path: root/drivers/input
2008-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: rename SW_RADIO to SW_RFKILL_ALL Input: gtco - fix double kfree in error handling path Input: pxa27x_keypad - miscellaneous fixes Input: atkbd - mark keyboard as disabled when suspending/unloading Input: apanel - remove duplicate include Input: wm9713 - support five wire panels Input: wm97xx-core - fix race on PHY init Input: wm97xx-core - fix driver name Input: wm97xx-core - report a phys for WM97xx touchscreens Input: i8042 - make sure Dritek quirk is invoked at resume Input: i8042 - add Dritek quirk for Acer TravelMate 660
2008-05-30Input: gtco - fix double kfree in error handling pathDmitry Torokhov
The code would try to free 'report' twice upon input_register_device() failure. Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-28Input: pxa27x_keypad - miscellaneous fixesAntonio Ospite
1. Set input bits for direct keys codes 2. Set input bits for rotary encoder codes only if rotary encoder is enabled 3. Enable EV_REL only if rotary encoder is enabled and rel_codes are set up Signed-off-by: Antonio Ospite <ao2@openezx.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-28Input: atkbd - mark keyboard as disabled when suspending/unloadingDmitry Torokhov
This will shut off garbage that may come from KBD port during resume. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: apanel - remove duplicate includeHuang Weiyi
Remove duplicate include file <linux/module.h>. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm9713 - support five wire panelsMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm97xx-core - fix race on PHY initMark Brown
The chip phy_init() function must be called before the dig_enable() function but dig_enable() is called when the device is opened and we only call phy_init() after having reigstered the device, meaning the two can race. Fix this by doing the phy_init() before we register the input device. Thanks to Rodolfo Giometti <giometti@enneenne.com> for the report. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm97xx-core - fix driver nameMark Brown
Fix driver name - thanks to Guennadi Liakhovetski <g.liakhovetski@gmx.de> for reporting this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: wm97xx-core - report a phys for WM97xx touchscreensMark Brown
phys is displayed in diagnostic output like that from evbug so ensure that it is set to something. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-27Input: i8042 - make sure Dritek quirk is invoked at resumeBruno Prémont
Also do not fail i8042 entire initialization if enabling dritek extension fails. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-21MODULE_LICENSE expects "GPL v2", not "GPLv2"Al Viro
... and we have few enough places using the latter to make it simpler to do search and replace... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-20Input: i8042 - add Dritek quirk for Acer TravelMate 660Bruno Prémont
The Acer TravelMate 660 series also requires the Dritek quirk to enable the extra scancodes. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-05-18m68k: Return -ENODEV if no device is foundGeert Uytterhoeven
According to the tests in do_initcalls(), the proper error code in case no device is found is -ENODEV, not -ENXIO or -EIO. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-18m68k: Some input drivers do not check the platformGeert Uytterhoeven
Some input drivers do not check whether they're actually running on the correct platform, causing multi-platform kernels to crash if they are not. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (37 commits) SH: catch negative denormal_subf1() retval in denormal_add() sh: Fix DMAC base address for SH7709S sh: update smc91x platform data for se7206. sh: Stub in cpu_to_node() and friends for NUMA build. sh: intc register modify fix sh: no high level trigger on some sh3 cpus sh: clean up sh7710 and sh7720 intc tables sh: add interrupt ack code to sh3 sh: unify external irq pin code for sh3 sh-sci: avoid writing to nonexistent registers sh-sci: sh7722 lacks scsptr registers sh-sci: improve sh7722 support sh: reset hardware from early printk sh: drain and wait for early printk sh: use sci_out() for early printk sh: add memory resources to /proc/iomem sh: add kernel bss resource sh: fix sh7705 interrupt vector typo sh: update smc91x platform data for se7722 sh: update smc91x platform data for MigoR ...
2008-05-08input: i8042: sh64 IRQ definitions depend on cayman board.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-07pcspkr: fix dependanciesStas Sergeev
fix pcspkr dependancies: make the pcspkr platform drivers to depend on a platform device, and not the other way around. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> CC: Vojtech Pavlik <vojtech@suse.cz> CC: Michael Opdenacker <michael-lists@free-electrons.com> [fixed for 2.6.26-rc1 by tiwai] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-05m68k: drivers/input/serio/hp_sdc.c needs <linux/semaphore.h>Geert Uytterhoeven
drivers/input/serio/hp_sdc.c: In function 'hp_sdc_take': drivers/input/serio/hp_sdc.c:198: error: implicit declaration of function 'up' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29input: use get_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_busAlexey Dobriyan
Remove proc_bus export and variable itself. Using pathnames works fine and is slightly more understandable and greppable. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28usb input endianness annotations and fixesAl Viro
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: video drivers: add facility level sparc: tcx.c make tcx_init and tcx_exit static sparc: ffb.c make ffb_init and ffb_exit static sparc: cg14.c make cg14_init and cg15_exit static sparc: bw2.c fix bw2_exit sparc64: Fix accidental syscall restart on child return from clone/fork/vfork. sparc64: Clean up handling of pt_regs trap type encoding. sparc: Remove old style signal frame support. sparc64: Kill bogus RT_ALIGNEDSZ macro from signal.c sparc: sunzilog.c remove unused argument sparc: fix drivers/video/tcx.c warning sparc64: Kill unused local ISA bus layer. input: Rewrite sparcspkr device probing. sparc64: Do not ignore 'pmu' device ranges. sparc64: Kill ISA_FLOPPY_WORKS code. sparc64: Kill CONFIG_SPARC32_COMPAT sparc64: Cleanups and corrections for arch/sparc64/Kconfig sparc64: Fix wedged irq regression.
