path: root/drivers/input
2018-05-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "Just a few driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: atmel_mxt_ts - add missing compatible strings to OF device table Input: atmel_mxt_ts - fix the firmware update Input: atmel_mxt_ts - add touchpad button mapping for Samsung Chromebook Pro MAINTAINERS: Rakesh Iyer can't be reached anymore Input: hideep_ts - fix a typo in Kconfig Input: alps - fix reporting pressure of v3 trackstick Input: leds - fix out of bound access Input: synaptics-rmi4 - fix an unchecked out of memory error path
2018-05-01Input: atmel_mxt_ts - add missing compatible strings to OF device tableJavier Martinez Canillas
Commit af503716ac14 ("i2c: core: report OF style module alias for devices registered via OF") fixed how the I2C core reports the module alias when devices are registered via OF. But the atmel_mxt_ts driver only has an "atmel,maxtouch" compatible in its OF device ID table, so if a Device Tree is using a different one, autoload won't be working for the module (the matching works because the I2C device ID table is used as a fallback). So add compatible strings for each of the entries in the I2C device table. Fixes: af503716ac14 ("i2c: core: report OF style module alias for devices registered via OF") Reported-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Signed-off-by: Javier Martinez Canillas <javierm@redhat.com> Tested-by: Enric Balletbo i Serra <enric.balletbo@collabora.com> Reviewed-by: Rob Herring <robh@kernel.org> [dtor: document which compatibles are deprecated and should not be used] Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-05-01Input: atmel_mxt_ts - fix the firmware updateNick Dyer
The automatic update mechanism will trigger an update if the info block CRCs are different between maxtouch configuration file (maxtouch.cfg) and chip. The driver compared the CRCs without retrieving the chip CRC, resulting always in a failure and firmware flashing action triggered. Fix this issue by retrieving the chip info block CRC before the check. Note that this solution has the benefit that by reading the information block and the object table into a contiguous region of memory, we can verify the checksum at probe time. This means we make sure that we are indeed talking to a chip that supports object protocol correctly. Using this patch on a kevin chromebook, the touchscreen and touchpad drivers are able to match the CRC: atmel_mxt_ts 3-004b: Family: 164 Variant: 14 Firmware V2.3.AA Objects: 40 atmel_mxt_ts 5-004a: Family: 164 Variant: 17 Firmware V2.0.AA Objects: 31 atmel_mxt_ts 3-004b: Resetting device atmel_mxt_ts 5-004a: Resetting device atmel_mxt_ts 3-004b: Config CRC 0x573E89: OK atmel_mxt_ts 3-004b: Touchscreen size X4095Y2729 input: Atmel maXTouch Touchscreen as /devices/platform/ff130000.i2c/i2c-3/3-004b/input/input5 atmel_mxt_ts 5-004a: Config CRC 0x0AF6BA: OK atmel_mxt_ts 5-004a: Touchscreen size X1920Y1080 input: Atmel maXTouch Touchpad as /devices/platform/ff140000.i2c/i2c-5/5-004a/input/input6 Signed-off-by: Nick Dyer <nick.dyer@shmanahar.org> Acked-by: Benson Leung <bleung@chromium.org> [Ezequiel: minor patch massage] Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Tested-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-05-01Input: atmel_mxt_ts - add touchpad button mapping for Samsung Chromebook ProVittorio Gambaletta (VittGam)
This patch adds the correct platform data information for the Caroline Chromebook, so that the mouse button does not get stuck in pressed state after the first click. The Samus button keymap and platform data definition are the correct ones for Caroline, so they have been reused here. Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net> Signed-off-by: Salvatore Bellizzi <lkml@seppia.net> Tested-by: Guenter Roeck <groeck@chromium.org> Cc: stable@vger.kernel.org [dtor: adjusted vendor spelling to match shipping firmware] Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-04-26Revert: Unify CLOCK_MONOTONIC and CLOCK_BOOTTIMEThomas Gleixner
