path: root/drivers/irqchip
2015-03-15Merge branch 'irqchip/urgent-gic' into irqchip/urgentJason Cooper
2015-03-08irqchip: gicv3-its: Support safe initializationYun Wu
It's unsafe to change the configurations of an activated ITS directly since this will lead to unpredictable results. This patch guarantees the ITSes being initialized are quiescent. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Yun Wu <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-12-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Define macros for GITS_CTLR fieldsYun Wu
Define macros for GITS_CTLR fields to avoid using magic numbers. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Yun Wu <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-11-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Add limitation to page orderYun Wu
When required size of Device Table is out of the page allocator's capability, the whole ITS will fail in probing. This actually is not the hardware's problem and is mainly a limitation of the kernel page allocator. This patch will keep ITS going on to the next initializaion stage with an explicit warning. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Yun Wu <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-10-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Use 64KB page as default granuleYun Wu
The field of page size in register GITS_BASERn might be read-only if an implementation only supports a single, fixed page size. But currently the ITS driver will throw out an error when PAGE_SIZE is less than the minimum size supported by an ITS. So addressing this problem by using 64KB pages as default granule for all the ITS base tables. Acked-by: Marc Zyngier <marc.zyngier@arm.com> [maz: fixed bug breaking non Device Table allocations] Signed-off-by: Yun Wu <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-9-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Zero itt before handling to hardwareYun Wu
Some kind of brain-dead implementations chooses to insert ITEes in rapid sequence of disabled ITEes, and an un-zeroed ITT will confuse ITS on judging whether an ITE is really enabled or not. Considering the implementations are still supported by the GICv3 architecture, in which ITT is not required to be zeroed before being handled to hardware, we do the favor in ITS driver. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Yun Wu <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-8-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gic-v3: Fix out of bounds access to cpu_logical_mapVladimir Murzin
While playing with KASan support for arm64/arm the following appeared on boot: ================================================================== BUG: AddressSanitizer: out of bounds access in __asan_load8+0x14/0x1c at addr ffffffc000ad0dc0 Read of size 8 by task swapper/0/1 page:ffffffbdc202b400 count:1 mapcount:0 mapping: (null) index:0x0 flags: 0x400(reserved) page dumped because: kasan: bad access detected Address belongs to variable __cpu_logical_map+0x200/0x220 CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.19.0-rc6-next-20150129+ #481 Hardware name: FVP Base (DT) Call trace: [<ffffffc00008a794>] dump_backtrace+0x0/0x184 [<ffffffc00008a928>] show_stack+0x10/0x1c [<ffffffc00075e46c>] dump_stack+0xa0/0xf8 [<ffffffc0001df490>] kasan_report_error+0x23c/0x264 [<ffffffc0001e0188>] check_memory_region+0xc0/0xe4 [<ffffffc0001dedf0>] __asan_load8+0x10/0x1c [<ffffffc000431294>] gic_raise_softirq+0xc4/0x1b4 [<ffffffc000091fc0>] smp_send_reschedule+0x30/0x3c [<ffffffc0000f0d1c>] try_to_wake_up+0x394/0x434 [<ffffffc0000f0de8>] wake_up_process+0x2c/0x6c [<ffffffc0000d9570>] wake_up_worker+0x38/0x48 [<ffffffc0000dbb50>] insert_work+0xac/0xec [<ffffffc0000dbd38>] __queue_work+0x1a8/0x374 [<ffffffc0000dbf60>] queue_work_on+0x5c/0x7c [<ffffffc0000d8a78>] call_usermodehelper_exec+0x170/0x188 [<ffffffc0004037b8>] kobject_uevent_env+0x650/0x6bc [<ffffffc000403830>] kobject_uevent+0xc/0x18 [<ffffffc00040292c>] kset_register+0xa8/0xc8 [<ffffffc0004d6c88>] bus_register+0x134/0x2e8 [<ffffffc0004d73b4>] subsys_virtual_register+0x2c/0x5c [<ffffffc000a76a4c>] wq_sysfs_init+0x14/0x20 [<ffffffc000082a28>] do_one_initcall+0xa8/0x1fc [<ffffffc000a70db4>] kernel_init_freeable+0x1ec/0x294 [<ffffffc00075aa5c>] kernel_init+0xc/0xec Memory state around the buggy address: ffffff80003e0820: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ffffff80003e0830: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 >ffffff80003e0840: fa fa fa fa 00 00 00 00 00 00 00 00 00 00 00 00 ^ ffffff80003e0850: 00 00 fa fa fa fa fa fa 00 00 00 00 00 00 00 00 ================================================================== The reason for that cpumask_next() returns >= nr_cpu_ids if no further cpus set, but "==" condition is checked only, so we end up with out-of-bounds access to cpu_logical_map. Fix is by using the condition check for cpumask_next. Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-7-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gic: Fix unsafe locking reported by lockdepMarc Zyngier
When compiled with CONFIG_LOCKDEP, the kernel shouts badly, saying that the locking in the GIC code is unsafe. I'm afraid the kernel is right: CPU0 ---- lock(irq_controller_lock); <Interrupt> lock(irq_controller_lock); *** DEADLOCK *** This can happen while enabling, disabling, setting the type or the affinity of an interrupt. The fix is to take the interrupt_controller_lock with interrupts disabled in these cases. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-6-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Fix unsafe locking reported by lockdepMarc Zyngier
When compiled with CONFIG_LOCKDEP, the kernel shouts badly, saying that my locking is unsafe. I'm afraid the kernel is right: CPU0 CPU1 ---- ---- lock(&its->lock); local_irq_disable(); lock(&irq_desc_lock_class); lock(&its->lock); <Interrupt> lock(&irq_desc_lock_class); *** DEADLOCK *** The fix is to always take its->lock with interrupts disabled. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-5-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Iterate over PCI aliases to generate ITS configurationMarc Zyngier
