path: root/drivers/isdn
2011-11-29isdn: avoid copying too long drvidDan Carpenter
"cfg->drvid" comes from the user so there is a possibility they didn't NUL terminate it properly. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29isdn: make sure strings are null terminatedDan Carpenter
These strings come from the user. We strcpy() them inside cf_command() so we should check that they are NULL terminated and return an error if not. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits) be2net: Add detect UE feature for Lancer be2net: Prevent CQ full condition for Lancer be2net: Fix disabling multicast promiscous mode be2net: Fix endian issue in RX filter command af_packet: de-inline some helper functions MAINTAINERS: Add can-gw include to maintained files net: Add back alignment for size for __alloc_skb net: add missing bh_unlock_sock() calls l2tp: fix race in l2tp_recv_dequeue() ixgbevf: Update release version ixgbe: DCB, return max for IEEE traffic classes ixgbe: fix reading of the buffer returned by the firmware ixgbe: Fix compiler warnings ixgbe: fix smatch splat due to missing NULL check ixgbe: fix disabling of Tx laser at probe ixgbe: Fix link issues caused by a reset while interface is down igb: Fix for I347AT4 PHY cable length unit detection e100: make sure vlan support isn't advertised on old adapters e1000e: demote a debugging WARN to a debug log message net: fix typo in drivers/net/ethernet/xilinx/ll_temac_main.c ...
2011-11-02Merge branch 'for-linus' of git://github.com/richardweinberger/linuxLinus Torvalds
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits) um: fix ubd cow size um: Fix kmalloc argument order in um/vdso/vma.c um: switch to use of drivers/Kconfig UserModeLinux-HOWTO.txt: fix a typo UserModeLinux-HOWTO.txt: remove ^H characters um: we need sys/user.h only on i386 um: merge delay_{32,64}.c um: distribute exports to where exported stuff is defined um: kill system-um.h um: generic ftrace.h will do... um: segment.h is x86-only and needed only there um: asm/pda.h is not needed anymore um: hw_irq.h can go generic as well um: switch to generic-y um: clean Kconfig up a bit um: a couple of missing dependencies... um: kill useless argument of free_chan() and free_one_chan() um: unify ptrace_user.h um: unify KSTK_... um: fix gcov build breakage ...
2011-11-02um: switch to use of drivers/KconfigAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-01isdn: hisax: Fix typo 'HISAX_DE_AOC'Paul Bolle
That should probably be 'CONFIG_DE_AOC'. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31drivers/isdn: Add export.h for EXPORT_SYMBOL/THIS_MODULE as required.Paul Gortmaker
In preparation of the module.h usage cleanup, call out the header that we need to get EXPORT_SYMBOL variants and THIS_MODULE into scope. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/isdn: Add module.h to ISDN files implicitly using it.Paul Gortmaker
So that we don't get build failures once the implicit module.h presence is terminated. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-26Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits) TTY: serial_core: Fix crash if DCD drop during suspend tty/serial: atmel_serial: bootconsole removed from auto-enumerates Revert "TTY: call tty_driver_lookup_tty unconditionally" tty/serial: atmel_serial: add device tree support tty/serial: atmel_serial: auto-enumerate ports tty/serial: atmel_serial: whitespace and braces modifications tty/serial: atmel_serial: change platform_data variable name tty/serial: RS485 bindings for device tree TTY: call tty_driver_lookup_tty unconditionally TTY: pty, release tty in all ptmx_open fail paths TTY: make tty_add_file non-failing TTY: drop driver reference in tty_open fail path 8250_pci: Fix kernel panic when pch_uart is disabled h8300: drivers/serial/Kconfig was moved parport_pc: release IO region properly if unsupported ITE887x card is found tty: Support compat_ioctl get/set termios_locked hvc_console: display printk messages on console. TTY: snyclinkmp: forever loop in tx_load_dma_buffer() tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case) ... Fix up Conflicts in: - drivers/tty/serial/8250_pci.c Trivial conflict with removed duplicate device ID - drivers/tty/serial/atmel_serial.c Annoying silly conflict between "specify the port num via platform_data" and other changes to atmel_console_init
2011-09-15Merge branch 'master' into for-nextJiri Kosina
Fast-forward merge with Linus to be able to merge patches based on more recent version of the tree.