Revert commits 92af4dcb4e1c ("tracing: Unify the "boot" and "mono" tracing clocks") 127bfa5f4342 ("hrtimer: Unify MONOTONIC and BOOTTIME clock behavior") 7250a4047aa6 ("posix-timers: Unify MONOTONIC and BOOTTIME clock behavior") d6c7270e913d ("timekeeping: Remove boot time specific code") f2d6fdbfd238 ("Input: Evdev - unify MONOTONIC and BOOTTIME clock behavior") d6ed449afdb3 ("timekeeping: Make the MONOTONIC clock behave like the BOOTTIME clock") 72199320d49d ("timekeeping: Add the new CLOCK_MONOTONIC_ACTIVE clock") As stated in the pull request for the unification of CLOCK_MONOTONIC and CLOCK_BOOTTIME, it was clear that we might have to revert the change. As reported by several folks systemd and other applications rely on the documented behaviour of CLOCK_MONOTONIC on Linux and break with the above changes. After resume daemons time out and other timeout related issues are observed. Rafael compiled this list: * systemd kills daemons on resume, after >WatchdogSec seconds of suspending (Genki Sky). [Verified that that's because systemd uses CLOCK_MONOTONIC and expects it to not include the suspend time.] * systemd-journald misbehaves after resume: systemd-journald[7266]: File /var/log/journal/016627c3c4784cd4812d4b7e96a34226/system.journal corrupted or uncleanly shut down, renaming and replacing. (Mike Galbraith). * NetworkManager reports "networking disabled" and networking is broken after resume 50% of the time (Pavel). [May be because of systemd.] * MATE desktop dims the display and starts the screensaver right after system resume (Pavel). * Full system hang during resume (me). [May be due to systemd or NM or both.] That happens on debian and open suse systems. It's sad, that these problems were neither catched in -next nor by those folks who expressed interest in this change. Reported-by: Rafael J. Wysocki <rjw@rjwysocki.net> Reported-by: Genki Sky <sky@genki.is>, Reported-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Kevin Easton <kevin@guarana.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salyzyn <salyzyn@android.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2018-04-23Input: hideep_ts - fix a typo in KconfigMasanari Iida
This patch fixes a spelling error found in Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-04-23Input: alps - fix reporting pressure of v3 trackstickPali Rohár
According to documentation, all 7 lower bits represents trackpoint pressure. Fixes: 4621c9660459 ("Input: alps - report pressure of v3 and v7 trackstick") Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-04-13Merge tag 'chrome-platform-for-linus-4.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bleung/chrome-platform Pull chrome platform updates from Benson Leung: - a series from Dmitry to remove platform data from chromeos_laptop.c, which was the only user of platform data for the atmel_mxt_ts driver. - a series to clean up sysfs and debugfs for cros_ec - other misc cleanups * tag 'chrome-platform-for-linus-4.17' of git://git.kernel.org/pub/scm/linux/kernel/git/bleung/chrome-platform: (22 commits) platform/chrome: mfd/cros_ec_dev: Add sysfs entry to set keyboard wake lid angle platform/chrome: cros_ec_debugfs: Add PD port info to debugfs platform/chrome: cros_ec_debugfs: Use octal permissions '0444' platform/chrome: cros_ec_sysfs: use permission-specific DEVICE_ATTR variants platform/chrome: cros_ec_sysfs: introduce to_cros_ec_dev define. platform/chrome: cros_ec_sysfs: Modify error handling platform/chrome: cros_ec_lpc: Add support for Google devices using custom coreboot firmware platform/chrome: cros_ec_lpc: wake up from s2idle on Chrome EC Input: atmel_mxt_ts - remove platform data support platform/chrome: chromeos_laptop - discard data for unneeded boards platform/chrome: chromeos_laptop - use device properties for Pixel platform/chrome: chromeos_laptop - rely on I2C to set up interrupt trigger platform/chrome: chromeos_laptop - use I2C notifier to create devices platform/chrome: chromeos_laptop - parse DMI IRQ data once platform/chrome: chromeos_laptop - rework i2c peripherals initialization platform/chrome: chromeos_laptop - factor out getting IRQ from DMI platform/chrome: chromeos_laptop - introduce pr_fmt() platform/chrome: chromeos_laptop - stop setting suspend mode for Atmel devices platform/chrome: chromeos_laptop - add SPDX identifier Input: atmel_mxt_ts - switch ChromeOS ACPI devices to generic props ...
