commit 4ef38351d770cc421f4a0c7a849fd13207fc5741 upstream.
This patch supports the separate handling of the USB transfer buffer length
and the length of the buffer used for multi packet support. For devices
supporting multiple report or diagnostic packets, the USB transfer size is now
limited to the USB endpoints wMaxPacketSize - otherwise it defaults to the
configured report packet size as before.
This fixes an issue where event reporting can be delayed for an arbitrary
time for multi packet devices. For instance the report size for eGalax devices
is defined to the 16 byte maximum diagnostic packet size as opposed to the 5
byte report packet size. In case the driver requests 16 byte from the USB
interrupt endpoint, the USB host controller driver needs to split up the
request into 2 accesses according to the endpoints wMaxPacketSize of 8 byte.
When the first transfer is answered by the eGalax device with not less than
the full 8 byte requested, the host controller has got no way of knowing
whether the touch controller has got additional data queued and will issue
the second transfer. If per example a liftoff event finishes at such a
wMaxPacketSize boundary, the data will not be available to the usbtouch driver
until a further event is triggered and transfered to the host. From user
perspective the BTN_TOUCH release event in this case is stuck until the next
touch down event.
Signed-off-by: Christian Engelmayer <christian.engelmayer@frequentis.com>
commit ae2aa3a512fa5f50f67feba9e66bc2efb394bd63 upstream.
The HID driver now handles these devices, regardless of what protocol
the device claims it supports.
Signed-off-by: Forest Bond <forest.bond@rapidrollout.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Certain eGalax devices expose an interface with class HID and protocol
None. Some work with usbhid and some work with usbtouchscreen, but
there is no easy way to differentiate. Sending an eGalax diagnostic
packet seems to kick them all into using the right protocol for
usbtouchscreen, so we can continue to bind them all there (as opposed to
handing some off to usbhid).
This fixes a regression for devices that were claimed by (and worked
with) usbhid prior to commit 139ebe8dc80dd74cb2ac9f5603d18fbf5cff049f
("Input: usbtouchscreen - fix eGalax HID ignoring"), which made
usbtouchscreen claim them instead. With this patch they will still be
claimed by usbtouchscreen, but they will actually report events
usbtouchscreen can understand. Note that these devices will be limited
to the usbtouchscreen feature set so e.g. dual touch features are not
supported.
I have the distinct pleasure of needing to support devices of both types
and have tested accordingly.
Previously I had made the struct device point to the input device, but
after talking with Dmitry, he said that the USB device would make more
sense for this driver to point to. So converted it to use that instead.
CC: Dmitry Torokhov <dmitry.torokhov@gmail.com>
CC: Henrik Rydberg <rydberg@euromail.se>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Viresh Kumar <viresh.kumar@st.com>
CC: Armando Visconti <armando.visconti@st.com>
dbg() was a very old USB-specific macro that should no longer
be used. This patch removes it from being used in the driver
and uses dev_dbg() instead.
We should always reference the input device for dev_err(), not the USB
device. Fix up the places where I got this wrong.
Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
err() was a very old USB-specific macro that I thought had
gone away. This patch removes it from being used in the
driver and uses dev_err() instead.
The Data Modul TP 72037 EasyTouch controller is derived from EGALAX
controller and is capable of detecting dual contacts. Packets can be 5
bytes or 10 bytes long, depending whether one or two contacts are
detected. Format is same as EGALAX touch controller, but with x and y
coordinates inverted.
Signed-off-by: Armando Visconti <armando.visconti@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits)
Input: tc3589x-keypad - add missing kerneldoc
Input: ucb1400-ts - switch to using dev_xxx() for diagnostic messages
Input: ucb1400_ts - convert to threaded IRQ
Input: ucb1400_ts - drop inline annotations
Input: usb1400_ts - add __devinit/__devexit section annotations
Input: ucb1400_ts - set driver owner
Input: ucb1400_ts - convert to use dev_pm_ops
Input: psmouse - make sure we do not use stale methods
Input: evdev - do not block waiting for an event if fd is nonblock
Input: evdev - if no events and non-block, return EAGAIN not 0
Input: evdev - only allow reading events if a full packet is present
Input: add driver for pixcir i2c touchscreens
Input: samsung-keypad - implement runtime power management support
Input: tegra-kbc - report wakeup key for some platforms
Input: tegra-kbc - add device tree bindings
Input: add driver for AUO In-Cell touchscreens using pixcir ICs
Input: mpu3050 - configure the sampling method
Input: mpu3050 - ensure we enable interrupts
Input: mpu3050 - add of_match table for device-tree probing
Input: sentelic - document the latest hardware
Fix up fairly trivial conflicts (device tree matching conflicting with
some independent cleanups) in drivers/input/keyboard/samsung-keypad.c
This converts the drivers in drivers/input/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Ville Syrjala <syrjala@sci.fi>
Cc: Henk Vergonet <Henk.Vergonet@gmail.com>
Cc: Alessandro Rubini <rubini@ipvvis.unipv.it>
Cc: Henrik Rydberg <rydberg@euromail.se>
Cc: "Magnus Hörlin" <magnus@alefors.se>
Cc: Chris Moeller <kode54@gmail.c>
Cc: Christoph Fritz <chf.fritz@googlemail.com>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Jesper Juhl <jj@chaosbits.net>
Cc: Edwin van Vliet <edwin@cheatah.nl>
Cc: Ping Cheng <pingc@wacom.com>
Cc: Eduard Hasenleithner <eduard@hasenleithner.at>
Cc: Alexander Strakh <strakh@ispras.ru>
Cc: Glenn Sommer <gsommer@datanordisk.dk>
Signed-off-by: Michael Gebetsroither <michael@mgeb.org>
Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
I've recently got my hands on a LG Flatron T1710B touchscreen.
