Migrate Tegra clock support to drivers/clk/tegra, this involves
moving:
1. definition of tegra_cpu_car_ops to clk.c
2. definition of reset functions to clk-peripheral.c
3. change parent of cpu clock.
4. Remove legacy clock initialization.
5. Initialize clocks using DT.
6. Remove all instance of mach/clk.h
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
[swarren: use to_clk_periph_gate().]
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input update from Dmitry Torokhov:
"Updates for the input subsystem. Just a couple of driver fixes this
time."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: gpio_keys - defer probing if GPIO probing is deferred
Input: gpio_keys_polled - defer probing if GPIO probing is deferred
Input: sentelic - only report position of first finger as ST coordinates
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
If of_get_gpio_flags() returns an error (as in case when GPIO probe is
deferred) the driver would attempt to claim invalid GPIO. It should
propagate the error code up the stack instead so that the probe either
fails or will be retried later (in case of -EPROBE_DEFER).
Cc: stable@vger.kernel.org
Reported-by: Gabor Juhos <juhosg@openwrt.org>
If GPIO probing is deferred, the driver tries to claim an invalid GPIO line
which leads to an error message like this:
gpio-keys-polled buttons.2: unable to claim gpio 4294966779, err=-22
gpio-keys-polled: probe of buttons.2 failed with error -22
We should make sure that error code returned by of_get_gpio_flags (including
-EPROBE_DEFER) is propagated up the stack.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Report only the position of the first finger as absolute non-MT coordinates,
instead of reporting both fingers alternatively. Actual MT events are
unaffected.
This fixes horizontal and improves vertical scrolling with the touchpad.
Signed-off-by: Christophe TORDEUX <christophe@tordeux.net>
Pull small x86 fixes from Peter Anvin:
"A collection of very small fixes, mostly pure documentation."
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, doc: Document that bootloader ID 4 is used also by iPXE
x86, doc: Add a formal bootloader ID for kexec-tools
x86, 8042: Enable A20 using KBC to fix S3 resume on some MSI laptops
Pull second round of input updates from Dmitry Torokhov:
"As usual, there are a couple of new drivers, input core now supports
managed input devices (devres), a slew of drivers now have device tree
support and a bunch of fixes and cleanups."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (71 commits)
Input: walkera0701 - fix crash on startup
Input: matrix-keymap - provide a proper module license
Input: gpio_keys_polled - switch to using gpio_request_one()
Input: gpio_keys - switch to using gpio_request_one()
Input: wacom - fix touch support for Bamboo Fun CTH-461
Input: xpad - add a few new VID/PID combinations
Input: xpad - minor formatting fixes
Input: gpio-keys-polled - honor 'autorepeat' setting in platform data
Input: tca8418-keypad - switch to using managed resources
Input: tca8418_keypad - increase severity of failures in probe()
Input: tca8418_keypad - move device ID tables closer to where they are used
Input: tca8418_keypad - use dev_get_platdata() to retrieve platform data
Input: tca8418_keypad - use a temporary variable for parent device
Input: tca8418_keypad - add support for shared interrupt
Input: tca8418_keypad - add support for device tree bindings
Input: remove Compaq iPAQ H3600 (Bitsy) touchscreen driver
Input: bu21013_ts - add support for Device Tree booting
Input: bu21013_ts - move GPIO init and exit functions into the driver
Input: bu21013_ts - request regulator that actually exists
ARM: ux500: Strip out duplicate touch screen platform information
Prepare first set of updates for 3.8 merge window.
The driver's timer must be set up before enabling IRQ handler, otherwise
bad things may happen.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Peter Popovec <popovec@fei.tuke.sk>
CC: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFS update from Samuel Ortiz:
"This is the MFD patch set for the 3.8 merge window.
We have several new drivers, most of the time coming with their sub
devices drivers:
- Austria Microsystem's AS3711
- Nano River's viperboard
- TI's TPS80031, AM335x TS/ADC,
- Realtek's MMC/memstick card reader
- Nokia's retu
We also got some notable cleanups and improvements:
- tps6586x got converted to IRQ domains.
- tps65910 and tps65090 moved to the regmap IRQ API.
- STMPE is now Device Tree aware.
- A general twl6040 and twl-core cleanup, with moves to the regmap
I/O and IRQ APIs and a conversion to the recently added PWM
framework.
- sta2x11 gained regmap support.
Then the rest is mostly tiny cleanups and fixes, among which we have
Mark's wm5xxx and wm8xxx patchset."
