path: root/drivers/lguest
2009-03-30lguest: use bool instead of intMatias Zabaljauregui
Impact: clean up Rusty told me, some time ago, that he had become a fan of "bool". So, here are some replacements. Signed-off-by: Matias Zabaljauregui <zabaljauregui at gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-30lguest: use KVM hypercallsMatias Zabaljauregui
Impact: cleanup This patch allow us to use KVM hypercalls Signed-off-by: Matias Zabaljauregui <zabaljauregui at gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-30lguest: fix spurious BUG_ON() on invalid guest stack.Rusty Russell
Impact: fix crash on misbehaving guest gpte_addr() contains a BUG_ON(), insisting that the present flag is set. We need to return before we call it if that isn't the case. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2009-03-27Merge branch 'core/percpu' into percpu-cpumask-x86-for-linus-2Ingo Molnar
Conflicts: arch/parisc/kernel/irq.c arch/x86/include/asm/fixmap_64.h arch/x86/include/asm/setup.h kernel/irq/handle.c Semantic merge: arch/x86/include/asm/fixmap.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-09lguest: fix for CONFIG_SPARSE_IRQ=yRusty Russell
Impact: remove lots of lguest boot WARN_ON() when CONFIG_SPARSE_IRQ=y We now need to call irq_to_desc_alloc_cpu() before set_irq_chip_and_handler_name(), but we can't do that from init_IRQ (no kmalloc available). So do it as we use interrupts instead. Also means we only alloc for irqs we use, which was the intent of CONFIG_SPARSE_IRQ anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2009-02-23x86: remove the Voyager 32-bit subarchIngo Molnar
Impact: remove unused/broken code The Voyager subarch last built successfully on the v2.6.26 kernel and has been stale since then and does not build on the v2.6.27, v2.6.28 and v2.6.29-rc5 kernels. No actual users beyond the maintainer reported this breakage. Patches were sent and most of the fixes were accepted but the discussion around how to do a few remaining issues cleanly fizzled out with no resolution and the code remained broken. In the v2.6.30 x86 tree development cycle 32-bit subarch support has been reworked and removed - and the Voyager code, beyond the build problems already known, needs serious and significant changes and probably a rewrite to support it. CONFIG_X86_VOYAGER has been marked BROKEN then. The maintainer has been notified but no patches have been sent so far to fix it. While all other subarchs have been converted to the new scheme, voyager is still broken. We'd prefer to receive patches which clean up the current situation in a constructive way, but even in case of removal there is no obstacle to add that support back after the issues have been sorted out in a mutually acceptable fashion. So remove this inactive code for now. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-30lguest: Fix a memory leak with the lg object during launcher closeMark Wallis
Fix a memory leak identified by Rusty Russell during LCA09 by kfree'ing the lg object instead of just clearing it when the launcher closes. Signed-off-by: Mark Wallis <mwallis@serialmonkey.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-30lguest: typos fixAtsushi SAKAI
3 points lguest_asm.S => i386_head.S LHCALL_BREAK => LHREQ_BREAK perferred => preferred Signed-off-by: Atsushi SAKAI <sakaia@jp.fujitsu.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-06lguest: do not statically allocate root deviceMark McLoughlin
We shouldn't be statically allocating the root device object, so dynamically allocate it using root_device_register() instead. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-30lguest: struct device - replace bus_id with dev_name()Mark McLoughlin
bus_id is gradually being removed, so use dev_name() instead. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-30lguest: move the initial guest page table creation code to the hostMatias Zabaljauregui
This patch moves the initial guest page table creation code to the host, so the launcher keeps working with PAE enabled configs. Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-30virtio: hand virtio ring alignment as argument to vring_new_virtqueueRusty Russell
This allows each virtio user to hand in the alignment appropriate to their virtio_ring structures. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
2008-12-30virtio: use LGUEST_VRING_ALIGN instead of relying on pagesizeRusty Russell
This doesn't really matter, since lguest is i386 only at the moment, but we could actually choose a different value. (lguest doesn't have a guarenteed ABI). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-23x86: fix lguest used_vectors breakage, -v2Yinghai Lu