The current PCI/MSI support in the GICv3 ITS doesn't really deal with systems where different PCI devices end-up using the same RequesterID (as it would be the case with non-transparent bridges, for example). It is likely that none of these devices would actually generate any interrupt, as the ITS is programmed with the device's own ID, and not that of the bridge. A solution to this is to iterate over the PCI hierarchy to discover what the device aliases too. We also use this to discover the upper bound of the number of MSIs that this sub-hierarchy can generate. With this in place, PCI aliases can be supported. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-4-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Allocate enough memory for the full range of DeviceIDMarc Zyngier
The ITS table allocator is only allocating a single page per table. This works fine for most things, but leads to silent lack of interrupt delivery if we end-up with a device that has an ID that is out of the range defined by a single page of memory. Even worse, depending on the page size, behaviour changes, which is not a very good experience. A solution is actually to allocate memory for the full range of ID that the ITS supports. A massive waste memory wise, but at least a safe bet. Tested on a Phytium SoC. Tested-by: Chen Baozi <chenbaozi@kylinos.com.cn> Acked-by: Chen Baozi <chenbaozi@kylinos.com.cn> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-3-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: gicv3-its: Fix ITS CPU initVladimir Murzin
We skip initialisation of ITS in case the device-tree has no corresponding description, but we are still accessing to ITS bits while setting CPU interface what leads to the kernel panic: ITS: No ITS available, not enabling LPIs CPU0: found redistributor 0 region 0:0x000000002f100000 Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = ffffffc0007fb000 [00000000] *pgd=00000000fc407003, *pud=00000000fc407003, *pmd=00000000fc408003, *pte=006000002f000707 Internal error: Oops: 96000005 [#1] PREEMPT SMP Modules linked in: CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.19.0-rc2+ #318 Hardware name: FVP Base (DT) task: ffffffc00077edb0 ti: ffffffc00076c000 task.ti: ffffffc00076c000 PC is at its_cpu_init+0x2c/0x320 LR is at gic_cpu_init+0x168/0x1bc It happens in gic_rdists_supports_plpis() because gic_rdists is NULL. The gic_rdists is set to non-NULL only when ITS node is presented in the device-tree. Fix this by moving the call to gic_rdists_supports_plpis() inside the !list_empty(&its_nodes) block, because it is that list that guards the validity of the rest of the information in this driver. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1425659870-11832-2-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-03-08irqchip: armada-370-xp: Fix chained per-cpu interruptsMaxime Ripard
On the Cortex-A9-based Armada SoCs, the MPIC is not the primary interrupt controller. Yet, it still has to handle some per-cpu interrupt. To do so, it is chained with the GIC using a per-cpu interrupt. However, the current code only call irq_set_chained_handler, which is called and enable that interrupt only on the boot CPU, which means that the parent per-CPU interrupt is never unmasked on the secondary CPUs, preventing the per-CPU interrupt to actually work as expected. This was not seen until now since the only MPIC PPI users were the Marvell timers that were not working, but not used either since the system use the ARM TWD by default, and the ethernet controllers, that are faking there interrupts as SPI, and don't really expect to have interrupts on the secondary cores anyway. Add a CPU notifier that will enable the PPI on the secondary cores when they are brought up. Cc: <stable@vger.kernel.org> # 3.15+ Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Link: https://lkml.kernel.org/r/1425378443-28822-1-git-send-email-maxime.ripard@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-02-21Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS: - a number of fixes that didn't make the 3.19 release. - a number of cleanups. - preliminary support for Cavium's Octeon 3 SOCs which feature up to 48 MIPS64 R3 cores with FPU and hardware virtualization. - support for MIPS R6 processors. Revision 6 of the MIPS architecture is a major revision of the MIPS architecture which does away with many of original sins of the architecture such as branch delay slots. This and other changes in R6 require major changes throughout the entire MIPS core architecture code and make up for the lion share of this pull request. - finally some preparatory work for eXtendend Physical Address support, which allows support of up to 40 bit of physical address space on 32 bit processors" [ Ahh, MIPS can't leave the PAE brain damage alone. It's like every CPU architect has to make that mistake, but pee in the snow by changing the TLA. But whether it's called PAE, LPAE or XPA, it's horrid crud - Linus ] * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (114 commits) MIPS: sead3: Corrected get_c0_perfcount_int MIPS: mm: Remove dead macro definitions MIPS: OCTEON: irq: add CIB and other fixes MIPS: OCTEON: Don't do acknowledge operations for level triggered irqs. MIPS: OCTEON: More OCTEONIII support MIPS: OCTEON: Remove setting of processor specific CVMCTL icache bits. MIPS: OCTEON: Core-15169 Workaround and general CVMSEG cleanup. MIPS: OCTEON: Update octeon-model.h code for new SoCs. MIPS: OCTEON: Implement DCache errata workaround for all CN6XXX MIPS: OCTEON: Add little-endian support to asm/octeon/octeon.h MIPS: OCTEON: Implement the core-16057 workaround MIPS: OCTEON: Delete unused COP2 saving code MIPS: OCTEON: Use correct instruction to read 64-bit COP0 register MIPS: OCTEON: Save and restore CP2 SHA3 state MIPS: OCTEON: Fix FP context save. MIPS: OCTEON: Save/Restore wider multiply registers in OCTEON III CPUs MIPS: boot: Provide more uImage options MIPS: Remove unneeded #ifdef __KERNEL__ from asm/processor.h MIPS: ip22-gio: Remove legacy suspend/resume support mips: pci: Add ifdef around pci_proc_domain ...
