This is the mindless scripted replacement of kernel use of POLL*
variables as described by Al, done by this script:
for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do
L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'`
for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done
done
with de-mangling cleanups yet to come.
NOTE! On almost all architectures, the EPOLL* constants have the same
values as the POLL* constants do. But they keyword here is "almost".
For various bad reasons they aren't the same, and epoll() doesn't
actually work quite correctly in some cases due to this on Sparc et al.
The next patch from Al will sort out the final differences, and we
should be all done.
Scripted-by: Al Viro <viro@zeniv.linux.org.uk>
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
This mechanically converts all remaining cases of ancient open-coded timer
setup with the old setup_timer() API, which is the first step in timer
conversions. This has no behavioral changes, since it ultimately just
changes the order of assignment to fields of struct timer_list when
finding variations of:
init_timer(&t);
f.function = timer_callback;
t.data = timer_callback_arg;
to be converted into:
setup_timer(&t, timer_callback, timer_callback_arg);
The conversion is done with the following Coccinelle script, which
is an improved version of scripts/cocci/api/setup_timer.cocci, in the
following ways:
- assignments-before-init_timer() cases
- limit the .data case removal to the specific struct timer_list instance
- handling calls by dereference (timer->field vs timer.field)
--dir . \
--cocci-file ~/src/data/setup_timer.cocci
@fix_address_of@
expression e;
init_timer(
-&(e)
+&e
// Match the common cases first to avoid Coccinelle parsing loops with
// "... when" clauses.
@match_immediate_function_data_after_init_timer@
expression e, func, da;
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
-\(e.function\|e->function\) = func;
-\(e.data\|e->data\) = da;
@match_immediate_function_data_before_init_timer@
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
@match_function_and_data_after_init_timer@
expression e, e2, e3, e4, e5, func, da;
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
... when != func = e2
when != da = e3
-e.function = func;
... when != da = e4
-e.data = da;
-e->function = func;
... when != da = e4
-e->data = da;
-e.data = da;
... when != func = e5
-e.function = func;
-e->data = da;
@match_function_and_data_before_init_timer@
-e.function = func;
... when != da = e4
-e.data = da;
... when != da = e4
-e->data = da;
-e.data = da;
-e.function = func;
-e->data = da;
when != da = e3
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
@r1 exists@
expression t;
identifier f;
position p;
f(...) { ... when any
init_timer@p(\(&t\|t\))
... when any
@r2 exists@
expression r1.t;
identifier g != r1.f;
expression e8;
g(...) { ... when any
\(t.data\|t->data\) = e8
... when any
// It is dangerous to use setup_timer if data field is initialized
// in another function.
@script:python depends on r2@
p << r1.p;
cocci.include_match(False)
@r3@
expression r1.t, func, e7;
position r1.p;
-init_timer@p(&t);
+setup_timer(&t, func, 0UL);
... when != func = e7
-t.function = func;
-t.function = func;
-init_timer@p(&t);
-init_timer@p(t);
+setup_timer(t, func, 0UL);
-t->function = func;
-init_timer@p(t);
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In isdn_ppp_write(), the header (i.e., protobuf) of the buffer is
fetched twice from userspace. The first fetch is used to peek at the
protocol of the message and reset the huptimer if necessary; while the
second fetch copies in the whole buffer. However, given that buf resides
in userspace memory, a user process can race to change its memory content
across fetches. By doing so, we can either avoid resetting the huptimer
for any type of packets (by first setting proto to PPP_LCP and later
change to the actual type) or force resetting the huptimer for LCP
packets.
This patch changes this double-fetch behavior into two single fetches
decided by condition (lp->isdn_device < 0 || lp->isdn_channel <0).
A more detailed discussion can be found at
https://marc.info/?l=linux-kernel&m=150586376926123&w=2
Signed-off-by: Meng Xu <mengxu.gatech@gmail.com>
This fixes a potential buffer overflow in isdn_net.c caused by an
unbounded strcpy.
[ ISDN seems to be effectively unmaintained, and the I4L driver in
particular is long deprecated, but in case somebody uses this..
