[ Upstream commit da25311c7ca8b0254a686fc0d597075b9aa3b683 ]
The Schenker XMG C504 is a rebranded Gigabyte P35 v2 laptop.
Therefore it also needs a keyboard reset to detect the Elantech touchpad.
Otherwise the touchpad appears to be dead.
With this patch the touchpad is detected:
$ dmesg | grep -E "(i8042|Elantech|elantech)"
[ 2.675399] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 2.680372] i8042: Attempting to reset device connected to KBD port
[ 2.789037] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.791586] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.813840] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 3.811431] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x361f0e)
[ 3.825424] psmouse serio1: elantech: Synaptics capabilities query result 0x00, 0x15, 0x0f.
[ 3.839424] psmouse serio1: elantech: Elan sample query result 03, 58, 74
[ 3.911349] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input6
Signed-off-by: Patrick Scheuring <patrick.scheuring.dev@gmail.com>
Cc: stable@vger.kernel.org
[ Upstream commit 47af45d684b5f3ae000ad448db02ce4f13f73273 ]
The commit 4097461897df ("Input: i8042 - break load dependency ...")
correctly set up ps2_cmd_mutex pointer for the KBD port but forgot to do
the same for AUX port(s), which results in communication on KBD and AUX
ports to clash with each other.
Fixes: 4097461897df ("Input: i8042 - break load dependency ...")
Reported-by: Bruno Wolff III <bruno@wolff.to>
Tested-by: Bruno Wolff III <bruno@wolff.to>
[ Upstream commit 4097461897df91041382ff6fcd2bfa7ee6b2448c ]
As explained in 1407814240-4275-1-git-send-email-decui@microsoft.com we
have a hard load dependency between i8042 and atkbd which prevents
keyboard from working on Gen2 Hyper-V VMs.
> hyperv_keyboard invokes serio_interrupt(), which needs a valid serio
> driver like atkbd.c. atkbd.c depends on libps2.c because it invokes
> ps2_command(). libps2.c depends on i8042.c because it invokes
> i8042_check_port_owner(). As a result, hyperv_keyboard actually
> depends on i8042.c.
> For a Generation 2 Hyper-V VM (meaning no i8042 device emulated), if a
> Linux VM (like Arch Linux) happens to configure CONFIG_SERIO_I8042=m
> rather than =y, atkbd.ko can't load because i8042.ko can't load(due to
> no i8042 device emulated) and finally hyperv_keyboard can't work and
> the user can't input: https://bugs.archlinux.org/task/39820
> (Ubuntu/RHEL/SUSE aren't affected since they use CONFIG_SERIO_I8042=y)
To break the dependency we move away from using i8042_check_port_owner()
and instead allow serio port owner specify a mutex that clients should use
to serialize PS/2 command stream.
Reported-by: Mark Laws <mdl@60hz.org>
Tested-by: Mark Laws <mdl@60hz.org>
[ Upstream commit dd0d0d4de582a6a61c032332c91f4f4cb2bab569 ]
Without i8042.nomux=1 the Elantech touch pad is not working at all on
a Fujitsu Lifebook U745. This patch does not seem necessary for all
U745 (maybe because of different BIOS versions?). However, it was
verified that the patch does not break those (see opensuse bug 883192:
https://bugzilla.opensuse.org/show_bug.cgi?id=883192).
Signed-off-by: Aurélien Francillon <aurelien@francillon.net>
This driver does not use any PCI IDs, don't include the pci_ids.h header.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
While registering serio device for i8042, mark them as wakeup-capable
and check their user space wakeup settings in i8042_pm_suspend() and
i8042_pm_resume() to enable or disable, respectively, their interrupts
to wake up the system.
This makes it possible to use the PC keyboard to wake up the system
from suspend-to-idle, among other things, after writing "enabled" to
the keyboard serio device's power/wakeup sysfs attribute.
Merge bfin_rotary driver changes from Sonic Zhang.
