path: root/drivers/input
2008-07-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: add driver for Atmel integrated touchscreen controller Input: ads7846 - optimize order of calculating Rt in ads7846_rx() Input: ads7846 - fix sparse endian warnings Input: uinput - remove duplicate include Input: serio - offload resume to kseriod Input: serio - mark serio_register_driver() __must_check
2008-07-28sh_keysc: remove request_mem_region() and release_mem_region()Tetsuya Mukawa
Remove request_mem_region() and release_mem_region() from sh_keysc driver. Those functions can find resource conflict, but it is already checked in platform_device_add(). Signed-off-by: Tetsuya Mukawa <mukawa@igel.co.jp> Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-25Undo duplicate "m68k: drivers/input/serio/hp_sdc.c needs <linux/semaphore.h>"Linus Torvalds
Both commits 0f17e4c796e89d1f69f13b653aba60e6ccfb8ae0 ("Add missing semaphore.h includes") and 4933d07531711e399d8d578036aa9fc1be2f9b20 ("m68k: drivers/input/serio/hp_sdc.c needs <linux/semaphore.h>") added a We only really need one ;) Reported-by: Huang Weiyi <weiyi.huang@gmail.com> Requested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Add missing semaphore.h includesMatthew Wilcox
These files use semaphores but don't include semaphore.h Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-07-23Input: add driver for Atmel integrated touchscreen controllerDan Liang
The AT91SAM9RL SoC integrates a Touchscreen Controller which can trigger ADC conversion periodically. Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Dan Liang <dan.liang@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-23Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (85 commits) [ARM] pxa: add base support for PXA930 Handheld Platform (aka SAAR) [ARM] pxa: add base support for PXA930 Evaluation Board (aka TavorEVB) [ARM] pxa: add base support for PXA930 (aka Tavor-P) [ARM] Update mach-types [ARM] pxa: make littleton to use the new smc91x platform data [ARM] pxa: make zylonite to use the new smc91x platform data [ARM] pxa: make mainstone to use the new smc91x platform data [ARM] pxa: make lubbock to use new smc91x platform data [NET] smc91x: prepare SMC_USE_PXA_DMA to be specified in platform data [NET] smc91x: prepare for SMC_IO_SHIFT to be a platform configurable variable [NET] smc91x: add SMC91X_NOWAIT flag to platform data [NET] smc91x: favor the use of SMC91X_USE_* instead of SMC_CAN_USE_* [NET] smc91x: remove "irq_flags" from "struct smc91x_platdata" [ARM] 5146/1: pxa2xx: convert all boards to call pxa2xx_transceiver_mode helper Support for LCD on e740 e750 e400 and e800 e-series PDAs E-series UDC support PXA UDC - allow use of inverted GPIO for pullup Add e350 support Fix broken e-series build E-series GPIO / IRQ definitions. ...
