Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Stacking driver queue limits are typically bounded exclusively by the
capabilities of the low level devices, not by the stacking driver
itself.
This patch introduces blk_set_stacking_limits() which has more liberal
metrics than the default queue limits function. This allows us to
inherit topology parameters from bottom devices without manually
tweaking the default limits in each driver prior to calling the stacking
function.
Since there is now a clear distinction between stacking and low-level
devices, blk_set_default_limits() has been modified to carry the more
conservative values that we used to manually set in
blk_queue_make_request().
Acked-by: Mike Snitzer <snitzer@redhat.com>
Introduce DM_TARGET_IMMUTABLE to indicate that the target type cannot be mixed
with any other target type, and once loaded into a device, it cannot be
replaced with a table containing a different type.
The thin provisioning pool device will use this.
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Add a target feature flag DM_TARGET_ALWAYS_WRITEABLE to indicate that a target
does not support read-only mode.
The initial implementation of the thin provisioning target uses this.
Introduce the concept of a singleton table which contains exactly one target.
If a target type sets the DM_TARGET_SINGLETON feature bit device-mapper
will ensure that any table that includes that target contains no others.
The thin provisioning pool target uses this.
Allow QUEUE_FLAG_NONROT to propagate up the device stack if all
underlying devices are non-rotational. Tools like ureadahead will
schedule IOs differently based on the rotational flag.
With this patch, I see boot time go from 7.75 s to 7.46 s on my device.
Suggested-by: J. Richard Barnette <jrbarnette@chromium.org>
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Jens Axboe <jaxboe@fusionio.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: dm-devel@redhat.com
If optional discard support in dm-crypt is enabled, discards requests
bypass the crypt queue and blocks of the underlying device are discarded.
For the read path, discarded blocks are handled the same as normal
ciphertext blocks, thus decrypted.
So if the underlying device announces discarded regions return zeroes,
dm-crypt must disable this flag because after decryption there is just
random noise instead of zeroes.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Commit a63a5cf (dm: improve block integrity support) introduced a
two-phase initialization of a DM device's integrity profile. This
patch avoids dereferencing a NULL 'template_disk' pointer in
blk_integrity_register() if there is an integrity profile mismatch in
dm_table_set_integrity().
This can occur if the integrity profiles for stacked devices in a DM
table are changed between the call to dm_table_prealloc_integrity() and
Reported-by: Zdenek Kabelac <zkabelac@redhat.com>
Cc: stable@kernel.org # 2.6.39
DM has always advertised both REQ_FLUSH and REQ_FUA flush capabilities
regardless of whether or not a given DM device's underlying devices
also advertised a need for them.
Block's flush-merge changes from 2.6.39 have proven to be more costly
for DM devices. Performance regressions have been reported even when
DM's underlying devices do not advertise that they have a write cache.
Fix the performance regressions by configuring a DM device's flushing
capabilities based on those of the underlying devices' capabilities.
Move multipath target argument parsing code into dm-table so other
targets can share it.
Add a new flag DMF_MERGE_IS_OPTIONAL to struct mapped_device to indicate
whether the device can accept bios larger than the size its merge
function returns. When set, use this to send large bios to snapshots
which can split them if necessary. Snapshot I/O may be significantly
fragmented and this approach seems to improve peformance.
Before the patch, dm_set_device_limits restricted bio size to page size
if the underlying device had a merge function and the target didn't
provide a merge function. After the patch, dm_set_device_limits
restricts bio size to page size if the underlying device has a merge
function, doesn't have DMF_MERGE_IS_OPTIONAL flag and the target doesn't
The snapshot target can't provide a merge function because when the merge
function is called, it is impossible to determine where the bio will be
remapped. Previously this led us to impose a 4k limit, which we can
now remove if the snapshot store is located on a device without a merge
function. Together with another patch for optimizing full chunk writes,
it improves performance from 29MB/s to 40MB/s when writing to the
filesystem on snapshot store.
If the snapshot store is placed on a non-dm device with a merge function
(such as md-raid), device mapper still limits all bios to page size.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
There is no need for __table_get_device to be factored out.
Also move the exports to the end of their respective functions.
Use vzalloc() instead of vmalloc()+memset().
Remove 'discards_supported' from the dm_table structure. The same
information can be easily discovered from the table's target(s) in
dm_table_supports_discards().
Before this fix dm_table_supports_discards() would skip checking the
individual targets' 'discards_supported' flag if any one target in the
table didn't set num_discard_requests > 0. Now the per-target
'discards_supported' flag is effective at insuring the final DM device
advertises discard support. But, to be clear, targets that don't
support discards (!num_discard_requests) will not receive discard
requests.