- Linus ]
Signed-off-by: Jiten Thakkar <jitenmt@gmail.com>
Signed-off-by: Annie Cherkaev <annie.cherk@gmail.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: stable@kernel.org
Pull misc user access cleanups from Al Viro:
"The first pile is assorted getting rid of cargo-culted access_ok(),
cargo-culted set_fs() and field-by-field copyouts.
The same description applies to a lot of stuff in other branches -
this is just the stuff that didn't fit into a more specific topical
branch"
* 'work.misc-set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
Switch flock copyin/copyout primitives to copy_{from,to}_user()
fs/fcntl: return -ESRCH in f_setown when pid/pgid can't be found
fs/fcntl: f_setown, avoid undefined behaviour
fs/fcntl: f_setown, allow returning error
lpfc debugfs: get rid of pointless access_ok()
adb: get rid of pointless access_ok()
isdn: get rid of pointless access_ok()
compat statfs: switch to copy_to_user()
fs/locks: don't mess with the address limit in compat_fcntl64
nfsd_readlink(): switch to vfs_get_link()
drbd: ->sendpage() never needed set_fs()
fs/locks: pass kernel struct flock to fcntl_getlk/setlk
fs: locks: Fix some troubles at kernel-doc comments
in my commit b952f4dff2751252db073c27c0f8a16a416a2ddc,
- *(u8 *)skb_put(skb_out, 1) = (u8)(accm >> 24); \
+ skb_put(skb_out, (u8)(accm >> 24)); \
it should skb_put_u8()
Fixes: b952f4dff275 ("net: manual clean code which call skb_put_[data:zero])")
Signed-off-by: yuan linyu <Linyu.Yuan@alcatel-sbell.com.cn>
Joe and Bjørn suggested that it'd be nicer to not have the
cast in the fairly common case of doing
*(u8 *)skb_put(skb, 1) = c;
Add skb_put_u8() for this case, and use it across the code,
using the following spatch:
expression SKB, C, S;
typedef u8;
identifier fn = {skb_put};
fresh identifier fn2 = fn ## "_u8";
- *(u8 *)fn(SKB, S) = C;
+ fn2(SKB, C);
Note that due to the "S", the spatch isn't perfect, it should
have checked that S is 1, but there's also places that use a
sizeof expression like sizeof(var) or sizeof(u8) etc. Turns
out that nobody ever did something like
*(u8 *)skb_put(skb, 2) = c;
which would be wrong anyway since the second byte wouldn't be
initialized.
Suggested-by: Joe Perches <joe@perches.com>
Suggested-by: Bjørn Mork <bjorn@mork.no>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
typedef u8;
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
- *(fn(SKB, LEN))
identifier fn = {
skb_pull,
__skb_pull,
skb_pull_inline,
__pskb_pull_tail,
__pskb_pull,
pskb_pull
type T;
+ E = fn(SKB, LEN)
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
type T;
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
copy_to_user()/copy_from_user()/get_user() check themselves
The driver may sleep under a spin lock, the function call path is:
isdn_ppp_mp_receive (acquire the lock)
isdn_ppp_mp_reassembly
isdn_ppp_push_higher
isdn_ppp_decompress
isdn_ppp_ccp_reset_trans
isdn_ppp_ccp_reset_alloc_state
kzalloc(GFP_KERNEL) --> may sleep
To fixed it, the "GFP_KERNEL" is replaced with "GFP_ATOMIC".
Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com>
Use setup_timer() instead of init_timer() to simplify the code.
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
<linux/sched/signal.h>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/signal.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Prepare to mark sensitive kernel structures for randomization by making
sure they're using designated initializers. These were identified during
allyesconfig builds of x86, arm, and arm64, with most initializer fixes
extracted from grsecurity.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty and serial driver updates from Greg KH:
"Here's the large TTY and Serial driver update for 4.7-rc1.
A few new serial drivers are added here, and Peter has fixed a bunch
of long-standing bugs in the tty layer and serial drivers as normal.
Full details in the shortlog.