2008-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - fix build failure
2008-04-26input: Rewrite sparcspkr device probing.David S. Miller
Remove all dependencies on EBUS and ISA bus layers, which we'd like to remove as they are superfluous. While we're here, add support for proper frequency changing on BBC beep devices. Unlike the comments that were here, this device can in fact use a programmable frequency. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27Input: xpad - fix build failureDmitry Torokhov
If both CONFIG_JOYSTICK_XPAD_FF and CONFIG_JOYSTICK_XPAD_LEDS are unset xpad_bulk_out is not defined and build fails. Move it out of the #ifdef block so it is always defined. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (120 commits) usb: don't update devnum for wusb devices wusb: make ep0_reinit available for modules wusb: devices dont use a set address wusb: teach choose_address() about wireless devices wusb: add link wusb-usb device wusb: add authenticathed bit to usb_dev USB: remove unnecessary type casting of urb->context usb serial: more fixes and groundwork for tty changes USB: replace remaining __FUNCTION__ occurrences USB: usbfs: export the URB_NO_INTERRUPT flag to userspace USB: fix compile problems in ehci-hcd USB: ehci: qh_completions cleanup and bugfix USB: cdc-acm: signedness fix USB: add documentation about callbacks USB: don't explicitly reenable root-hub status interrupts USB: OHCI: turn off RD when remote wakeup is disabled USB: HCDs use the do_remote_wakeup flag USB: g_file_storage: ignore bulk-out data after invalid CBW USB: serial: remove endpoints setting checks from core and header USB: serial: remove unneeded number endpoints settings ...
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: wacom - add support for Cintiq 20WSX Input: ucb1400_ts - IRQ probe fix Input: at32psif - update MODULE_AUTHOR with new email Input: mac_hid - add lockdep annotation to emumousebtn Input: i8042 - fix incorrect usage of strncpy and strncat Input: bf54x-keys - add infrastructure for keypad wakeups Input: add MODULE_ALIAS() to hotpluggable platform modules Input: drivers/char/keyboard.c - use time_after Input: fix ordering in joystick Makefile Input: wm97xx-core - support use as a wakeup source Input: wm97xx-core - use IRQF_SAMPLE_RANDOM Input: wm97xx-core - only schedule interrupt handler if not already scheduled Input: add Zhen Hua driver Input: aiptek - add support for Genius G-PEN 560 tablet Input: wacom - implement suspend and autosuspend Input: xpad - set proper buffer length for outgoing requests Input: omap-keypad - fix build warning Input: gpio_keys - irq handling cleanup Input: add PS/2 serio driver for AVR32 devices Input: put ledstate in the keyboard notifier ...
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next: (52 commits) xen: add balloon driver xen: allow compilation with non-flat memory xen: fold xen_sysexit into xen_iret xen: allow set_pte_at on init_mm to be lockless xen: disable preemption during tlb flush xen pvfb: Para-virtual framebuffer, keyboard and pointer driver xen: Add compatibility aliases for frontend drivers xen: Module autoprobing support for frontend drivers xen blkfront: Delay wait for block devices until after the disk is added xen/blkfront: use bdget_disk xen: Make xen-blkfront write its protocol ABI to xenstore xen: import arch generic part of xencomm xen: make grant table arch portable xen: replace callers of alloc_vm_area()/free_vm_area() with xen_ prefixed one xen: make include/xen/page.h portable moving those definitions under asm dir xen: add resend_irq_on_evtchn() definition into events.c Xen: make events.c portable for ia64/xen support xen: move events.c to drivers/xen for IA64/Xen support xen: move features.c from arch/x86/xen/features.c to drivers/xen xen: add missing definitions in include/xen/interface/vcpu.h which ia64/xen needs ...