Also DMWARN if a target sets 'discards_supported' override but forgets
to set 'num_discard_requests'.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
This patch adds a check that a block device has a request function
defined before it is used. Otherwise, misconfiguration can cause an oops.
Because we are allowing devices with zero size e.g. an offline multipath
device as in commit 2cd54d9bedb79a97f014e86c0da393416b264eb3
("dm: allow offline devices") there needs to be an additional check
to ensure devices are initialised. Some block devices, like a loop
device without a backing file, exist but have no request function.
Reproducer is trivial: dm-mirror on unbound loop device
(no backing file on loop devices)
dmsetup create x --table "0 8 mirror core 2 8 sync 2 /dev/loop0 0 /dev/loop1 0"
and mirror resync will immediatelly cause OOps.
BUG: unable to handle kernel NULL pointer dereference at (null)
? generic_make_request+0x2bd/0x590
? kmem_cache_alloc+0xad/0x190
submit_bio+0x53/0xe0
? bio_add_page+0x3b/0x50
dispatch_io+0x1ca/0x210 [dm_mod]
? read_callback+0x0/0xd0 [dm_mirror]
dm_io+0xbb/0x290 [dm_mod]
do_mirror+0x1e0/0x748 [dm_mirror]
Permit a target to support discards regardless of whether or not all its
underlying devices do.
The current block integrity (DIF/DIX) support in DM is verifying that
all devices' integrity profiles match during DM device resume (which
is past the point of no return). To some degree that is unavoidable
(stacked DM devices force this late checking). But for most DM
devices (which aren't stacking on other DM devices) the ideal time to
verify all integrity profiles match is during table load.
Introduce the notion of an "initialized" integrity profile: a profile
that was blk_integrity_register()'d with a non-NULL 'blk_integrity'
template. Add blk_integrity_is_initialized() to allow checking if a
profile was initialized.
Update DM integrity support to:
- check all devices with _initialized_ integrity profiles match
during table load; uninitialized profiles (e.g. for underlying DM
device(s) of a stacked DM device) are ignored.
- disallow a table load that would result in an integrity profile that
conflicts with a DM device's existing (in-use) integrity profile
- avoid clearing an existing integrity profile
- validate all integrity profiles match during resume; but if they
don't all we can do is report the mismatch (during resume we're past
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
MD and DM create a new bio_set for every metadevice. Each bio_set has an
integrity mempool attached regardless of whether the metadevice is
capable of passing integrity metadata. This is a waste of memory.
Instead we defer the allocation decision to MD and DM since we know at
metadevice creation time whether integrity passthrough is needed or not.
Automatic integrity mempool allocation can then be removed from
bioset_create() and we make an explicit integrity allocation for the
fs_bio_set.
Acked-by: Mike Snitzer <snizer@redhat.com>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Commit e09b457b (block: simplify holder symlink handling) incorrectly
assumed that there is only one link at maximum. dm may use multiple
links and expects block layer to track reference count for each link,
which is different from and unrelated to the exclusive device holder
identified by @holder when the device is opened.
Remove the single holder assumption and automatic removal of the link
and revive the per-link reference count tracking. The code
essentially behaves the same as before commit e09b457b sans the
unnecessary kobject reference count dancing.
While at it, note that this facility should not be used by anyone else
than the current ones. Sysfs symlinks shouldn't be abused like this
and the whole thing doesn't belong in the block layer at all.
Reported-by: Milan Broz <mbroz@redhat.com>
Cc: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Cc: linux-raid@vger.kernel.org
Cc: Kay Sievers <kay.sievers@vrfy.org>
Add per-target unplug callback support.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
DM currently implements congestion checking by checking on congestion
in each component device. For raid456 we need to also check if the
stripe cache is congested.
Add per-target congestion checker callback support.
Extending the target_callbacks structure with additional callback
functions allows for establishing multiple callbacks per-target (a
callback is also needed for unplug).
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
Implement blk_limits_max_hw_sectors() and make
blk_queue_max_hw_sectors() a wrapper around it.
DM needs this to avoid setting queue_limits' max_hw_sectors and
max_sectors directly. dm_set_device_limits() now leverages
blk_limits_max_hw_sectors() logic to establish the appropriate
max_hw_sectors minimum (PAGE_SIZE). Fixes issue where DM was
incorrectly setting max_sectors rather than max_hw_sectors (which
caused dm_merge_bvec()'s max_hw_sectors check to be ineffective).