2015-02-16Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irqchip updates from Ingo Molnar: "Various irqchip driver updates, plus a genirq core update that allows the initial spreading of irqs amonst CPUs without having to do it from user-space" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Fix null pointer reference in irq_set_affinity_hint() irqchip: gic: Allow interrupt level to be set for PPIs irqchip: mips-gic: Handle pending interrupts once in __gic_irq_dispatch() irqchip: Conexant CX92755 interrupts controller driver irqchip: Devicetree: document Conexant Digicolor irq binding irqchip: omap-intc: Remove unused legacy interface for omap2 irqchip: omap-intc: Fix support for dm814 and dm816 irqchip: mtk-sysirq: Get irq number from register resource size irqchip: renesas-intc-irqpin: r8a7779 IRLM setup support genirq: Set initial affinity in irq_set_affinity_hint()
2015-02-13Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM update from Paolo Bonzini: "Fairly small update, but there are some interesting new features. Common: Optional support for adding a small amount of polling on each HLT instruction executed in the guest (or equivalent for other architectures). This can improve latency up to 50% on some scenarios (e.g. O_DSYNC writes or TCP_RR netperf tests). This also has to be enabled manually for now, but the plan is to auto-tune this in the future. ARM/ARM64: The highlights are support for GICv3 emulation and dirty page tracking s390: Several optimizations and bugfixes. Also a first: a feature exposed by KVM (UUID and long guest name in /proc/sysinfo) before it is available in IBM's hypervisor! :) MIPS: Bugfixes. x86: Support for PML (page modification logging, a new feature in Broadwell Xeons that speeds up dirty page tracking), nested virtualization improvements (nested APICv---a nice optimization), usual round of emulation fixes. There is also a new option to reduce latency of the TSC deadline timer in the guest; this needs to be tuned manually. Some commits are common between this pull and Catalin's; I see you have already included his tree. Powerpc: Nothing yet. The KVM/PPC changes will come in through the PPC maintainers, because I haven't received them yet and I might end up being offline for some part of next week" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits) KVM: ia64: drop kvm.h from installed user headers KVM: x86: fix build with !CONFIG_SMP KVM: x86: emulate: correct page fault error code for NoWrite instructions KVM: Disable compat ioctl for s390 KVM: s390: add cpu model support KVM: s390: use facilities and cpu_id per KVM KVM: s390/CPACF: Choose crypto control block format s390/kernel: Update /proc/sysinfo file with Extended Name and UUID KVM: s390: reenable LPP facility KVM: s390: floating irqs: fix user triggerable endless loop kvm: add halt_poll_ns module parameter kvm: remove KVM_MMIO_SIZE KVM: MIPS: Don't leak FPU/DSP to guest KVM: MIPS: Disable HTW while in guest KVM: nVMX: Enable nested posted interrupt processing KVM: nVMX: Enable nested virtual interrupt delivery KVM: nVMX: Enable nested apic register virtualization KVM: nVMX: Make nested control MSRs per-cpu KVM: nVMX: Enable nested virtualize x2apic mode KVM: nVMX: Prepare for using hardware MSR bitmap ...
2015-02-06Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "The pending MIPS fixes for 3.19. All across the field and nothing particularly severe or dramatic" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (23 commits) IRQCHIP: mips-gic: Avoid rerouting timer IRQs for smp-cmp MIPS: Fix syscall_get_nr for the syscall exit tracing. MIPS: elf2ecoff: Ignore PT_MIPS_ABIFLAGS program headers. MIPS: elf2ecoff: Rewrite main processing loop to switch. MIPS: fork: Fix MSA/FPU/DSP context duplication race MIPS: Fix C0_Pagegrain[IEC] support. MIPS: traps: Fix inline asm ctc1 missing .set hardfloat MIPS: mipsregs.h: Add write_32bit_cp1_register() MIPS: Fix kernel lockup or crash after CPU offline/online MIPS: OCTEON: fix kernel crash when offlining a CPU MIPS: ARC: Fix build error. MIPS: IRQ: Fix disable_irq on CPU IRQs MIPS: smp-mt,smp-cmp: Enable all HW IRQs on secondary CPUs MIPS: Fix restart of indirect syscalls MIPS: ELF: fix loading o32 binaries on 64-bit kernels MIPS: mips-cm: Fix sparse warnings MIPS: Kconfig: Fix recursive dependency. MIPS: Compat: Fix build error if CONFIG_MIPS32_COMPAT but no compat ABI. MIPS: JZ4740: Fixup #include's (sparse) MIPS: Wire up execveat(2). ...
2015-02-05MIPS: cevt-r4k: Drop GIC special caseJames Hogan
The cevt-r4k driver used to call into the GIC driver to find whether the timer was pending, but only with External Interrupt Controller (EIC) mode, where the Cause.IP bits can't be used as they encode the interrupt priority level (Cause.RIPL) instead. However commit e9de688dac65 ("irqchip: mips-gic: Support local interrupts") changed the condition from cpu_has_veic to gic_present. This fails on cores such as P5600 which have a GIC but the local interrupts aren't routable by the GIC, causing c0_compare_int_usable() to consider the interrupt unusable so r4k_clockevent_init() fails. The previous behaviour, added in commit 98b67c37db33 ("MIPS: Add EIC support for GIC."), wasn't really correct either as far as I can tell, since P5600 apparently supports EIC mode too, and in any case the use of Cause.TI with r2 should have been sufficient anyway since commit 010c108d7af7 ("MIPS: PowerTV: Fix support for timer interrupts with > 64 external IRQs"). Therefore drop the call into the gic driver altogether, and add a comment in c0_compare_int_pending() to clarify that Cause.TI does get checked since MIPS r2. Signed-off-by: James Hogan <james.hogan@imgtec.com> Fixes: e9de688dac65 ("irqchip: mips-gic: Support local interrupts") Reviewed-by: Andrew Bresticker <abrestic@chromium.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Steven J. Hill <steven.hill@imgtec.com> Cc: Qais Yousef <qais.yousef@imgtec.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/9077/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-02-05IRQCHIP: mips-gic: Avoid rerouting timer IRQs for smp-cmpJames Hogan