2008-07-23Input: ads7846 - optimize order of calculating Rt in ads7846_rx()Hans-Christian Egtvedt
Alter the if expression for calculating Rt. The old implementation would run unnecessary code when the ADS7843 device was used. The patch also fixes the code style to kernel standard. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-23Input: ads7846 - fix sparse endian warningsHarvey Harrison
Also remove the temporary pointer and use ->rx_buf directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-23Input: uinput - remove duplicate includeHuang Weiyi
Remove duplicate include file <linux/smp_lock.h> in drivers/input/misc/uinput.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-23Input: serio - offload resume to kseriodShaohua Li
When resuming AUX ports psmouse driver calls psmouse_extensions() to determine if the attached mouse is still the same, which may take a while to complete for generic mice. Offload the resume process to kseriod so the rest of the system may continue resuming without waiting for the mouse. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-21Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 into nextDmitry Torokhov
2008-07-20m68k: Return -ENODEV if no device is foundGeert Uytterhoeven
According to the tests in do_initcalls(), the proper error code in case no device is found is -ENODEV, not -ENXIO or -EIO. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20tty: Ldisc revampAlan Cox
Move the line disciplines towards a conventional ->ops arrangement. For the moment the actual 'tty_ldisc' struct in the tty is kept as part of the tty struct but this can then be changed if it turns out that when it all settles down we want to refcount ldiscs separately to the tty. Pull the ldisc code out of /proc and put it with our ldisc code. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19Input: i8042 - add Arima-Rioworks HDAMB board to noloop listDmitry Torokhov
The board does not raise AUX IRQ in response to AUX LOOP command. Reported-by: Guillaume Morin <guillaume@morinfr.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-19Input: sgi_btns - add support for SGI Indy volume buttonsThomas Bogendoerfer
Also rename sgio2_btns to sgi_btns since the driver is not only for SGI O2 anymore. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-19Input: add option to disable HP SDC driverHelge Deller
Add "no_hpsdc" kernel module option to the hp_sdc driver, so that the driver can be instructed to not enable the HP SDC port. This is useful on some older HPPA boxes with HIL keyboard and HIL mouse where the new HP SDC HIL drivers don't work yet. By disabling the new hp_sdc driver users are able to use the older hilkbd driver instead. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-13Merge branch 'pxa' into develRussell King
Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-12Merge branch 'pxa-tosa' into pxaRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/tosa.c arch/arm/mach-pxa/spitz.c
2008-07-08Merge branches 'x86/numa-fixes', 'x86/apic', 'x86/apm', 'x86/bitops', ↵Ingo Molnar
'x86/build', 'x86/cleanups', 'x86/cpa', 'x86/cpu', 'x86/defconfig', 'x86/gart', 'x86/i8259', 'x86/intel', 'x86/irqstats', 'x86/kconfig', 'x86/ldt', 'x86/mce', 'x86/memtest', 'x86/pat', 'x86/ptemask', 'x86/resumetrace', 'x86/threadinfo', 'x86/timers', 'x86/vdso' and 'x86/xen' into x86/devel
2008-07-07Input: add new serio driver for Xilinx XPS PS2 IPJohn Linn
Added a new driver for Xilinx XPS PS2 IP. This driver is a flat driver to better match the Linux driver pattern. Signed-off-by: Sadanand <sadanan@xilinx.com> Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: add driver for Tabletkiosk Sahara TouchIT-213 touchscreenClaudio Nieder
Signed-off-by: Claudio Nieder <private@claudio.ch> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: new driver for SGI O2 volume buttonsThomas Bogendoerfer
This driver adds support for the volume buttons on the front of every SGI O2 workstation. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: yealink - reliably kill urbsOliver Neukum
Yealink uses two URBs that submit each other. This arrangement cannot be reliably killed with usb_kill_urb() alone, as there's a window during which the wrong URB may be killed. The fix is to introduce a flag. [dtor@mail.ru: remove spinlock, flag alone should be enough] Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: q40kbd - make q40kbd_lock staticAdrian Bunk
This patch makes the needlessly global q40kbd_lock static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: gtco - eliminate early returnJulia Lawall
There seems to be no reason why this error case should do less cleaning up than the other adjacent ones, so the goto, which is currently dead code, seems to be what is intended. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07Input: i8042 - add Dritek quirk for Acer Aspire 5720Carlos Corbacho
The Acer Aspire 5720 series also requires the Dritek quirk to enable the extra scancodes. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-07[ARM] 5064/1: pxa: explicitly specify tosa keyboard GPIOs' low power states ↵eric miao
