isdbt_common_channel':
drivers/media/dvb-frontends/dib8000.c:2358:3: warning: comparison is always true due to limited range of data type [-Wtype-limits]
drivers/media/dvb-frontends/dib8000.c: In function 'dib8000_tune':
drivers/media/dvb-frontends/dib8000.c:3107:8: warning: comparison is always false due to limited range of data type [-Wtype-limits]
drivers/media/dvb-frontends/dib8000.c:3153:9: warning: comparison is always false due to limited range of data type [-Wtype-limits]
drivers/media/dvb-frontends/dib8000.c:3160:5: warning: comparison is always false
It should also be noticed that ARIB STD-B31, item
"3.15.6.8 Number of segments" at TMCC table defines the
value 15 for unused segment, and 14 as reserved.
So, better to change the check to consider any value
bigger than 13 to mean that sub-channels should be
disabled, fixing the warning and doing the right thing
even if an invalid value is filled by userspace.
dtv_property_cache is used on several places on very long lines.
On all places it is used, a long list of struct reference is done.
Instead of doing it, at the routines where it is used more than once,
replace it by one temporary var. That may help the compiler to
use a better code. It also makes easier to review the code, as the
lines becomes closer to 80 columns, making them a way clearer
to read.
drivers/media/dvb-frontends/dib8000.c:2412:5: warning: no previous prototype for 'dib8000_wait_lock' [-Wmissing-prototypes]
drivers/media/dvb-frontends/dib8000.c:2688:5: warning: no previous prototype for 'dib8000_get_symbol_duration' [-Wmissing-prototypes]
The intend of this patch is to improve the support of the dib8000.
Signed-off-by: Patrick Boettcher <patrick.boettcher@parrot.com>
Raise the DVB frontends one level up, as the intention is to remove
the drivers/media/dvb directory.