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
After recent blkdev_get() modifications, open_by_devnum() and
open_bdev_exclusive() are simple wrappers around blkdev_get().
Replace them with blkdev_get_by_dev() and blkdev_get_by_path().
blkdev_get_by_dev() is identical to open_by_devnum().
blkdev_get_by_path() is slightly different in that it doesn't
automatically add %FMODE_EXCL to @mode.
All users are converted. Most conversions are mechanical and don't
introduce any behavior difference. There are several exceptions.
* btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no
reason to OR it explicitly on blkdev_put().
* gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in
sb->s_mode.
* With the above changes, sb->s_mode now always should contain
FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect
errors.
The new blkdev_get_*() functions are with proper docbook comments.
While at it, add function description to blkdev_get() too.
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Joern Engel <joern@lazybastard.org>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: reiserfs-devel@vger.kernel.org
Cc: xfs-masters@oss.sgi.com
Over time, block layer has accumulated a set of APIs dealing with bdev
open, close, claim and release.
* blkdev_get/put() are the primary open and close functions.
* bd_claim/release() deal with exclusive open.
* open/close_bdev_exclusive() are combination of open and claim and
the other way around, respectively.
* bd_link/unlink_disk_holder() to create and remove holder/slave
symlinks.
* open_by_devnum() wraps bdget() + blkdev_get().
The interface is a bit confusing and the decoupling of open and claim
makes it impossible to properly guarantee exclusive access as
in-kernel open + claim sequence can disturb the existing exclusive
open even before the block layer knows the current open if for another
exclusive access. Reorganize the interface such that,
* blkdev_get() is extended to include exclusive access management.
@holder argument is added and, if is @FMODE_EXCL specified, it will
gain exclusive access atomically w.r.t. other exclusive accesses.
* blkdev_put() is similarly extended. It now takes @mode argument and
if @FMODE_EXCL is set, it releases an exclusive access. Also, when
the last exclusive claim is released, the holder/slave symlinks are
removed automatically.
* bd_claim/release() and close_bdev_exclusive() are no longer
necessary and either made static or removed.
* bd_link_disk_holder() remains the same but bd_unlink_disk_holder()
is no longer necessary and removed.
* open_bdev_exclusive() becomes a simple wrapper around lookup_bdev()
and blkdev_get(). It also has an unexpected extra bdev_read_only()
test which probably should be moved into blkdev_get().
* open_by_devnum() is modified to take @holder argument and pass it to
blkdev_get().
Most of bdev open/close operations are unified into blkdev_get/put()
and most exclusive accesses are tested atomically at the open time (as
it should). This cleans up code and removes some, both valid and
invalid, but unnecessary all the same, corner cases.
open_bdev_exclusive() and open_by_devnum() can use further cleanup -
rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop
special features. Well, let's leave them for another day.
Most conversions are straight-forward. drbd conversion is a bit more
involved as there was some reordering, but the logic should stay the
same.
Acked-by: Neil Brown <neilb@suse.de>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Alex Elder <aelder@sgi.com>
Cc: drbd-dev@lists.linbit.com
Cc: Leo Chen <leochen@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Joern Engel <joern@logfs.org>
Code to manage symlinks in /sys/block/*/{holders|slaves} are overly
complex with multiple holder considerations, redundant extra
references to all involved kobjects, unused generic kobject holder
support and unnecessary mixup with bd_claim/release functionalities.
Strip it down to what's necessary (single gendisk holder) and make it
use a separate interface. This is a step for cleaning up
bd_claim/release. This patch makes dm-table slightly more complex but
it will be simplified again with further changes.
We have several users of min_not_zero, each of them using their own
definition. Move the define to kernel.h.
Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
Allow discards to be passed through to linear mappings if at least one
underlying device supports it. Discards will be forwarded only to
devices that support them.
A target that supports discards should set num_discard_requests to
indicate how many times each discard request must be submitted to it.
Verify table's underlying devices support discards prior to setting the
associated DM device as capable of discards (via QUEUE_FLAG_DISCARD).
Reviewed-by: Joe Thornber <thornber@redhat.com>
This change unifies the various checks and finalization that occurs on a
table prior to use. By doing so, it allows table construction without
traversing the dm-ioctl interface.
Signed-off-by: Will Drewry <wad@chromium.org>
Remove unused parameters(start and len) of dm_get_device()
and fix the callers.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Remove the dm_get() in dm_table_get_md() because dm_table_get_md() could
be called from presuspend/postsuspend, which are called while
mapped_device is in DMF_FREEING state, where dm_get() is not allowed.
