commit ca6e6126db5494f18c6c6615060d4d803b528bff upstream.
Implement memory barriers according to Documentation/circular-buffers.txt:
- use smp_store_release() to update ringbuffer read/write pointers
- use smp_load_acquire() to load write pointer on reader side
- use ACCESS_ONCE() to load read pointer on writer side
This fixes data stream corruptions observed e.g. on an ARM Cortex-A9
quad core system with different types (PCI, USB) of DVB tuners.
Signed-off-by: Soeren Moch <smoch@web.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit c9d57de6103e343f2d4e04ea8d9e417e10a24da7 upstream.
When in FE_TUNE_MODE_ONESHOT the frontend must report
the actual capabilities so user can take appropriate
action.
With frontends that can't do auto inversion this is done
by dvb-core automatically so CAN_INVERSION_AUTO is valid.
However, when in FE_TUNE_MODE_ONESHOT this is not true.
So only set FE_CAN_INVERSION_AUTO in modes other than
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
While we can't document #defines, documenting enums are
well supported by kernel-doc. So, convert the bitmap defines
into an enum.
The usage of #define at the kABI is fine, but it doesn't
allow adding a proper description. As those defines deserve
a proper documentation, let's convert them into an enum and
document them at device-drivers DocBook.
The dvb/kdapi.tmpl has already an extensive documentation about
this callback. Now that we've added function typedefs at kernel-doc,
add such documentation at demux.h, for it to appear at device-drivers
DocBook.
DocBook.
There are lots of CodingStyle violations here. Now that we're
touching a log on this header files, adding the documentation
here, make sure that this will follow the Kernel CodingStyle.
Document the following data types:
struct dmx_ts_feed
struct dmx_section_filter
struct dmx_section_feed
enum dmx_frontend_source
struct dmx_frontend
The DVB core has a provision for other frontend sources, but no
drivers use it. The kdapi.xml contains provision for some other
frontend source types, but it is not in sync with the code.
So, remove the unused types and sync both files.
This enum is not actually used anymore. The only value used from
the enum is DMX_OK, passed as a parameter on two callbacks.
Yet, this value is not used anywhere. So, just remove it.
There are two callbacks still not documented:
.//drivers/media/dvb-core/demux.h:422: warning: No description found for parameter 'get_pes_pids'
.//drivers/media/dvb-core/demux.h:422: warning: No description found for parameter 'get_stc'
The purpose of first one is clear. The second one is used only
on the obsolete av7110 driver, and its purpose is not clear,
as it just returns a 64-bit word from the firmware to userspace.
Let's document get_pes_pids and mark get_stc as private, adding
a comment to not use it, while this is not documented.
There are two DVB demux callbacks and ioctls that aren't documented
and aren't used at all by the DVB core or by any DVB driver upstream.
Let's comment out the code for those two ioctls and remove on some
future version.
There are a few inconsistencies between the old documentation
that got imported into the header and the current status.
Update them, and use the proper doc-nano nomenclature for
struct artuments "@", instead of foo().
The DocBook/media/dvb/kdapi.xml contains the description of
the kABI for DVB. The problem is that, by being maintained
on a separate file and not being updated for years, it got
outdated. So, for example, some callback parameters were
changed, but the DocBook were still using the old stuff.
As a first step to fix it, let's move the documentation of
struct dmx_demux into demux.h and fix the parameters used
there.
For now, don't document any other field nor touch the
descriptions that got moved, letting this job to other
patches. That makes easier to review the patch.
PS.: Please notice that an additional patch will be needed
in order to fix the return values (some uses non-existent
return codes) and to the functions and callbacks mentioned at
the descriptions.
There are several CodingStyle violations at the DVB code. While
we won't be fixing them as a hole, let's fix at least the
headers, as we're touching on them already in order to properly
document them.
No functional changes.
This struct is already documented at the header file, but it is
not using Kernel doc-nano format. Convert to it.
Adds Terratec H7 Rev. 4 with USB id 0ccd:10a5 to DVBSky driver.