As other LG products, this seems to use the ITM panel.
Signed-off-by: Glenn Sommer <gsommer@datanordisk.dk>
This implements reset_resume() by splitting init into allocations
of private data structures and device initializations. Device
initializations are repeated upon reset_resume.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Tested-by: Petr Štetiar <ynezz@true.cz>
Tested-by: Ondrej Zary <linux@rainbow-software.org>
This implement USB autosuspend while the device is opened for
devices that do remote wakeup with a fallback to open/close for
those devices that don't. Devices that require the host to
constantly poll them are never autosuspended.
This implements basic support for suspend & resume.
This patch adds support for the ET&T TC4UM 4-wire USB touchscreen
controller and tries to reuse the bits for TC5UH controller in kernel
already. Data interface is same.
Tested-by: Roger Pueyo Centelles <rogerpueyo@rogerpueyo.com>
Signed-off-by: Petr Štetiar <ynezz@true.cz>
Let's perform be16_to_cpu() conversions once for each received packet,
and then use cached values. Makes code a little bit easier to follow.
Input: usbtouchscreen - support bigger iNexio touchscreens
Input: ads7846 - return error on regulator_get() failure
Input: twl4030-vibra - correct the power down sequence
Input: enable onkey driver of max8925
Input: use ABS_CNT rather than (ABS_MAX + 1)
Bigger Nexio touchscreens not only send more data but also the header
values are modified somewhat. Fix the header (it's a guesswork but
it works at least on one 46" touchscreen with 2.00SMS firmware) and
also increase rept_size.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (229 commits)
USB: remove unused usb_buffer_alloc and usb_buffer_free macros
usb: musb: update gfp/slab.h includes
USB: ftdi_sio: fix legacy SIO-device header
USB: kl5usb105: reimplement using generic framework
USB: kl5usb105: minor clean ups
USB: kl5usb105: fix memory leak
USB: io_ti: use kfifo to implement write buffering
USB: io_ti: remove unsused private counter
USB: ti_usb: use kfifo to implement write buffering
USB: ir-usb: fix incorrect write-buffer length
USB: aircable: fix incorrect write-buffer length
USB: safe_serial: straighten out read processing
USB: safe_serial: reimplement read using generic framework
USB: safe_serial: reimplement write using generic framework
usb-storage: always print quirks
USB: usb-storage: trivial debug improvements
USB: oti6858: use port write fifo
USB: oti6858: use kfifo to implement write buffering
USB: cypress_m8: use kfifo to implement write buffering
USB: cypress_m8: remove unused drain define
Fix up conflicts (due to usb_buffer_alloc/free renaming) in
drivers/input/tablet/acecad.c
drivers/input/tablet/kbtab.c
drivers/input/tablet/wacom_sys.c
drivers/media/video/gspca/gspca.c
sound/usb/usbaudio.c
For more clearance what the functions actually do,
usb_buffer_alloc() is renamed to usb_alloc_coherent()
usb_buffer_free() is renamed to usb_free_coherent()
They should only be used in code which really needs DMA coherency.
All call sites have been changed accordingly, except for staging
drivers.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pedro Ribeiro <pedrib@gmail.com>
Use kmemdup when some other buffer is immediately copied into the
allocated region.
Generaltouch protocol allows for coordinates in [0, 0xffff] range and
there are devices reporting coordinates as high as 0x7fff so let's update
the driver to reflect that.
Signed-off-by: Roy Yin <yhch@generaltouch.com>
Fix urb leak in error path of initialization and make sure we handle
errors from initial usb_submit_urb().
Add support for NEXIO (or iNexio) USB touchscreens to usbtouchscreen
driver. Tested with NEX170MRT 17" LCD monitor with integrated touchscreen
(with xserver-xorg-input-evtouch 0.8.8-1):
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 54 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=02(comm.) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=1870 ProdID=0001 Rev= 1.00
S: Manufacturer=iNexio
S: Product=iNexio USB
C:* #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=02 Prot=00 Driver=(none)
E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=255ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=(none)
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
No datasheet is available, this was written by capturing some data with
SniffUSB in Windows: http://www.rainbow-software.org/linux_files/nexio/
Find input enpoint automatically instead of assuming that the first one is
OK. This is needed for devices with multiple endpoints such as iNexio
where the first endpoint might be output.
