path: root/drivers/isdn/hisax/isar.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-03hisax: timeout off by one in waitrecmsg()Roel Kluin
With `while (timeout++ < maxdelay)' timeout reaches maxdelay + 1 after the loop This is probably unlikely a problem in practice. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09isdn: fix section mismatch warnings in isac.c and isar.cSam Ravnborg
Fix the following warnings: WARNING: drivers/isdn/hisax/built-in.o(.text+0x1b276): Section mismatch in reference from the function inithscxisac() to the function .devinit.text:clear_pending_isac_ints() WARNING: drivers/isdn/hisax/built-in.o(.text+0x1b286): Section mismatch in reference from the function inithscxisac() to the function .devinit.text:initisac() WARNING: drivers/isdn/hisax/built-in.o(.text+0x1fec7): Section mismatch in reference from the function AVM_card_msg() to the function .devinit.text:clear_pending_isac_ints() WARNING: drivers/isdn/hisax/built-in.o(.text+0x21669): Section mismatch in reference from the function AVM_card_msg() to the function .devinit.text:clear_pending_isac_ints() WARNING: drivers/isdn/hisax/built-in.o(.text+0x21671): Section mismatch in reference from the function AVM_card_msg() to the function .devinit.text:initisac() WARNING: drivers/isdn/hisax/built-in.o(.text+0x2991e): Section mismatch in reference from the function Sedl_card_msg() to the function .devinit.text:clear_pending_isac_ints() WARNING: drivers/isdn/hisax/built-in.o(.text+0x29936): Section mismatch in reference from the function Sedl_card_msg() to the function .devinit.text:initisac() WARNING: drivers/isdn/hisax/built-in.o(.text+0x2993e): Section mismatch in reference from the function Sedl_card_msg() to the function .devinit.text:initisar() WARNING: drivers/isdn/hisax/built-in.o(.text+0x2e026): Section mismatch in reference from the function NETjet_S_card_msg() to the function .devinit.text:clear_pending_isac_ints() WARNING: drivers/isdn/hisax/built-in.o(.text+0x2e02e): Section mismatch in reference from the function NETjet_S_card_msg() to the function .devinit.text:initisac() WARNING: drivers/isdn/hisax/built-in.o(.text+0x37813): Section mismatch in reference from the function BKM_card_msg() to the function .devinit.text:clear_pending_isac_ints() WARNING: drivers/isdn/hisax/built-in.o(.text+0x37823): Section mismatch in reference from the function BKM_card_msg() to the function .devinit.text:initisac() initisar(), initisac() and clear_pending_isac_ints() were all used via a cardmsg fnction - which may be called ouside __devinit context. So remove the bogus __devinit annotation of the above three functions to fix the warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Karsten Keil <kkeil@suse.de> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-27[PATCH] ISDN: fix BChannel_bh() call from isar_bh()Jiri Kosina
isar_bh() bh handler calls another (compatible) bh handler - BChannel_bh() - but passes struct BCState* instead of struct work_struct*, which seems wrong. Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] drivers/isdn/hisax/: proper prototypesAdrian Bunk
- add functions prototypes for some global functions to header files - remove unneeded "extern"s from some function prototypes You might note that this patch results in a new warning - that's due to the fact that with a proper prototype gcc is able to discover a broken work_struct conversion. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2005-11-07[PATCH] kfree cleanup: drivers/isdnJesper Juhl
This is the drivers/isdn/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/isdn/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/isdn/hisax/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - remove the compiled but unused st5481_hdlc.{c,h} - kill enternow.h - enternow_pci.c: kill InByte/OutByte/BYTE - isdnl2.c: kill FreeSkb - remove or #if 0 the following unused functions: - config.c: IsdnCardState - ipacx.c: ipacx_new_ph - ipacx.c: dch_bh - ipacx.c: setup_ipacx - isdnl2.c: IsRR Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Kai Germaschewski <kai@germaschewski.name> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