All of these have been in linux-next for a while with no reported
issues"
* tag 'tty-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (88 commits)
MAINTAINERS: 8250: remove website reference
serial: core: Fix port mutex assert if lockdep disabled
serial: 8250_dw: fix wrong logic in dw8250_check_lcr()
tty: vt, finish looping on duplicate
tty: vt, return error when con_startup fails
QE-UART: add "fsl,t1040-ucc-uart" to of_device_id
serial: mctrl_gpio: Drop support for out1-gpios and out2-gpios
serial: 8250dw: Add device HID for future AMD UART controller
Fix OpenSSH pty regression on close
serial: mctrl_gpio: add IRQ locking
serial: 8250: Integrate Fintek into 8250_base
serial: mps2-uart: add support for early console
serial: mps2-uart: add MPS2 UART driver
dt-bindings: document the MPS2 UART bindings
serial: sirf: Use generic uart-has-rtscts DT property
serial: sirf: Introduce helper variable struct device_node *np
serial: mxs-auart: Use generic uart-has-rtscts DT property
serial: imx: Use generic uart-has-rtscts DT property
doc: DT: Add Generic Serial Device Tree Bindings
serial: 8250: of: Make tegra_serial_handle_break() static
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
Replace ASYNC_INITIALIZED bit in the tty_port::flags field with
TTY_PORT_INITIALIZED bit in the tty_port::iflags field. Introduce helpers
tty_port_set_initialized() and tty_port_initialized() to abstract
atomic bit ops.
Note: the transforms for test_and_set_bit() and test_and_clear_bit()
are unnecessary as the state transitions are already mutually exclusive;
the tty lock prevents concurrent open/close/hangup.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Replace ASYNC_CHECK_CD bit in the tty_port::flags field with
TTY_PORT_CHECK_CD bit in the tty_port::iflags field. Introduce helpers
tty_port_set_check_carrier() and tty_port_check_carrier() to abstract
the atomic bit ops.
Replace ASYNC_NORMAL_ACTIVE bit in the tty_port::flags field with
TTY_PORT_ACTIVE bit in the tty_port::iflags field. Introduce helpers
tty_port_set_active() and tty_port_active() to abstract atomic bit ops.
Extract state changes from port lock sections, as this usage is
broken and confused; the state transitions are protected by the
tty lock (which mutually excludes parallel open/close/hangup),
and no user tests the active state while holding the port lock.
Abstract TTY_IO_ERROR status test treewide with tty_io_error().
NB: tty->flags uses atomic bit ops; replace non-atomic bit test
with test_bit().
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here is the big staging driver pull request for 4.6-rc1.
Lots of little things here, over 1600 patches or so. Notable is all
of the good Lustre work happening, those developers have finally woken
up and are cleaning up their code greatly. The Outreachy intern
application process is also happening, which brought in another 400 or
so patches. Full details are in the very long shortlog.
All of these have been in linux-next with no reported issues"
* tag 'staging-4.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1673 commits)
staging: lustre: fix aligments in lnet selftest
staging: lustre: report minimum of two buffers for LNet selftest load test
staging: lustre: test for proper errno code in lstcon_rpc_trans_abort
staging: lustre: filter remaining extra spacing for lnet selftest
staging: lustre: remove extra spacing when setting variable for lnet selftest
staging: lustre: remove extra spacing of variable declartions for lnet selftest
staging: lustre: fix spacing issues checkpatch reported in lnet selftest
staging: lustre: remove returns in void function for lnet selftest
staging: lustre: fix bogus lst errors for lnet selftest
staging: netlogic: Replacing pr_err with dev_err after the call to devm_kzalloc
staging: mt29f_spinand: Replacing pr_info with dev_info after the call to devm_kzalloc
staging: android: ion: fix up file mode
staging: ion: debugfs invalid gfp mask
staging: rts5208: Replace pci_enable_device with pcim_enable_device
Staging: ieee80211: Place constant on right side of the test.
staging: speakup: Replace del_timer with del_timer_sync
staging: lowmemorykiller: fix 2 checks that checkpatch complained
staging: mt29f_spinand: Drop void pointer cast
staging: rdma: hfi1: file_ops: Replace ALIGN with PAGE_ALIGN
staging: rdma: hfi1: driver: Replace IS_ALIGNED with PAGE_ALIGNED
The icn, act2000 and pcbit drivers are all for very old hardware,
and it is highly unlikely that anyone is actually still using them
on modern kernels, if at all.
All three drivers apparently are for hardware that predates PCI
being the common connector, as they are ISA-only and active
PCI ISDN cards were widely available in the 1990s.