2018-04-11Input: leds - fix out of bound accessDmitry Torokhov
UI_SET_LEDBIT ioctl() causes the following KASAN splat when used with led > LED_CHARGING: [ 1274.663418] BUG: KASAN: slab-out-of-bounds in input_leds_connect+0x611/0x730 [input_leds] [ 1274.663426] Write of size 8 at addr ffff88003377b2c0 by task ckb-next-daemon/5128 This happens because we were writing to the led structure before making sure that it exists. Reported-by: Tasos Sahanidis <tasos@tasossah.com> Tested-by: Tasos Sahanidis <tasos@tasossah.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-04-09Input: atmel_mxt_ts - remove platform data supportDmitry Torokhov
Now that there are no users of custom Atmel platform data, and everyone has switched to the generic device properties, we can remove support for the platform data. Acked-by: Nick Dyer <nick@shmanahar.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Benson Leung <bleung@chromium.org>
2018-04-09Input: atmel_mxt_ts - switch ChromeOS ACPI devices to generic propsDmitry Torokhov
Move older ChromeOS devices describing Atmel controllers in ACPI, but not providing enough details to configure the controllers properly, from platform data over to generic device properties. This will allow us remove support for platform data later on, leaving only generic device properties in place. Acked-by: Nick Dyer <nick@shmanahar.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Benson Leung <bleung@chromium.org>
2018-04-09Input: atmel_mxt_ts - switch from OF to generic device propertiesDmitry Torokhov
Instead of using OF-specific APIs to fecth device properties, let's switch to generic device properties API. This will allow us to use device properties on legacy ChromeOS devices and get rid of platform data down the road. Acked-by: Nick Dyer <nick@shmanahar.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Benson Leung <bleung@chromium.org>
2018-04-09Input: atmel_mxt_ts - do not pass suspend mode in platform dataDmitry Torokhov
The way we are supposed to put controller to sleep and wake it up does not depend on the platform, but rather on controller itself, so we want to get rid of suspend mode in platform data (and eventually get rid of platform data completely). Unfortunately some early chromebooks (the original Pixel, Acer C720) were shipped with config that requires manually re-enabling touch reporting in T9. We will sort it out, but in the meantime let's switch to a simple DMI quirk. We'll keep pdata->suspend_mode for now and remove it when we rework chromeos-laptop driver. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Benson Leung <bleung@chromium.org>
2018-04-06Input: synaptics-rmi4 - fix an unchecked out of memory error pathChristophe JAILLET
When extending the rmi_spi buffers, we must check that no out of memory error occurs, otherwise we may access data above the currently allocated memory. Propagate the error code returned by 'rmi_spi_manage_pools()' instead. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Reviewed-by: Andrew Duggan <aduggan@synaptics.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-04-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: - new driver for PhoenixRC Flight Controller Adapter - new driver for RAVE SP Power button - fixes for autosuspend-related deadlocks in a few unput USB dirvers - support for 2nd wheel in ATech PS/2 mouse - fix for ALPS trackpoint detection on Thinkpad L570 and Latitude 7370 - bunch of cleanups in various in PS/2 protocols - other assorted changes and fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (35 commits) Input: i8042 - enable MUX on Sony VAIO VGN-CS series to fix touchpad Input: stmfts, s6sy761 - update my e-mail Input: stmfts - use async probe & suspend/resume to avoid 2s delay Input: ALPS - fix TrackStick detection on Thinkpad L570 and Latitude 7370 Input: xpad - add PDP device id 0x02a4 Input: alps - report pressure of v3 and v7 trackstick Input: pxrc - new driver for PhoenixRC Flight Controller Adapter Input: usbtouchscreen - do not rely on input_dev->users Input: usbtouchscreen - fix deadlock in autosuspend Input: pegasus_notetaker - do not rely on input_dev->users Input: pagasus_notetaker - fix deadlock in autosuspend Input: synaptics_usb - do not rely on input_dev->users Input: synaptics_usb - fix deadlock in autosuspend Input: gpio-keys - add support for wakeup event action Input: appletouch - use true and false for boolean values Input: silead - add Chuwi Hi8 support Input: analog - use get_cycles() on PPC Input: stmpe-keypad - remove VLA usage Input: i8042 - add Lenovo ThinkPad L460 to i8042 reset list Input: add RAVE SP Powerbutton driver ...