2011-09-15isdn: Convert vmalloc/memset to vzallocJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-25TTY: use tty_wait_until_sent_from_close in other driversJiri Slaby
Let's use the newly added helper to avoid stalls in drivers which are not yet ported to tty_port helpers. Those which are broken (call tty_wait_until_sent with irqs disabled) are left untouched. They are in a deeper trouble than we are trying to solve here. This includes amiserial, 68328serial, 68360serial and crisv10. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (32 commits) tg3: Remove 5719 jumbo frames and TSO blocks tg3: Break larger frags into 4k chunks for 5719 tg3: Add tx BD budgeting code tg3: Consolidate code that calls tg3_tx_set_bd() tg3: Add partial fragment unmapping code tg3: Generalize tg3_skb_error_unmap() tg3: Remove short DMA check for 1st fragment tg3: Simplify tx bd assignments tg3: Reintroduce tg3_tx_ring_info ASIX: Use only 11 bits of header for data size ASIX: Simplify condition in rx_fixup() Fix cdc-phonet build bonding: reduce noise during init bonding: fix string comparison errors net: Audit drivers to identify those needing IFF_TX_SKB_SHARING cleared net: add IFF_SKB_TX_SHARED flag to priv_flags net: sock_sendmsg_nosec() is static forcedeth: fix vlans gianfar: fix bug caused by 87c288c6e9aa31720b72e2bc2d665e24e1653c3e gro: Only reset frag0 when skb can be pulled ...
2011-07-27net: Audit drivers to identify those needing IFF_TX_SKB_SHARING clearedNeil Horman
After the last patch, We are left in a state in which only drivers calling ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real hardware call ether_setup for their net_devices and don't hold any state in their skbs. There are a handful of drivers that violate this assumption of course, and need to be fixed up. This patch identifies those drivers, and marks them as not being able to support the safe transmission of skbs by clearning the IFF_TX_SKB_SHARING flag in priv_flags Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Karsten Keil <isdn@linux-pingi.de> CC: "David S. Miller" <davem@davemloft.net> CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: Patrick McHardy <kaber@trash.net> CC: Krzysztof Halasa <khc@pm.waw.pl> CC: "John W. Linville" <linville@tuxdriver.com> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Marcel Holtmann <marcel@holtmann.org> CC: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-13net: Push protocol type directly down to header_ops->cache()David S. Miller
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-17gigaset: call module_put before restart of if_open()Pavel Shved
if_open() calls try_module_get(), and after an attempt to lock a mutex the if_open() function may return -ERESTARTSYS without putting the module. Then, when if_open() is executed again, try_module_get() is called making the reference counter of THIS_MODULE greater than one at successful exit from if_open(). The if_close() function puts the module only once, and as a result it can't be unloaded. This patch adds module_put call before the return from if_open(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Pavel Shved <shved@ispras.ru> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-11ISDN, hfcsusb: Don't leak in hfcsusb_ph_info()Jesper Juhl
We leak the memory allocated to 'phi' when the variable goes out of scope in hfcsusb_ph_info(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-26isdn/diva: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Cc: Armin Schindler <mac@melware.de> Cc: netdev@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits) bonding: documentation and code cleanup for resend_igmp bonding: prevent deadlock on slave store with alb mode (v3) net: hold rtnl again in dump callbacks Add Fujitsu 1000base-SX PCI ID to tg3 bnx2x: protect sequence increment with mutex sch_sfq: fix peek() implementation isdn: netjet - blacklist Digium TDM400P via-velocity: don't annotate MAC registers as packed xen: netfront: hold RTNL when updating features. sctp: fix memory leak of the ASCONF queue when free asoc net: make dev_disable_lro use physical device if passed a vlan dev (v2) net: move is_vlan_dev into public header file (v2) bug.h: Fix build with CONFIG_PRINTK disabled. wireless: fix fatal kernel-doc error + warning in mac80211.h wireless: fix cfg80211.h new kernel-doc warnings iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled dst: catch uninitialized metrics be2net: hash key for rss-config cmd not set bridge: initialize fake_rtable metrics net: fix __dst_destroy_metrics_generic() ... Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
2011-05-25isdn: netjet - blacklist Digium TDM400PPrarit Bhargava