Far amount of annoying but largely trivial conflicts. Many due to
__devinit/exit removal, others due to one or two of the new drivers also
having come in through another tree.
* tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits)
mfd: tps6507x: Convert to devm_kzalloc
mfd: stmpe: Update DT support for stmpe driver
mfd: wm5102: Add readback of DSP status 3 register
mfd: arizona: Log if we fail to create the primary IRQ domain
mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ
mfd: tps80031: Add terminating entry for tps80031_id_table
mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask()
mfd: wm5102: Add tuning for revision B
mfd: arizona: Defer patch initialistation until after first device boot
mfd: tps65910: Fix wrong ack_base register
mfd: tps65910: Remove unused data
mfd: stmpe: Get rid of irq_invert_polarity
mfd: ab8500-core: Fix invalid free of devm_ allocated data
mfd: wm5102: Mark DSP memory regions as volatile
mfd: wm5102: Correct default for LDO1_CONTROL_2
mfd: arizona: Register haptics devices
mfd: wm8994: Make current device behaviour the default
mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ
mfd: Fix stmpe.c build when OF is not enabled
mfd: jz4740-adc: Use devm_kzalloc
These devices are not available on other architectures, so
let's limit them to omap.
If the driver subsystem maintainers want to build test
system wide changes without building for each target,
it's easy to carry a test patch that just strips out the
depends entries from Kconfig files.
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID subsystem updates from Jiri Kosina:
1) Support for HID over I2C bus has been added by Benjamin Tissoires.
ACPI device discovery is still in the works.
2) Support for Win8 Multitiouch protocol is being added, most work done
by Benjamin Tissoires as well
3) EIO/ERESTARTSYS is fixed in hiddev/hidraw, fixes by Andrew Duggan
and Jiri Kosina
4) ION iCade driver added by Bastien Nocera
5) Support for a couple new Roccat devices has been added by Stefan
Achatz
6) HID sensor hubs are now auto-detected instead of having to list all
the VID/PID combinations in the blacklist array
7) other random fixes and support for new device IDs
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (65 commits)
HID: i2c-hid: add mutex protecting open/close race
Revert "HID: sensors: add to special driver list"
HID: sensors: autodetect USB HID sensor hubs
HID: hidp: fallback to input session properly if hid is blacklisted
HID: i2c-hid: fix ret_count check
HID: i2c-hid: fix i2c_hid_get_raw_report count mismatches
HID: i2c-hid: remove extra .irq field in struct i2c_hid
HID: i2c-hid: reorder allocation/free of buffers
HID: i2c-hid: fix memory corruption due to missing hid declaration
HID: i2c-hid: remove superfluous include
HID: i2c-hid: remove unneeded test in i2c_hid_remove
HID: i2c-hid: i2c_hid_get_report may fail
HID: i2c-hid: also call i2c_hid_free_buffers in i2c_hid_remove
HID: i2c-hid: fix error messages
HID: i2c-hid: fix return paths
HID: i2c-hid: remove unused static declarations
HID: i2c-hid: fix i2c_hid_dbg macro
HID: i2c-hid: fix checkpatch.pl warning
HID: i2c-hid: enhance Kconfig
HID: i2c-hid: change I2C name
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This update contains a fairly wide range of changes all over in sound
subdirectory, mainly because of UAPI header moves by David and __dev*
annotation removals by Bill. Other highlights are:
- Introduced the support for wallclock timestamps in ALSA PCM core
- Add the poll loop implementation for HD-audio jack detection
- Yet more VGA-switcheroo fixes for HD-audio
- New VIA HD-audio codec support
- More fixes on resource management in USB audio and MIDI drivers
- More quirks for USB-audio ASUS Xonar U3, Reloop Play, Focusrite,
Roland VG-99, etc
- Add support for FastTrack C400 usb-audio
- Clean ups in many drivers regarding firmware loading
- Add PSC724 Ultiimate Edge support to ice1712
- A few hdspm driver updates
- New Stanton SCS.1d/1m FireWire driver
- Standardisation of the logging in ASoC codes
- DT and dmaengine support for ASoC Atmel
- Support for Wolfson ADSP cores
- New drivers for Freescale/iVeia P1022 and Maxim MAX98090
- Lots of other ASoC driver fixes and developments"
Fix up trivial conflicts. And go out on a limb and assume the dts file
'status' field of one of the conflicting things was supposed to be
"disabled", not "disable" like in pretty much all other cases.
* tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (341 commits)
ALSA: hda - Move runtime PM check to runtime_idle callback
ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522
ALSA: hda - Avoid doubly suspend after vga switcheroo
ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3
ALSA: hda - Check validity of CORB/RIRB WP reads
ALSA: hda - use usleep_range in link reset and change timeout check
ALSA: HDA: VIA: Add support for codec VT1808.
ALSA: HDA: VIA Add support for codec VT1705CF.
ASoC: codecs: remove __dev* attributes
ASoC: utils: remove __dev* attributes
ASoC: ux500: remove __dev* attributes
ASoC: txx9: remove __dev* attributes
ASoC: tegra: remove __dev* attributes
ASoC: spear: remove __dev* attributes
ASoC: sh: remove __dev* attributes
ASoC: s6000: remove __dev* attributes
ASoC: OMAP: remove __dev* attributes
ASoC: nuc900: remove __dev* attributes
ASoC: mxs: remove __dev* attributes
ASoC: kirkwood: remove __dev* attributes
Pull ARM SoC multiplatform conversion patches from Olof Johansson:
"Here are more patches in the progression towards multiplatform, sparse
irq conversions in particular.
Tegra has a handful of cleanups and general groundwork, but is not
quite there yet on full enablement.
Platforms that are enabled through this branch are VT8500 and Zynq.
Note that i.MX was converted in one of the earlier cleanup branches as
well (before we started a separate topic for multiplatform). And both
new platforms for this merge window, sunxi and bcm, were merged with
multiplatform support enabled."
Fix up conflicts mostly as per Olof.
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: zynq: Remove all unused mach headers
ARM: zynq: add support for ARCH_MULTIPLATFORM
ARM: zynq: make use of debug_ll_io_init()
ARM: zynq: remove TTC early mapping
ARM: tegra: move debug-macro.S to include/debug
ARM: tegra: don't include iomap.h from debug-macro.S
ARM: tegra: decouple uncompress.h and debug-macro.S
ARM: tegra: simplify DEBUG_LL UART selection options
ARM: tegra: select SPARSE_IRQ
ARM: tegra: enhance timer.c to get IO address from device tree
ARM: tegra: enhance timer.c to get IRQ info from device tree
ARM: timer: fix checkpatch warnings
ARM: tegra: add TWD to device tree
ARM: tegra: define DT bindings for and instantiate RTC
ARM: tegra: define DT bindings for and instantiate timer
clocksource/mtu-nomadik: use apb_pclk
clk: ux500: Register mtu apb_pclocks
ARM: plat-nomadik: convert platforms to SPARSE_IRQ
mfd/db8500-prcmu: use the irq_domain_add_simple()
mfd/ab8500-core: use irq_domain_add_simple()
Pull ARM SoC Header cleanups from Olof Johansson:
"This is a collection of header file cleanups, mostly for OMAP and
AT91, that keeps moving the platforms in the direction of
multiplatform by removing the need for mach-dependent header files
used in drivers and other places."
Fix up mostly trivial conflicts as per Olof.
* tag 'headers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (106 commits)
ARM: OMAP2+: Move iommu/iovmm headers to platform_data
ARM: OMAP2+: Make some definitions local
ARM: OMAP2+: Move iommu2 to drivers/iommu/omap-iommu2.c
ARM: OMAP2+: Move plat/iovmm.h to include/linux/omap-iommu.h
ARM: OMAP2+: Move iopgtable header to drivers/iommu/
ARM: OMAP: Merge iommu2.h into iommu.h
atmel: move ATMEL_MAX_UART to platform_data/atmel.h
ARM: OMAP: Remove omap_init_consistent_dma_size()
arm: at91: move at91rm9200 rtc header in drivers/rtc
arm: at91: move reset controller header to arm/arm/mach-at91
arm: at91: move pit define to the driver
arm: at91: move at91_shdwc.h to arch/arm/mach-at91
arm: at91: move board header to arch/arm/mach-at91
arn: at91: move at91_tc.h to arch/arm/mach-at91
arm: at91 move at91_aic.h to arch/arm/mach-at91
arm: at91 move board.h to arch/arm/mach-at91
arm: at91: move platfarm_data to include/linux/platform_data/atmel.h
arm: at91: drop machine defconfig
ARM: OMAP: Remove NEED_MACH_GPIO_H
ARM: OMAP: Remove unnecessary mach and plat includes
Some MSI laptop BIOSes are broken - INT 15h code uses port 92h to enable A20
line but resume code assumes that KBC was used.
The laptop will not resume from S3 otherwise but powers off after a while
and then powers on again stuck with a blank screen.