2018-04-04Merge branch 'next' into for-linusDmitry Torokhov
Prepare input updates for 4.17 merge window.
2018-04-04Input: i8042 - enable MUX on Sony VAIO VGN-CS series to fix touchpadOndrej Zary
The touch sensor buttons on Sony VAIO VGN-CS series laptops (e.g. VGN-CS31S) are a separate PS/2 device. As the MUX is disabled for all VAIO machines by the nomux blacklist, the data from touch sensor buttons and touchpad are combined. The protocol used by the buttons is probably similar to the touchpad protocol (both are Synaptics) so both devices get enabled. The controller combines the data, creating a mess which results in random button clicks, touchpad stopping working and lost sync error messages: psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 4 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: TouchPad at isa0060/serio1/input0 lost sync at byte 1 psmouse serio1: issuing reconnect request Add a new i8042_dmi_forcemux_table whitelist with VGN-CS. With MUX enabled, touch sensor buttons are detected as separate device (and left disabled as there's currently no driver), fixing all touchpad problems. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-04-04Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull time(r) updates from Thomas Gleixner: "A small set of updates for timers and timekeeping: - The most interesting change is the consolidation of clock MONOTONIC and clock BOOTTIME. Clock MONOTONIC behaves now exactly like clock BOOTTIME and does not longer ignore the time spent in suspend. A new clock MONOTONIC_ACTIVE is provived which behaves like clock MONOTONIC in kernels before this change. This allows applications to programmatically check for the clock MONOTONIC behaviour. As discussed in the review thread, this has the potential of breaking user space and we might have to revert this. Knock on wood that we can avoid that exercise. - Updates to the NTP mechanism to improve accuracy - A new kernel internal data structure to aid the ongoing Y2038 work. - Cleanups and simplifications of the clocksource code. - Make the alarmtimer code play nicely with debugobjects" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: alarmtimer: Init nanosleep alarm timer on stack y2038: Introduce struct __kernel_old_timeval tracing: Unify the "boot" and "mono" tracing clocks hrtimer: Unify MONOTONIC and BOOTTIME clock behavior posix-timers: Unify MONOTONIC and BOOTTIME clock behavior timekeeping: Remove boot time specific code Input: Evdev - unify MONOTONIC and BOOTTIME clock behavior timekeeping: Make the MONOTONIC clock behave like the BOOTTIME clock timekeeping: Add the new CLOCK_MONOTONIC_ACTIVE clock timekeeping/ntp: Determine the multiplier directly from NTP tick length timekeeping/ntp: Don't align NTP frequency adjustments to ticks clocksource: Use ATTRIBUTE_GROUPS clocksource: Use DEVICE_ATTR_RW/RO/WO to define device attributes clocksource: Don't walk the clocksource list for empty override
2018-04-03Merge tag 'media/v4.17-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - new CEC pin injection code for testing purposes - DVB frontend cxd2099 promoted from staging - new platform driver for Sony cxd2880 DVB devices - new sensor drivers: mt9t112, ov2685, ov5695, ov772x, tda1997x, tw9910.c - removal of unused cx18 and ivtv alsa mixers - the reneseas-ceu driver doesn't depend on soc_camera anymore and moved from staging - removed the mantis_vp3028 driver, unused since 2009 - s5p-mfc: add support for version 10 of the MSP - added a decoder for imon protocol - atomisp: lots of cleanups - imx074 and mt9t031: don't depend on soc_camera anymore, being promoted from staging - added helper functions to better support DVB I2C binding - lots of driver improvements and cleanups * tag 'media/v4.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (438 commits) media: v4l2-ioctl: rename a temp var that stores _IOC_SIZE(cmd) media: fimc-capture: get rid of two warnings media: dvb-usb-v2: fix a missing dependency of I2C_MUX media: uvc: to the right check at uvc_ioctl_enum_framesizes() media: cec-core: fix a bug at cec_error_inj_write() media: tda9840: cleanup a warning media: tm6000: avoid casting just to print pointer address media: em28xx-input: improve error handling code media: zr364xx: avoid casting just to print pointer address media: vivid-radio-rx: add a cast to avoid a warning media: saa7134-alsa: don't use casts to print a buffer address media: solo6x10: get rid of an address space warning media: zoran: don't cast pointers to print them media: ir-kbd-i2c: change the if logic to avoid a warning media: ir-kbd-i2c: improve error handling code media: saa7134-input: improve error handling media: s2255drv: fix a casting warning media: ivtvfb: Cleanup some warnings media: videobuf-dma-sg: Fix a weird cast soc_camera: fix a weird cast on printk ...
