path: root/drivers/macintosh/smu.c
2015-03-25drivers/macintosh: Delete an unnecessary check before the function call ↵Markus Elfring
"of_node_put" The of_node_put() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-10-20macintosh: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-24powerpc/macintosh/smu.c: Fix closing brace followed by ifRasmus Villemoes
A closing brace followed by "if" is almost certainly a mistake. Maybe "else if" was meant, but in this case it doesn't really matter. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-04-23powerpc/pmac/smu: Use %*ph to print small buffersAndy Shevchenko
Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-12-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlight is probably some base POWER8 support. There's more to come such as transactional memory support but that will wait for the next one. Overall it's pretty quiet, or rather I've been pretty poor at picking things up from patchwork and reviewing them this time around and Kumar no better on the FSL side it seems..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (73 commits) powerpc+of: Rename and fix OF reconfig notifier error inject module powerpc: mpc5200: Add a3m071 board support powerpc/512x: don't compile any platform DIU code if the DIU is not enabled powerpc/mpc52xx: use module_platform_driver macro powerpc+of: Export of_reconfig_notifier_[register,unregister] powerpc/dma/raidengine: add raidengine device powerpc/iommu/fsl: Add PAMU bypass enable register to ccsr_guts struct powerpc/mpc85xx: Change spin table to cached memory powerpc/fsl-pci: Add PCI controller ATMU PM support powerpc/86xx: fsl_pcibios_fixup_bus requires CONFIG_PCI drivers/virt: the Freescale hypervisor driver doesn't need to check MSR[GS] powerpc/85xx: p1022ds: Use NULL instead of 0 for pointers powerpc: Disable relocation on exceptions when kexecing powerpc: Enable relocation on during exceptions at boot powerpc: Move get_longbusy_msecs into hvcall.h and remove duplicate function powerpc: Add wrappers to enable/disable relocation on exceptions powerpc: Add set_mode hcall powerpc: Setup relocation on exceptions for bare metal systems powerpc: Move initial mfspr LPCR out of __init_LPCR powerpc: Add relocation on exception vector handlers ...
2012-12-11bootmem: fix wrong call parameter for free_bootmem()Joonsoo Kim
It is strange that alloc_bootmem() returns a virtual address and free_bootmem() requires a physical address. Anyway, free_bootmem()'s first parameter should be physical address. There are some call sites for free_bootmem() with virtual address. So fix them. [akpm@linux-foundation.org: improve free_bootmem() and free_bootmem_pate() documentation] Signed-off-by: Joonsoo Kim <js1304@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-15powerpc+of: Rename the drivers/of prom_* functions to of_*Nathan Fontenot
Rename the prom_*_property routines of the generic OF code to of_*_property. This brings them in line with the naming used by the rest of the OF code. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Acked-by: Geoff Levand <geoff@infradead.org> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-05drivers/macintosh/smu.c: Replace abs_to_virt() with __va()Michael Ellerman
abs_to_virt() is just a wrapper around __va(), call __va() directly. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-12-21driver-core: remove sysdev.h usage.Kay Sievers
The sysdev.h file should not be needed by any in-kernel code, so remove the .h file from these random files that seem to still want to include it. The sysdev code will be going away soon, so this include needs to be removed no matter what. Cc: Jiandong Zheng <jdzheng@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: "Venkatesh Pallipadi Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2011-02-28dt/powerpc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/powerpc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-15mac: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@ozlabs.org
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-04-07powerpc/pmac: Add missing unlocks in error pathJulia Lawall
In some error handling cases the lock is not unlocked. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression E1; identifier f; @@ f (...) { <+... * spin_lock_irqsave (E1,...); ... when != E1 * return ...; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-15powerpc/macintosh: Make Open Firmware device id constantMárton Németh
The match_table field of the struct of_device_id is constant in <linux/of_platform.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-15Merge commit '85082fd7cbe3173198aac0eb5e85ab1edcc6352c' into test-buildBenjamin Herrenschmidt
Manual fixup of: arch/powerpc/Kconfig
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-01drivers/macintosh/smu.c: Improve error handlingJulia Lawall
This makes two changes: * As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem never returns NULL and always returns a zeroed region of memory. Thus the error checking code and memset after the call to alloc_bootmem are not necessary. * The old error handling code consisted of setting a global variable to NULL and returning an error code, which could cause previously allocated resources never to be freed. The patch adds calls to appropriate resource deallocation functions. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-30macintosh: Use linux/of_{device,platform}.h instead of asmStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-20macintosh-smu: BKL pushdownArnd Bergmann
2008-06-16[POWERPC] Add missing of_node_put in drivers/macintosh/smu.cJulia Lawall
