path: root/drivers/md/dm-kcopyd.c
2009-04-09dm kcopyd: fix callback raceMikulas Patocka
If the thread calling dm_kcopyd_copy is delayed due to scheduling inside split_job/segment_complete and the subjobs complete before the loop in split_job completes, the kcopyd callback could be invoked from the thread that called dm_kcopyd_copy instead of the kcopyd workqueue. dm_kcopyd_copy -> split_job -> segment_complete -> job->fn() Snapshots depend on the fact that callbacks are called from the singlethreaded kcopyd workqueue and expect that there is no racing between individual callbacks. The racing between callbacks can lead to corruption of exception store and it can also mean that exception store callbacks are called twice for the same exception - a likely reason for crashes reported inside pending_complete() / remove_exception(). This patch fixes two problems: 1. job->fn being called from the thread that submitted the job (see above). - Fix: hand over the completion callback to the kcopyd thread. 2. job->fn(read_err, write_err, job->context); in segment_complete reports the error of the last subjob, not the union of all errors. - Fix: pass job->write_err to the callback to report all error bits (it is done already in run_complete_job) Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-04-09dm kcopyd: prepare for callback race fixMikulas Patocka
Use a variable in segment_complete() to point to the dm_kcopyd_client struct and only release job->pages in run_complete_job() if any are defined. These changes are needed by the next patch. Cc: stable@kernel.org Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2009-02-18block: fix bad definition of BIO_RW_SYNCJens Axboe
We can't OR shift values, so get rid of BIO_RW_SYNC and use BIO_RW_SYNCIO and BIO_RW_UNPLUG explicitly. This brings back the behaviour from before 213d9417fec62ef4c3675621b9364a667954d4dd. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-21dm: remove dm header from targetsMikulas Patocka
Change #include "dm.h" to #include <linux/device-mapper.h> in all targets. Targets should not need direct access to internal DM structures. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-10-21dm kcopyd: avoid queue shuffleKazuo Ito
Write throughput to LVM snapshot origin volume is an order of magnitude slower than those to LV without snapshots or snapshot target volumes, especially in the case of sequential writes with O_SYNC on. The following patch originally written by Kevin Jamieson and Jan Blunck and slightly modified for the current RCs by myself tries to improve the performance by modifying the behaviour of kcopyd, so that it pushes back an I/O job to the head of the job queue instead of the tail as process_jobs() currently does when it has to wait for free pages. This way, write requests aren't shuffled to cause extra seeks. I tested the patch against 2.6.27-rc5 and got the following results. The test is a dd command writing to snapshot origin followed by fsync to the file just created/updated. A couple of filesystem benchmarks gave me similar results in case of sequential writes, while random writes didn't suffer much. dd if=/dev/zero of=<somewhere on snapshot origin> bs=4096 count=... [conv=notrunc when updating] 1) linux 2.6.27-rc5 without the patch, write to snapshot origin, average throughput (MB/s) 10M 100M 1000M create,dd 511.46 610.72 11.81 create,dd+fsync 7.10 6.77 8.13 update,dd 431.63 917.41 12.75 update,dd+fsync 7.79 7.43 8.12 compared with write throughput to LV without any snapshots, all dd+fsync and 1000 MiB writes perform very poorly. 10M 100M 1000M create,dd 555.03 608.98 123.29 create,dd+fsync 114.27 72.78 76.65 update,dd 152.34 1267.27 124.04 update,dd+fsync 130.56 77.81 77.84 2) linux 2.6.27-rc5 with the patch, write to snapshot origin, average throughput (MB/s) 10M 100M 1000M create,dd 537.06 589.44 46.21 create,dd+fsync 31.63 29.19 29.23 update,dd 487.59 897.65 37.76 update,dd+fsync 34.12 30.07 26.85 Although still not on par with plain LV performance - cannot be avoided because it's copy on write anyway - this simple patch successfully improves throughtput of dd+fsync while not affecting the rest. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Kazuo Ito <ito.kazuo@oss.ntt.co.jp> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Cc: stable@kernel.org
2008-04-25dm: unplug queues in threadsMikulas Patocka
Remove an avoidable 3ms delay on some dm-raid1 and kcopyd I/O. It is specified that any submitted bio without BIO_RW_SYNC flag may plug the queue (i.e. block the requests from being dispatched to the physical device). The queue is unplugged when the caller calls blk_unplug() function. Usually, the sequence is that someone calls submit_bh to submit IO on a buffer. The IO plugs the queue and waits (to be possibly joined with other adjacent bios). Then, when the caller calls wait_on_buffer(), it unplugs the queue and submits the IOs to the disk. This was happenning: When doing O_SYNC writes, function fsync_buffers_list() submits a list of bios to dm_raid1, the bios are added to dm_raid1 write queue and kmirrord is woken up. fsync_buffers_list() calls wait_on_buffer(). That unplugs the queue, but there are no bios on the device queue as they are still in the dm_raid1 queue. wait_on_buffer() starts waiting until the IO is finished. kmirrord is scheduled, kmirrord takes bios and submits them to the devices. The submitted bio plugs the harddisk queue but there is no one to unplug it. (The process that called wait_on_buffer() is already sleeping.) So there is a 3ms timeout, after which the queues on the harddisks are unplugged and requests are processed. This 3ms timeout meant that in certain workloads (e.g. O_SYNC, 8kb writes), dm-raid1 is 10 times slower than md raid1. Every time we submit something asynchronously via dm_io, we must unplug the queue actually to send the request to the device. This patch adds an unplug call to kmirrord - while processing requests, it keeps the queue plugged (so that adjacent bios can be merged); when it finishes processing all the bios, it unplugs the queue to submit the bios. It also fixes kcopyd which has the same potential problem. All kcopyd requests are submitted with BIO_RW_SYNC. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-25dm: move include filesAlasdair G Kergon
Publish the dm-io, dm-log and dm-kcopyd headers in include/linux. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-04-25dm kcopyd: renameAlasdair G Kergon
Rename kcopyd.[ch] to dm-kcopyd.[ch]. Signed-off-by: Alasdair G Kergon <agk@redhat.com>