The patch "module: fix types of device tables aliases" newly requires
that invocations of
MODULE_DEVICE_TABLE(type, name);
come *after* the definition of `name'. That is reasonable, but gscps2
wasn't doing this. Fix it.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer updates from Dmitry Torokhov:
"Just a few quirks for PS/2 this time"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elantech - add more Fujtisu notebooks to force crc_enabled
Input: i8042 - add noloop quirk for Medion Akoya E7225 (MD98857)
Input: synaptics - adjust min/max for Lenovo ThinkPad X1 Carbon 2nd
This driver implements support for PS2 controller found on Allwinner A10,
A20 SOCs. It has been tested on A20 Olimex-Lime2 board and also on A10.
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Without this the aux port does not get detected, and consequently the touchpad
will not work.
$ dmesg | grep -E "(SYN|i8042|serio)"
pnp 00:03: Plug and Play ACPI device, IDs SYN1d22 PNP0f13 (active)
psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x126800, board id: 2863, fw id: 1473085
input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
dmidecode excerpt for this laptop is:
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Medion
Product Name: Akoya E7225
Version: 1.0
Signed-off-by: Jochen Hein <jochen@jochen.org>
Pull input subsystem fixes from Dmitry Torokhov.
Input: uinput - fix ioctl nr overflow for UI_GET_SYSNAME/VERSION
Input: I8042 - add Acer Aspire 7738 to the nomux list
Input: elantech - support new ICs types for version 4
Input: i8042 - reset keyboard to fix Elantech touchpad detection
MAINTAINERS: remove Dmitry Torokhov's alternate address
When KBC is in active multiplexing mode the touchpad on this laptop does
not work.
Reported-by: Bilal Koc <koc.bilo@googlemail.com>
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
Pull input subsystem updates from Dmitry Torokhov:
"Two new drivers for Elan hardware (for I2C touchpad and touchscreen
found in several Chromebooks and other devices), a driver for Goodix
touch panel, and small fixes to Cypress I2C trackpad and other input
drivers.
Also we switched to use __maybe_unused instead of gating suspend/
resume code with #ifdef guards to get better compile coverage"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (27 commits)
Input: gpio_keys - fix warning regarding uninitialized 'button' variable
Input: add support for Elan eKTH I2C touchscreens
Input: gpio_keys - fix warning regarding uninitialized 'irq' variable
Input: cyapa - use 'error' for error codes
Input: cyapa - fix resuming the device
Input: gpio_keys - add device tree support for interrupt only keys
Input: amikbd - allocate temporary keymap buffer on the stack
Input: amikbd - fix build if !CONFIG_HW_CONSOLE
Input: lm8323 - missing error check in lm8323_set_disable()
Input: initialize device counter variables with -1
Input: initialize input_no to -1 to avoid subtraction
Input: i8042 - do not try to load on Intel NUC D54250WYK
Input: atkbd - correct MSC_SCAN events for force_release keys
Input: cyapa - switch to using managed resources
Input: lifebook - use "static inline" instead of "inline" in lifebook.h
Input: touchscreen - use __maybe_unused instead of ifdef around suspend/resume
Input: mouse - use __maybe_unused instead of ifdef around suspend/resume
Input: misc - use __maybe_unused instead of ifdef around suspend/resume
Input: cap11xx - support for irq-active-high option
Input: cap11xx - add support for various cap11xx devices
Prepare input updates for 3.19.
Let's initialize atomic_t variables keeping track of number of various
devices created so far with -1 in order to avoid extra subtraction
operation.
Signed-off-by: Aniroop Mathur <aniroop.mathur@gmail.com>
The Intel NUC D54250WYK has no PS/2 controller, however the DSDT declares
PS/2 devices which trigger the loading of the i8042 driver.