Fix it by enabling A20 using KBC in i8042_platform_init for x86.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=12878
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/201212112218.06551.linux@rainbow-software.org
The matrix-keymap module is currently lacking a proper module license,
add one so we don't have this module tainting the entire kernel. This
issue has been present since commit 1932811f426f ("Input: matrix-keymap
- uninline and prepare for device tree support")
Signed-off-by: Florian Fainelli <florian@openwrt.org>
CC: stable@vger.kernel.org # v3.5+
issue has been present since commit 1932811f (Input: matrix-keymap -
uninline and prepare for device tree support)
This saves us a few lines of code.
Commit f393ee2b814e3291c12565000210b3cf10aa5c1d forgot to add the
touch_max property for Wacom Bamboo Fun CTH-461/S, ID 056a:00d2.
This broke the touch functionality for that device. This patch,
(done with help of Ping Cheng), adds the correct value and makes
touch work again.
Signed-off-by: Diego Calleja <diegocg@gmail.com>
Reviewed-by: Ping Cheng <pinglinux@gmail.com>
Cc: stable@kernel.org
This adds VID/PID combinations for MadCatz, PDP and PowerA (new).
Removed Pelican 'TSZ' Wired Xbox 360 Controller since it's clashing with Edge
wireless Controller and I failed to confirm the PID.
Signed-off-by: "Guillermo A. Amaral B." <g@maral.me>
Fixed a few minor coding style issues in xpad driver.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Let's switch to using devm_*() interfaces to manage our resources,
thus will simplify error unwinding a bit.
Reviewed-by: Alban Bedel <alban.bedel@avionic-design.de>
Failures to build a keymap, request an IRQ, or register input device are
fatal for the driver, therefore the messages should have "error" severity
instead of "debug".
This matches structure of most other input drivers.
We need to use proper accessor functions instead of directly poking into
various structures.
Use a temporary variable for our parent device (coming from I2C client
structure); we'll be also using it during conversion to managed resources.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
The Arizona CODECs contain a haptics module providing vibration feedback
support. Implement basic support for this, providing simple start/stop and
signal magnitude control.
Since the output path for haptics is routed through the CODEC audio routing
it is modelled as a signal generator within ASoC, the haptics driver calls
DAPM to start and stop the output drivers. An appropriate output path must
be configured via ALSA to connect the haptics source to the correct output.
The kernel does not contain the symbol SA1100_BITSY so the driver
is never compiled and can be removed safely.
Now we can register the BU21013_ts touch screen when booting with Device
Tree enabled. Here we parse all the necessary components previously
expected to be passed from platform data.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
These GPIO init and exit functions have no place in platform data, they
should be part of the driver instead,
Currently the BU21013 Touch Screen driver requests a regulator by the
name of 'V-TOUCH', which doesn't exist anywhere in the kernel. The
correct name, as referenced in platform regulator code is 'avdd'. Here,
when we request a regulator, we use the correct name instead.
Disable hardware if active when suspending if the hw can not
wake the system from suspend.
[Dmitry Torokhov: use input_dev->users instead of a separate flag]
Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com>
Signed-off-by: Philippe Langlais <philippe.langlais@linaro.org>
Reviewed-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com>
Instead of reporting the initial stage when the device is registered we
should do it when the device is opened (so there are users).
devm_* functions are device managed and make error handling and code
simpler. While at it also fix error exit paths.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
clk_{un}prepare is mandatory for platforms using common clock framework.
Because for SPEAr we don't do anything in clk_{un}prepare() calls, just
call them once in probe/remove.
Signed-off-by: Vipul Kumar Samar <vipulkumar.samar@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
In imx_keypad_inhibit(), all 8 columns were set to open-drain, in
contrast to the rest of the driver, where only the enabled columns
are modified/used.
Contrary to the normal expectation, this also affects column I/Os not
even mapped via IOMUX to the KPP hardware module but used as a GPIO.
Therefore only init enabled columns to open-drain and leave all others
with their default reset value of 0, i.e. totem-pole.
Signed-off-by: Andreas Pretzsch <apr@cn-eng.de>
We do not need to call tasklet_disable() before calling tasklet_kill() if
taskelt does not reschedult itself.
Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com>
To facilitate upcoming cleanup in twl stack switch from using
TWL4030_MODULE_PM_MASTER define to usingTWL_MODULE_PM_MASTER.
There are no functional changes.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
This patch allows the STMPE driver to be successfully probed and
initialised when Device Tree support is enabled. Besides the usual
platform data changes, we also separate the process of filling in
the 'in use' pin bitmap, as we have to extract the information from
Device Tree in the DT boot case.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devinitconst is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinitdata is no
longer needed.