2018-04-03Merge branch 'parisc-4.17-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc updates from Helge Deller: "Lots of small enhancements and fixes in this patchset: - improved the x86-64 compatibility for PCI cards by returning -1UL for timed out MMIO transactions (instead of crashing) - fixed HPMC handler for PAT machines: size needs to be multiple of 16 - prepare machine_power_off() to be able to turn rp3410 and c8000 machines off via IMPI - added code to extract machine info for usage with qemu - some init sections fixes - lots of fixes for sparse-, ubsan- and uninitalized variables warnings" * 'parisc-4.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Fix out of array access in match_pci_device() parisc: Add code generator for Qemu/SeaBIOS machine info parisc/pci: Switch LBA PCI bus from Hard Fail to Soft Fail mode parisc: Fix HPMC handler by increasing size to multiple of 16 bytes parisc: Directly call machine_power_off() in power button driver parisc: machine_power_off() should call pm_power_off() parisc/Kconfig: SMP kernels boot on all machines parisc: Silence uninitialized variable warning in dbl_to_sgl_fcnvff() parisc: Move various functions and strings to init section parisc: Convert MAP_TYPE to cover 4 bits on parisc parisc: Force to various endian types for sparse parisc/gscps2: Fix sparse warnings parisc/led: Fix sparse warnings parisc/parport_gsc: Use NULL to avoid sparse warning parisc/stifb: Use fb_memset() to avoid sparse warning
2018-04-02Merge tag 'arch-removal' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pul removal of obsolete architecture ports from Arnd Bergmann: "This removes the entire architecture code for blackfin, cris, frv, m32r, metag, mn10300, score, and tile, including the associated device drivers. I have been working with the (former) maintainers for each one to ensure that my interpretation was right and the code is definitely unused in mainline kernels. Many had fond memories of working on the respective ports to start with and getting them included in upstream, but also saw no point in keeping the port alive without any users. In the end, it seems that while the eight architectures are extremely different, they all suffered the same fate: There was one company in charge of an SoC line, a CPU microarchitecture and a software ecosystem, which was more costly than licensing newer off-the-shelf CPU cores from a third party (typically ARM, MIPS, or RISC-V). It seems that all the SoC product lines are still around, but have not used the custom CPU architectures for several years at this point. In contrast, CPU instruction sets that remain popular and have actively maintained kernel ports tend to all be used across multiple licensees. [ See the new nds32 port merged in the previous commit for the next generation of "one company in charge of an SoC line, a CPU microarchitecture and a software ecosystem" - Linus ] The removal came out of a discussion that is now documented at https://lwn.net/Articles/748074/. Unlike the original plans, I'm not marking any ports as deprecated but remove them all at once after I made sure that they are all unused. Some architectures (notably tile, mn10300, and blackfin) are still being shipped in products with old kernels, but those products will never be updated to newer kernel releases. After this series, we still have a few architectures without mainline gcc support: - unicore32 and hexagon both have very outdated gcc releases, but the maintainers promised to work on providing something newer. At least in case of hexagon, this will only be llvm, not gcc. - openrisc, risc-v and nds32 are still in the process of finishing their support or getting it added to mainline gcc in the first place. They all have patched gcc-7.3 ports that work to some degree, but complete upstream support won't happen before gcc-8.1. Csky posted their first kernel patch set last week, their situation will be similar [ Palmer Dabbelt points out that RISC-V support is in mainline gcc since gcc-7, although gcc-7.3.0 is the recommended minimum - Linus ]" This really says it all: 2498 files changed, 95 insertions(+), 467668 deletions(-) * tag 'arch-removal' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (74 commits) MAINTAINERS: UNICORE32: Change email account staging: iio: remove iio-trig-bfin-timer driver tty: hvc: remove tile driver tty: remove bfin_jtag_comm and hvc_bfin_jtag drivers serial: remove tile uart driver serial: remove m32r_sio driver serial: remove blackfin drivers serial: remove cris/etrax uart drivers usb: Remove Blackfin references in USB support usb: isp1362: remove blackfin arch glue usb: musb: remove blackfin port usb: host: remove tilegx platform glue pwm: remove pwm-bfin driver i2c: remove bfin-twi driver spi: remove blackfin related host drivers watchdog: remove bfin_wdt driver can: remove bfin_can driver mmc: remove bfin_sdh driver input: misc: remove blackfin rotary driver input: keyboard: remove bf54x driver ...
