path: root/drivers/leds/leds-pwm.c
2014-06-12Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED updates from Bryan Wu: "I just found merge window is open and I'm quite busy and almost forget to send out this pull request. Thanks Russell and Alexandre ping me about this. So basically we got some clean up and leds-pwm fixing patches from Russell" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: Remove duplicated OOM message for individual driver drivers/leds: Replace __get_cpu_var use through this_cpu_ptr leds: lp55xx: add DT bindings for LP55231 leds: 88pm860x: Fix missing refcount decrement for parent of_node leds: 88pm860x: Use of_get_child_by_name leds: leds-pwm: add DT support for LEDs wired to supply leds: leds-pwm: implement PWM inversion leds: leds-pwm: convert OF parsing code to use led_pwm_add() leds: leds-pwm: provide a common function to setup a single led-pwm device leds: pca9685: Remove leds-pca9685 driver dell-led: add mic mute led interface
2014-05-21leds: leds-pwm: retrieve configured PWM periodAlexandre Belloni
The PWM core is now able to initialize the PWM period from a lookup table defined by board files. Use it if available and fallback to the value supplied in pwm_period_ns. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-05-08leds: leds-pwm: add DT support for LEDs wired to supplyRussell King
The non-DT driver allowed an active low property to be specified, but DT is missing this in its description. Add the property to the DT binding document, making it optional. It defaults to active high, which retains compatibility with existing descriptions. This should only be used for causes where the LED is wired to supply, and the PWM does not sensibly support its own inversion. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-05-08leds: leds-pwm: implement PWM inversionRussell King
Some PWM outputs are wired such that the LED they're controlling is connected to supply rather than ground. These PWMs may not support output inversion, or when they do, disabling the PWM may set the PWM output low, causing a "brightness" value of zero to turn the LED fully on. The platform data for this driver already indicates that this was thought about, and we have the "active_low" property there already. However, the implementation for this is missing. Add the trivial implementation for this feature. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-05-08leds: leds-pwm: convert OF parsing code to use led_pwm_add()Russell King
Convert the OF parsing code to use the common PWM LED registration code, which means we have a consistent method, and single point where the registration happens for both paths. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-05-08leds: leds-pwm: provide a common function to setup a single led-pwm deviceRussell King
Provide a common function to setup a single led-pwm device, replacing the platform data initialisation path with this function. This allows us to have a common method of creating these devices in a consistent manner, which then allows us to place the probe failure cleanup in one place. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-04-07leds: leds-pwm: properly clean up after probe failureRussell King
When probing with DT, we add each LED one at a time. If we find a LED without a PWM device (because it is not available yet) we fail the initialisation, unregister previous LEDs, and then by way of managed resources, we free the structure. The problem with this is we may have a scheduled and active work_struct in this structure, and this results in a nasty kernel oops. We need to cancel this work_struct properly upon cleanup - and the cleanup we require is the same cleanup as we do when the LED platform device is removed. Rather than writing this same code three times, move it into a separate function and use it in all three places. Fixes: c971ff185f64 ("leds: leds-pwm: Defer led_pwm_set() if PWM can sleep") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-02-27drivers/leds: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Cc: Bryan Wu <cooloney@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: linux-leds@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-01-27leds: pwm: Remove a warning on non-DT platformsOlof Johansson
This removes a warning on non-DT-enabled platforms: drivers/leds/leds-pwm.c: In function 'led_pwm_create_of': drivers/leds/leds-pwm.c:88:22: warning: unused variable 'node' Really caused by the local variable that is assigned to and then never used. Just do away with the local var, it's not needed. Technically this code path can never be entered without DT enabled, since there's an earlier check about number of children in the calling function, but the compiler can't see that. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2014-01-27leds: leds-pwm: fix duty time overflow.Xiubo Li
Overflow maybe occurs when calculates the duty time. For instance, the period time is 990000000ns, and the max_brightness is 127, when setting the brightness to 12, the duty value will be 25906026ns, but it should be 93543307ns. Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-12-02leds: pwm: Fix for deferred probe in DT booted modePeter Ujfalusi