Commit e9de688dac65 ("irqchip: mips-gic: Support local interrupts") changed the GIC irqchip driver so that all local interrupts were routed to the same CPU pin used for external interrupts. Unfortunately this causes a regression when smp-cmp is used. The CPUs are started by the bootloader and put in a timer based waiting poll loop, but when their timer interrupts are rerouted to a different IRQ pin which is not unmasked they never wake up. Since smp-cmp support is deprecated and everybody who was using it should be switching to smp-cps which brings up the secondary CPUs without bootloader assistance, I've gone for the simple fix which can be easily removed once smp-cmp is removed, rather than a fully generic fix. In __gic_init() the local GIC_VPE_TIMER_MAP register is read to find the boot-time routing of the local timer interrupt, and a chained handler is added to that CPU pin as well as the normal one. Signed-off-by: James Hogan <james.hogan@imgtec.com> Fixes: e9de688dac65 ("irqchip: mips-gic: Support local interrupts") Cc: Andrew Bresticker <abrestic@chromium.org> Cc: Qais Yousef <qais.yousef@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Reviewed-by: Andrew Bresticker <abrestic@chromium.org> Patchwork: https://patchwork.linux-mips.org/patch/9081/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-01-26irqchip: gic: Allow interrupt level to be set for PPIsLiviu Dudau
During a recent cleanup of the arm64 DTs it has become clear that the handling of PPIs in xxxx_set_type() is incorrect. The ARM TRMs for GICv2 and later allow for "implementation defined" support for setting the edge or level type of the PPI interrupts and don't restrict the activation level of the signal. Current ARM implementations do restrict the PPI level type to IRQ_TYPE_LEVEL_LOW, but licensees of the IP can decide to shoot themselves in the foot at any time. Signed-off-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: Marc Zyngier <Marc.Zyngier@arm.com> Cc: LAKML <linux-arm-kernel@lists.infradead.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Rob Herring <robh+dt@kernel.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Haojian Zhuang <haojian.zhuang@linaro.org> Link: http://lkml.kernel.org/r/1421772779-25764-1-git-send-email-Liviu.Dudau@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-26irqchip: mips-gic: Handle pending interrupts once in __gic_irq_dispatch()Qais Yousef
When an interrupt occurs __gic_irq_dispatch() continuously reads local and shared pending registers until all is serviced before returning. The problem with that is that it could introduce a long delay before returning if a piece of hardware keeps triggering while in one of these loops. To ensure fairness and priority doesn't get skewed a lot, read local and shared pending registers once to service each pending IRQ once. If another interupt triggers while servicing the current ones, then we shall re-enter the handler after we return. Signed-off-by: Qais Yousef <qais.yousef@imgtec.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Bresticker <abrestic@chromium.org> Cc: <linux-mips@linux-mips.org> Link: http://lkml.kernel.org/r/1421668289-828-1-git-send-email-qais.yousef@imgtec.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-26irqchip: Conexant CX92755 interrupts controller driverBaruch Siach
Add interrupt controller driver to the Conexant CX92755 SoC, part of the Digicolor SoCs series. Use the generic irq framework support. Use syscon to access the system global UC_IRQ_CONTROL register. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Cc: linux-arm-kernel@lists.infradead.org Cc: Arnd Bergmann <arnd@arndb.de> Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Jason Cooper <jason@lakedaemon.net> Link: http://lkml.kernel.org/r/5b769e3c23dfa5fde08c4f3bc966c2c2b3921d8a.1421317616.git.baruch@tkos.co.il Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-26irqchip: omap-intc: Remove unused legacy interface for omap2Tony Lindgren
Nowadays omap2 is booting in device tree only mode so there is no need to keep the legacy interface around for omap2_init_irq(). Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Cc: Jason Cooper <jason@lakedaemon.net> Link: http://lkml.kernel.org/r/1421187806-6804-3-git-send-email-tony@atomide.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-26irqchip: omap-intc: Fix support for dm814 and dm816Tony Lindgren
On dm81xx we have 128 interrupts like am33xx has. Let's add compatible flags for dm814x and dm816x, and document the existing binding. As the dm81xx are booting in device tree only mode, we can now also remove ti81xx_init_irq() legacy function. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Cc: Brian Hutchinson <b.hutchman@gmail.com> Cc: Jason Cooper <jason@lakedaemon.net> Link: http://lkml.kernel.org/r/1421187806-6804-2-git-send-email-tony@atomide.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-26irqchip: mtk-sysirq: Get irq number from register resource sizeYingjoe Chen
Originally mtk-sysirq hardcoded supported irq number to 224. This was fine since all SoCs before support the same number of irqs for intpol. However MT8173 intpol support 32 more irq pins, changes to get irq number from register resource size to suppor MT8173 properly. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Eddie Huang <eddie.huang@mediatek.com> Cc: <srv_heupstream@mediatek.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Olof Johansson <olof@lixom.net> Cc: Robert Richter <rrichter@cavium.com> Cc: Mark Brown <broonie@linaro.org> Cc: <linux-arm-kernel@lists.infradead.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: <marc.zyngier@arm.com> Cc: <peter.maydell@linaro.org> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Jason Cooper <jason@lakedaemon.net> Link: http://lkml.kernel.org/r/1421054073-43468-3-git-send-email-eddie.huang@mediatek.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-26irqchip: renesas-intc-irqpin: r8a7779 IRLM setup supportMagnus Damm