of_node_put is needed before discarding a value received from of_find_node_by_type, eg in error handling code. The semantic patch that makes the change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct device_node *n; struct device_node *n1; struct device_node *n2; statement S; identifier f1,f2; expression E1,E2; constant C; @@ n = of_find_node_by_type(...) ... if (!n) S ... when != of_node_put(n) when != n1 = f1(n,...) when != E1 = n when any when strict ( + of_node_put(n); return -C; | of_node_put(n); | n2 = f2(n,...) | E2 = n | return ...; ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-08[POWERPC] Disable G5 NAP mode during SMU commands on U3Benjamin Herrenschmidt
It appears that with the U3 northbridge, if the processor is in NAP mode the whole time while waiting for an SMU command to complete, then the SMU will fail. It could be related to the weird backward mechanism the SMU uses to get to system memory via i2c to the northbridge that doesn't operate properly when the said bridge is in napping along with the CPU. That is on U3 at least, U4 doesn't seem to be affected. This didn't show before NO_HZ as the timer wakeup was enough to make it work it seems, but that is no longer the case. This fixes it by disabling NAP mode on those machines while an SMU command is in flight. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-03drivers/macintosh/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07[POWERPC] Rename device_is_compatible to of_device_is_compatibleStephen Rothwell
for consistency with other Open Firmware interfaces (and Sparc). This is just a straight replacement. This leaves the compatibility define in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-27[POWERPC] Rename get_property to of_get_property: partial driversStephen Rothwell
This does drivers/machintosh and the hvc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-17drivers/macintosh/smu.c: fix locking snafuAndrew Morton
It got its lock and unlock backwards. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=8334 (obviously, this code could be using plain old spin_lock_irq(), too) Cc: <matthias.kaehlcke@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
2007-04-13[POWERPC] Make struct property's value a void *Stephen Rothwell
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/ata/libata-scsi.c include/linux/libata.h Futher merge of Linus's head and compilation fixups. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[POWERPC] Souped-up of_platform_device supportBenjamin Herrenschmidt
This patch first splits of_device.c and of_platform.c, the later containing the bits relative to of_platform_device's. On the "breaks" side of things, drivers uisng of_platform_device(s) need to include asm/of_platform.h now and of_(un)register_driver is now of_(un)register_platform_driver. In addition to a few utility functions to locate of_platform_device(s), the main new addition is of_platform_bus_probe() which allows the platform code to trigger an automatic creation of of_platform_devices for a whole tree of devices. The function acts based on the type of the various "parent" devices encountered from a provided root, using either a default known list of bus types that can be "probed" or a passed-in list. It will only register devices on busses matching that list, which mean that typically, it will not register PCI devices, as expected (since they will be picked up by the PCI layer). This will be used by Cell platforms using 4xx-type IOs in the Axon bridge and can be used by any embedded-type device as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-01Merge branch 'merge'Paul Mackerras
2006-07-31[POWERPC] powermac: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powermac platform & macintosh driver changes. Built for pmac32_defconfig, g5_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-10[PATCH] powerpc: fix SMU driver interrupt mappingBenjamin Herrenschmidt
The SMU driver tries to map an interrupt from the device-tree before the interrupt controllers in the machine have been enumerated. This doesn't work properly and cause machines like the Quad g5 to fail booting later on when some drivers waits endlessly for an SMU request to complete. This is the second problem preventing boot on the Quad g5. This fixes it and also makes the SMU driver a bit more resilient to not having an interrupt. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[POWERPC] Add new interrupt mapping core and change platforms to use itBenjamin Herrenschmidt
This adds the new irq remapper core and removes the old one. Because there are some fundamental conflicts with the old code, like the value of NO_IRQ which I'm now setting to 0 (as per discussions with Linus), etc..., this commit also changes the relevant platform and driver code over to use the new remapper (so as not to cause difficulties later in bisecting). This patch removes the old pre-parsing of the open firmware interrupt tree along with all the bogus assumptions it made to try to renumber interrupts according to the platform. This is all to be handled by the new code now. For the pSeries XICS interrupt controller, a single remapper host is created for the whole machine regardless of how many interrupt presentation and source controllers are found, and it's set to match any device node that isn't a 8259. That works fine on pSeries and avoids having to deal with some of the complexities of split source controllers vs. presentation controllers in the pSeries device trees. The powerpc i8259 PIC driver now always requests the legacy interrupt range. It also has the feature of being able to match any device node (including NULL) if passed no device node as an input. That will help porting over platforms with broken device-trees like Pegasos who don't have a proper interrupt tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] powerpc: tidy-up of_register_driver()/driver_register() return valuesBjorn Helgaas
Remove the assumption that driver_register() returns the number of devices bound to the driver. In fact, it returns zero for success or a negative error value. Nobody uses the return value of of_register_driver() anyway. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