Justification for that is the lifetime of both objects: As far as the
current dm design/implementation, mapped_device is never freed while
targets are doing something, because dm core waits for targets to become
quiet in dm_put() using presuspend/postsuspend. So targets should be
able to touch mapped_device without holding reference count of the
mapped_device, and we should allow targets to touch mapped_device even
if it is in DMF_FREEING state.
Backgrounds:
I'm trying to remove the multipath internal queue, since dm core now has
a generic queue for request-based dm. In the patch-set, the multipath
target wants to request dm core to start/stop queue. One of such
start/stop requests can happen during postsuspend() while the target
waits for pg-init to complete, because the target stops queue when
starting pg-init and tries to restart it when completing pg-init. Since
queue belongs to mapped_device, it involves calling dm_table_get_md()
and dm_put(). On the other hand, postsuspend() is called in dm_put()
for mapped_device which is in DMF_FREEING state, and that triggers
BUG_ON(DMF_FREEING) in the 2nd dm_put().
I had tried to solve this problem by changing only multipath not to
touch mapped_device which is in DMF_FREEING state, but I couldn't and I
came up with a question why we need dm_get() in dm_table_get_md().
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Make DM use bdev_stack_limits() function so that partition offsets get
taken into account when calculating alignment. Clarify stacking
warnings.
Also remove obsolete clearing of final alignment_offset and misalignment
flag.
Cc: Alasdair G. Kergon <agk@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm: (80 commits)
dm snapshot: use merge origin if snapshot invalid
dm snapshot: report merge failure in status
dm snapshot: merge consecutive chunks together
dm snapshot: trigger exceptions in remaining snapshots during merge
dm snapshot: delay merging a chunk until writes to it complete
dm snapshot: queue writes to chunks being merged
dm snapshot: add merging
dm snapshot: permit only one merge at once
dm snapshot: support barriers in snapshot merge target
dm snapshot: avoid allocating exceptions in merge
dm snapshot: rework writing to origin
dm snapshot: add merge target
dm exception store: add merge specific methods
dm snapshot: create function for chunk_is_tracked wait
dm snapshot: make bio optional in __origin_write
dm mpath: reject messages when device is suspended
dm: export suspended state to targets
dm: rename dm_suspended to dm_suspended_md
dm: swap target postsuspend call and setting suspended flag
dm crypt: add plain64 iv
Makes use of skip_spaces() defined in lib/string.c for removing leading
spaces from strings all over the tree.
It decreases lib.a code size by 47 bytes and reuses the function tree-wide:
64688 584 592 65864 10148 (TOTALS-BEFORE)
64641 584 592 65817 10119 (TOTALS-AFTER)
Also, while at it, if we see (*str && isspace(*str)), we can be sure to
remove the first condition (*str) as the second one (isspace(*str)) also
evaluates to 0 whenever *str == 0, making it redundant. In other words,
"a char equals zero is never a space".
Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below,
and found occurrences of this pattern on 3 more files:
drivers/leds/led-class.c
drivers/leds/ledtrig-timer.c
drivers/video/output.c
expression str;
( // ignore skip_spaces cases
while (*str && isspace(*str)) { \(str++;\|++str;\) }
- *str &&
isspace(*str)
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Cc: Julia Lawall <julia@diku.dk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: <linux-ext4@vger.kernel.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Takashi Iwai <tiwai@suse.de>
When replacing a mapped device's table during a 'resume', delay the
destruction of the old table until the new one is successfully in place.
This will make it easier for a later patch to transfer internal state
information from the old table to the new one (something we do not currently
support) while giving us more options for reversion if a later part
of the operation fails.
Devices are always in the suspended state during dm_swap_table().
This patch reinforces the requirement that all I/O must have been
flushed from the table targets while in this state (including any in
workqueues). In the case of 'noflush' suspending, unprocessed
I/O should have been 'pushed back' to the dm core prior to this point,
for resubmission after the new table is in place.
Set sensible I/O hints for striped DM devices in the topology
infrastructure added for 2.6.31 for userspace tools to
obtain via sysfs.
Add .io_hints to 'struct target_type' to allow the I/O hints portion
(io_min and io_opt) of the 'struct queue_limits' to be set by each
target and implement this for dm-stripe.
A couple of recent warning messages make it difficult for the reader to
determine exactly what is wrong. This patch adds more information to
those messages.