Impact: fix lguest, clean up 32-bit lguest used used_vectors to record vectors, but that model of allocating vectors changed and got broken, after we changed vector allocation to a per_cpu array. Try enable that for 64bit, and the array is used for all vectors that are not managed by vector_irq per_cpu array. Also kill system_vectors[], that is now a duplication of the used_vectors bitmap. [ merged in cpus4096 due to io_apic.c cpumask changes. ] [ -v2, fix build failure ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-26lguest: update commentryRusty Russell
2008-08-12lguest: use get_user_pages_fast() instead of get_user_pages()Rusty Russell
Using a simple page table thrashing program I measure a slight improvement. The program creates five processes. Each touches 1000 pages then schedules the next process. We repeat this 1000 times. As lguest only caches 4 cr3 values, this rebuilds a lot of shadow page tables requiring virt->phys mappings. Before: 5.93 seconds After: 5.40 seconds (Counts of slow vs fastpath in this usage are 6092 and 2852462 respectively.) And more importantly for lguest, the code is simpler. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-29lguest: use cpu capability accessorsAndrew Morton
To support my little make-x86-bitops-use-proper-typechecking projectlet. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-29lguest: fix switcher_page leak on unloadJohannes Weiner
map_switcher allocates the array, unmap_switcher has to free it accordingly. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-29lguest: Guest int3 fixRusty Russell
Ron Minnich noticed that guest userspace gets a GPF when it tries to int3: we need to copy the privilege level from the guest-supplied IDT to the real IDT. int3 is the only common case where guest userspace expects to invoke an interrupt, so that's the symptom of failing to do this. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: Add transport feature handling stub for virtio_ring.Rusty Russell
To prepare for virtio_ring transport feature bits, hook in a call in all the users to manipulate them. This currently just clears all the bits, since it doesn't understand any features. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: Rename set_features to finalize_featuresRusty Russell
Rather than explicitly handing the features to the lower-level, we just hand the virtio_device and have it set the features. This make it clear that it has the chance to manipulate the features of the device at this point (and that all feature negotiation is already done). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-15Merge branch 'generic-ipi' into generic-ipi-for-linusIngo Molnar
Conflicts: arch/powerpc/Kconfig arch/s390/kernel/time.c arch/x86/kernel/apic_32.c arch/x86/kernel/cpu/perfctr-watchdog.c arch/x86/kernel/i8259_64.c arch/x86/kernel/ldt.c arch/x86/kernel/nmi_64.c arch/x86/kernel/smpboot.c arch/x86/xen/smp.c include/asm-x86/hw_irq_32.h include/asm-x86/hw_irq_64.h include/asm-x86/mach-default/irq_vectors.h include/asm-x86/mach-voyager/irq_vectors.h include/asm-x86/smp.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-10x86, VisWS: turn into generic arch, eliminate Kconfig specialsIngo Molnar
remove leftover traces of various VISWS related Kconfig specials. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-25Merge commit 'v2.6.26-rc8' into x86/xenIngo Molnar
Conflicts: arch/x86/xen/enlighten.c arch/x86/xen/mmu.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-20x86: fix NULL pointer deref in __switch_toSuresh Siddha
I am able to reproduce the oops reported by Simon in __switch_to() with lguest. My debug showed that there is at least one lguest specific issue (which should be present in 2.6.25 and before aswell) and it got exposed with a kernel oops with the recent fpu dynamic allocation patches. In addition to the previous possible scenario (with fpu_counter), in the presence of lguest, it is possible that the cpu's TS bit it still set and the lguest launcher task's thread_info has TS_USEDFPU still set. This is because of the way the lguest launcher handling the guest's TS bit. (look at lguest_set_ts() in lguest_arch_run_guest()). This can result in a DNA fault while doing unlazy_fpu() in __switch_to(). This will end up causing a DNA fault in the context of new process thats getting context switched in (as opossed to handling DNA fault in the context of lguest launcher/helper process). This is wrong in both pre and post 2.6.25 kernels. In the recent 2.6.26-rc series, this is showing up as NULL pointer dereferences or sleeping function called from atomic context(__switch_to()), as we free and dynamically allocate the FPU context for the newly created threads. Older kernels might show some FPU corruption for processes running inside of lguest. With the appended patch, my test system is running for more than 50 mins now. So atleast some of your oops (hopefully all!) should get fixed. Please give it a try. I will spend more time with this fix tomorrow. Reported-by: Simon Holm Thøgersen <odie@cs.aau.dk> Reported-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-16Merge branch 'linus' into x86/xentip-x86-xen-2008-06-16_09.21_MonIngo Molnar