[2nd try ... 1st attempt didn't make it to netdev mailing list] A quick google search reveals that people with this card are blacklisting it in the initramfs and in the module blacklist based on a statement that it is unsupported. Since the older Digium is also unsupported I'm pretty confident that this newer card is also not supported. lspci -xxx -vv shows 04:07.0 Communication controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface Subsystem: Device b100:0003 P. ----8<---- The Asterisk Voice Card, DIGIUM TDM400P is unsupported by the netjet driver. Blacklist it like the Digium X100P/X101P card. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-19isdn: capi: Use pr_debug() instead of ifdefs.David S. Miller
I was investigating some warnings that spew because of the _DEBUG_FOO ifdef'ery in here. Instead of adding more ifdefs to fix that warning, let's use pr_debug() and get rid of these CPP checks altogether. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13drivers/isdn/hisax: Drop unused listJulia Lawall
The file st5481_init.c locally defines and initializes the adapter_list variable, but does not use it for anything. Removing the list makes it possible to remove the list field from the st5481_adapter data structure. In the function probe_st5481, it also makes it possible to free the locally allocated adapter value on an error exit. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-04-22tty: make receive_buf() return the amout of bytes receivedFelipe Balbi
it makes it simpler to keep track of the amount of bytes received and simplifies how flush_to_ldisc counts the remaining bytes. It also fixes a bug of lost bytes on n_tty when flushing too many bytes via the USB serial gadget driver. Tested-by: Stefan Bigler <stefan.bigler@keymile.com> Tested-by: Toby Gray <toby.gray@realvnc.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-17isdn: i4l: isdn_tty: Fix unused-but-set variables.David S. Miller
The variable 'fcr' is set but not used in isdn_tty_change_speed(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: mISDN: socket: Fix set-but-unused variables.David S. Miller
The variable 'len' is set but unused in data_sock_getsockopt(). The code should use 'len' to validate that the user's socket option is indeed the right size. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: i4l: isdn_net: Fix set-but-unused variables.David S. Miller
The variable 'unused' is set but unused in isdn_net_ciscohdlck_slarp_in(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: i4l: isdn_common: Fix set-but-unused variables.David S. Miller
The variable 'ch' is set but unused in isdn_capi_rec_hl_msg(). Just kill it off. Similarly for 'chidx' in isdn_ioctl() and 'di' in isdn_capi_rec_hl_msg(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: teles_cs: Fix set-but-unused variables.David S. Miller
The variable 'dev' is set but unused in teles_cs_config(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: l3ni1: Fix set-but-unused variables.David S. Miller
The variable 'cause' is set but unused in ni1up(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: l3dss1: Fix set-but-unused variables.David S. Miller
The variable 'cause' is set but unused in dss1up(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: jade: Fix set-but-unused variables.David S. Miller
The variable 'i' is set but unused in JadeVersion(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: ipacx: Fix set-but-unused variables.David S. Miller
The variable 'cda2_cr' is set but unused in ctrl_complete(). Just kill it off. Keep the cs->readisac() call just in case the register read has side effects. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: hfc_usb: Fix set-but-unused variables.David S. Miller
The variable 'buf' is set but unused in ctrl_complete(). Just kill it off. Similarly for 'err' in hfc_usb_init(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: elsa_ser: Fix set-but-unused variables.David S. Miller
The variable 'bits' is set but unused in change_speed(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: elsa_cs: Fix set-but-unused variables.David S. Miller
The variable 'dev' is set but unused in elsa_cs_config(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: arcofi: Fix set-but-unused variables.David S. Miller
The variable 'val' is set but unused in send_arcofi(). Just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: hfcsusb: Fix set-but-unused variables.David S. Miller
The variable 'buf' is set but unused in ctrl_complete(). Just kill it off. Similarly for the variable 'err' in setup_hfcsusb(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: hfcpci: Fix set-but-unused variables.David S. Miller
The variable 'total' is set but unused in hfcpci_empty_bfifo(). Just kill it off. Similarly for the variable 'val' in ph_state_nt(). Signed-off-by: David S. Miller <davem@davemloft.net>
