path: root/drivers/md/dm-linear.c
2009-07-23dm table: pass correct dev area size to device_area_is_validMike Snitzer
Incorrect device area lengths are being passed to device_area_is_valid(). The regression appeared in 2.6.31-rc1 through commit 754c5fc7ebb417b23601a6222a6005cc2e7f2913. With the dm-stripe target, the size of the target (ti->len) was used instead of the stripe_width (ti->len/#stripes). An example of a consequent incorrect error message is: device-mapper: table: 254:0: sdb too small for target Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-06-22dm target:s introduce iterate devices fnMike Snitzer
Add .iterate_devices to 'struct target_type' to allow a function to be called for all devices in a DM target. Implemented it for all targets except those in dm-snap.c (origin and snapshot). (The raid1 version number jumps to 1.12 because we originally reserved 1.1 to 1.11 for 'block_on_error' but ended up using 'handle_errors' instead.) Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: martin.petersen@oracle.com
2009-06-22dm: linear support flushMikulas Patocka
Flush support for the linear target. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-09dm: remove limited barrier supportMikulas Patocka
Prepare for full barrier implementation: first remove the restricted support. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: support barriers on simple devicesAndi Kleen
Implement barrier support for single device DM devices This patch implements barrier support in DM for the common case of dm linear just remapping a single underlying device. In this case we can safely pass the barrier through because there can be no reordering between devices. NB. Any DM device might cease to support barriers if it gets reconfigured so code must continue to allow for a possible -EOPNOTSUPP on every barrier bio submitted. - agk Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-01-06dm: consolidate target deregistration error handlingMikulas Patocka
Change dm_unregister_target to return void and use BUG() for error reporting. dm_unregister_target can only fail because of programming bug in the target driver. It can't fail because of user's behavior or disk errors. This patch changes unregister_target to return void and use BUG if someone tries to unregister non-registered target or unregister target that is in use. This patch removes code duplication (testing of error codes in all dm targets) and reports bugs in just one place, in dm_unregister_target. In some target drivers, these return codes were ignored, which could lead to a situation where bugs could be missed. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdevLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/bdev: (66 commits) [PATCH] kill the rest of struct file propagation in block ioctls [PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSET [PATCH] get rid of blkdev_locked_ioctl() [PATCH] get rid of blkdev_driver_ioctl() [PATCH] sanitize blkdev_get() and friends [PATCH] remember mode of reiserfs journal [PATCH] propagate mode through swsusp_close() [PATCH] propagate mode through open_bdev_excl/close_bdev_excl [PATCH] pass fmode_t to blkdev_put() [PATCH] kill the unused bsize on the send side of /dev/loop [PATCH] trim file propagation in block/compat_ioctl.c [PATCH] end of methods switch: remove the old ones [PATCH] switch sr [PATCH] switch sd [PATCH] switch ide-scsi [PATCH] switch tape_block [PATCH] switch dcssblk [PATCH] switch dasd [PATCH] switch mtd_blkdevs [PATCH] switch mmc ...
2008-10-21dm: remove dm header from targetsMikulas Patocka
Change #include "dm.h" to #include <linux/device-mapper.h> in all targets. Targets should not need direct access to internal DM structures. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-21[PATCH] introduce __blkdev_driver_ioctl()Al Viro
Analog of blkdev_driver_ioctl() with sane arguments. For now uses fake struct file, by the end of the series it won't and blkdev_driver_ioctl() will become a wrapper around it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] lose unused arguments in dm ioctl callbacksAl Viro
2008-07-21dm: linear add mergeMilan Broz
This patch implements biovec merge function for linear target. If the underlying device has merge function defined, call it. If not, keep precomputed value. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2006-12-08[PATCH] dm: map and endio symbolic return codesKiyoshi Ueda
Update existing targets to use the new symbols for return values from target map and end_io functions. There is no effect on behaviour. Test results: Done build test without errors. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: dm-devel@redhat.com Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert mdJosef Sipek
2006-10-03[PATCH] dm: support ioctls on mapped devices: fix with fake fileMilan Broz
The new ioctl code passes the wrong file pointer to the underlying device. No file pointer is available so make a temporary fake one. ioctl_by_bdev() does set_fs(KERNEL_DS) so it's for ioctls originating within the kernel and unsuitable here. We are processing ioctls that originated in userspace and mapping them to different devices. Fixing the existing callers that pass a NULL file struct and consolidating the fake_file users are separate matters to solve in later patches. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm: export blkdev_driver_ioctlAlasdair G Kergon
Export blkdev_driver_ioctl for device-mapper. If we get as far as the device-mapper ioctl handler, we know the ioctl is not a standard block layer BLK* one, so we don't need to check for them a second time and can call blkdev_driver_ioctl() directly. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] dm linear: support ioctlsMilan Broz
When an ioctl is performed on a device with a linear target, simply pass it on to the underlying block device. Note that the ioctl will pass through the filtering in blkdev_ioctl() twice. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] dm: improve error message consistencyAlasdair G Kergon
Tidy device-mapper error messages to include context information automatically. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm: remove SECTOR_FORMATAndrew Morton
We don't know what type sector_t has. Sometimes it's unsigned long, sometimes it's unsigned long long. For example on ppc64 it's unsigned long with CONFIG_LBD=n and on x86_64 it's unsigned long long with CONFIG_LBD=n. The way to handle all of this is to always use unsigned long long and to always typecast the sector_t when printing it. Acked-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