Signed-off-by: Todor Minchev <todor.minchev@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next
Remove all .owner fields from platform drivers
Use them devm_ managed resources API to simplify error handling in
altera_ps2_probe() and to reduce the size of altera_ps2_remove() and the
ps2if struct.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
This reverts commit 68da166491655bc54051bf04c78ce648e2e33508.
It turns out that the assertion about scope of regressions due to
always keeping keyboard controller in legacy mode was proven wrong.
There are laptops, such as Clevo W650SH, that only have internal
touchpad (no external PS/2 ports), that require active multiplexing
mode to switch the touchpad (Elantech) into native mode instead of
basic PS/2 emulation.
Reported-by: Roel Aaij <roel.aaij@gmail.com>
The irq function altera_ps2_rxint returns an irqreturn_t, so use the
same type for variable storing the return value.
In altera_ps2_close, the data register (offset 0) is written instead of
the control register (offset 4), leading to the RX interrupt not being
disabled. Fix this by calling writel() with the offset for the proper
register.
These models need i8042.notimeout, otherwise the touchpad will not work.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=69731
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1111138
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Active multiplexing is a nice feature as it allows several pointing devices
(such as touchpad and external mouse) use their native protocols at the
same time. Unfortunately many manufacturers do not implement the feature
properly even though they advertise it. The problematic implementations are
never fixed, since Windows by default does not use this mode, and move from
one BIOS/model of laptop to another. When active multiplexing is broken
turning it on usually results in touchpad, keyboard, or both unresponsive.
With PS/2 usage on decline (most of PS/2 devices in use nowadays are
internal laptop touchpads), I expect number of users who have laptops with
working MUX implementation, docking stations with external PS/2 ports, and
who are still using external PS/2 mice, to be rather small. Let's flip the
default to be OFF and allow activating it through i8042.nomux=0 kernel
option. We'll also keep DMI table where we can record known good models.
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Hans de Goede <hdegoede@redhat.com>
https://bugzilla.redhat.com/show_bug.cgi?id=1110011
Synchronize with mainline to bring in changes to Synaptics and i8042
drivers.
Fix the format string for serio device name generation to avoid negative
device numbers when the id exceeds the maximum signed integer value.
Signed-off-by: Richard Leitner <richard.leitner@skidata.com>
We need to add this module to the nomux table to be able to detect the
touchpad.
Cc: stablevger.kernel.org
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
So that firmware-id matching can be used with multiplexed aux ports too.
The sys_vendor / product_name are somewhat generic unfortunately, so this
may lead to some false positives. But nomux usually does no harm, where as
not having it clearly is causing problems on the Avatar AVIU-145A6.
https://bugzilla.kernel.org/show_bug.cgi?id=77391
Reported-by: Hugo P <saurosii@gmail.com>
Reported-by: Jason Robinson <mail@jasonrobinson.me>
When running a 32-bit inputattach utility in a 64-bit system, there will be
error code "inputattach: can't set device type". This is caused by the
serport device driver not supporting compat_ioctl, so that SPIOCSTYPE ioctl
fails.
Signed-off-by: John Sung <penmount.touch@gmail.com>
kbd_res is used only when CONFIG_PCI is defined; condition its declaration as
well. This fixes the following compilation warning:
drivers/input/serio/i8042-sparcio.h:20:25: warning: ‘kbd_res’ defined but not used [-Wunused-variable]
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Prepare first round of input updates for 3.17.
With this patch, we can press a key to wake up the VM after the VM executes
"echo freeze > /sys/power/state".
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Acer Aspire needs to be added to nomux blacklist, otherwise the touchpad
misbehaves rather randomly.
Prepare input updates for 3.16.
Merge with Linux 3.15-rc5 to sync up Wacom and other changes.
Make of_device_id array const, because all OF functions handle it as const.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Recent ARM boards have the KMI devices share one interrupt line rather
than having dedicated IRQs. Update the driver to take that into account.
Signed-off-by: Liviu Dudau <Liviu.Dudau@arm.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Fill in the new serio firmware_id sysfs attribute for pnp instantiated
8042 serio ports.
