path: root/drivers/isdn
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25isdn: Cleanup Sections in PCMCIA driver elsaHenne
Compiling this driver gave a section mismatch, so I reviewed the init/exit paths of the driver and made the correct changes. WARNING: drivers/isdn/hisax/built-in.o(.text+0x55e37): Section mismatch in reference from the function elsa_cs_config() to the function .devinit.text:hisax_init_pcmcia() The function elsa_cs_config() references the function __devinit hisax_init_pcmcia(). This is often because elsa_cs_config lacks a __devinit annotation or the annotation of hisax_init_pcmcia is wrong. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25isdn: Cleanup Sections in PCMCIA driver avma1Henne
Compiling this driver gave a section mismatch, so I reviewed the init/exit paths of the driver and made the correct changes. WARNING: drivers/isdn/hisax/built-in.o(.text+0x56512): Section mismatch in reference from the function avma1cs_config() to the function .devinit.text:hisax_init_pcmcia() The function avma1cs_config() references the function __devinit hisax_init_pcmcia(). This is often because avma1cs_config lacks a __devinit annotation or the annotation of hisax_init_pcmcia is wrong. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25isdn: Cleanup Sections in PCMCIA driver telesHenne
Compiling this driver gave a section mismatch, so I reviewed the init/exit paths of the driver and made the correct changes. WARNING: drivers/isdn/hisax/built-in.o(.text+0x56bfb): Section mismatch in reference from the function teles_cs_config() to the function .devinit.text:hisax_init_pcmcia() The function teles_cs_config() references the function __devinit hisax_init_pcmcia(). This is often because teles_cs_config lacks a __devinit annotation or the annotation of hisax_init_pcmcia is wrong. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25isdn: Cleanup Sections in PCMCIA driver sedlbauerHenne
Compiling this driver gave a section mismatch, so I reviewed the init/exit paths of the driver and made the correct changes. WARNING: drivers/isdn/hisax/built-in.o(.text+0x558d6): Section mismatch in reference from the function sedlbauer_config() to the function .devinit.text:hisax_init_pcmcia() The function sedlbauer_config() references the function __devinit hisax_init_pcmcia(). This is often because sedlbauer_config lacks a __devinit annotation or the annotation of hisax_init_pcmcia is wrong. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Acked-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-17gigaset: fix build failureTilman Schmidt
Update the dummy LL interface to the LL interface change introduced by commit daab433c03c15fd642c71c94eb51bdd3f32602c8. This fixes the build failure occurring after that commit when enabling ISDN_DRV_GIGASET but neither ISDN_I4L nor ISDN_CAPI. Impact: bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16gigaset: correct range checking off by one errorTilman Schmidt
Correct a potential array overrun due to an off by one error in the range check on the CAPI CONNECT_REQ CIPValue parameter. Found and reported by Dan Carpenter using smatch. Impact: bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15ISDN: Add PCI ID for HFC-2S/4S Beronet Card PCIeLars Ellenberg
A few subdevice IDs seem to have been dropped when hfc_multi was included upstream, just compare the list at http://www.openvox.cn/viewvc/misdn/trunk/hfc_multi.c?revision=75&view=annotate#l175 with the IDs in drivers/isdn/hardware/mISDN/hfcmulti.c Added PCIe 2 Port card and LED settings (same as PCI) Do not use <linux/pci_ids.h> /KKe Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-03-15gigaset: prune use of tty_buffer_request_roomTilman Schmidt
Calling tty_buffer_request_room() before tty_insert_flip_string() is unnecessary, costs CPU and for big buffers can mess up the multi-page allocation avoidance. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Acked-by: Karsten Keil <keil@b1-systems.de> CC: Alan Cox <alan@lxorguk.ukuu.org.uk>, stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15gigaset: correct clearing of at_state strings on RINGTilman Schmidt
In RING handling, clear the table of received parameter strings in a loop like everywhere else, instead of by enumeration which had already gotten out of sync. Impact: minor bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Acked-by: Karsten Keil <keil@b1-systems.de> CC: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15gigaset: avoid registering CAPI driver more than onceTilman Schmidt
Registering/unregistering the Gigaset CAPI driver when a device is connected/disconnected causes an Oops when disconnecting two Gigaset devices in a row, because the same capi_driver structure gets unregistered twice. Fix by making driver registration/unregistration a separate operation (empty in the ISDN4Linux case) called when the main module is loaded/unloaded. Impact: bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Acked-by: Karsten Keil <keil@b1-systems.de> CC: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15i4l: change magic numbers in Eicon DIVA ISDN driver to symbolic namesIan Munsie
Replace references to the '20' magic number found throughout the Eicon ISDN driver for the length of the station_id field in the T30_INFO struct with the T30_MAX_STATION_ID_LENGTH symbolic constant. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Cc: Armin Schindler <mac@melware.de> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15i4l: silence compiler warnings for array access in Eicon DIVA ISDN driverIan Munsie