Add r8a7779 specific support for IRLM bit configuration in the INTC-IRQPIN driver. Without this code we need special workaround code in arch/arm/mach-shmobile. The IRLM bit for the INTC hardware exists on various older SH-based SoCs and is used to select between two modes for the external interrupt pins IRQ0 to IRQ3: IRLM = 0: (default from reset on r8a7779) In this mode the pins IRQ0 to IRQ3 are used together to give a value between 0 and 15 to the SoC. External logic is required for masking. This mode is not supported by the INTC-IRQPIN driver. IRLM = 1: (needs this patch or configuration elsewhere) In this mode IRQ0 to IRQ3 operate as 4 individual external interrupt pins. In this mode the SMSC ethernet chip can be used via IRQ1 on r8a7779 Marzen. This mode is the only supported mode by the INTC-IRQPIN driver. For this patch to work the r8a7779 DTS needs to pass the ICR0 register as the last register bank. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: horms@verge.net.au Cc: jason@lakedaemon.net Link: http://lkml.kernel.org/r/20141203121803.5936.35881.sendpatchset@w520 Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-20arm64: GICv3: introduce symbolic names for GICv3 ICC_SGI1R_EL1 fieldsAndre Przywara
The gic_send_sgi() function used hardcoded bit shift values to generate the ICC_SGI1R_EL1 register value. Replace this with symbolic names to allow reusing them later. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-01-07irqchip: atmel-aic-common: Prevent clobbering of priority when changing IRQ typeGavin Li
This patch makes the bitmask for AIC_SRCTYPE consistent with that of its valid values, and prevents the priority field at bits 2:0 from being clobbered by an incorrect AND with the AIC_SRCTYPE mask. Signed-off-by: Gavin Li <gavinli@thegavinli.com> Cc: <stable@vger.kernel.org> # v3.17+ Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Link: https://lkml.kernel.org/r/1420598843-8409-1-git-send-email-gavinli@thegavinli.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-01-07irqchip: omap-intc: Fix legacy DMA regressionFelipe Balbi
commit 55601c9f2467 (arm: omap: intc: switch over to linear irq domain) introduced a regression with SDMA legacy driver because that driver strictly depends on INTC's IRQs starting at NR_IRQs. Aparently irq_domain_add_linear() won't guarantee that, since we see a 7 IRQs difference when booting with and without the commit cited above. Until arch/arm/plat-omap/dma.c is properly fixed, we must maintain OMAP2/3 using irq_domain_add_legacy(). A FIXME note was added so people know to delete that code once that legacy DMA driver is fixed up. Fixes: 55601c9f2467 (arm: omap: intc: switch over to linear irq domain) Cc: <stable@vger.kernel.org> # v3.18 Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Link: https://lkml.kernel.org/r/1420576688-10604-1-git-send-email-balbi@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-01-07irqchip: gic-v3-its: Fix use of max with decimal constantWill Deacon
arm64 defconfig spits out the following compiler warning from the ITS driver: In file included from include/linux/bitmap.h:9:0, from drivers/irqchip/irq-gic-v3-its.c:18: drivers/irqchip/irq-gic-v3-its.c: In function ‘its_create_device’: include/linux/kernel.h:716:17: warning: comparison of distinct pointer types lacks a cast (void) (&_max1 == &_max2); \ ^ drivers/irqchip/irq-gic-v3-its.c:1056:12: note: in expansion of macro ‘max’ nr_ites = max(2, roundup_pow_of_two(nvecs)); Fix the warning by specifying the decimal constant `2' explicitly as an unsigned long type. Cc: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1418825469-30529-1-git-send-email-will.deacon@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-01-07irqchip: hip04: Initialize hip04_cpu_map to 0xffffWang Long
HiP04 GIC extends to support 16 cores, so we should initialize the hip04_cpu_map to 0xffff. Signed-off-by: Wang Long <long.wanglong@huawei.com> Acked-by: Haojian Zhuang <haojian.zhuang@linaro.org> Link: https://lkml.kernel.org/r/1418295816-179583-1-git-send-email-long.wanglong@huawei.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2015-01-07irqchip: mtk-sysirq: Use IS_ERR() instead of NULL pointer checkYingjoe Chen
Beniamino noticed a bug that an invalid DT file for the mediatek interrupt polarity extension will cause kernel oops. The reason is that the interrupt polarity support for mediatek chips merely checks for NULL pointer instead of a casted error return value in mtk_sysirq_of_init() so any other casted error value passes the NULL pointer check and causes a kernel panic when dereferenced. Use IS_ERR() and return the error value via PTR_ERR(). [ jac: took V2 over V3 for diff formatting, hand-added V3 changes, tweaked subject line. ] Reported-by: Beniamino Galvani <b.galvani@gmail.com> Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Link: https://lkml.kernel.org/r/1418205302-22531-1-git-send-email-yingjoe.chen@mediatek.