path: root/drivers/leds/leds-pca9532.c
2014-09-18driver:gpio remove all usage of gpio_remove retval in driverabdoulaye berthe
this remove all reference to gpio_remove retval in all driver except pinctrl and gpio. the same thing is done for gpio and pinctrl in two different patches. Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com> Acked-by: Michael Büsch <m@bues.ch> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-26leds: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: pca9532: fix suspect code indent for conditional statementsJingoo Han
Fixed the checkpatch warning as below: WARNING: suspect code indent for conditional statements (8, 8) Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-01leds: pca9532: Convert to devm_input_allocate_device()Axel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-07-24leds: convert PCA9532 LED driver to devm_kzalloc()Bryan Wu
Cc: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-01-10leds: convert led i2c drivers to module_i2c_driverAxel Lin
Factor out some boilerplate code for i2c driver registration into module_i2c_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Haojian Zhuang <hzhuang1@marvell.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Michael Hennerich <hennerich@blackfin.uclinux.org> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08drivers/leds/leds-pca9532.c: change driver name to be uniqueWolfram Sang
This driver handles the variants pca9530-pca9533, so it chose the name "pca953x". However, there is a gpio driver which decided on the same name. As a result, those two can't be loaded at the same time. Add a subsystem prefix to make the driver name unique. Device matching will not suffer, because both are I2C drivers which match using a i2c_device_id-table which is not altered. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Richard Purdie <richard.purdie@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25drivers/leds/leds-pca9532.c: add support pca9530, pca9531 and pca9533Jan Weitzel
The pca953x family are only different in number of leds and register layout Adding chipinfo to use driver with whole pca953x family Rename driver to pca953x, but left files and platformflags named pca9532. Tested with pca9530 and pca9533 Tested-by: Juergen Kilb <j.kilb@phytec.de> Signed-off-by: Jan Weitzel <j.weitzel@phytec.de> Acked-by: Joachim Eastwood <joachim.eastwood@jotron.com> Tested-by: Joachim Eastwood <joachim.eastwood@jotron.com> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25drivers/leds/leds-pca9532.c: add gpio capabilityJoachim Eastwood
Allow unused leds on pca9532 to be used as gpio. The board I am working on now has no less than 6 pca9532 chips. One chips is used for only leds, one has 14 leds and 2 gpio and the rest of the chips are gpio only. There is also one board in mainline which could use this capabilty; arch/arm/mach-iop32x/n2100.c 232 { .type = PCA9532_TYPE_NONE }, /* power OFF gpio */ 233 { .type = PCA9532_TYPE_NONE }, /* reset gpio */ This patch defines a new pin type, PCA9532_TYPE_GPIO, and registers a gpiochip if any pin has this type set. The gpio will registers all chip pins but will filter on gpio_request. [randy.dunlap@oracle.com: fix build when GPIOLIB is not enabled] Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jan Weitzel <j.weitzel@phytec.de> Cc: Juergen Kilb <j.kilb@phytec.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13leds: leds-pca9532 cleanupsAxel Lin
- Remove unneeded input_free_device() after input_unregister_device(). - Add pca9532_destroy_devices() function for destroy devices. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-04leds: leds-pca9532 - Drop unused module parametersJean Delvare
The I2C_CLIENT_INSMOD_1 macro is only useful for i2c drivers which implement device detection. The leds-pca9532 driver doesn't, so there is no point in calling it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Riku Voipio <riku.voipio@iki.fi>
2009-09-07leds: Fix leds-pca9532 whitespace issuesRichard Purdie
Signed-off-by: Richard Purdie <rpurdie@linux.intel.com
2009-06-23leds: pca9532 - Indent using tabs, not spaces.Antonio Ospite
Indent using tabs, not spaces. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Acked-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Fix &&/|| confusion in leds-pca9532.cRiku Voipio
This fixes the expression in the driver to do the correct thing, not that I think anyone would send SND_* without EV_SND. Thanks to Roel Kluin <roel.kluin@gmail.com> for noticing. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-03-30trivial: Update my email addressRiku Voipio
Update my email address. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-01-08leds: leds-pcs9532 - Move i2c work to a workquequeRiku Voipio
Apparently these might be called under atomic context, and i2c operations may sleep. BUG found by Ross Burton <ross@burtonini.com> Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-01-08leds: leds-pca9532 - fix memory leak and properly handle errorsSven Wegener
When the registration fails, we need to release the memory we allocated. Also we need to save the error from led_classdev_register and propagate it up, else we'll return success, even if we failed. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-01-08leds: eds-pca9532: mark pca9532_event() staticSven Wegener
Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2008-07-23leds: Add pca9532 led driverRiku Voipio
NXP pca9532 is a LED dimmer/controller attached to i2c bus. It allows attaching upto 16 leds which can either be on, off or dimmed and/or blinked with the two PWM modulators available. This driver is a "new-style" i2c driver that adheres to the driver model and implements the led framework api. Since the leds connected to the driver are platform specific, it is only useful when platform data is passed to the driver to define what leds are connected to which pins. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