Convert usbtouchscreen from storing usb_device to usb_interface. This is
needed for multi-interface touchscreen devices such as iNexio.
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it makes sense to mark the initialization data also constant.
Signed-off-by: Márton Németh <nm127@freemail.hu>
This patch adds support for the ET&T TC5UH 5-wire USB touchscreen controller.
More info at http://www.etandt.com.tw/board_solution.html
Zytronic USB-attached capacitive touchscreen support within the generic
USB touchscreen driver.
Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Signed-off-by: Vincent Sanders <vince@simtec.co.uk>
Signed-off-by: Simtec Linux Team <linux@simtec.co.uk>
usb_kill_urb() in disconnect is not needed as unregistering will cause
close() to be called.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
This patch adds support for the e2i touchscreen controller used in the
Mimo 740 (and probably in other e2i touchscreen products). Tested on
Mimo 740.
Signed-off-by: Florian Echtler <floe@butterbrot.org>
controllers
Add support for the JASTEC/DigiTech DTR-02U USB touch screen
controllers.
Signed-off-by: Jim Persson <jim-linux@nurd.se>
Commit ec42d4481e36cbdb5b2801f957e678211a9e5ae2 broke usbtouchscreen for
some eGalax/EETI devices that claim to be HID, but are not.
Devices confirmed to be real HID have the class set to HID and the protocol
set to 'mouse'. Some have HID class but protocol set to 'none'. Those are
not HID and should be driven by usbtouchscreen.
Fix the device ignoring macro by adding match for the protocol too.
This patch adds a module parameter to report either the raw
coordinate data or the hardware-calibrated coordinate data for
MicroTouch/3M touchscreens. The default is set to the raw
coordinates for backwards compatibilty.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
The usbtouchscreen module implements a driver for the TSC-10 DM USB
touchscreen controllers, but assumes a 2-byte response for the
CMD_RESET and CMD_RATE commands, when they can be only a single byte
when no EEPROM is connected.
The driver worked with an earlier controller revision, but new
revisions of the controller fail.
It seems the problem is that the early controller had the
SEL4/EEPROM-CS pin high, but the new controller has it down, making
the response different.
Without the fix, the controller would answer the single byte 0x06
(ACK), making the init fail with -ENODEV because buf[1] is 0xFF (as
initialized before).
As the single byte is the only thing we need to check it was ok, there
is no need to verify the second byte.
The [0x15 0x01] case is the NAK [0x15] response for when there is no
data in the EEPROM [bit-0 of second byte set], so I let that be, as I
don't have any controller with an EEPROM.
With this patch, both the earlier and latest controller work the same.
Note: This was previously submited as BUG #11961 [1] on the bugzilla
tracker, but rebased to version 2.6.27.4 and with unnecessary comments
and printk's removed.
[1] http://bugzilla.kernel.org/show_bug.cgi?id=11961
Signed-off-by: Nuno Lucas <ntlucas@gmail.com>
Acked-by: Daniel Ritz <daniel.ritz@gmx.ch>
The newer versions of the eGalax/EETI screen implement the HID protocol.
The device IDs are still the same, but the USB interface descriptor shows
the device being of HID class. Change usbtouchscreen to ignore the HID
models as they are handled properly by usbhid.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
DMA on the stack is not allowed. The buffer must be kmalloced.
Fix a buffer overflow in mutli-packet handling code. The overflow can
only happen with eGalax devices and is even there very unlikely (only
non-report packet are affected any only when truncated after the first
byte).
Also changes the mutli-packet handling code not to drop unknown packets,
but rather just drop one byte. This allows synchronizing on report packets
in the data stream. It's required for some egalax devices to work at all.
Also remove the pointless 'flags' member of the device struct and set the
version number to 0.6, plus some minor cleanups.
Input: appletouch - apply idle reset logic to all touchpads
Input: usbtouchscreen - add support for GoTop tablet devices
Input: bf54x-keys - return real error when request_irq() fails
Input: i8042 - export i8042_command()
Add support for GoTop Super_Q2/GogoPen/PenPower tablets to usbtouchscreen.
Protocol discovery was done by Yick Yan Lam.
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: <dtor@mail.ru>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
drivers/macintosh/adbhid.c
Signed-off-by: Ilya Frolov <zeylie@gmail.com>
A reply of 0x0600 means all OK, 0x1501 means OK, but EEPROM empty.
The behavior with an empty EEPROM is the same as without one at all
so do not fail loading the driver.
This patch fixes a nasty typo in usbtouchscreen driver. The typo
is inherited from the original mtouchusb. It used to make the input
subsytem to incorrectly report the physical device ids to userspace
that in turn is very confusing for, e.g. XInput hotplug facilities
in setups with multiple identical touchscreens.
Signed-off-by: Vladimir Shebordaev <vshebordaev@mail.ru>