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-12-15Merge branch 'irq-irqdomain-arm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq domain ARM updates from Thomas Gleixner: "This set of changes make use of hierarchical irqdomains to provide: - MSI/ITS support for GICv3 - MSI support for GICv2m - Interrupt polarity extender for GICv1 Marc has come more cleanups for the existing extension hooks of GIC in the pipeline, but they are going to be 3.20 material" * 'irq-irqdomain-arm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits) irqchip: gicv3-its: Fix ITT allocation irqchip: gicv3-its: Move some alloc/free code to activate/deactivate irqchip: gicv3-its: Fix domain free in multi-MSI case irqchip: gic: Remove warning by including linux/irqdomain.h irqchip: gic-v2m: Add DT bindings for GICv2m irqchip: gic-v2m: Add support for ARM GICv2m MSI(-X) doorbell irqchip: mtk-sysirq: dt-bindings: Add bindings for mediatek sysirq irqchip: mtk-sysirq: Add sysirq interrupt polarity support irqchip: gic: Support hierarchy irq domain. irqchip: GICv3: Binding updates for ITS irqchip: GICv3: ITS: enable compilation of the ITS driver irqchip: GICv3: ITS: plug ITS init into main GICv3 code irqchip: GICv3: ITS: DT probing and initialization irqchip: GICv3: ITS: MSI support irqchip: GICv3: ITS: device allocation and configuration irqchip: GICv3: ITS: tables allocators irqchip: GICv3: ITS: LPI allocator irqchip: GICv3: ITS: irqchip implementation irqchip: GICv3: ITS command queue irqchip: GICv3: rework redistributor structure ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-13irqchip: gicv3-its: Fix ITT allocationMarc Zyngier
When issuing a MAPD command, one of the parameters passed to the ITS is the number of EventID bits used to index the per-device Interrupt Translation Table (ITT). Crucially, this is the number of bits *minus one*. This has two consequences: - The size of the ITT has to be a strict power of two, no matter how many different events the device is actually going to generate. - It is impossible to express an ITT with a single entry, as you would have to tell the ITS to "use zero bit from the EventID", and that clashes with "minus one" above. Fix this by allocating the ITT with the number of vectors rounded up to the next power of two, with a minimum of two entries. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Yun Wu (Abel) <wuyun.wu@huawei.com> Cc: Robert Richter <robert.richter@caviumnetworks.com> Cc: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-12-13irqchip: gicv3-its: Move some alloc/free code to activate/deactivateMarc Zyngier
The ITS code could do a bit less in the alloc/free paths, and a bit more in the activate/deactivate methods, giving a better separation between software allocation and HW programing. Suggested-by: Wuyun Wu (Abel) <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Yun Wu (Abel) <wuyun.wu@huawei.com> Cc: Robert Richter <robert.richter@caviumnetworks.com> Cc: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-12-13irqchip: gicv3-its: Fix domain free in multi-MSI caseMarc Zyngier
Fix stupid thinko on the path freeing the interrupts, where only the first interrupt would get reset, and none of the others. This should only affect multi-MSI allocations. Reported-by: Wuyun Wu (Abel) <wuyun.wu@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Robert Richter <robert.richter@caviumnetworks.com> Cc: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-12-11Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is an unusually large pull request for MIPS - in parts because lots of patches missed the 3.18 deadline but primarily because some folks opened the flood gates. - Retire the MIPS-specific phys_t with the generic phys_addr_t. - Improvments for the backtrace code used by oprofile. - Better backtraces on SMP systems. - Cleanups for the Octeon platform code. - Cleanups and fixes for the Loongson platform code. - Cleanups and fixes to the firmware library. - Switch ATH79 platform to use the firmware library. - Grand overhault to the SEAD3 and Malta interrupt code. - Move the GIC interrupt code to drivers/irqchip - Lots of GIC cleanups and updates to the GIC code to use modern IRQ infrastructures and features of the kernel. - OF documentation updates for the GIC bindings - Move GIC clocksource driver to drivers/clocksource - Merge GIC clocksource driver with clockevent driver. - Further updates to bring the GIC clocksource driver up to date. - R3000 TLB code cleanups - Improvments to the Loongson 3 platform code. - Convert pr_warning to pr_warn. - Merge a bunch of small lantiq and ralink fixes that have been staged/lingering inside the openwrt tree for a while. - Update archhelp for IP22/IP32 - Fix a number of issues for Loongson 1B. - New clocksource and clockevent driver for Loongson 1B. - Further work on clk handling for Loongson 1B. - Platform work for Broadcom BMIPS. - Error handling cleanups for TurboChannel. - Fixes and optimization to the microMIPS support. - Option to disable the FTLB. - Dump more relevant information on machine check exception - Change binfmt to allow arch to examine PT_*PROC headers - Support for new style FPU register model in O32 - VDSO randomization. - BCM47xx cleanups - BCM47xx reimplement the way the kernel accesses NVRAM information. - Random cleanups - Add support for ATH25 platforms - Remove pointless locking code in some PCI platforms. - Some improvments to EVA support - Minor Alchemy cleanup" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (185 commits) MIPS: Add MFHC0 and MTHC0 instructions to uasm. MIPS: Cosmetic cleanups of page table headers. MIPS: Add CP0 macros for extended EntryLo registers MIPS: Remove now unused definition of phys_t. MIPS: Replace use of phys_t with phys_addr_t. MIPS: Replace MIPS-specific 64BIT_PHYS_ADDR with generic PHYS_ADDR_T_64BIT PCMCIA: Alchemy Don't select 64BIT_PHYS_ADDR in Kconfig. MIPS: lib: memset: Clean up some MIPS{EL,EB} ifdefery MIPS: iomap: Use __mem_{read,write}{b,w,l} for MMIO MIPS: <asm/types.h> fix indentation. MAINTAINERS: Add entry for BMIPS multiplatform kernel MIPS: Enable VDSO randomization MIPS: Remove a temporary hack for debugging cache flushes in SMTC configuration MIPS: Remove declaration of obsolete arch_init_clk_ops() MIPS: atomic.h: Reformat to fit in 79 columns MIPS: Apply `.insn' to fixup labels throughout MIPS: Fix microMIPS LL/SC immediate offsets MIPS: Kconfig: Only allow 32-bit microMIPS builds MIPS: signal.c: Fix an invalid cast in ISA mode bit handling MIPS: mm: Only build one microassembler that is suitable ...