2018-03-30Input: stmfts, s6sy761 - update my e-mailAndi Shyti
Because I will be leaving Samsung soon, for reachability update my reference e-mail to etezian.org. Signed-off-by: Andi Shyti <andi.shyti@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-30Input: stmfts - use async probe & suspend/resume to avoid 2s delayMarek Szyprowski
Executing stmfts_power_on() function lasts over 2 seconds, what significantly slows down the boot and resume processes if driver is compiled in. Avoid this delay by forcing this driver to be probed and suspended/resumed asynchronously. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-30Input: ALPS - fix TrackStick detection on Thinkpad L570 and Latitude 7370Masaki Ota
The primary interface for the touchpad device in Thinkpad L570 is SMBus, so ALPS overlooked PS2 interface Firmware setting of TrackStick, and shipped with TrackStick otp bit is disabled. The address 0xD7 contains device number information, so we can identify the device by checking this value, but to access it we need to enable Command mode, and then re-enable the device. Devices shipped in Thinkpad L570 report either 0x0C or 0x1D as device numbers, if we see them we assume that the devices are DualPoints. The same issue exists on Dell Latitude 7370. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=196929 Fixes: 646580f793 ("Input: ALPS - fix multi-touch decoding on SS4 plus touchpads") Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com> Tested-by: Aaron Ma <aaron.ma@canonical.com> Tested-by: Jonathan Liu <net147@gmail.com> Tested-by: Jaak Ristioja <jaak@ristioja.ee> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-27parisc/gscps2: Fix sparse warningsHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de>
2018-03-26Input: xpad - add PDP device id 0x02a4Francis Therien
Adds support for a PDP Xbox One controller with device ID (0x06ef:0x02a4). The Product string for this device is "PDP Wired Controller for Xbox One - Stealth Series | Phantom Black". Signed-off-by: Francis Therien <frtherien@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-26Input: alps - report pressure of v3 and v7 trackstickPali Rohár
ALPS v3 and v7 packet formats reports trackstick pressure. This information is already parsed in unused "z" variable. ALPS SS4 S2 devices already reports trackstick pressure as ABS_PRESSURE attribute, therefore reports pressure in the same way also for v3 and v7. This patch also updates parsing v3 pressure information, it is also stored in 7 bits. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-26Input: pxrc - new driver for PhoenixRC Flight Controller AdapterMarcus Folkesson
This driver let you plug in your RC controller to the adapter and use it as input device in various RC simulators. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-26Input: usbtouchscreen - do not rely on input_dev->usersMarcus Folkesson
If the device is unused and suspended, a call to open will cause the device to autoresume through the call to usb_autopm_get_interface(). input_dev->users is already incremented by the input subsystem, therefore this expression will always be evaluated to true: if (input->users || usbtouch->type->irq_always) result = usb_submit_urb(usbtouch->irq, GFP_NOIO); The same URB will then be fail when resubmitted in usbtouch_open(). Introduce usbtouch->is_open to keep track of the state instead. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-26Input: usbtouchscreen - fix deadlock in autosuspendMarcus Folkesson
usb_autopm_get_interface() that is called in usbtouch_open() does an autoresume if the device is suspended. input_dev->mutex used in usbtouch_resume() is in this case already taken by the input subsystem and will cause a deadlock. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-26input: misc: remove blackfin rotary driverArnd Bergmann
The blackfin architecture is getting removed, so this one is obsolete as well. Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Aaron Wu <aaron.wu@analog.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-03-26input: keyboard: remove bf54x driverArnd Bergmann
The blackfin architecture is getting removed, so this driver is now obsolete. Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-03-26treewide: simplify Kconfig dependencies for removed archsArnd Bergmann
