path: root/drivers/leds/leds-lp55xx-common.c
2013-02-06leds-lp55xx: fix problem on removing LED attributesMilo(Woogyom) Kim
LP55XX common device attributes, 'led_current' and 'max_current' are created while loading the driver. Those are LED device attributes which are removed automatically on releasing led class devices - led_classdev_unregister(). Therefore, this duplicate code should be removed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: add new function for removing device attribtuesMilo(Woogyom) Kim
lp55xx_unregister_sysfs() is used for removing lp55xx device attributes. Chip specific and engine attributes are removed on unloading the driver. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: support device specific attributesMilo(Woogyom) Kim
To support device specific attributes, new common driver function is added. Eventually those are created on registering the sysfs with common dev attrs. Furthermore, this patch makes adding device attributes simple in each driver. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: support firmware interfaceMilo(Woogyom) Kim
This patch provides additional device attributes which enable loading the firmware. ('select_engine' and 'run_engine') To run a LED pattern, two parts of driver should be enabled. Common features : lp55xx-common =============================== Firmware interface for loading LED patterns Chip specific features : leds-lp5521, leds-lp5523 ================================================= Register addresses for loading firmware data Register addresses for running selected engine Pattern programming sequence ============================ LP55xx chips have three program engines. To load and run a LED pattern, the programming sequence is as follows. (1) Select an engine number (1/2/3) (2) Set engine mode to load (3) Write pattern data into selected area (4) Set engine mode to run This sequence is almost same as the firmware interface. (1) Select an engine number : 'select_engine' dev attribute (2) Mode change to load : 'loading' of firmware class (3) Write pattern data into selected area : 'data' of firmware class (4) Mode change to run : 'run_engine' dev attribute (1) and (4) are device specific features which provide callback functions (2) and (3) are common features. For example, echo 1 or 2 or 3 > /sys/bus/i2c/devices/xxxx/select_engine echo 1 > /sys/class/firmware/lp5521/loading echo "4000600040FF6000" > /sys/class/firmware/lp5521/data echo 0 > /sys/class/firmware/lp5521/loading echo 1 > /sys/bus/i2c/devices/xxxx/run_engine As soon as 'loading' is set to 0, registered callback is called. Inside the callback, the selected engine is loaded and memory is updated. To run programmed pattern, 'run_engine' attribute should be enabled. Device specific data structure ============================== o Firmware callback load selected engine and update program memory o Run engine change the engine mode o 'engine_idx' and firmware data, 'fw' Those are used in the driver internally with callback functions Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: add new lp55xx_register_sysfs() for the firmware interfaceMilo(Woogyom) Kim
LP55xx family chips have internal program memory which run various patterns. Using this memory, LEDs continue on blinking/dimming without continuous I2C commands. That means the I2C HOST can be entered into sleep once the memory is updated. An application can get hex data from a file and write them into the program memory through the I2C. This is general firwmare interface. This patch is the initial step for adding the firmware interface. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: fix error condition in lp55xx_register_leds()Milo(Woogyom) Kim
Use lp55xx_unregister_leds() rather than duplicate code. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx_unregister_leds()Milo(Woogyom) Kim
To unregister led class devices and sysfs attributes, LP5521 and LP5523 have each driver function. This patch makes both drivers simple using common driver function, lp55xx_unregister_leds(). And some unused variables are removed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: provide common LED current settingMilo(Woogyom) Kim
LED current is configurable via the sysfs. Max current is a read-only attribute. These attributes code can be shared in lp55xx common driver. Device attributes: 'led_current' and 'max_current' move to lp55xx common driver Replaced functions: show_max_current() => lp55xx_show_max_current() show_current() => lp55xx_show_current() store_current() => lp55xx_store_current() LED setting function: set_led_current() Current registers are device specific, so configurable function is added in each driver. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx_set_brightness()Milo(Woogyom) Kim
