The ISDN4Linux HiSax driver family contains the last remaining users
of the deprecated pci_find_device() function. This patch creates a
private copy of that function in HiSax, and removes the now unused
global function together with its controlling configuration option,
CONFIG_PCI_LEGACY.
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
The result of container_of should not be NULL. In particular, in this case
the argument to the enclosing function has passed though INIT_WORK, which
dereferences it, implying that its container cannot be NULL.
A simplified version of the semantic patch that makes this change is as
follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
identifier fn,work,x,fld;
type T;
expression E1,E2;
statement S;
static fn(struct work_struct *work) {
... when != work = E1
x = container_of(work,T,fld)
... when != x = E2
- if (x == NULL) S
// </smpl>
Signed-off-by: Karsten Keil <keil@b1-systems.de>
Replace wrong code with correct DMA API functions.
For the vast majority of CardType[card->typ] uses (but not all!),
the string is constant for each driver. Therefore, we may replace
CardType[card->typ] with the actual string describing the driver, making
each printk() a bit more simple.
This also has the nice, intended side effect of greatly reducing
external references to hisax global CardType[]. This will be of value
once the ISDN drivers are converted to the ISA/PCI/PNP hotplug APIs.
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
* trim trailing whitespace
* remove CONFIG_PCI ifdefs, this driver is always PCI (Kconfig enforced)
* remove return statements at the tail of a function
* remove indentation levels by returning an error code immediately.
Makes the code much more readable, and easier to update to PCI hotplug
API.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
* diva, sedlbauer: the 'ready' label is only used in certain configurations
* hfc_pci:
- cast 'arg' to proper size for testing and printing
- print out 'void __iomem *' variables with %p,
rather than using incorrect casts that throw warnings
Acked-by: Karsten Keil <kkeil@suse.de>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Fix the warnings about the section mismatches for __init* in the HiSax
driver.
Signed-off-by: Karsten Keil <kkeil@suse.de>
Cc: Karsten Keil <kkeil@suse.de>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
resource_size_t where needed
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Add new PCI IDs for HFC-S PCI based ISDN TA 'Primux II S0' and 'Primux II S0'
from Gerdes AG
Signed-off-by: Martin Bachem <info@colognechip.com>
Sitecom DC-105 PCI work with hfc_pci HiSax driver
This patch contains the following possible cleanups:
- make needlessly global code static
- remove the compiled but unused st5481_hdlc.{c,h}
- kill enternow.h
- enternow_pci.c: kill InByte/OutByte/BYTE
- isdnl2.c: kill FreeSkb
- remove or #if 0 the following unused functions:
- config.c: IsdnCardState
- ipacx.c: ipacx_new_ph
- ipacx.c: dch_bh
- ipacx.c: setup_ipacx
- isdnl2.c: IsRR
Acked-by: Kai Germaschewski <kai@germaschewski.name>
infrastructure for it.
Let it rip!