A lot of Kconfig symbols have architecture specific dependencies. In those cases that depend on architectures we have already removed, they can be omitted. Acked-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-03-17Input: pegasus_notetaker - do not rely on input_dev->usersMarcus Folkesson
If the device is unused and suspended, a call to open will cause the device to autoresume through the call to usb_autopm_get_interface(). input_dev->users is already incremented by the input subsystem, therefore this expression will always be evaluated to true: if (pegasus->dev->users && usb_submit_urb(pegasus->irq, GFP_NOIO) < 0) retval = -EIO; The same URB will then be fail when resubmitted in pegasus_open(). Introduce pegasus->is_open to keep track of the state instead. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-17Input: pagasus_notetaker - fix deadlock in autosuspendMarcus Folkesson
usb_autopm_get_interface() that is called in pegasus_open() does an autoresume if the device is suspended. input_dev->mutex used in pegasus_resume() is in this case already taken by the input subsystem and will cause a deadlock. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-17Input: synaptics_usb - do not rely on input_dev->usersMarcus Folkesson
If the device is unused and suspended, a call to open will cause the device to autoresume through the call to usb_autopm_get_interface(). input_dev->users is already incremented by the input subsystem, therefore this expression will always be evaluated to true: if ((input_dev->users || (synusb->flags & SYNUSB_IO_ALWAYS)) && usb_submit_urb(synusb->urb, GFP_NOIO) < 0) { retval = -EIO; } The same URB will then be fail when resubmitted in synusb_open(). Introduce synusb->is_open to keep track of the state instead. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-17Input: synaptics_usb - fix deadlock in autosuspendMarcus Folkesson
usb_autopm_get_interface() that is called in synusb_open() does an autoresume if the device is suspended. input_dev->mutex used in synusb_resume() is in this case already taken by the input subsystem and will cause a deadlock. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-17Merge branch 'psmouse' into nextDmitry Torokhov
Merge various PS/2 handling improvements.
2018-03-14Input: gpio-keys - add support for wakeup event actionJeffy Chen
Add support for specifying event actions to trigger wakeup when using the gpio-keys input device as a wakeup source. This would allow the device to configure when to wakeup the system. For example a gpio-keys input device for pen insert, may only want to wakeup the system when ejecting the pen. Suggested-by: Brian Norris <briannorris@chromium.org> Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-14Input: appletouch - use true and false for boolean valuesGustavo A. R. Silva
Assign true or false to boolean variables instead of an integer value. This issue was detected with the help of Coccinelle. Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-14Input: silead - add Chuwi Hi8 supportMaruyama Shohei
This commit add ACPI support for Chuwi Hi8 tablet. On the ACPI table of the tablet, GSL1680 is registered as MSSL0001, so the driver does not recognize the device. This commit resolve it. Signed-off-by: Shohei Maruyama <cheat.sc.linux@outlook.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-14Input: analog - use get_cycles() on PPCMichael Ellerman
The analog joystick driver spits a warning at us: drivers/input/joystick/analog.c:176:2: warning: #warning Precise timer not defined for this architecture. PPC has get_cycles() so use that. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-13Input: Evdev - unify MONOTONIC and BOOTTIME clock behaviorThomas Gleixner
Now that the MONOTONIC and BOOTTIME clocks are indentical, remove all the special casing. The user space visible interfaces still support both clocks, but their behavior is identical. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Kevin Easton <kevin@guarana.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Salyzyn <salyzyn@android.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Petr Mladek <pmladek@suse.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-input@vger.kernel.org Link: http://lkml.kernel.org/r/20180301165150.155899327@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-03-10Input: stmpe-keypad - remove VLA usageGustavo A. R. Silva