The messages were added by these commits:
5dea271b6d87bd1d79a59c1d5baac2596a841c37 ("dm table: pass correct dev area size
to device_area_is_valid")
ea9df47cc92573b159ef3b4fda516c32cba9c4fd ("dm table: fix blk_stack_limits arg
to use bytes not sectors")
The patch also corrects references to logical_block_size in printk format
strings from %hu to %u.
The logic to check for valid device areas is inverted relative to proper
use with iterate_devices.
The iterate_devices method calls its callback for every underlying
device in the target. If any callback returns non-zero, iterate_devices
exits immediately. But the callback device_area_is_valid() returns 0 on
error and 1 on success. The overall effect without is that an error is
issued only if every device is invalid.
This patch renames device_area_is_valid to device_area_is_invalid and
inverts the logic so that one invalid device is sufficient to raise
an error.
Incorrect device area lengths are being passed to device_area_is_valid().
The regression appeared in 2.6.31-rc1 through commit
754c5fc7ebb417b23601a6222a6005cc2e7f2913.
With the dm-stripe target, the size of the target (ti->len) was used
instead of the stripe_width (ti->len/#stripes). An example of a
consequent incorrect error message is:
device-mapper: table: 254:0: sdb too small for target
This patch removes DM's bio-based vs request-based conditional setting
of next_ordered. For bio-based DM the next_ordered check is no longer a
concern (as that check is now in the __make_request path). For
request-based DM the default of QUEUE_ORDERED_NONE is now appropriate.
bio-based DM was changed to work-around the previously misplaced
next_ordered check with this commit:
99360b4c18f7675b50d283301d46d755affe75fd
request-based DM does not yet support barriers but reacted to the above
bio-based DM change with this commit:
5d67aa2366ccb8257d103d0b43df855605c3c086
The above changes are no longer needed given Neil Brown's recent fix to
put the next_ordered check in the __make_request path:
db64f680ba4b5c56c4be59f0698000df89ff0281
Cc: NeilBrown <neilb@suse.de>
Acked-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Acked-by: Mikulas Patocka <mpatocka@redhat.com>
The offset passed to blk_stack_limits() must be in bytes not sectors.
Fixes false warnings like the following:
device-mapper: table: 254:1: target device sda6 is misaligned
Reported-by: Frans Pop <elendil@planet.nl>
Tested-by: Frans Pop <elendil@planet.nl>
Request-based dm doesn't have barrier support yet.
So we need to set QUEUE_ORDERED_DRAIN only for bio-based dm.
Since the device type is decided at the first table loading time,
the flag set is deferred until then.
Acked-by: Hannes Reinecke <hare@suse.de>
This patch enables request-based dm.
o Request-based dm and bio-based dm coexist, since there are
some target drivers which are more fitting to bio-based dm.
Also, there are other bio-based devices in the kernel
(e.g. md, loop).
Since bio-based device can't receive struct request,
there are some limitations on device stacking between
bio-based and request-based.
type of underlying device
bio-based request-based
bio-based OK OK
request-based -- OK
The device type is recognized by the queue flag in the kernel,
so dm follows that.
o The type of a dm device is decided at the first table binding time.
Once the type of a dm device is decided, the type can't be changed.
o Mempool allocations are deferred to at the table loading time, since
mempools for request-based dm are different from those for bio-based
dm and needed mempool type is fixed by the type of table.
o Currently, request-based dm supports only tables that have a single
target. To support multiple targets, we need to support request
splitting or prevent bio/request from spanning multiple targets.
The former needs lots of changes in the block layer, and the latter
needs that all target drivers support merge() function.
Both will take a time.
This patch adds core functions for request-based dm.
When struct mapped device (md) is initialized, md->queue has
an I/O scheduler and the following functions are used for
request-based dm as the queue functions:
make_request_fn: dm_make_request()
pref_fn: dm_prep_fn()
request_fn: dm_request_fn()
softirq_done_fn: dm_softirq_done()
lld_busy_fn: dm_lld_busy()
Actual initializations are done in another patch (PATCH 2).
Below is a brief summary of how request-based dm behaves, including:
- making request from bio
- cloning, mapping and dispatching request
- completing request and bio
- suspending md
- resuming md
bio to request
md->queue->make_request_fn() (dm_make_request()) calls __make_request()
for a bio submitted to the md.
Then, the bio is kept in the queue as a new request or merged into
another request in the queue if possible.