Signed-off-by: Erik Andresen <erik@vontaene.de>
Those two came from dvb_register_adapter cut-and-paste:
.//drivers/media/dvb-core/dvbdev.h:199: warning: Excess function parameter 'device' description in 'dvb_register_device'
.//drivers/media/dvb-core/dvbdev.h:199: warning: Excess function parameter 'adapter_nums' description in 'dvb_register_device'
Remove them.
Document the most relevant functions and data structs for
developers that are working with the DVB subsystem.
Acked-by: Jonathan Corbet <corbet@lwn.net>
That struct is used on every DVB Front End driver, as it
contains what's needed to register/use a frontend at the
Kernel.
Document it.
Most of the parameters here are already well defined at
the userspace documentation. Yet, it is good to add some
documentation, for the developers to be sure that they
are the same as the ones at userspace API.
This is one of the most important functions of the DVB
frontend, containing the logic needed to set the parameters
at the demux and to send commands via SEC.
Document it.
The dvb_frontend.c core defines a FE_ALGO_HW symbol that it is
never used. Also, both cx24123 returns 1 to get_algo() callback
instead of using DVBFE_ALGO_HW.
Probably, those are some left overs from some code cleanup.
Let's stop returning magic numbers and use the proper macro
value.
Add documentation for struct analog_demod_info and
struct analog_demod_ops.
The struct dvb_tuner_ops contains lots of callbacks used
by tuners. Document them.
That struct inside dvb-frontend.h stores some parameters
from V4L2 API (videodev2.h), in order to be used by the
hybrid analog/digital TV tuners.
Document it.
This enum is not used anymore, as drivers use the
modulation definitions from the public API. It is probably
a left over from some DVB core cleanup.
Despite being used everywhere at DVB frontends, the
struct dvb_tuner_info were never documented.
Add Documentation for dvb_frontend_tune_settings struct.
There are already some comments at dvb_ringbuffer.h that are ready
for DocBook, although not properly formatted.
Convert them, fix some issues and add this file to
the device-drivers DocBook.
While here, put multi-line comments on the right format.
There are already some comments at dvb_math.h that are ready
There are already some comments at dvb_frontend.h that are ready
Convert them, and add this file to the device-drivers DocBook.
There are already some tags at dvb_ca_en50221.h, but using a
different format. Convert them, fix a few entries and add
There are lots of docbook marks at the media subsystem, but
those aren't used.
Add the core headers/code in order to start generating docs.
Use eth_zero_addr to assign the zero address to the given address
array instead of memset when second argument is address of zero.
The Coccinelle semantic patch that makes this change is as follows:
// <smpl>
@eth_zero_addr@
expression e;
-memset(e,0x00,ETH_ALEN);
+eth_zero_addr(e);
// </smpl>
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
Quite a few of the ->diseqc_send_master_cmd() implementations don't
check cmd->msg_len so it can lead to memory corruption.
struct timeval uses a 32-bit seconds representation which will
overflow in the year 2038 and beyond. This patch replaces
the usage of struct timeval with ktime_t which is a 64-bit
timestamp and is year 2038 safe.
This patch is part of a larger attempt to remove all instances
of 32-bit timekeeping variables (timeval, timespec, time_t)
which are not year 2038 safe, from the kernel.
[mchehab@osg.samsung.com: add a missing parenthesis, breaking compilation]
Suggested-by: Arnd Bergmann <arndb@arndb.de>
Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The DVB API was originally defined using typedefs. This is against
Kernel CodingStyle, and there's no good usage here. While we can't
remove its usage on userspace, we can avoid its usage in Kernelspace.
So, let's do it.
This patch was generated by this shell script:
for j in $(grep typedef include/uapi/linux/dvb/frontend.h |cut -d' ' -f 3); do for i in $(find drivers/media -name '*.[ch]' -type f) $(find drivers/staging/media -name '*.[ch]' -type f); do sed "s,${j}_t,enum $j," <$i >a && mv a $i; done; done
While here, make CodingStyle fixes on the affected lines.
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> # for drivers/media/firewire/*
Frontend bandwidth calculation overflows on very high DVB-S/S2
symbol rates. Use mult_frac() macro in order to keep calculation
correct.