Looking through the git logs, it I cannot find any indication of a
patch to any of these drivers that has been tested on real hardware,
only cleanups or global API changes.
Acked-by: Karsten Keil <isdn@linux-pingi.de>
The tty core no longer provides ASYNC_CLOSING. Use private flag for
same purpose, which is to disable AT-emulator output (why this is
necessary is not clear).
The 'sc' ISDN driver relies on using readl() to access ISA I/O memory.
This has been deprecated and produced warnings since linux-2.3.23,
disabled by default since 2.4.10 and finally removed in 2.6.5.
I found this because the compiling the driver for ARM produces
a warning:
In file included from ../drivers/isdn/sc/includes.h:8:0,
from ../drivers/isdn/sc/init.c:13:
../arch/arm/include/asm/io.h:115:21: note: expected 'const volatile void *' but argument is of type 'long unsigned int'
It is pretty clear that this driver has not been used for a long time
and there is no point fixing it now, so let's remove it.
Pull tty/serial driver updates from Greg KH:
"Here is the big tty and serial driver update for 4.4-rc1.
Lots of serial driver updates and a few small tty core changes. Full
All of these have been in linux-next for a while"
* tag 'tty-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (148 commits)
tty: Use unbound workqueue for all input workers
tty: Abstract tty buffer work
tty: Prevent tty teardown during tty_write_message()
tty: core: Use correct spinlock flavor in tiocspgrp()
tty: Combine SIGTTOU/SIGTTIN handling
serial: amba-pl011: fix incorrect integer size in pl011_fifo_to_tty()
ttyFDC: Fix build problems due to use of module_{init,exit}
tty: remove unneeded return statement
serial: 8250_mid: add support for DMA engine handling from UART MMIO
dmaengine: hsu: remove platform data
dmaengine: hsu: introduce stubs for the exported functions
dmaengine: hsu: make the UART driver in control of selecting this driver
serial: fix mctrl helper functions
serial: 8250_pci: Intel MID UART support to its own driver
serial: fsl_lpuart: add earlycon support
tty: disable unbind for old 74xx based serial/mpsc console port
serial: pl011: Spelling s/clocks-names/clock-names/
n_tty: Remove reader wakeups for TTY_BREAK/TTY_PARITY chars
tty: synclink, fix indentation
serial: at91, fix rs485 properties
Currently slhc_init() treats out-of-range values of rslots and tslots
as equivalent to 0, except that if tslots is too large it will
dereference a null pointer (CVE-2015-7799).
Add a range-check at the top of the function and make it return an
ERR_PTR() on error instead of NULL. Change the callers accordingly.
Compile-tested only.
Reported-by: 郭永刚 <guoyonggang@360.cn>
References: http://article.gmane.org/gmane.comp.security.oss.general/17908
tty_wait_until_sent_from_close() drops the tty lock while waiting
for the tty driver to finish sending previously accepted data (ie.,
data remaining in its write buffer and transmit fifo).
tty_wait_until_sent_from_close() was added by commit a57a7bf3fc7e
("TTY: define tty_wait_until_sent_from_close") to prevent the entire
tty subsystem from being unable to open new ttys while waiting for
one tty to close while output drained.
However, since commit 0911261d4cb6 ("tty: Don't take tty_mutex for tty
count changes"), holding a tty lock while closing does not prevent other
ttys from being opened/closed/hung up, but only prevents lifetime event
changes for the tty under lock.
Holding the tty lock while waiting for output to drain does prevent
parallel non-blocking opens (O_NONBLOCK) from advancing or returning
while the tty lock is held. However, all parallel opens _already_
block even if the tty lock is dropped while closing and the parallel
open advances. Blocking in open has been in mainline since at least 2.6.29
(see tty_port_block_til_ready(); note the test for O_NONBLOCK is _after_
the wait while ASYNC_CLOSING).
IOW, before this patch a non-blocking open will sleep anyway for the
_entire_ duration of a parallel hardware shutdown, and when it wakes, the
error return will cause a release of its tty, and it will restart with
a fresh attempt to open. Similarly with a blocking open that is already
waiting; when it's woken, the hardware shutdown has already completed
to ASYNC_INITIALIZED is not set, which forces a release and restart as
well.