2014-12-10Merge branch 'irq-irqdomain-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq domain updates from Thomas Gleixner: "The real interesting irq updates: - Support for hierarchical irq domains: For complex interrupt routing scenarios where more than one interrupt related chip is involved we had no proper representation in the generic interrupt infrastructure so far. That made people implement rather ugly constructs in their nested irq chip implementations. The main offenders are x86 and arm/gic. To distangle that mess we have now hierarchical irqdomains which seperate the various interrupt chips and connect them via the hierarchical domains. That keeps the domain specific details internal to the particular hierarchy level and removes the criss/cross referencing of chip internals. The resulting hierarchy for a complex x86 system will look like this: vector mapped: 74 msi-0 mapped: 2 dmar-ir-1 mapped: 69 ioapic-1 mapped: 4 ioapic-0 mapped: 20 pci-msi-2 mapped: 45 dmar-ir-0 mapped: 3 ioapic-2 mapped: 1 pci-msi-1 mapped: 2 htirq mapped: 0 Neither ioapic nor pci-msi know about the dmar interrupt remapping between themself and the vector domain. If interrupt remapping is disabled ioapic and pci-msi become direct childs of the vector domain. In hindsight we should have done that years ago, but in hindsight we always know better :) - Support for generic MSI interrupt domain handling We have more and more non PCI related MSI interrupts, so providing a generic infrastructure for this is better than having all affected architectures implementing their own private hacks. - Support for PCI-MSI interrupt domain handling, based on the generic MSI support. This part carries the pci/msi branch from Bjorn Helgaas pci tree to avoid a massive conflict. The PCI/MSI parts are acked by Bjorn. I have two more branches on top of this. The full conversion of x86 to hierarchical domains and a partial conversion of arm/gic" * 'irq-irqdomain-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) genirq: Move irq_chip_write_msi_msg() helper to core PCI/MSI: Allow an msi_controller to be associated to an irq domain PCI/MSI: Provide mechanism to alloc/free MSI/MSIX interrupt from irqdomain PCI/MSI: Enhance core to support hierarchy irqdomain PCI/MSI: Move cached entry functions to irq core genirq: Provide default callbacks for msi_domain_ops genirq: Introduce msi_domain_alloc/free_irqs() asm-generic: Add msi.h genirq: Add generic msi irq domain support genirq: Introduce callback irq_chip.irq_write_msi_msg genirq: Work around __irq_set_handler vs stacked domains ordering issues irqdomain: Introduce helper function irq_domain_add_hierarchy() irqdomain: Implement a method to automatically call parent domains alloc/free genirq: Introduce helper irq_domain_set_info() to reduce duplicated code genirq: Split out flow handler typedefs into seperate header file genirq: Add IRQ_SET_MASK_OK_DONE to support stacked irqchip genirq: Introduce irq_chip.irq_compose_msi_msg() to support stacked irqchip genirq: Add more helper functions to support stacked irq_chip genirq: Introduce helper functions to support stacked irq_chip irqdomain: Do irq_find_mapping and set_type for hierarchy irqdomain in case OF ...
2014-12-10Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq core updates from Thomas Gleixner: "This is the first (boring) part of irq updates: - support for big endian I/O accessors in the generic irq chip - cleanup of brcmstb/bcm7120 drivers so they can be reused for non ARM SoCs - the usual pile of fixes and updates for the various ARM irq chips" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits) irqchip: dw-apb-ictl: Add PM support irqchip: dw-apb-ictl: Enable IRQ_GC_MASK_CACHE_PER_TYPE irqchip: dw-apb-ictl: Always use use {readl|writel}_relaxed ARM: orion: convert the irq_reg_{readl,writel} calls to the new API irqchip: atmel-aic: Add missing entry for rm9200 irq fixups irqchip: atmel-aic: Rename at91sam9_aic_irq_fixup for naming consistency irqchip: atmel-aic: Add specific irq fixup function for sam9g45 and sam9rl irqchip: atmel-aic: Add irq fixups for at91sam926x SoCs irqchip: atmel-aic: Add irq fixup for RTT block irqchip: brcmstb-l2: Convert driver to use irq_reg_{readl,writel} irqchip: bcm7120-l2: Convert driver to use irq_reg_{readl,writel} irqchip: bcm7120-l2: Decouple driver from brcmstb-l2 irqchip: bcm7120-l2: Extend driver to support 64+ bit controllers irqchip: bcm7120-l2: Use gc->mask_cache to simplify suspend/resume functions irqchip: bcm7120-l2: Fix missing nibble in gc->unused mask irqchip: bcm7120-l2: Make sure all register accesses use base+offset irqchip: bcm7120-l2, brcmstb-l2: Remove ARM Kconfig dependency irqchip: bcm7120-l2: Eliminate bad IRQ check irqchip: brcmstb-l2: Eliminate dependency on ARM code genirq: Generic chip: Add big endian I/O accessors ...
2014-12-09Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "The DT branch adds a lot of new stuff for additional SoC and board support. The branch is the largest one and contains 513 out of the total 972 non-merge arm-soc changesets for 3.19. Most of the changes are about enabling additional on-chip devices for existing machines, but there are also an unusual number of new SoC types being added this time: - AMLogic Meson8 - ARM Realview in DT mode - Allwinner A80 - Broadcom BCM47081 - Broadcom Cygnus - Freescale LS1021A - Freescale Vybrid 500 series - Mediatek MT6592, MT8127, MT8135 - STMicroelectronics STiH410 - Samsung Exynos4415 The level of support for the above differs widely, some are just stubs with nothing more than CPU, memory and a UART, but others are fairly complete. As usual, these get extended over time. There are also many new boards getting added, this is the list of model strings that are showing up in new dts files: - ARM RealView PB1176 - Altera SOCFPGA Arria 10 - Asus RT-N18U (BCM47081) - Buffalo WZR-1750DHP (BCM4708) - Buffalo WZR-600DHP2 (BCM47081) - Cygnus Enterprise Phone (BCM911360_ENTPHN) - D-Link DIR-665 - Google Spring - IGEP COM MODULE Rev. G (TI OMAP AM/DM37x) - IGEPv2 Rev. F (TI OMAP AM/DM37x) - LS1021A QDS Board - LS1021A TWR Board - LeMaker Banana Pi - MarsBoard RK3066 - MediaTek MT8127 Moose Board - MediaTek MT8135 evaluation board - Mele M3 - Merrii A80 Optimus Board - Netgear R6300 V2 (BCM4708) - Nomadik STN8815NHK - NovaTech OrionLXm - Olimex A20-OLinuXino-LIME2 - Raspberry Pi Model B+ - STiH410 B2120 - Samsung Monk board - Samsung Rinato board - Synology DS213j - Synology DS414 - TBS2910 Matrix ARM mini PC - TI AM5728 BeagleBoard-X15 - Toradex Colibri VF50 on Colibri Evaluation Board - Zynq ZYBO Development Board Other notable changes include: - exynos: cleanup of existing dts files - mvebu: improved pinctrl support for Armada 370/XP - nomadik: restructuring dts files - omap: added CAN bus support - shmobile: added clock support for some SoCs - shmobile: added sound support for some SoCs - sirf: reset controller support - sunxi: continuing the relicensing under dual GPL/MIT - sunxi: lots of new on-chip device support - sunxi: working simplefb support (long awaited) - various: provide stdout-path property for earlycon" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits) ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured Revert "ARM: dts: rockchip: temporarily disable smp on rk3288" ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2 ARM: BCM5301X: Add DT for Asus RT-N18U ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP ARM: BCM5301X: Add DT for Netgear R6300 V2 ARM: BCM5301X: Add buttons for Netgear R6250 ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file arm: dts: zynq: Add Digilent ZYBO board arm: dts: zynq: Move crystal freq. to board level doc: dt: vendor-prefixes: Add Digilent Inc Documentation: devicetree: Fix Xilinx VDMA specification ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188 ARM: dts: rockchip: add label property for leds on Radxa Rock ARM: BCM5301X: Add LEDs for Netgear R6250 V1 ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file ARM: dts: add sysreg phandle to i2c device nodes for exynos ARM: dts: Remove unused bootargs from exynos3250-rinato ARM: dts: add board dts file for Exynos3250-based Monk board ...