We need to make sure that the error code from devm_of_pwm_get() is the one the module returns in case of failure. Restructure the code to make this possible for DT booted case. With this patch the driver can ask for deferred probing when the board is booted with DT. Fixes for example omap4-sdp board's keyboard backlight led. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-10-22leds: pwm: Remove redundant of_match_ptrSachin Kamat
The data structure of_match_ptr() protects is always compiled in. Hence of_match_ptr() is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-08-26leds: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-04-01leds: leds-pwm: Defer led_pwm_set() if PWM can sleepFlorian Vaussard
Call to led_pwm_set() can happen inside atomic context, like triggers. If the PWM call can sleep, defer using a worker. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: leds-pwm: Add device tree bindingsPeter Ujfalusi
The DT binding for the pwm-leds devices are similar to the gpio-leds type. LEDs are represented as sub-nodes of the pwm-leds device. The code for handling the DT boot is based on the code found in the leds-gpio driver and adapted to use PWMs instead of GPIOs. To avoid having custom cleanup code in case of DT boot the newly created devm_of_pwm_get() API is used to get the correct PWM instance. For usage see: Documentation/devicetree/bindings/leds/leds-pwm.txt Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: leds-pwm: Simplify cleanup codePeter Ujfalusi
The code looks more nicer if we use: while (i--) instead: if (i > 0) for (i = i - 1; i >= 0; i--) Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: leds-pwm: Preparing the driver for device tree supportPeter Ujfalusi
In order to be able to add device tree support for leds-pwm driver we need to rearrange the data structures used by the drivers. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: leds-pwm: Convert to use devm_get_pwmPeter Ujfalusi
Update the driver to use the new API for requesting pwm so we can take advantage of the pwm_lookup table to find the correct pwm to be used for the LED functionality. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-12-15Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu. * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (47 commits) leds: leds-lp5521: return an error code on error in probe() leds: leds-clevo-mail: Use pr_* instead of printks leds: leds-rb532: Fix checkpatch errors leds: led-triggers: Fix checkpatch warnings leds: ledtrig-backlight: Fix checkpatch error leds: leds-wrap: Use <linux/io.h> instead of <asm/io.h> leds: leds-wm8350: Use dev_err instead of printk leds: leds-pwm: Fix checkpatch warning leds: leds-pca955x: Use dev_info instead of printk leds: leds-net48xx: Use linux/io.h instead of asm/io.h leds: leds-lt3593: Fix checkpatch warnings leds: leds-gpio: Use dev_info instead of printk leds: leds-da903x: Fix checkpatch error and warnings leds: leds-bd2802: Fix checkpatch warnings leds: leds-adp5520: Fix checkpatch warnings leds: led-class: Fix checkpatch warning leds: leds-ns2: use devm_gpio_request_one leds: leds-lt3593: use devm_gpio_request_one leds: leds-gpio: use devm_gpio_request_one leds: lp3944: Fix return value ...
2012-11-28leds: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28leds: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-27leds: leds-pwm: Fix checkpatch warningSachin Kamat
Fixes the following checkpatch warning: WARNING: please, no space before tabs FILE: leds/leds-pwm.c:29: ^Iunsigned int ^I^Iactive_low;$ Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-07-24leds: Use devm_kzalloc in leds-pwm.c fileSachin Kamat
devm_kzalloc() makes cleanup simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-01-10leds: convert led platform drivers to module_platform_driverAxel Lin
Factor out some boilerplate code for platform driver registration into module_platform_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Haojian Zhuang <hzhuang1@marvell.com> [led-88pm860x.c] Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Michael Hennerich <hennerich@blackfin.uclinux.org> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-26leds: leds-pwm: return proper error if pwm_request failedAxel Lin
Return PTR_ERR(led_dat->pwm) instead of 0 if pwm_request failed Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Luotao Fu <l.fu@pengutronix.de> Cc: Reviewed-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17leds: leds-pwm: Set led_classdev max_brightnessLars-Peter Clausen
Currently the driver leds-pwm doesn't set max_brightness for the led device although it's platform data proides a maximum brightness. Instead it stores its own private driver struct. The max_brightness defaults to 255 for led device if it has not been set. As a result any leds-pwm device with a different maximum brightness will show incorrect behavior, as it is posible to either set a longer then period duty time or not be able to switch the led to full brightness. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: simple driver for pwm driven LEDsLuotao Fu
Add a simple driver for pwm driver LEDs. pwm_id and period can be defined in board file. It is developed for pxa, however it is probably generic enough to be used on other platforms with pwm. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