So, holding the tty lock across the _entire_ close (which is what this
patch does), even while waiting for output to drain, is equivalent to
the current outcome wrt parallel opens.
Cc: Alan Cox <alan@linux.intel.com>
Cc: David Laight <David.Laight@aculab.com>
CC: Arnd Bergmann <arnd@arndb.de>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: linuxppc-dev@lists.ozlabs.org
Pull trivial tree updates from Jiri Kosina:
"As usual, mostly comment, kerneldoc and printk() fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
lpfc: Grammar s/an negative/a negative/
ARM: lib/lib1funcs.S: fix typo s/substractions/subtractions/
cx25821: cx25821-medusa-reg.h: fix 0x0x prefix
lib: crc-itu-t.[ch] fix 0x0x prefix in integer constants
rapidio: Fix kerneldoc and comment
qla4xxx: Fix printk() in qla4_83xx_read_reset_template() and qla4_83xx_pre_loopback_config()
treewide: Kconfig: fix wording / spelling
usb/serial: fix grammar in Kconfig help text for FTDI_SIO
megaraid_sas: fix kerneldoc
netfilter: ebtables: fix comment grammar
drm/radeon: fix comment
isdn: fix grammar in comment
ARM: KVM: fix comment
Fix grammar / typo in comment.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Now that there are no more users kill dev_rebuild_header and all of it's
implementations.
This is long overdue.
ISDN4Linux always enables CTS flow control and does not use the
tty_port_cts_enabled() helper function; remove ASYNC_CTS_FLOW
state enable/disable.
cc: Karsten Keil <isdn@linux-pingi.de>
cc: <netdev@vger.kernel.org>
clean up names related to socket filtering and bpf in the following way:
- everything that deals with sockets keeps 'sk_*' prefix
- everything that is pure BPF is changed to 'bpf_*' prefix
split 'struct sk_filter' into
struct sk_filter {
atomic_t refcnt;
struct rcu_head rcu;
struct bpf_prog *prog;
and
struct bpf_prog {
u32 jited:1,
len:31;
struct sock_fprog_kern *orig_prog;
unsigned int (*bpf_func)(const struct sk_buff *skb,
const struct bpf_insn *filter);
union {
struct sock_filter insns[0];
struct bpf_insn insnsi[0];
struct work_struct work;
so that 'struct bpf_prog' can be used independent of sockets and cleans up
'unattached' bpf use cases
split SK_RUN_FILTER macro into:
SK_RUN_FILTER to be used with 'struct sk_filter *' and
BPF_PROG_RUN to be used with 'struct bpf_prog *'
__sk_filter_release(struct sk_filter *) gains
__bpf_prog_release(struct bpf_prog *) helper function
also perform related renames for the functions that work
with 'struct bpf_prog *', since they're on the same lines:
sk_filter_size -> bpf_prog_size
sk_filter_select_runtime -> bpf_prog_select_runtime
sk_filter_free -> bpf_prog_free
sk_unattached_filter_create -> bpf_prog_create
sk_unattached_filter_destroy -> bpf_prog_destroy
sk_store_orig_filter -> bpf_prog_store_orig_filter
sk_release_orig_filter -> bpf_release_orig_filter
__sk_migrate_filter -> bpf_migrate_filter
__sk_prepare_filter -> bpf_prepare_filter
API for attaching classic BPF to a socket stays the same:
sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *)
and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program
which is used by sockets, tun, af_packet
API for 'unattached' BPF programs becomes:
bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *)
and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program
which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
This patch changes instances of magic numbers like 4 and 8 to equivalent
constants.
The Coccinelle semantic patch used for making the change is as follows:
// <smpl>
@r@
type T;
T E;
identifier fld;
identifier c;
E->fld & c
@s@
constant C;
identifier r.c;
#define c C
r.T E;
identifier r.fld;
identifier r.c;
constant s.C;
E->fld &
- C
+ c
// </smpl>
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
drivers/infiniband/hw/cxgb4/device.c
The cxgb4 conflict was simply overlapping changes.