2014-12-09Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support, notable changes include: - bcm: brcmstb SMP support initial iproc/cygnus support - exynos: Exynos4415 SoC support PMU and suspend support for Exynos5420 PMU support for Exynos3250 pm related maintenance - imx: new LS1021A SoC support vybrid 610 global timer support - integrator: convert to using multiplatform configuration - mediatek: earlyprintk support for mt8127/mt8135 - meson: meson8 soc and l2 cache controller support - mvebu: Armada 38x CPU hotplug support drop support for prerelease Armada 375 Z1 stepping extended suspend support, now works on Armada 370/XP - omap: hwmod related maintenance prcm cleanup - pxa: initial pxa27x DT handling - rockchip: SMP support for rk3288 add cpu frequency scaling support - shmobile: r8a7740 power domain support various small restart, timer, pci apmu changes - sunxi: Allwinner A80 (sun9i) earlyprintk support - ux500: power domain support Overall, a significant chunk of changes, coming mostly from the usual suspects: omap, shmobile, samsung and mvebu, all of which already contain a lot of platform specific code in arch/arm" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits) ARM: mvebu: use the cpufreq-dt platform_data for independent clocks soc: integrator: Add terminating entry for integrator_cm_match ARM: mvebu: add SDRAM controller description for Armada XP ARM: mvebu: adjust mbus controller description on Armada 370/XP ARM: mvebu: add suspend/resume DT information for Armada XP GP ARM: mvebu: synchronize secondary CPU clocks on resume ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume ARM: mvebu: Armada XP GP specific suspend/resume code ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume ARM: mvebu: implement suspend/resume support for Armada XP clk: mvebu: add suspend/resume for gatable clocks bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration bus: mvebu-mbus: suspend/resume support clocksource: time-armada-370-xp: add suspend/resume support irqchip: armada-370-xp: Add suspend/resume support ARM: add lolevel debug support for asm9260 ARM: add mach-asm9260 ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf power: reset: imx-snvs-poweroff: add power off driver for i.mx6 ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A ...
2014-11-30irqchip: armada-370-xp: Add suspend/resume supportThomas Petazzoni
This commit adds suspend/resume support to the irqchip driver used on Armada XP platforms (amongst others). It does so by adding a set of suspend/resume syscore_ops, that will respectively save and restore the necessary registers to ensure interrupts continue to work after resume. It is worth mentioning that the affinity is lost during a suspend/resume cycle, because when a secondary CPU is brought off-line, all interrupts that are assigned to this CPU in terms of affinity gets re-assigned to a still running CPU. Therefore, right before entering suspend, all interrupts are assigned to the boot CPU. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: linux-kernel@vger.kernel.org Link: https://lkml.kernel.org/r/1416585613-2113-4-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: dw-apb-ictl: Add PM supportJisheng Zhang
This patch adds in support for S2R for dw-apb-ictl irqchip driver. We can used relaxed variants in the resume hook because there's no DMA at all here, the device type memory attribute can ensure the operations order and relaxed version imply compiler barrier. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Link: https://lkml.kernel.org/r/1415773374-4629-4-git-send-email-jszhang@marvell.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: dw-apb-ictl: Enable IRQ_GC_MASK_CACHE_PER_TYPEJisheng Zhang
The irq_chip_type instances have separate mask registers, so we need to enable IRQ_GC_MASK_CACHE_PER_TYPE to actually handle separate mask registers. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1415773374-4629-3-git-send-email-jszhang@marvell.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: dw-apb-ictl: Always use use {readl|writel}_relaxedJisheng Zhang
There's no DMA at all, the device type memory attribute can ensure the operations order and relaxed version imply compiler barrier, so we are safe to use relaxed version to improve the performance a bit. Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1415773374-4629-2-git-send-email-jszhang@marvell.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: gic-v2m: Add support for ARM GICv2m MSI(-X) doorbellSuravee Suthikulpanit
ARM GICv2m specification extends GICv2 to support MSI(-X) with a new register frame. This allows a GICv2 based system to support MSI with minimal changes. Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> [maz: converted the driver to use stacked irq domains, updated changelog] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1416941243-7181-2-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: mtk-sysirq: Add sysirq interrupt polarity supportYingjoe Chen
Mediatek SoCs have interrupt polarity support in sysirq which allows to invert polarity for given interrupt. Add this support using hierarchy irq domain. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Link: https://lkml.kernel.org/r/1416902662-19281-3-git-send-email-yingjoe.chen@mediatek.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: gic: Support hierarchy irq domain.Yingjoe Chen
Add support to use gic as a parent for stacked irq domain. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1416902662-19281-2-git-send-email-yingjoe.chen@mediatek.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-11-26irqchip: GICv3: ITS: enable compilation of the ITS driverMarc Zyngier
Get the show on the road... Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1416839720-18400-13-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