In preparation to enabling -Wvla, remove VLA and replace it with a fixed-length array instead. Fixed as part of the directive to remove all VLAs from the kernel: https://lkml.org/lkml/2018/3/7/621 Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-09mn10300: Remove the architectureDavid Howells
Remove the MN10300 arch as the hardware is defunct. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David Howells <dhowells@redhat.com> cc: Masahiro Yamada <yamada.masahiro@socionext.com> cc: linux-am33-list@redhat.com Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-03-08Input: i8042 - add Lenovo ThinkPad L460 to i8042 reset listDennis Wassenberg
Reset i8042 before probing because of insufficient BIOS initialisation of the i8042 serial controller. This makes Synaptics touchpad detection possible. Without resetting the Synaptics touchpad is not detected because there are always NACK messages from AUX port. Signed-off-by: Dennis Wassenberg <dennis.wassenberg@secunet.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-08Input: add RAVE SP Powerbutton driverAndrey Smirnov
Add driver that properly handles input event emitted by RAVE SP devices. Reviewed-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com> Reviewed-by: Rob Herring <robh@kernel.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2018-03-08Merge tag 'v4.16-rc4' into nextDmitry Torokhov
Sync up with mainline to bring in RAVE MFD device core.
2018-03-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input fixes from Dmitry Torokhov: - we are reverting patch that was switched touchpad on Lenovo T460P over to native RMI because on these boxes BIOS messes up with SMBus controller state. We might re-enable it later once SMBus issue is resolved - disabling interrupts in matrix_keypad driver was racy - mms114 now has SPDX header and matching MODULE_LICENSE * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Revert "Input: synaptics - Lenovo Thinkpad T460p devices should use RMI" Input: matrix_keypad - fix race when disabling interrupts Input: mms114 - add SPDX identifier Input: mms114 - fix license module information
2018-03-07Revert "Input: synaptics - Lenovo Thinkpad T460p devices should use RMI"Arkadiusz Hiler
This reverts commit 48282969826b3d3c76e908182f69724d86d995fe which caused the following issues: 1. On T460p with BIOS version 2.22 touchpad and trackpoint stop working after suspend-resume cycle. Due to strange state of the device another suspend is impossible. The following dmesg errors can be observed: thinkpad_acpi: EC reports that Thermal Table has changed rmi4_smbus 7-002c: failed to get SMBus version number! rmi4_physical rmi4-00: rmi_driver_reset_handler: Failed to read current IRQ mask. rmi4_f01 rmi4-00.fn01: Failed to restore normal operation: -16. rmi4_f01 rmi4-00.fn01: Resume failed with code -16. rmi4_physical rmi4-00: Failed to suspend functions: -16 rmi4_smbus 7-002c: Failed to resume device: -16 PM: resume devices took 0.640 seconds rmi4_f03 rmi4-00.fn03: rmi_f03_pt_write: Failed to write to F03 TX register (-16). rmi4_physical rmi4-00: rmi_driver_clear_irq_bits: Failed to change enabled interrupts! rmi4_physical rmi4-00: rmi_driver_set_irq_bits: Failed to change enabled interrupts! psmouse: probe of serio3 failed with error -1 2. On another T460p with BIOS version 2.15 two finger scrolling gesture on the touchpad stops working after suspend-resume cycle (about 75% reproducibility, when it still works, the scrolling gesture becomes laggy). Nothing suspicious appears in the dmesg. Analysis form Richard Schütz: "RMI is unreliable on the ThinkPad T460p because the device is affected by the firmware behavior addressed in a7ae81952cda ("i2c: i801: Allow ACPI SystemIO OpRegion to conflict with PCI BAR")." The affected devices often show: i801_smbus 0000:00:1f.4: BIOS is accessing SMBus registers i801_smbus 0000:00:1f.4: Driver SMBus register access inhibited Reported-by: Richard Schütz <rschuetz@uni-koblenz.de> Signed-off-by: Arkadiusz Hiler <arkadiusz.hiler@intel.com> Tested-by: Martin Peres <martin.peres@linux.intel.com> Tested-by: Arkadiusz Hiler <arkadiusz.hiler@intel.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