When compiling this driver, the compiler throws the following warnings: drivers/isdn/hardware/eicon/message.c:8426: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8427: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8434: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8435: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8436: warning: array subscript is above array bounds drivers/isdn/hardware/eicon/message.c:8447: warning: array subscript is above array bounds This arises from the particular semantics the driver is using to write to the nlc array (static byte[256]). The array has a length in byte 0 followed by a T30_INFO struct starting at byte 1. The T30_INFO struct has a number of variable length strings after the station_id entry, which cannot be explicitly defined in the struct and the driver accesses them with an array index to station_id beyond the length of station_id. This patch merely changes the semantics that the driver uses to access the entries after the station_id entry to use the original 256 byte nlc array taking the offset and length of the station_id entry to calculate where to write in the array, thereby silencing the warning. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Cc: Armin Schindler <mac@melware.de> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15isdn: misplaced parenthesis in pof_handle_data()Roel Kluin
The parenthesis was misplaced. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-26isdn: remove ishexdigit() in regard to isxdigit()Andy Shevchenko
Samll cleanup in drivers/isdn/gigaset/capi.c where own implementation of isxdigit() has been changed to kernel native one. Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26gigaset: reduce syslog clutterTilman Schmidt
Improve readability of the Gigaset driver's kernel messages by removing a few unnecessary messages and limiting the emission of some debug messages more narrowly. Impact: logging Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26bas_gigaset: collapse CR/LF at end of AT responseTilman Schmidt
Copy the mechanism from ser_/usb_gigaset to avoid producing spurious empty responses for CR/LF sequences from the device. Add a comment in all drivers documenting that behaviour. Correct an off by one error that might result in a one byte buffer overflow when receiving an unexpectedly long reply. Impact: minor bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22PCI: push deprecated pci_find_device() function to last userTilman Schmidt
The ISDN4Linux HiSax driver family contains the last remaining users of the deprecated pci_find_device() function. This patch creates a private copy of that function in HiSax, and removes the now unused global function together with its controlling configuration option, CONFIG_PCI_LEGACY. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22isdn: fix a few Kconfig imperfectionsTilman Schmidt
1. Rewrite the outdated help texts for config options ISDN and ISDN_CAPI. 2. The MISDN config option appeared between ISDN_I4L and the I4L hardware driver options; move it to a less irritating place. 3. HYSDN is not in fact an I4L driver, and needn't depend on ISDN_I4L, so move it from the I4L section to the general section. 4. ISDN_HDLC is now also used by drivers outside I4L. Move it from the I4L section to the general section, too. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Remove experimental tag from middleware featureJan Kiszka
Despite all its bugs, the middleware support of our CAPI stack was already in use for many, many moons. And after going through its code, fixing all issues I found, I feel it deserves to officially become a non-experimental feature. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Schedule capifs for removalJan Kiszka
With dynamic TTY nodes and the help of udev, we no longer need this special filesystem. Schedule it for removal in one year from now. As a last duty to this feature, move its help to right option so that users can read the rationale. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop special controller lookup from capi20_put_messageJan Kiszka
This strange special rule to fall back to controller 1 cannot be derived from the CAPI specs and looks a lot like it was once dedicated to some out-of-tree driver, probably AVM's broken fcdsl2 (FRITZ!Card DSL v2.0). I found no in-tree user that needs this check, and I'm now taking care of the fcdsl2. So drop these bits from our stack. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop return value of handle_minor_sendJan Kiszka
We did not evaluate handle_minor_send's return value, just (void)'ed it away. Time for a cleanup. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Clean up capiminor_*_ackJan Kiszka
No need for irqsave acquisition of acklock, bh-safe is sufficient. Moverover, move kfree out of the lock and do not take acklock at all in capiminor_del_all_ack as we are the last user of the list here. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Fix locking around capiminor's output queue and drop workaround_lockJan Kiszka
Introduce outlock as a spin lock that protects capiminor's outqueue, outbytes and outskb (formerly known as ttyskb). outlock can be acquired from soft-IRQ context via capinc_write, so make it bh-safe. This finally removes the last reason for keeping the workaround lock around (which was incomplete and partly broken anyway). And as we no longer call handle_recv_skb in atomic context, gen_data_b3_resp_for can use non-atomic allocation now. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop capiminor's unused inbytes counterJan Kiszka
