path: root/drivers/md/faulty.c
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] md: Don't assume that READ==0 and WRITE==1 - use the names explicitlyNeilBrown
Thanks Jens for alerting me to this. Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <raziebe@gmail.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: allow array level to be set textually via sysfsNeilBrown
Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] md: remove personality numbering from mdNeilBrown
md supports multiple different RAID level, each being implemented by a 'personality' (which is often in a separate module). These personalities have fairly artificial 'numbers'. The numbers are use to: 1- provide an index into an array where the various personalities are recorded 2- identify the module (via an alias) which implements are particular personality. Neither of these uses really justify the existence of personality numbers. The array can be replaced by a linked list which is searched (array lookup only happens very rarely). Module identification can be done using an alias based on level rather than 'personality' number. The current 'raid5' modules support two level (4 and 5) but only one personality. This slight awkwardness (which was handled in the mapping from level to personality) can be better handled by allowing raid5 to register 2 personalities. With this change in place, the core md module does not need to have an exhaustive list of all possible personalities, so other personalities can be added independently. This patch also moves the check for chunksize being non-zero into the ->run routines for the personalities that need it, rather than having it in core-md. This has a side effect of allowing 'faulty' and 'linear' not to have a chunk-size set. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
