git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (505 commits)
[media] af9015: Fix max I2C message size when used with tda18271
[media] IR: initialize ir_raw_event in few more drivers
[media] Guard a divide in v4l1 compat layer
[media] imon: fix nomouse modprobe option
[media] imon: remove redundant change_protocol call
[media] imon: fix my egregious brown paper bag w/rdev/idev split
[media] cafe_ccic: Configure ov7670 correctly
[media] ov7670: allow configuration of image size, clock speed, and I/O method
[media] af9015: support for DigitalNow TinyTwin v3 [1f4d:9016]
[media] af9015: map DigitalNow TinyTwin v2 remote
[media] DigitalNow TinyTwin remote controller
[media] af9015: RC fixes and improvements
videodev2.h.xml: Update to reflect the latest changes at videodev2.h
[media] v4l: document new Bayer and monochrome pixel formats
[media] DocBook/v4l: Add missing formats used on gspca cpia1 and sn9c2028
[media] firedtv: add parameter to fake ca_system_ids in CA_INFO
[media] tm6000: fix a macro coding style issue
tm6000: Remove some ugly debug code
[media] Nova-S-Plus audio line input
[media] [RFC,1/1] V4L2: Use new CAP bits in existing RDS capable drivers
Pointed out by Bonne Eggleston on the lirc list.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
There was a redundant call to imon_ir_change_protocol -- its already
getting called from ir_input_register. Also do some minor housekeeping
with var names and formatting.
Somehow, I managed to screw things up when reworking the rdev/idev split
patch from David, and started trying to get ir_input_dev from idev
instead of rdev, thus resulting in button presses hanging the system.
This fixes it.
Use the standard error logging mechanisms.
Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s" fmt, __func__
Remove __func__ from err calls, add '\n', rename to pr_err
Acked-by: Jarod Wilson <jarod@redhat.com>
Currently, they get set up with the pad keytable, which they can't
actually use at all. Also add another variant of volume scancodes from
another 0xffdc device, and properly set up the 0x9e 0xffdc device as an
iMON VFD w/MCE proto IR.
Based on data and a prior patch from Anders Eriksson on the lirc list.
Lest we get our keycodes wrong... Thus far, in practice, I've not found
it to actually matter, but its one of the issues raised in
https://bugzilla.kernel.org/show_bug.cgi?id=16351 that wasn't addressed
by converting to using native IR keydown/up functions.
This is a stab at separating the mouse (and front panel/knob) events
out to a separate input device. This is necessary in preparation for
the next patch which makes the rc-core input dev opaque to rc
drivers.
I can't verify the correctness of the patch beyond the fact that it
compiles without warnings. The driver has resisted most of my
attempts at understanding it properly...for example, the double calls
to le64_to_cpu() and be64_to_cpu() which are applied in
imon_incoming_packet() and imon_panel_key_lookup() would amount
to a bswab64() call, irregardless of the cpu endianness, and I think
the code wouldn't have worked on a big-endian machine...
- Minor alterations to apply with minimal core IR changes
- Use timer for imon keys too, since its entirely possible for the
receiver to miss release codes (either by way of another key being
pressed while the first is held or by the remote pointing away from
the recevier when the key is release. yes, I know, its ugly).
- Bump driver version number, since this is a fairly significant change
(for the much much better).
Tested successfully w/an imon knob receiver.
Signed-off-by: David Härdeman <david@hardeman.nu>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
The ir_input_dev gets filled in by __ir_input_register, the one
allocated in imon_init_idev was being overwritten by the correct one
shortly after it was initialized (ultimately resulting in a memory
leak). Additionally, there was an ill-advised memcpy into that
extraneous ir_input_dev which gets fixed by this.
Ill-advised memcpy pointed out by Dmitry Torokhov, bad usage of
ir_input_dev pointed out by Maxim Levitsky.
Per Dmitry Torokhov, following input_unregister_device with an
input_free_device is forbidden, the former is sufficient alone.
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Per Pieter Hoekstra:
I have a Antec Fusion with a iMON Lcd and I get the following error:
imon 6-1:1.0: Unknown 0xffdc device, defaulting to VFD and iMON IR (id
0x9e)
The driver is functional if I load it like this: (I do not use a remote for it)
modprobe imon display_type=1 (On Mythbuntu 10.04/2.6.32)
This device is a lcd-type with support for a MCE remote. Looking at
the source code, this device (0x9e) is the same as id 0x9f.
Was using input_unregister_device directly, instead of using
ir_input_unregister, which tears down a bunch of other things in
addition to eventually calling input_unregister_device.