The inbytes counter was only updated but never read. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Use atomics for capiminor's datahandle and msgidJan Kiszka
The capiminor members datahandle and msgid are incremented outside any lock, so better do this atomically. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rename datahandle_queue -> ackqueue_entryJan Kiszka
This struct is describing a queue entry, not the queue itself. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rework capiminor RX handlerJan Kiszka
Avoid re-queuing skbs unless the error detected in handle_recv_skb is expected to be recoverable such as lacking memory, a full CAPI queue, a full TTY input buffer, or a not yet existing TTY. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop handle_minor_recv from capinc_tty_writeJan Kiszka
Sending a message down the CAPI stack may trigger the reception of an answer, but this will go through capi_recv_message and call handle_minor_recv from there. There is no need to walk the receive queue on capinc_tty_write. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop atomic ttyopencountJan Kiszka
Not needed, tty->count keeps track of this information. At this chance, drop traces of ancient attempts to debug this logic via _DEBUG_REFCOUNT. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Clean up capiminors_lockJan Kiszka
Use a plain spin lock for capiminors_lock, drop inconsistent irqsafe acquisitions (it's only used in process context anyway). Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop obsolete nccip from capiminor structJan Kiszka
The nccip in capiminor used to serve as an indicator that the NCCI was close. But we don't need this, we issue a hangup on capincci_free_minor. So drop this legacy. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Issue synchronous hangup on capincci_free_minorJan Kiszka
capincci_free and, thus, capincci_free_minor runs in process context, so we can issue the hangup of the associated TTY synchronously. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Drop remaining NULL checks on tty->driver_dataJan Kiszka
tty_struct's driver_data cannot be NULL, no need to test for it. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Use tty_port to keep track of capiminor's ttyJan Kiszka
Use the reference management features of tty_port to look up and drop again the tty_struct associated with a capiminor. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Establish install/cleanup handlers for capiminor TTYsJan Kiszka
Properly associate/disassociate a capiminor object with its TTY via the install/cleanup handlers instead of trying to guess first open and last close. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Use kref on capiminorJan Kiszka
Install a reference counter for capiminor objects. Acquire it when obtaining a capiminor from the array during capinc_tty_open, drop it when closing the tty again. Another reference is held for the hook-up with capincci. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Use dynamic major for NCCI TTYs by defaultJan Kiszka
No need to allocate a fixed major for this TTY, both capifs and udev make this transparent to the user. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Dynamically register minor devicesJan Kiszka
Register capiminors dynamically with the TTY core so that udev can make them show up as the NCCIs appear or disappear. This removes the need to check if the capiminor requested in capinc_tty_open actually exists. And this completely obsoletes capifs which will be scheduled for removal in a later patch. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Clean up capinc_tty_init/exitJan Kiszka
Return proper error code if tty_register_driver fails. In contrast, tty_unregister_driver cannot practically fail, so drop that error handling. Finally, mark capinc_tty_init/exit with __init/__exit. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Switch capiminor list to arrayJan Kiszka
Using a plain array of pointers simplifies the management of capiminors. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Switch NCCI list to standard doubly linked listJan Kiszka
Replace open-coded NCCI list management with standard mechanisms. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Fix racy capi_readJan Kiszka
capi_read still used interruptible_sleep_on, risking to miss a wakeup this way. Convert it to wait_event_interruptible. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Use non-atomic allocation during NCCI setupJan Kiszka
Both capincci_alloc and capiminor_alloc run in non-atomic context, update their memory allocations accordingly. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Rework locking of capidev membersJan Kiszka
Rename 'ncci_list_mtx' to 'lock', expressing that it now protects a larger set of capidev members: the NCCI list, ap.applid (ie. the registration of the application), and modifications of userflags. We do not need to protect each and every check for ap.applid because, once an application is registered, it will stay for the whole lifetime of the device. Also, there is no need to apply the capidev mutex during release (if there could be concurrent users, we would crash them anyway by freeing the device at the end of capi_release). Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16CAPI: Clean up capi_open/releaseJan Kiszka
Fold capidev_alloc and capidev_free into capi_open and capi_release - there are no other users. Someone pushed a lock_kernel into capi_open. Drop it, we don't need it. Also remove the useless test from open that checks for private_data == NULL. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: David S. Miller <davem@davemloft.net>