Commit 568f194e8bd16c353ad50f9ab95d98b20578a39d ("net: ppp: use
sk_unattached_filter api") inadvertently changed the logic when setting
PPP pass and active filters. This applies to both the generic PPP subsystem
implemented by drivers/net/ppp/ppp_generic.c and the ISDN PPP subsystem
implemented by drivers/isdn/i4l/isdn_ppp.c. The original code in ppp_ioctl()
(or isdn_ppp_ioctl(), resp.) handling PPPIOCSPASS and PPPIOCSACTIVE allowed to
remove a pass/active filter previously set by using a filter of length zero.
However, with the new code this is not possible anymore as this case is not
explicitly checked for, which leads to passing NULL as a filter to
sk_unattached_filter_create(). This results in returning EINVAL to the caller.
Additionally, the variables ppp->pass_filter and ppp->active_filter (or
is->pass_filter and is->active_filter, resp.) are not reset to NULL, although
the filters they point to may have been destroyed by
sk_unattached_filter_destroy(), so in this EINVAL case dangling pointers are
left behind (provided the pointers were previously non-NULL).
This patch corrects both problems by checking whether the filter passed is
empty or non-empty, and prevents sk_unattached_filter_create() from being
called in the first case. Moreover, the pointers are always reset to NULL
as soon as sk_unattached_filter_destroy() returns.
Signed-off-by: Christoph Schulz <develop@kristov.de>
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
sk_unattached_filter api") causes sk_chk_filter() to be called twice when
setting a PPP pass or active filter. This applies to both the generic PPP
subsystem implemented by drivers/net/ppp/ppp_generic.c and the ISDN PPP
subsystem implemented by drivers/isdn/i4l/isdn_ppp.c. The first call is from
within get_filter(). The second one is through the call chain
ppp_ioctl() or isdn_ppp_ioctl()
--> sk_unattached_filter_create()
--> __sk_prepare_filter()
--> sk_chk_filter()
The first call from within get_filter() should be deleted as get_filter() is
called just before calling sk_unattached_filter_create() later on, which
eventually calls sk_chk_filter() anyway.
For 3.15.x, this proposed change is a bugfix rather than a pure optimization as
in that branch, sk_chk_filter() may replace filter codes by other codes which
are not recognized when executing sk_chk_filter() a second time. So with
3.15.x, if sk_chk_filter() is called twice, the second invocation may yield
EINVAL (this depends on the filter codes found in the filter to be set, but
because the replacement is done for frequently used codes, this is almost
always the case). The net effect is that setting pass and/or active PPP filters
does not work anymore, since sk_unattached_filter_create() always returns
EINVAL due to the second call to sk_chk_filter(), regardless whether the filter
was originally sane or not.
Acked-by: Daniel Borkmann <dborkman@redhat.com>
The sk_unattached_filter_create() API is used by BPF filters that
are not directly attached or related to sockets, and are used in
team, ptp, xt_bpf, cls_bpf, etc. As such all users do their own
internal managment of obtaining filter blocks and thus already
have them in kernel memory and set up before calling into
sk_unattached_filter_create(). As a result, due to __user annotation
in sock_fprog, sparse triggers false positives (incorrect type in
assignment [different address space]) when filters are set up before
passing them to sk_unattached_filter_create(). Therefore, let
sk_unattached_filter_create() API use sock_fprog_kern to overcome
this issue.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Similarly as in ppp, we need to migrate the ISDN/PPP code to make use
of the sk_unattached_filter api in order to decouple having direct
filter structure access. By using sk_unattached_filter_{create,destroy},
we can allow for the possibility to jit compile filters for faster
filter verdicts as well.
Joint work with Alexei Starovoitov.
Cc: isdn4linux@listserv.isdn4linux.de
Use del_timer_sync to ensure that the timer is stopped on all CPUs before
the driver exists.
This change was suggested by Thomas Gleixner.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r@
declarer name module_exit;
identifier ex;
module_exit(ex);
identifier r.ex;
ex(...) {
- del_timer
+ del_timer_sync
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The isdn core code uses a couple of wait queues with
interruptible_sleep_on, which is racy and about to get
removed from the kernel. Fortunately, we know for each case
what we are waiting for, so they can all be converted to
the better wait_event_interruptible interface.
Use possibly more efficient ether_addr_equal
instead of memcmp.
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