to DRIVE_LOW Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03Input: usbtouchscreen - ignore eGalax screens supporting HID protocolDaniel Ritz
The newer versions of the eGalax/EETI screen implement the HID protocol. The device IDs are still the same, but the USB interface descriptor shows the device being of HID class. Change usbtouchscreen to ignore the HID models as they are handled properly by usbhid. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-03Input: i8042 - add Medion NAM 2070 to noloop blacklistDmitry Torokhov
AUX LOOP command fails with a timeout although this laptop has a touchpad. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-03Input: i8042 - add Gericom Bellagio to nomux blacklistJiri Kosina
Gericom Bellagio needs to be added to nomux blacklist, otherwise its touchpad misbehaves. Reported-by: Roland Kletzing <roland.kletzing@materna.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-03Input: i8042 - add Acer Aspire 1360 to nomux blacklistJiri Kosina
Acer Aspire 1360 needs to be added to nomux blacklist, otherwise its touchpad misbehaves. Reported-by: Clark Tompsett <clarkt@cnsp.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-07-02drivers/input/ff-core.c needs <linux/sched.h>Geert Uytterhoeven
Commit 656acd2bbc4ce7f224de499ee255698701396c48 ("Input: fix locking in force-feedback core") causes the following regression on m68k: | linux/drivers/input/ff-core.c: In function 'input_ff_upload': | linux/drivers/input/ff-core.c:172: error: dereferencing pointer to incomplete type | linux/drivers/input/ff-core.c: In function 'erase_effect': | linux/drivers/input/ff-core.c:197: error: dereferencing pointer to incomplete type | linux/drivers/input/ff-core.c:204: error: dereferencing pointer to incomplete type | make[4]: *** [drivers/input/ff-core.o] Error 1 As the incomplete type is `struct task_struct', including <linux/sched.h> fixes it. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02uinput: BKL pushdownArnd Bergmann
2008-07-02serio: BKL pushdownArnd Bergmann
2008-07-02mousedev: BKL pushdownArnd Bergmann
2008-06-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: fix locking in force-feedback core Input: add KEY_MEDIA_REPEAT definition
2008-06-30Input: hp_sdc_mlc.c - make a struct staticAdrian Bunk
This patch makes the needlessly global struct hp_sdc_mlc_priv_s static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: hil_mlc.c - make code staticAdrian Bunk
2008-06-30Input: wistron - generate normal key event if bluetooth or wifi not presentÉric Piel
If the subsystem is not present, instead of not doing anything, report the key press as a normal key. This is done by modifying at initialization the copied key entry table. Signed-off-by: Eric Piel <Eric.Piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: atkbd - fix HP 2133 not sending release event for video switchJiri Kosina
Video switch key on HP 2133 doesn't send release event, so we have to create workaround similar to what we do for Dell Latitude, i.e. perform DMI match for the system and generate 'false' release event ourselves, so that userspace doesn't think that the key is stuck forever. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: Add driver for iNexio serial touchscreen.Richard Lemon
Signed-off-by: Richard Lemon <richard@codelemon.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: wm9712 - no pressure measurement with 5-wire modeMark Brown
The hardware does not support pressure measurement is 5-wire mode so warn the user if he tries to request it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: fix force feedback upload issue in compat modeAdam Dawidowski
Force feedback upload of effects through the event device (ioctl EVIOCSFF) is not working in 32 bit applications running on 64-bit kernel due to the fact that struct ff_effect contains a pointer, resulting in the structure having different sizes in 64 and 32 bit programs and causing difference in ioctl numbers. [dtor@mail.ru: refactor to keep all ugliness in evdev] Signed-off-by: Adam Dawidowski <drake_ster@wp.pl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: atamouse - various cleanupsDmitry Torokhov
2008-06-30Input: evbug - identify device by its sysfs IDDmitry Torokhov
This should help with devices that don't set up their phys or name since sysfs ID is always present. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-06-30Input: don't reset sync flag when ignoring eventDmitry Torokhov
2008-06-30Input: fix locking in force-feedback coreDmitry Torokhov
The newly added event_lock spinlock in the input core disallows sleeping and therefore using mutexes in event handlers. Convert force-feedback core to rely on event_lock instead of mutex to protect slots allocated for fore-feedback effects. The original mutex is still used to serialize uploading and erasing of effects. Reported-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