2008-05-30virtio: set device index in common code.Rusty Russell
Anthony Liguori points out that three different transports use the virtio code, but each one keeps its own counter to set the virtio_device's index field. In theory (though not in current practice) this means that names could be duplicated, and that risk grows as more transports are created. So we move the selection of the unique virtio_device.index into the common code in virtio.c, which has the side-benefit of removing duplicate code. The only complexity is that lguest and S/390 use the index to uniquely identify the device in case of catastrophic failure before register_virtio_device() is called: now we use the offset within the descriptor page as a unique identifier for the printks. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chris Lalancette <clalance@redhat.com> Cc: Anthony Liguori <anthony@codemonkey.ws>
2008-05-30lguest: use ioremap_cache, not ioremapRusty Russell
Thanks to Jon Corbet & LWN. Only took me a day to join the dots. Host->Guest netcat before (with unnecessily large receive buffers): 1073741824 bytes (1.1 GB) copied, 24.7528 seconds, 43.4 MB/s After: 1073741824 bytes (1.1 GB) copied, 17.6369 seconds, 60.9 MB/s Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-27x86/paravirt: add pte_flags to just get pte flagsJeremy Fitzhardinge
Add pte_flags() to extract the flags from a pte. This is a special case of pte_val() which is only guaranteed to return the pte's flags correctly; the page number may be corrupted or missing. The intent is to allow paravirt implementations to return pte flags without having to do any translation of the page number (most notably, Xen). Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-02lguest: make Launcher see device status updatesRusty Russell
This brings us closer to Real Life, where we'd examine the device features once it's set the DRIVER_OK status bit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02lguest: remove bogus NULL cpu checkRusty Russell
If lg isn't NULL, and cpu_id is sane, &lg->cpus[cpu_id] can't be NULL. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02lguest: avoid using NR_CPUS as a bounds check.Rusty Russell
NR_CPUS (being a host number) is an arbitrary limit for the Guest. Using the array size directly (which currently happes to be NR_CPUS) is more futureproof. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02virtio: explicit advertisement of driver featuresRusty Russell
A recent proposed feature addition to the virtio block driver revealed some flaws in the API: in particular, we assume that feature negotiation is complete once a driver's probe function returns. There is nothing in the API to require this, however, and even I didn't notice when it was violated. So instead, we require the driver to specify what features it supports in a table, we can then move the feature negotiation into the virtio core. The intersection of device and driver features are presented in a new 'features' bitmap in the struct virtio_device. Note that this highlights the difference between Linux unsigned-long bitmaps where each unsigned long is in native endian, and a straight-forward little-endian array of bytes. Drivers can still remove feature bits in their probe routine if they really have to. API changes: - dev->config->feature() no longer gets and acks a feature. - drivers should advertise their features in the 'feature_table' field - use virtio_has_feature() for extra sanity when checking feature bits Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-04-18drivers: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-03-30misc __user misannotations (pointless casts to long)Al Viro
2008-03-28lguest: comment documentation update.Rusty Russell
Took some cycles to re-read the Lguest Journey end-to-end, fix some rot and tighten some phrases. Only comments change. No new jokes, but a couple of recycled old jokes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-03-28lguest: Add puppies which where previously missing.Tim Ansell
lguest doesn't have features, it has puppies! Signed-off-by: Timothy R Ansell <mithro@mithis.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-03-11lguest: Revert 1ce70c4fac3c3954bd48c035f448793867592bc0, fix real problem.Rusty Russell
