path: root/drivers/leds/leds-ss4200.c
2013-08-26leds: ss4200: Fix incorrect placement of __initdataSachin Kamat
__initdata should be placed between the variable name and equal sign for the variable to be placed in the intended section. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Dave Hansen <dave@sr71.net> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-08-26leds: leds-ss4200: Staticize nasgpio_led_get_attr()Jingoo Han
nasgpio_led_get_attr() is used only in this file. Fix the following sparse warning: drivers/leds/leds-ss4200.c:200:5: warning: symbol 'nasgpio_led_get_attr' was not declared. Should it be static? Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: leds-ss4200: use DEFINE_PCI_DEVICE_TABLEJingoo Han
This macro is used to create a struct pci_device_id array. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-12-15Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu. * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (47 commits) leds: leds-lp5521: return an error code on error in probe() leds: leds-clevo-mail: Use pr_* instead of printks leds: leds-rb532: Fix checkpatch errors leds: led-triggers: Fix checkpatch warnings leds: ledtrig-backlight: Fix checkpatch error leds: leds-wrap: Use <linux/io.h> instead of <asm/io.h> leds: leds-wm8350: Use dev_err instead of printk leds: leds-pwm: Fix checkpatch warning leds: leds-pca955x: Use dev_info instead of printk leds: leds-net48xx: Use linux/io.h instead of asm/io.h leds: leds-lt3593: Fix checkpatch warnings leds: leds-gpio: Use dev_info instead of printk leds: leds-da903x: Fix checkpatch error and warnings leds: leds-bd2802: Fix checkpatch warnings leds: leds-adp5520: Fix checkpatch warnings leds: led-class: Fix checkpatch warning leds: leds-ns2: use devm_gpio_request_one leds: leds-lt3593: use devm_gpio_request_one leds: leds-gpio: use devm_gpio_request_one leds: lp3944: Fix return value ...
2012-11-28leds: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26leds: leds-ss4200: replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-11-25leds: fix bug with reading NAS SS4200 dmi codeSteven Rostedt
While running randconfg with ktest.pl I stumbled upon this bug: BUG: unable to handle kernel NULL pointer dereference at 0000000000000003 IP: [<ffffffff815fe44f>] strstr+0x39/0x86 PGD 0 Oops: 0000 [#1] SMP last sysfs file: CPU 0 Modules linked in: Pid: 1, comm: swapper Not tainted 2.6.37-rc1-test+ #6 DG965MQ/ RIP: 0010:[<ffffffff815fe44f>] [<ffffffff815fe44f>] strstr+0x39/0x86 RSP: 0018:ffff8800797cbd80 EFLAGS: 00010213 RAX: 0000000000000000 RBX: 0000000000000003 RCX: ffffffffffffffff RDX: 0000000000000000 RSI: ffffffff82eb7ac9 RDI: 0000000000000003 RBP: ffff8800797cbda0 R08: ffff880000000003 R09: 0000000000030725 R10: ffff88007d294c00 R11: 0000000000014c00 R12: 0000000000000020 R13: ffffffff82eb7ac9 R14: ffffffffffffffff R15: ffffffff82eb7b08 FS: 0000000000000000(0000) GS:ffff88007d200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000003 CR3: 0000000002a1d000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 1, threadinfo ffff8800797ca000, task ffff8800797d0000) Stack: 00000000000000ba ffffffff82eb7ac9 ffffffff82eb7ab8 00000000000000ba ffff8800797cbdf0 ffffffff81e2050f ffff8800797cbdc0 00000000815f913b ffff8800797cbe00 ffffffff82eb7ab8 0000000000000000 0000000000000000 Call Trace: [<ffffffff81e2050f>] dmi_matches+0x117/0x154 [<ffffffff81e205d7>] dmi_check_system+0x3d/0x8d [<ffffffff82e1ad25>] ? nas_gpio_init+0x0/0x2c8 [<ffffffff82e1ad49>] nas_gpio_init+0x24/0x2c8 [<ffffffff820d750d>] ? wm8350_led_init+0x0/0x20 [<ffffffff82e1ad25>] ? nas_gpio_init+0x0/0x2c8 [<ffffffff810022f7>] do_one_initcall+0xab/0x1b2 [<ffffffff82da749c>] kernel_init+0x248/0x331 [<ffffffff8100e624>] kernel_thread_helper+0x4/0x10 [<ffffffff82da7254>] ? kernel_init+0x0/0x331 Found that the nas_led_whitelist dmi_system_id structure array had no NULL end delimiter, causing the dmi_check_system() loop to read an undefined entry. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Dave Hansen <dave@sr71.net> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-26leds: leds-ss4200: fix led_classdev_unregister twice in error handlingAxel Lin
In current implementation, if device_create_file failed in register_nasgpio_led, led_classdev_unregister will be executed twice. ( in register_nasgpio_led it calls led_classdev_unregister before return and in nas_gpio_init out_err ) This patch fixes it by only unregistering those that were successfully registered in out_err. ( not including last failed register_nasgpio_led call ) Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Dave Hansen <dave@sr71.net> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-03-16leds: make PCI device id constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make pci_device_id also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-12-17leds: drivers/leds/leds-ss4200.c: fix return statementakpm@linux-foundation.org
drivers/leds/leds-ss4200.c: In function 'ich7_lpc_probe': drivers/leds/leds-ss4200.c:353: warning: 'return' with no value, in function returning non-void Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-12-16leds-ss4200: Check pci_enable_device returnDave Hansen
pci_enable_result is defined using the __must_check macro but leds-ss4200 is not checking the return value. Signed-off-by: Javier Martinez Canillas <martinez.javier@gmail.com> Signed-off-by: Dave Hansen <dave@sr71.net> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-12-16leds: LED driver for Intel NAS SS4200 series (v5)Dave Hansen
This code is based on a driver that came in the "Open-source and GPL components" download here: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Server+Products&ProductLine=Intel%C2%AE+Storage+Systems&ProductProduct=Intel%C2%AE+Entry+Storage+System+SS4200-E&OSVersion=OS+Independent It was in a file called nasgpio.c inside of a second zip file called SS4200-E_Linux_SIO_Driver-v1.4.zip and is based on this updated to use the LED subsystem with the ioctl and hardware monitor support removed. I don't have any need for brightness control, and its code is *completely* separate from the on/off controls implemented here. If anyone else wants it, I'd be happy to look into adding it, but I don't care enough for now. Except for the probe routines, I rewrote most of it. I also Note that I don't have any hardware documentation except for the original driver. Thanks go to Arjan for his help in getting the original source for this released and for chasing down some licensing issues. Signed-off-by: Dave Hansen <dave@sr71.net> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