Signed-off-by: Antti Palosaari <crope@iki.fi>
git://people.freedesktop.org/~airlied/linux into v4l_for_linus
* 'drm-next-merged' of git://people.freedesktop.org/~airlied/linux: (9717 commits)
media-bus: Fixup RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus format
hexdump: avoid warning in test function
fs: take i_mutex during prepare_binprm for set[ug]id executables
smp: Fix error case handling in smp_call_function_*()
iommu-common: Fix PARISC compile-time warnings
sparc: Make LDC use common iommu poll management functions
sparc: Make sparc64 use scalable lib/iommu-common.c functions
Break up monolithic iommu table/lock into finer graularity pools and lock
sparc: Revert generic IOMMU allocator.
tools/power turbostat: correct dumped pkg-cstate-limit value
tools/power turbostat: calculate TSC frequency from CPUID(0x15) on SKL
tools/power turbostat: correct DRAM RAPL units on recent Xeon processors
tools/power turbostat: Initial Skylake support
tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for O= option in Makefile
tools/power turbostat: modprobe msr, if needed
tools/power turbostat: dump MSR_TURBO_RATIO_LIMIT2
tools/power turbostat: use new MSR_TURBO_RATIO_LIMIT names
Bluetooth: hidp: Fix regression with older userspace and flags validation
config: Enable NEED_DMA_MAP_STATE by default when SWIOTLB is selected
perf/x86/intel/pt: Fix and clean up error handling in pt_event_add()
That solves several merge conflicts:
Documentation/DocBook/media/v4l/subdev-formats.xml
Documentation/devicetree/bindings/vendor-prefixes.txt
drivers/staging/media/mn88473/mn88473.c
include/linux/kconfig.h
include/uapi/linux/media-bus-format.h
The ones at subdev-formats.xml and media-bus-format.h are not trivial.
That's why we opted to merge from DRM.
Add Leadtek WinFast DTV2000DS Plus device based on Realtek RTL2832U.
I have not tested the remote, but it is the Y04G0051 model.
Signed-off-by: Christian Dale <kernel@techmunk.com>
ID 1b80:d3a4 Afatech
Simply added the PID (0xd3a4) of this DVB-T USB device to the list of rtl2832u-supported devices. VID (0x1b80) is same as KWORLD2.
Tested and verified to work in amd64 with kernels 3.13.0 and 3.16.0.
Signed-off-by: Dimitris Lampridis <dlampridis@logikonlabs.com>
Reviewed-by: Antti Palosaari <crope@iki.fi>
The functions "dvb_unregister_device" and "kfree" could still be called
by the dvb_ca_en50221_init() function in the case that a previous resource
allocation failed.
* Corresponding details could be improved by adjustments for jump targets.
* Let us delete also an unnecessary check for the variable "ca" there.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
The dvb_unregister_device() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
TechnoTrend TT-connect S2-4600 is a USB2.0 DVB-S/S2 tuner using the popular
Montage M88DS3103/M88TS2022 demod/tuner.
The demodulator needs a firmware. Antti posted a firmware when releasing
support for PCTV 461e, available here:
http://palosaari.fi/linux/v4l-dvb/firmware/M88DS3103/
Signed-off-by: Olli Salonen <olli.salonen@iki.fi>
Now that there are no more users kill dev_rebuild_header and all of it's
implementations.
This is long overdue.
This is really a simple function, but using it avoids to have
if's inside the drivers.
Also, the kABI becomes a little more clearer.
This shouldn't generate any overhead, and the type check
will happen when compiling with MC DVB enabled.
So, let's do it.
Instead of using media_dev argument for dvb_create_media_graph(),
use the adapter.
That allows to create a stub for this function, if compiled
without DVB support, avoiding to add extra if's at the drivers.
Prefix all DVB media controller entities with "dvb-" and use dash
instead of underline at the names.
Requested-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
if CONFIG_MEDIA_CONTROLLER_DVB is not selected, it is now
producing this warning:
drivers/media/dvb-core/dvb_frontend.c: In function ‘dvb_frontend_thread’:
drivers/media/dvb-core/dvb_frontend.c:695:6: warning: unused variable ‘ret’ [-Wunused-variable]
int ret;
Reported-by: Hans Verkuil <hans.verkuil@cisco.com>