Add auto-config support for iMON 2.4G LT RF device, based on
debug output from Giulio Amodeo in Red Hat bugzilla #572288.
Also flips the switch on only setting up the rf associate sysfs
attr only if we think we're looking at an RF device, vs. previously,
setting up the attr for all 0xffdc devices, so its possible (but a bit
unlikely) there's another iMON RF device we'll have to fix up.
Nb: should be applied after "IR/imon: clean up usage of bools", or there
will be a slight contextual mismatch.
There was a mix of 0/1 and false/true. Pick one convention and stick
with it (I picked false/true).
On Tue, May 04, 2010 at 06:06:41PM +0200, Dan Carpenter wrote:
> On Tue, May 04, 2010 at 10:03:18AM -0400, Jarod Wilson wrote:
> > @@ -1205,7 +1204,7 @@ static u32 imon_panel_key_lookup(u64 hw_code)
> > if (imon_panel_key_table[i].hw_code == (code | 0xffee))
> > break;
> > - keycode = imon_panel_key_table[i % IMON_KEY_RELEASE_OFFSET].keycode;
> > + keycode = imon_panel_key_table[i].keycode;
> > return keycode;
> There is still potentially a problem here because if we don't hit the
> break statement, then we're one past the end of the array.
D'oh. Okay, here's v2, should fix that buglet too.
This hack was used when the imon driver was using internal key lookup
routines, but became dead weight when the driver was converted to use
ir-core's key lookup routines. These bits simply didn't get removed,
drop 'em now.
Pointed out by Dan Carpenter.
v2: fix possible attempt to access beyond end of key table array,
also pointed out by Dan.
If there is an error here we should unlock in the caller (which is
imon_init_intf1()). We can remove this stray unlock.
There is a typo here. We meant to test "ir" instead of "props". The
"props" variable was tested earlier.
The original condition is always false because ! has higher precedence
than == and neither 0 nor 1 is equal to IMON_DISPLAY_TYPE_VGA.
Simplified from version 1, in that hacks heisted from ati_remote2.c
aren't actually necessary, the real fix for too many repeats was
from setting too long a timer release value (200ms) on repeats in
mce mode -- this patch drops the release timeout to 33ms, matching
the input subsystem default input_dev->rep[REP_PERIOD].
This is a follow-up to my prior patch implementing ir-core's
change_protocol functionality in the imon driver, which eliminates
a false warning when change_protocol is called without a specific
protocol selected yet (i.e., still IR_TYPE_UNKNOWN). It also removes
some extraneous blank lines getting spewn into dmesg.
Drop the imon driver's internal protocol definitions in favor of using
those provided by ir-core. Should make ir-keytable Just Work for
switching protocol on the fly on the imon devices that support both the
native imon remotes and mce remotes.
The imon-no-pad-stabilize pseudo-protocol was dropped as a protocol, and
converted to a separate modprobe option (which it probably should have
been in the first place). On the TODO list is to convert this to an as yet
unwritten protocol-specific options framework.
While the mce remotes obviously map to IR_TYPE_RC6, I've yet to look at
what the actual ir signals from the native imon remotes are, so for the
moment, imon native ir is mapped to IR_TYPE_OTHER. Nailing it down more
accurately is also on the TODO list.
Driver is not properly initializing u64 constants on 32 bit systems:
drivers/media/IR/imon.c:301: warning: integer constant is too large for ‘long’ type
drivers/media/IR/imon.c:302: warning: integer constant is too large for ‘long’ type
drivers/media/IR/imon.c:304: warning: integer constant is too large for ‘long’ type
drivers/media/IR/imon.c:305: warning: integer constant is too large for ‘long’ type
drivers/media/IR/imon.c:308: warning: integer constant is too large for ‘long’ type
drivers/media/IR/imon.c:309: warning: integer constant is too large for ‘long’ type
drivers/media/IR/imon.c:310: warning: integer constant is too large for ‘long’ type
Fix also a few troubles at error printk handling:
drivers/media/IR/imon.c: In function ‘imon_init_intf0’:
drivers/media/IR/imon.c:1909: warning: ‘ret’ may be used uninitialized in this function
drivers/media/IR/imon.c: In function ‘imon_init_intf1’:
drivers/media/IR/imon.c:1989: warning: ‘ret’ may be used uninitialized in this function
Cc: Jarod Wilson <jarod@redhat.com>
This is a new driver for the SoundGraph iMON and Antec Veris IR/display
devices commonly found in many home theater pc cases and as after-market
case additions.
[mchehab@redhat.com: add KERN_CONT on line 2098 to shutup checkpatc.pl]
