path: root/drivers/isdn/hardware
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-18USB: convert some miscellanies drivers to use module_usb_driver()Greg Kroah-Hartman
This converts the remaining USB drivers in the kernel to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Till Harbaum <till@harbaum.org> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-31drivers/isdn: Add module.h to ISDN files implicitly using it.Paul Gortmaker
So that we don't get build failures once the implicit module.h presence is terminated. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-11ISDN, hfcsusb: Don't leak in hfcsusb_ph_info()Jesper Juhl
We leak the memory allocated to 'phi' when the variable goes out of scope in hfcsusb_ph_info(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-26isdn/diva: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Cc: Armin Schindler <mac@melware.de> Cc: netdev@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits) bonding: documentation and code cleanup for resend_igmp bonding: prevent deadlock on slave store with alb mode (v3) net: hold rtnl again in dump callbacks Add Fujitsu 1000base-SX PCI ID to tg3 bnx2x: protect sequence increment with mutex sch_sfq: fix peek() implementation isdn: netjet - blacklist Digium TDM400P via-velocity: don't annotate MAC registers as packed xen: netfront: hold RTNL when updating features. sctp: fix memory leak of the ASCONF queue when free asoc net: make dev_disable_lro use physical device if passed a vlan dev (v2) net: move is_vlan_dev into public header file (v2) bug.h: Fix build with CONFIG_PRINTK disabled. wireless: fix fatal kernel-doc error + warning in mac80211.h wireless: fix cfg80211.h new kernel-doc warnings iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled dst: catch uninitialized metrics be2net: hash key for rss-config cmd not set bridge: initialize fake_rtable metrics net: fix __dst_destroy_metrics_generic() ... Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
2011-05-25isdn: netjet - blacklist Digium TDM400PPrarit Bhargava
[2nd try ... 1st attempt didn't make it to netdev mailing list] A quick google search reveals that people with this card are blacklisting it in the initramfs and in the module blacklist based on a statement that it is unsupported. Since the older Digium is also unsupported I'm pretty confident that this newer card is also not supported. lspci -xxx -vv shows 04:07.0 Communication controller: Tiger Jet Network Inc. Tiger3XX Modem/ISDN interface Subsystem: Device b100:0003 P. ----8<---- The Asterisk Voice Card, DIGIUM TDM400P is unsupported by the netjet driver. Blacklist it like the Digium X100P/X101P card. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-06pcmcia: Convert pcmcia_device_id declarations to constJoe Perches
Saves about 50KB of data. Old/new size of all objects: text data bss dec hex filename 563015 80096 130684 773795 bcea3 (TOTALS) 610916 32256 130632 773804 bceac (TOTALS) Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> (for drivers/net/can/softing/softing_cs.c) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-04-17isdn: hfcsusb: Fix set-but-unused variables.David S. Miller
The variable 'buf' is set but unused in ctrl_complete(). Just kill it off. Similarly for the variable 'err' in setup_hfcsusb(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: hfcpci: Fix set-but-unused variables.David S. Miller
The variable 'total' is set but unused in hfcpci_empty_bfifo(). Just kill it off. Similarly for the variable 'val' in ph_state_nt(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17isdn: eicon: Fix set-but-unused variables.David S. Miller
The variable 'best_id' is set but unused in diva_mnt_add_xdi_adapter(). Just kill it off. Similarly for the variable 'CIP' in connect_req(), 'Number' in sig_ind(), 'Info' in dtmf_confirmation() mixer_command() fax_connect_ack_command() fax_edata_ack_command() rtp_connect_b3_res_command() and rtp_connect_b3_res_command(), and 'a' in mixer_indication_coefs_set(), Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28drivers:isdn:istream.c Fix typo pice to pieceJustin Mattock
The below patch changes a typo "pice" to "piece" Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2010-11-15drivers/isdn: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-27drivers/isdn: delete double assignmentJulia Lawall
Delete successive assignments to the same location. In the first case, the hscx array has two elements, so change the assignment to initialize the second one. In the second case, the two assignments are simply identical. Furthermore, neither is necessary, because the effect of the assignment is only visible in the next line, in the assignment in the if test. The patch inlines the right hand side value in the latter assignment and pulls that assignment out of the if test. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression i; @@ *i = ...; i = ...; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-22Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: remove in_workqueue_context() workqueue: Clarify that schedule_on_each_cpu is synchronous memory_hotplug: drop spurious calls to flush_scheduled_work() shpchp: update workqueue usage pciehp: update workqueue usage isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr() workqueue: add and use WQ_MEM_RECLAIM flag workqueue: fix HIGHPRI handling in keep_working() workqueue: add queue_work and activate_work trace points workqueue: prepare for more tracepoints workqueue: implement flush[_delayed]_work_sync() workqueue: factor out start_flush_work() workqueue: cleanup flush/cancel functions workqueue: implement alloc_ordered_workqueue() Fix up trivial conflict in fs/gfs2/main.c as per Tejun
2010-10-17isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr()Tejun Heo
diva doesn't use workqueue and there is no reason to flush the system workqueue from diva_os_remove_soft_isr(). Remove it. This is to prepare for the deprecation and removal of flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Armin Schindler <armin@melware.de>
2010-10-06eicon: make buffer largerDan Carpenter
In diva_mnt_add_xdi_adapter() we do this: strcpy (clients[id].drvName, tmp); strcpy (clients[id].Dbg.drvName, tmp); The "clients[id].drvName" is a 128 character buffer and "clients[id].Dbg.drvName" was originally a 16 character buffer but I've changed it to 128 as well. We don't actually use 128 characters but we do use more than 16. I've also changed the size of "tmp" to 128 characters instead of 256. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-29pcmcia: remove obsolete and wrong commentsDominik Brodowski