Ahmed managed to crash the Host in release_pgd(), which cannot be a Guest bug, and indeed it wasn't. The bug was that handing a 0 as the address of the toplevel page table being manipulated can cause the lookup code in find_pgdir() to return an uninitialized cache entry (we shadow up to 4 top level page tables for each Guest). Commit 37cc8d7f963ba2deec29c9b68716944516a3244f introduced this behaviour in the Guest, uncovering the bug. The patch which he submitted (which removed the /4 from the index calculation) simply ensured that these high-indexed entries hit the early exit path of guest_set_pmd(). But you get lots of segfaults in guest userspace as the PMDs aren't being updated. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-03-11lguest: fix __get_vm_area usage.Rusty Russell
Robert Bragg's 5dc331852848a38ca00a2817e5b98a1d0561b116 tightened (ie. fixed) the checking in __get_vm_area, and it broke lguest. lguest should pass the exact "end" it wants, not some random constant (it was possible previously that it would actually get an address different from SWITCHER_ADDR). Also, Fabio Checconi pointed out that we should make sure we're not hitting the fixmap area. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Robert Bragg <robert@sixbynine.org>
2008-03-11lguest: make sure cpu is initialized before accessing itEugene Teo
If req is LHREQ_INITIALIZE, and the guest has been initialized before (unlikely), it will attempt to access cpu->tsk even though cpu is not yet initialized. Signed-off-by: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-09lguest: accept guest _PAGE_PWT page table entriesAhmed S. Darwish
Beginning from commit 4138cc3418f5, ioremap_nocache() sets the _PAGE_PWT flag. Lguest doesn't accept a guest pte with a _PWT flag and reports a "bad page table entry" in that case. Accept guest _PAGE_PWT page table entries. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08Fix container_of() usageAlexey Dobriyan
Using "attr" twice is not OK, because it effectively prohibits such container_of() on variables not named "attr". Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04virtio: reset functionRusty Russell
A reset function solves three problems: 1) It allows us to renegotiate features, eg. if we want to upgrade a guest driver without rebooting the guest. 2) It gives us a clean way of shutting down virtqueues: after a reset, we know that the buffers won't be used by the host, and 3) It helps the guest recover from messed-up drivers. So we remove the ->shutdown hook, and the only way we now remove feature bits is via reset. We leave it to the driver to do the reset before it deletes queues: the balloon driver, for example, needs to chat to the host in its remove function. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: explicit enable_cb/disable_cb rather than callback return.Rusty Russell
It seems that virtio_net wants to disable callbacks (interrupts) before calling netif_rx_schedule(), so we can't use the return value to do so. Rename "restart" to "cb_enable" and introduce "cb_disable" hook: callback now returns void, rather than a boolean. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-31lguest: fix mis-merge against hpa's TSS renamingRusty Russell
drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’: drivers/lguest/x86/core.c:97: error: ‘struct x86_hw_tss’ has no member named ‘esp1’ Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (27 commits) lguest: use __PAGE_KERNEL instead of _PAGE_KERNEL lguest: Use explicit includes rateher than indirect lguest: get rid of lg variable assignments lguest: change gpte_addr header lguest: move changed bitmap to lg_cpu lguest: move last_pages to lg_cpu lguest: change last_guest to last_cpu lguest: change spte_addr header lguest: per-vcpu lguest pgdir management lguest: make pending notifications per-vcpu lguest: makes special fields be per-vcpu lguest: per-vcpu lguest task management lguest: replace lguest_arch with lg_cpu_arch. lguest: make registers per-vcpu lguest: make emulate_insn receive a vcpu struct. lguest: map_switcher_in_guest() per-vcpu lguest: per-vcpu interrupt processing. lguest: per-vcpu lguest timers lguest: make hypercalls use the vcpu struct lguest: make write() operation smp aware ... Manual conflict resolved (maybe even correctly, who knows) in drivers/lguest/x86/core.c
2008-01-30x86: use generic register name in the thread and tss structuresH. Peter Anvin
This changes size-specific register names (eip/rip, esp/rsp, etc.) to generic names in the thread and tss structures. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