2008-04-24USB: convert away from urb->status in xpad driverOliver Neukum
USB is moving to transfering status as a parameter. To ease the transition urb->status is to be touched only once in a function. The xpad driver has been overlooked. Dmitry wants this to go through the USB tree. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24Input: wacom - add support for Cintiq 20WSXPing Cheng
Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24xen pvfb: Para-virtual framebuffer, keyboard and pointer driverMarkus Armbruster
This is a pair of Xen para-virtual frontend device drivers: drivers/video/xen-fbfront.c provides a framebuffer, and drivers/input/xen-kbdfront provides keyboard and mouse. The backends run in dom0 user space. The two drivers are not in two separate patches, because the intermediate step (one driver, not the other) is somewhat problematic: the backend in dom0 needs both drivers, and will refuse to complete device initialization unless they're both present. Signed-off-by: Markus Armbruster <armbru@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24Merge branch 'wm97xx'Dmitry Torokhov
2008-04-24Input: ucb1400_ts - IRQ probe fixVernon Sauder
The UCB1400 driver IRQ probe code fails to find an interrupt if all the interrupts in the range 0-31 are nonprobe-able. This patch removes the check of the return value so interrupts above 31 can be detected. Tested on InHand Fingertip4 PXA270 board. Signed-off-by: Vernon Sauder <vsauder@inhand.com> Acked-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: at32psif - update MODULE_AUTHOR with new emailHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: i8042 - fix incorrect usage of strncpy and strncatRoel Kluin
Fix incorrect length argument for strncpy and strncat by replacing them with strlcpy and strlcat Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: bf54x-keys - add infrastructure for keypad wakeupsMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: add MODULE_ALIAS() to hotpluggable platform modulesKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable "input" platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24Input: fix ordering in joystick MakefileJiri Kosina
Make entries in drivers/input/joystick/Makefile properly alphabetically ordered. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-24pcsp - Don't build pcspkr when snd-pcsp is enabledStas Sergeev
- Update CREDITS with the pc-speaker driver authors. - Prevent pcspkr from being built together with snd-pcsp. Both pcspkr and snd-pcsp use the same platform driver name "pcspkr". Signed-off-by: Stas Sergeev <stsp@aknet.ru>
2008-04-21Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Deprecate the asm/semaphore.h files in feature-removal-schedule. Convert asm/semaphore.h users to linux/semaphore.h security: Remove unnecessary inclusions of asm/semaphore.h lib: Remove unnecessary inclusions of asm/semaphore.h kernel: Remove unnecessary inclusions of asm/semaphore.h include: Remove unnecessary inclusions of asm/semaphore.h fs: Remove unnecessary inclusions of asm/semaphore.h drivers: Remove unnecessary inclusions of asm/semaphore.h net: Remove unnecessary inclusions of asm/semaphore.h arch: Remove unnecessary inclusions of asm/semaphore.h
2008-04-21Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (212 commits) [ARM] pxa: Phycore pcm-990-specific code for the PXA270 Quick Capture driver [ARM] pxa: V4L2 soc_camera driver for PXA270 [ARM] pxa: restrict availability of pxa2xx PCMCIA drivers [ARM] 5005/1: BAST: Fix kset_name initialiser [ARM] 4967/1: Adds functions to set clkout rate for Samsung S3C2410 [ARM] 4988/1: Add GPIO lib support to the EP93xx [ARM] Add initial sparsemem support [ARM] pxa: initialise PXA devices before platform init code [ARM] 5002/1: tosa: add two more leds [ARM] 5004/1: Tosa: make several unreferenced structures static. [ARM] 5003/1: Shut up sparse warnings [ARM] 4977/2: soc - pxa2xx-ac97 - Add missing clk_enable() [ARM] 4976/1: zylonite: Configure GPIO for WM9713 IRQ line [ARM] 4974/1: Drop unused leds-tosa. [ARM] 4973/1: Tosa: use leds-gpio driver. [ARM] 4972/1: Tosa: convert scoop GPIOs usage to generic gpio code [ARM] 4971/1: pxaficp_ir: provide startup and shutdown hooks [ARM] pxa: lubbock: move mis-placed SPI info [ARM] 4970/1: tosa: correct gpio used for wake up. [ARM] 4966/1: magician: add MFP pin configuration ...
2008-04-19Merge branch 'omap2-upstream' into develRussell King
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18Fix sh_keysc double freeMagnus Damm
Avoid double free situation from happening by removing input_free_device() after input_unregister_device(). Suggested by Dmitry Torokhov. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-18sh: SuperH KEYSC platform driverMagnus Damm
Add a platform driver for the SuperH KEYSC block. The driver expects to get mode, timing information and keypad layout from the board code as platform data. The board code is resonsible for pin configuration. Both sh7343 and sh7722 should be supported, but only the sh7722 processor has been tested so far. SH_KEYSC_MODE_3 is yet to be tested. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-17Input: wm97xx-core - support use as a wakeup sourceMark Brown
The WM97xx touch screen controllers can be used to generate a wakeup event when the system is suspended. Provide a new core API call wm97xx_set_suspend_mode() allowing machine drivers to enable this. If no suspend_mode is provided then the touch panel will be powered down when the system is suspended. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-17Input: wm97xx-core - use IRQF_SAMPLE_RANDOMMark Brown
The touchscreen interrupt is driven by human input which can reasonably be used to provide entropy. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