lp5521_set_brightness() and lp5523_set_brightness() are replaced with common function, lp55xx_set_brightness(). This function is invoked when the brightness of each LED channel is updated. LP5521 and LP5523 have different register address for the brightness control, so this work is done by chip specific brightness_work_fn(). lp5521/5523_led_brightness_work(): use lp55xx_led and lp55xx_chip data structure. use lp55xx write function. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx_init_led() common functionMilo(Woogyom) Kim
lp5521_init_led() and lp5523_init_led() are replaced with one common function, lp55xx_init_led(). Max channels is configurable, so it's used in lp55xx_init_led(). 'LP5523_LEDS' are changed to 'LP5523_MAX_LEDS'. lp55xx_set_brightness, lp55xx_led_attributes: skeleton Will be filled in next patches. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx common led registration functionMilo(Woogyom) Kim
LED class devices are registered in lp5521_register_leds() and lp5523_register_leds(). Two separate functions are merged into consolidated lp55xx function, lp55xx_register_leds(). Error handling fix: Unregistering LEDS are handled in lp55xx_register_leds() when LED registration failure occurs. So each driver error handler is changed to 'err_register_leds' Chip dependency: 'brightness_work_fn' and 'set_led_current' To make the structure abstract, both functions are configured in each driver. Those functions should be done by each driver because register control is chip-dependant work. lp55xx_init_led: skeleton Will be filled in next patch Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx common deinit functionMilo(Woogyom) Kim
Two separate de-init functions are merged into one common function. And it is used in err_post_init of lp55xx_init_device(). Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: clean up init functionMilo(Woogyom) Kim
lp5521/5523_init_device() are replaced with lp55xx common function, lp55xx_init_device(). Error handler in init_device: deinit function are matched with 'err_post_init' section in lp55xx_init_device(). Remove LP5523 engine intialization code: Engine functionality is not mandatory but optional. Moreover engine initialization is done internally with device reset command. Therefore, this code is unnecessary. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx common init function - post intMilo(Woogyom) Kim
LP5521/5523 chip configuration is replaced with lp55xx common function, lp55xx_post_init_device(). Name change: lp5521/5523_configure() to lp5521/5523_post_init_device() These are called in init function. Register access function Argument type is changed from 'i2c_client' to 'lp55xx_chip'. Use exported R/W functions of lp55xx common driver. Temporary variables in lp5521/5523_init_device() These functions will be removed but temporary variables are needed for blocking build warnings - incompatible pointer. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx common init function - detectMilo(Woogyom) Kim
LP5521/5523 chip detection functions are replaced with lp55xx common function, lp55xx_detect_device(). Chip dependent address and values are configurable in each driver. In init function, chip detection is executed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx common init function - resetMilo(Woogyom) Kim
LP5521/5523 reset device functions are moved to lp55xx common driver. Value of register address and value are chip dependent. Those are configured in each driver. In init function, reset command is executed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: use lp55xx common init function - platform dataMilo(Woogyom) Kim
LP5521/5523 platform data functions are moved to lp55xx common driver. New init function, lp55xx_init_device() is created. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2013-02-06leds-lp55xx: add new common driver for lp5521/5523Milo(Woogyom) Kim
This patch supports basic common driver code for LP5521, LP5523/55231 devices. ( Driver Structure Data ) lp55xx_led and lp55xx_chip In lp55xx common driver, two different data structure is used. o lp55xx_led control multi output LED channels such as led current, channel index. o lp55xx_chip general chip control such like the I2C and platform data. For example, LP5521 has maximum 3 LED channels. LP5523/55231 has 9 output channels. lp55xx_chip for LP5521 ... lp55xx_led #1 lp55xx_led #2 lp55xx_led #3 lp55xx_chip for LP5523 ... lp55xx_led #1 lp55xx_led #2 . . lp55xx_led #9 ( Platform Data ) LP5521 and LP5523/55231 have own specific platform data. However, this data can be handled with just one platform data structure. The lp55xx platform data is declared in the header. This structure is derived from leds-lp5521.h and leds-lp5523.h Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