What's worse than no comment? A wrong comment. Several PCMCIA device drivers contained the same comments, which were based on how the PCMCIA subsystem worked in the old days of 2.4., and which were originally part of a "dummy_cs" driver. These comments no longer matched at all what is happening now, and therefore should be removed. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move config_{base,index,regs} to struct pcmcia_deviceDominik Brodowski
Several drivers prefer to explicitly set config_{base,index,regs}, formerly known as ConfigBase, ConfigIndex and Present. Instead of passing these values inside config_req_t, store it in struct pcmcia_device. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) netfilter: fix CONFIG_COMPAT support isdn/avm: fix build when PCMCIA is not enabled header: fix broken headers for user space e1000e: don't check for alternate MAC addr on parts that don't support it e1000e: disable ASPM L1 on 82573 ll_temac: Fix poll implementation netxen: fix a race in netxen_nic_get_stats() qlnic: fix a race in qlcnic_get_stats() irda: fix a race in irlan_eth_xmit() net: sh_eth: remove unused variable netxen: update version 4.0.74 netxen: fix inconsistent lock state vlan: Match underlying dev carrier on vlan add ibmveth: Fix opps during MTU change on an active device ehea: Fix synchronization between HW and SW send queue bnx2x: Update bnx2x version to 1.52.53-4 bnx2x: Fix PHY locking problem rds: fix a leak of kernel memory netlink: fix compat recvmsg netfilter: fix userspace header warning ...
2010-08-22Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/linux/if_pppox.h Fix conflict between Changli's __packed header file fixes and the new PPTP driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-22isdn/avm: fix build when PCMCIA is not enabledRandy Dunlap
Why wouldn't kconfig symbol ISDN_DRV_AVMB1_B1PCMCIA also depend on PCMCIA? Fix build for PCMCIA not enabled: ERROR: "b1_free_card" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1ctl_proc_fops" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_reset_ctr" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_load_firmware" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_send_message" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_release_appl" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_register_appl" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_getrevision" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_detect" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_interrupt" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! ERROR: "b1_alloc_card" [drivers/isdn/hardware/avm/b1pcmcia.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Carsten Paeth <calle@calle.de> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits) ctcm: rename READ/WRITE defines to avoid redefinitions claw: rename READ/WRITE defines to avoid redefinitions phylib: available for any speed ethernet can: add limit for nframes and clean up signed/unsigned variables pkt_sched: Check .walk and .leaf class handlers pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops caif-spi: Bugfix SPI_DATA_POS settings were inverted. caif: Bugfix - Increase default headroom size for control channel. net: make netpoll_rx return bool for !CONFIG_NETPOLL Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM Bluetooth: Change default L2CAP ERTM retransmit timeout Bluetooth: Fix endianness issue with L2CAP MPS configuration net: Use NET_XMIT_SUCCESS where possible. isdn: mISDN: call pci_disable_device() if pci_probe() failed isdn: avm: call pci_disable_device() if pci_probe() failed isdn: avm: call pci_disable_device() if pci_probe() failed usbnet: rx_submit() should return an error code. pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles ...
2010-08-10isdn: mISDN: call pci_disable_device() if pci_probe() failedKulikov Vasiliy
Driver should call pci_disable_device() if it returns from pci_probe() with error. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-10isdn: avm: call pci_disable_device() if pci_probe() failedKulikov Vasiliy
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq pcmcia: do not request windows if you don't need to pcmcia: insert PCMCIA device resources into resource tree pcmcia: export resource information to sysfs pcmcia: use struct resource for PCMCIA devices, part 2 pcmcia: remove memreq_t pcmcia: move local definitions out of include/pcmcia/cs.h pcmcia: do not use io_req_t when calling pcmcia_request_io() pcmcia: do not use io_req_t after call to pcmcia_request_io() pcmcia: use struct resource for PCMCIA devices pcmcia: clean up cs.h pcmcia: use pcmica_{read,write}_config_byte pcmcia: remove cs_types.h pcmcia: remove unused flag, simplify headers pcmcia: remove obsolete CS_EVENT_ definitions pcmcia: split up central event handler pcmcia: simplify event callback pcmcia: remove obsolete ioctl Conflicts in: - drivers/staging/comedi/drivers/* - drivers/staging/wlags49_h2/wl_cs.c due to dev_info_t and whitespace changes
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t after call to pcmcia_request_io()Dominik Brodowski
After pcmcia_request_io(), do not make use of the values stored in io_req_t, but instead use those found in struct pcmcia_device->resource[]. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-15mISDN: Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used)Peter Huewe
This patch converts pci_table entries, where .subvendor=PCI_ANY_ID and .subdevice=PCI_ANY_ID, .class=0 and .class_mask=0, to use the PCI_VDEVICE macro, and thus improves readability. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15isdn/hardware/eicon: Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID ↵Peter Huewe
is used) This patch converts pci_table entries, where .subvendor=PCI_ANY_ID and .subdevice=PCI_ANY_ID, .class=0 and .class_mask=0, to use the PCI_VDEVICE macro, and thus improves readability. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15isdn/hardware/mISDN: Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID ↵Peter Huewe
2010-07-12isdn: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-11fix comment/printk typos concerning "already"Uwe Kleine-König