Cloning and Mapping
Cloning and mapping are done in md->queue->request_fn() (dm_request_fn()),
when requests are dispatched after they are sorted by the I/O scheduler.
dm_request_fn() checks busy state of underlying devices using
target's busy() function and stops dispatching requests to keep them
on the dm device's queue if busy.
It helps better I/O merging, since no merge is done for a request
once it is dispatched to underlying devices.
Actual cloning and mapping are done in dm_prep_fn() and map_request()
called from dm_request_fn().
dm_prep_fn() clones not only request but also bios of the request
so that dm can hold bio completion in error cases and prevent
the bio submitter from noticing the error.
(See the "Completion" section below for details.)
After the cloning, the clone is mapped by target's map_rq() function
and inserted to underlying device's queue using
blk_insert_cloned_request().
Completion
Request completion can be hooked by rq->end_io(), but then, all bios
in the request will have been completed even error cases, and the bio
submitter will have noticed the error.
To prevent the bio completion in error cases, request-based dm clones
both bio and request and hooks both bio->bi_end_io() and rq->end_io():
bio->bi_end_io(): end_clone_bio()
rq->end_io(): end_clone_request()
Summary of the request completion flow is below:
blk_end_request() for a clone request
=> blk_update_request()
=> bio->bi_end_io() == end_clone_bio() for each clone bio
=> Free the clone bio
=> Success: Complete the original bio (blk_update_request())
Error: Don't complete the original bio
=> blk_finish_request()
=> rq->end_io() == end_clone_request()
=> blk_complete_request()
=> dm_softirq_done()
=> Free the clone request
=> Success: Complete the original request (blk_end_request())
Error: Requeue the original request
end_clone_bio() completes the original request on the size of
the original bio in successful cases.
Even if all bios in the original request are completed by that
completion, the original request must not be completed yet to keep
the ordering of request completion for the stacking.
So end_clone_bio() uses blk_update_request() instead of
blk_end_request().
In error cases, end_clone_bio() doesn't complete the original bio.
It just frees the cloned bio and gives over the error handling to
end_clone_request().
end_clone_request(), which is called with queue lock held, completes
the clone request and the original request in a softirq context
(dm_softirq_done()), which has no queue lock, to avoid a deadlock
issue on submission of another request during the completion:
- The submitted request may be mapped to the same device
- Request submission requires queue lock, but the queue lock
has been held by itself and it doesn't know that
The clone request has no clone bio when dm_softirq_done() is called.
So target drivers can't resubmit it again even error cases.
Instead, they can ask dm core for requeueing and remapping
the original request in that cases.
suspend
Request-based dm uses stopping md->queue as suspend of the md.
For noflush suspend, just stops md->queue.
For flush suspend, inserts a marker request to the tail of md->queue.
And dispatches all requests in md->queue until the marker comes to
the front of md->queue. Then, stops dispatching request and waits
for the all dispatched requests to complete.
After that, completes the marker request, stops md->queue and
wake up the waiter on the suspend queue, md->wait.
resume
Starts md->queue.
Currently, device-mapper maintains a separate instance of 'struct
queue_limits' for each table of each device. When the configuration of
a device is to be changed, first its table is loaded and this structure
is populated, then the device is 'resumed' and the calculated
queue_limits are applied.
This places restrictions on how userspace may process related devices,
where it is often advantageous to 'load' tables for several devices
at once before 'resuming' them together. As the new queue_limits
only take effect after the 'resume', if they are changing and one
device uses another, the latter must be 'resumed' before the former
may be 'loaded'.
This patch moves the calculation of these queue_limits out of
the 'load' operation into 'resume'. Since we are no longer
pre-calculating this struct, we no longer need to maintain copies
within our dm structs.
dm_set_device_limits() now passes the 'start' of the device's
data area (aka pe_start) as the 'offset' to blk_stack_limits().
init_valid_queue_limits() is replaced by blk_set_default_limits().
Cc: martin.petersen@oracle.com
Copy the table's queue_limits to the DM device's request_queue. This
properly initializes the queue's topology limits and also avoids having
to track the evolution of 'struct queue_limits' in
dm_table_set_restrictions()
Also fixes a bug that was introduced in dm_table_set_restrictions() via
commit ae03bf639a5027d27270123f5f6e3ee6a412781d. In addition to
establishing 'bounce_pfn' in the queue's limits blk_queue_bounce_limit()
also performs an allocation to setup the ISA DMA pool. This allocation
resulted in "sleeping function called from invalid context" when called
from dm_table_set_restrictions().
Use blk_stack_limits() to stack block limits (including topology) rather
than duplicate the equivalent within Device Mapper.