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
serio devices exposed via platform firmware interfaces such as ACPI may
provide additional identifying information of use to userspace.
We don't associate the serio devices with the firmware device (we don't
set it as parent), so there's no way for userspace to make use of this
information.
We cannot change the parent for serio devices instantiated though a
firmware interface as that would break suspend / resume ordering.
Therefore this patch adds a new firmware_id sysfs attribute so that
userspace can get a string from there with any additional identifying
information the firmware interface may provide.
I don't think the OLPC AP-SP driver is generally useful without OLPC
support. So make it depend on OLPC, unless build testing is enabled.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Make sure that no callback is running before we teardown the module.
"Just a swath of driver fixes and cleanups, no new drivers this time
(although ALPS now supports one of the newer protocols, more to come)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits)
Input: wacom - add support for DTU-1031
Input: wacom - fix wacom->shared guards for dual input devices
Input: edt_ft5x06 - use devm_* functions where appropriate
Input: hyperv-keyboard - pass through 0xE1 prefix
Input: logips2pp - fix spelling s/reciver/receiver/
Input: delete non-required instances of include <linux/init.h>
Input: twl4030-keypad - convert to using managed resources
Input: twl6040-vibra - remove unneeded check for CONFIG_OF
Input: twl4030-keypad - add device tree support
Input: twl6040-vibra - add missing of_node_put
Input: twl4030-vibra - add missing of_node_put
Input: i8042 - cleanup SERIO_I8042 dependencies
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on x86
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on unicore32
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on sparc
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO for SH_CAYMAN
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on powerpc
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on mips
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on IA64
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on ARM/Footbridge
Pull ARM updates from Russell King:
"In this set, we have:
- Refactoring of some of the old StrongARM-1100 GPIO code to make
things simpler by Dmitry Eremin-Solenikov
- Read-only and non-executable support for modules on ARM from Laura
Abbot
- Removal of unnecessary set_drvdata() calls in AMBA code
- Some non-executable support for kernel lowmem mappings at the 1MB
section granularity, and dumping of kernel page tables via debugfs
- Some improvements for the timer/clock code on Footbridge platforms,
and cleanup some of the LED code there
- Fix fls/ffs() signatures to match x86 to prevent build warnings,
particularly where these are used with min/max() macros
- Avoid using the bootmem allocator on ARM (patches from Santosh
Shilimkar)
- Various asid/unaligned access updates from Will Deacon"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (51 commits)
ARM: SMP implementations are not supposed to return from smp_ops.cpu_die()
ARM: ignore memory below PHYS_OFFSET
Fix select-induced Kconfig warning for ZBOOT_ROM
ARM: fix ffs/fls implementations to match x86
ARM: 7935/1: sa1100: collie: add gpio-keys configuration
ARM: 7932/1: bcm: Add DEBUG_LL console support
ARM: 7929/1: Remove duplicate SCHED_HRTICK config option
ARM: 7928/1: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU
ARM: 7927/1: dcache: select DCACHE_WORD_ACCESS for big-endian CPUs
ARM: 7926/1: mm: flesh out and fix the comments in the ASID allocator
ARM: 7925/1: mm: keep track of last ASID allocation to improve bitmap searching
ARM: 7924/1: mm: don't bother with reserved ttbr0 when running with LPAE
ARM: PCI: add legacy IDE IRQ implementation
ARM: footbridge: cleanup LEDs code
ARM: pgd allocation: retry on failure
ARM: footbridge: add one-shot mode for DC21285 timer
ARM: footbridge: add sched_clock implementation
ARM: 7922/1: l2x0: add Marvell Tauros3 support
ARM: 7877/1: use built-in byte swap function
ARM: 7921/1: mcpm: remove redundant dsb instructions prior to sev
Pass through the 0xE1 prefix so atkbd can properly parse the scancode
data.
